Std Cirrus: Blue or Gray trim color ONLY!...why?
Old September 5th 10, 08:06 PM posted to rec.aviation.soaring
R[_3_]
Default Std Cirrus: Blue or Gray trim color ONLY!...why?
On 9/5/2010 7:24 AM, Scott Alexander wrote:
On my last annual, the IA showed me the AD's and a special note for
Standard Cirrus gliders that they can only have "light gray or blue
trim colors only." huh???
Is it just light blue and gray to which you are limited?
The US type certificate G23EU for the "STANDARD CIRRUS" includes other
light colors.
NOTE 3. All external portions of the glider exposed to sunlight must
be painted white. Registration and Competition
numbers must be painted blue-gray or in any other light colors.
This note's exact same verbiage is also found on other fiberglass makes
and models from the late 60's through 1980.
Is there a change to the STD CIRRUS TCDS someplace requiring "only" the
blue-gray or are you working from his interpretation of what a light
color should be? The last revision for the TCDS was June 3,1976.
G23EU:
http://rgl.faa.gov/Regulatory_and_Guidance_library/rgMakeModel.nsf/0/52ab636a446c519686256e5f00477449/$FILE/G23eu.PDF
Russ
Old September 5th 10, 09:12 PM posted to rec.aviation.soaring
John Dezzutti[_3_]
Scott,
First you declare a task with your contest ID instead of your registration
number and now you have medium gray trim instead of light grey. What's
next? No respect for the rules. What are you some sort of troble maker?
JD
Old September 6th 10, 04:45 AM posted to rec.aviation.soaring
Read the TCDS for the Cirrus.
Your IA is correct.
And you cannot get around this by going Experimental E&R...
sky is gray but we can still see the F-16s Pensacola Beachcomber Aviation Photos 1 January 10th 08 05:50 PM
sky is gray but we can still see the F-16 as it flys by Pensacola Beachcomber Aviation Photos 0 January 10th 08 05:28 PM
sky is gray but we can still see the F-16 as it flys by.... Pensacola Beachcomber Aviation Photos 0 January 10th 08 05:27 PM
Does anyone know if FS 26270 Haze Gray = RAL 7042 Traffic Gray ? Landy Man Naval Aviation 2 January 9th 08 03:42 AM
