![]() "Scott" wrote in message .. . On 9-6-2010 20:50, nimbus wrote: We inspected every millimeter with Dye Check test inspection. No cracks means no cracks.. Well, the good news with that is that when they decide on a test procedure, you shouldn't have anything to worry about unless they mandate something like removing wing skins to inspect... My guess is that with a problem of this magnitude, removing the wing skins to replace the structure or to modify the structure is exactly what is going to be required. If I was an enterprising manufacturer, I would be designing a new wing kit to sell to people with these grounded gliders. I would design it to use as many parts from the old wing as possible. It sounds to me as if the engineers of this glider really screwed the pooch, with this mess. No way a well designed wing should be having this serious of a problem, IMHO. -- Jim in NC |
On Sep 6, 7:09*pm, "Morgans" wrote:
"Scott" wrote in message .. . On 9-6-2010 20:50, nimbus wrote: We inspected every millimeter with Dye Check test inspection. No cracks means no cracks.. Well, the good news with that is that when they decide on a test procedure, you shouldn't have anything to worry about unless they mandate something like removing wing skins to inspect... My guess is that with a problem of this magnitude, removing the wing skins to replace the structure or to modify the structure is exactly what is going to be required. If I was an enterprising manufacturer, I would be designing a new wing kit to sell to people with these grounded gliders. *I would design it to use as many parts from the old wing as possible. It sounds to me as if the engineers of this glider really screwed the pooch, with this mess. *No way a well designed wing should be having this serious of a problem, IMHO. -- Jim in NC IIRC, this is what they attempted to do over twenty years ago as L-13's approached their initial life limits in the early-mids 1980's. Return to factory for spar cap replacements. Some suspected it was a make work attempt. Pressure was such that a 500 hour inspection scheme was initiated in some countries. The troubling thing is that a wing came off a 2300 hour glider in Austria. That said, the right wing broke off an L-13 over Aspen, Colorado in August 1975 also with two fatalities. The sketchy NTSB report cites severe turbulence at cloud base and no fitted g-meter. This latest EASA AD is still only suggesting that fatigue MAY be the cause. Exceeding the flight envelope frequently is certainly another possibility leading to wing failure or accelerated fatigue. Frank Whiteley |
Blanik L-13 AD | Jim[_18_] | Soaring | 20 | August 30th 10 08:25 PM |
Blanik L-23 Super Blanik Manual -F.C.F.S. | Joel Flamenbaum | Soaring | 2 | April 14th 10 03:29 PM |
Blanik L-13 AD | [email protected] | Soaring | 7 | February 3rd 08 08:01 AM |
Blanik L-23 | BDS[_2_] | Soaring | 7 | June 27th 07 03:35 PM |
Blanik L-13 | brien | Soaring | 0 | December 5th 04 02:00 PM |
