Push-Pull propeller combinations.
Old September 3rd 10, 08:05 PM posted to rec.aviation.military,rec.aviation.military.naval
David E. Powell
Default Push-Pull propeller combinations.
On Sep 3, 8:24*am, Peter Skelton wrote:
On Thu, 2 Sep 2010 18:22:49 -0700 (PDT), Eunometic
On Sep 3, 10:48*am, John wrote:
On Sep 2, 10:08*am, Eunometic wrote:
Several aircraft have been built with both a pull (or tractor)
propeller and a push (or rear) propeller aligned with each other.
Supposedly the arrangment is inefficient, yet the some of the Dornier
aircraft were record breakers.
Given that some aircraft were ruined or delayed by the problem of
combining gearboxes (He 177, Northrop XB-35 and if it ever came to it
the B-29 with its backup V-3420) * it looks like an attractive
proposition.
What's going on here?
List of such aircraft:
Cessna 337 Skymaster
Rutan Model 76 Vogager
Adam A500
Dornier Wal
Dornier Do X
Dornier Do 18 Seaplane, the German PPY Catalina.
Dornier Do 26K Seaplane, possibly the longer ranged seaplane ever
built.
Dornier Do 335 Pfeil (arrow) *perhaps one of the fastest piston
engined aircraft ever built.
Dornier Seawings Seastar, modern Seaplane of composites.
Savoia-Marchetti S.55
LeO H-242
I don't know about the others but my understanding is that the
Skymaster was an attempt to design a twin engined plane that would
have the same overall dimensions as a single engine aircraft and be
safer to fly since it would eliminate asymetric thrust during engine
failure. *The ironic thing is that the Skymaster safety record is no
better than a conventional twin.- Hide quoted text -
- Show quoted text -
Possibly psychological "a single engined failure isn't dangerous so I
won't maintain the aircraft factor" and ofcourse perhaps engine
failure isn't the major cause of light plane crashes.
A single engined turbo prop is safer than a twin engine piston and
possibly even safer than a twin turbo since the pilots inabiility to
handle asymetrical thrust may be worse than his abillity to handle a
glide/crash landing.
Famously some singles *have crashed and smashed through brick walls
and the pilot walked free unscathed, the engine acting as a battering
ram and protection.
That a single piston is safer than a twin is a classic of
probability theory, taugh in junior high around here (not back in
the day though).
Peter Skelton
Twice the number of things to go wrong?
Old September 3rd 10, 08:59 PM posted to rec.aviation.military,rec.aviation.military.naval
Peter Skelton
On Fri, 3 Sep 2010 12:05:31 -0700 (PDT), "David E. Powell"
proposition.
Adam A500
Dornier Wal
Dornier Do X
built.
LeO H-242
ram and protection.
the day though).
Peter Skelton
That and a non zero probability of crash as the result of a
single failure. The number was worked out sometime around the end
or WWII, aircraft with higher power reserves might show different
results.
Peter Skelton
Old September 3rd 10, 09:52 PM posted to rec.aviation.military,rec.aviation.military.naval
vaughn[_3_]
"Peter Skelton" wrote in message
failure. The ironic thing is that the Skymaster safety record is no
Yes. One of the classic crash modes of the Skymaster is when the pilot attempts
a takeoff after failing to notice that the rear prop is not turning. The
procedure developed to detect that simple condition is to lead with the rear
engine throttle. If you push in the throttle and the noise level remains
unchanges, it is time to abort the takeoff and investigate!
results.
Of course, the biggest danger is loss of an engine on takeoff, but even a
single-engine *landing* can come to grief in various ways. We had a twin
fatally crash into our neighborhood from exactly that event.
One situation where twins are considered inherently safer is night IFR. The
classic advice for a forced landing at night is to maintain control of the
airplane; in particular maintain a safe airspeed. At 300 feet, turn on the
landing lights. If you don't like what you see, turn them off!
Vaughn
Just pull the little red handle! JJ Sinclair Soaring 65 September 5th 10 11:57 AM
Propeller or jet to push an in-line skater? John Doe[_4_] Home Built 33 July 28th 10 09:28 PM
PUSH START stanley adelson Aviation Photos 0 July 15th 08 01:16 AM
Question about center-line push-pull engine configuration Shin Gou Home Built 4 June 7th 04 05:57 PM
Nasal cannula, flowmeter combinations. Lord Struthers Soaring 0 May 5th 04 05:04 PM
