On Sep 2, 4:25*pm, Robert Holliday wrote:
I currently download my flights using 3UTPC256 which creates an IGC file. I am applying for a state record on one of my flights and we sent the flight file to our state record keeper in the IGC format. He is insisting that we send him a CAI file which he claims is more secure. Can someone help me figure out how to get this flight off of my 302 in CAI. PS: i have SEE- YOU installed on the lap top and it puts an icon before the IGC file name on every flight I download. Thanks. bob holliday USA I'd suggest that you and your observer review the IGC approval for the 302. One way to get there is via this link http://www.fai.org/gliding/system/fi...proved_frs.pdf then clicking on cambridge 302 will allow a download of the approval which contains the following: "7. Analysis of Flight Data. Analysis for flights to be validated to IGC criteria should be through the use of a program which complies with IGC rules and procedures and is approved for this purpose by the relevant NAC. For a list of programs which are capable of reading and displaying flight data in the IGC file format, see the fai.org/gliding/gnss web site under the link to SOFTWARE (the full web reference is at the beginning of this document). Before a Flight Performance is officially validated, the authority responsible for validation must check that the data in the IGC file has originated from the Recorder concerned, and has not been altered after it was download from the Recorder to a PC. This is simply done by checking the IGC data file with an authorised copy of the VALICAM2.EXE short program. The VALI program is on a single file and must have originated from the current FAI/IGC web site for software at the beginning of this document. See Annex B for how to use the VALI program file with any IGC flight data file." and "B.2.3 Transferring the Flight Data. The flight data can be transferred to a portable PC at the glider, without disturbing the installation of the FR (see para A7.1). If a portable PC is not available, the OO shall check and break any sealing to the glider, and take the FR to a PC. As this model is designed primarily for panel mounting, this should be avoided wherever possible. If the OO is not familiar with the actions required, the pilot or another person may transfer the data while the OO witnesses the process. Security is maintained by electronic coding embedded in the FR which is then independently checked later at the NAC (and at FAI if the claim goes to them) through the VALIDATE (VALI) program. Method: Use the standard IGC connector cable that has a 9-pin RS232 male connector for the FR and a RS232 female connector for the PC. A current version of the short program file DATCAM2.EXE (or the manufacturer's equivalent Windows-based program) must be available on the PC. The DATACAM2 program is available free from the IGC GNSS web site for software given at the beginning of this document, or through a link from the main fai.org/gliding/gnss web site. The DATA program file can be executed on either a floppy diskette or on the PC hard disk. When the DATA program is executed, the software version is shown at the top of the menu (see under software on page 1, which gives the required version). This program file executes in the normal way such as either by typing "DATACAM2, enter" at a DOS prompt (DOS window or re-boot into DOS mode); or by double- clicking "DATACAM2" in a Windows file list (File Manager for W3x, Windows Explorer for W95/98/ ME or NT/2000/XP). If settings such as the COM port, Baud rate, etc. need to be changed, the help menu is accessed by typing the file name, space, hyphen, then the letter h. In the event of any problems in getting DATACAM2 to work through the hard disk of a PC, install it on a self-booting floppy diskette, re-boot to the diskette and type "DATACAM2". Files produced. This process will automatically produce a *.IGC-format flight data file both with the file name YMDCXXXF, where Y=year, M=month, D=day, C= manufacturer, XXX = FR Serial Number/letters and F = flight number of the day (full key, Appendix 1 to the IGC GNSS FR Specification, also listed in Annex C to the Sporting Code, SC3C)." I don't see any reference to a CAI file not do I think the 302 can produce one. All references are to the IGC file. Andy |
On Sep 2, 5:23*pm, Andy wrote:
I don't see any reference to a CAI file not do I think the 302 can produce one. All references are to the IGC file. p.s. The assertion that a CAI file is more secure than the IGC file relates to Cambridge recorders that pre-date the 302 series. Those earlier recorders produced ONLY a CAI file and it has to be post processed to create an IGC file that then has no security. Andy |
On Sep 2, 8:23*pm, Andy wrote:
I don't see any reference to a CAI file not do I think the 302 can produce one. Right, it's not in the docs, anywhere. But it can, and it will. The fact that the binary download is blazingly fast compared to the typical igc d/l causes me to wonder if the 302 uses the old cai format internally and the igc file creation is done 'on the fly' during download. -T8 |
On 9/2/2010 6:07 PM, T8 wrote:
On Sep 2, 8:23 pm, wrote: I don't see any reference to a CAI file not do I think the 302 can produce one. Right, it's not in the docs, anywhere. But it can, and it will. I've never heard of this claim before, and if it's not in the approval document, you can't use it, anyway. The fact that the binary download is blazingly fast compared to the typical igc d/l causes me to wonder if the 302 uses the old cai format internally and the igc file creation is done 'on the fly' during download. Nope, the 302 uses a different, more secure algorithm than the old Model 20, etc, and that is why it has the highest level of IGC approval (all flights), and the Model 10, 20, and 25 do not (badges only). -- Eric Greenwell - Washington State, USA (netto to net to email me) |
I thought the binary download is a raw memory dump, not a CAI,
suitable for debugging and nothing else. -Tom On Sep 2, 6:07*pm, T8 wrote: The fact that the binary download is blazingly fast compared to the typical igc d/l causes me to wonder if the 302 uses the old cai format internally and the igc file creation is done 'on the fly' during download. |
On Sep 2, 11:30*pm, 5Z wrote:
I thought the binary download is a raw memory dump, not a CAI, suitable for debugging and nothing else. Don't know for sure as it's undocumented. Only reason I was fooling around with this was trying all available options to recover a flight log with a security problem. It gave me a file with a .cai extension. I don't recall now if I did anything with the file past that point, or not. If they were using the same extension for two different file types, well, I really don't have anything very nice to say about that. -T8 |
Downloading from AOPA | Lou | Home Built | 3 | November 14th 06 02:56 PM |
Help downloading this site | TripFarmer | Owning | 17 | December 2nd 05 01:59 AM |
Downloading Flying Music? | Jay Honeck | Home Built | 59 | February 4th 04 06:08 AM |
Downloading flying music? | Jay Honeck | Piloting | 54 | February 3rd 04 09:47 AM |
Downloading Flying Music? | Mark Mallory | Owning | 1 | January 27th 04 12:48 PM |
