Std Cirrus: Blue or Gray trim color ONLY!...why?
Old September 6th 10, 05:22 AM posted to rec.aviation.soaring
Gary Boggs
Default Std Cirrus: Blue or Gray trim color ONLY!...why?
Haven't test by the military shown that anything other than all white
less visable?
Boggs
On Sep 5, 5:31*am, Scott Alexander
After the multiple mid-airs we have had this year, I am wanting to add
some high-vis trim colors on the nose, wingtips and rudder. *How would
I go about getting approval for a high visibility color that isn't
blue or gray? *Or maybe there's a high visibility blue out there I can
use.
Old September 6th 10, 06:16 AM posted to rec.aviation.soaring
SoaringXCellence
less visable?
Boggs
use.
I think I heard that in Sweden that ALL sailplanes are required to
have "high visibility" wing tips, nose and tail. I know that several
imports from Sweden did come with such markings.
You might check with the manufacturer about how they meet the Sweden
requirements
Mike
Old September 6th 10, 09:19 AM posted to rec.aviation.soaring
David Salmon[_2_]
At 05:16 06 September 2010, SoaringXCellence wrote:
less visable?
Boggs
On Sep 5, 5:31=A0am, Scott Alexander
add
some high-vis trim colors on the nose, wingtips and rudder. =A0How
woul=
d
blue or gray? =A0Or maybe there's a high visibility blue out there
I
ca=
n
use.
requirements
Mike
Quite a long time ago, the BGA did some controlled tests re visibility
markings. I can't remember the details, but I am fairly certain that the
findings were that conspicuity patches etc did nothing to improve seeing
gliders in the air.
Dave
Old September 6th 10, 05:19 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
less visable?
Boggs
add
woul=
d
I
ca=
n
use.
I think I heard that in Sweden that ALL sailplanes are required to have
"high visibility" wing tips, nose and tail. I know that several imports
requirements
Mike
gliders in the air.
I seem to remember that to be any use the patches must be big and a
single colour - small patches and/or multicoloured ones are quite good
camouflage.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old September 8th 10, 04:41 PM posted to rec.aviation.soaring
John Gilbert[_2_]
less visable?
Boggs
use.
have "high visibility" wing tips, nose and tail. *I know that several
requirements
Mike
My understanding is that the hi-vis markings are for landing out in
snow. In the air, the darker tips tend to decrease visible span.
John
Old September 10th 10, 09:05 PM posted to rec.aviation.soaring
8A
This restriction is definatly due to temperature issues (glass
transition temperature) with room temperature cure epoxy. This issue
is very real. I can show you damage on the wing of 8A where a
previous owner left a dark object. As for colored markings -
reference TN 278-4 But you will need to read German.
There has been considerable testing by the aircraft industry on this
subject.
H.L.C.
Test Engineer Beech / Raytheon Aircraft, NIAR
sky is gray but we can still see the F-16s Pensacola Beachcomber Aviation Photos 1 January 10th 08 05:50 PM
sky is gray but we can still see the F-16 as it flys by Pensacola Beachcomber Aviation Photos 0 January 10th 08 05:28 PM
sky is gray but we can still see the F-16 as it flys by.... Pensacola Beachcomber Aviation Photos 0 January 10th 08 05:27 PM
Does anyone know if FS 26270 Haze Gray = RAL 7042 Traffic Gray ? Landy Man Naval Aviation 2 January 9th 08 03:42 AM
