Adding vents to Smiley bags
Old September 7th 10, 06:25 AM posted to rec.aviation.soaring
JS
Default Adding vents to Smiley bags
My technique for the last 20 years or so has been to use a standpipe
and fill both wings simultaneously, vacuuming first especially if the
bags are not vented. This worked for the LS-4 (both vented and
unvented bags), LS-6 (unvented), AS-W20 (vented), another AS-W27
(vented), but of course not the Nimbus 3. Never flew with water in the
AS-W17 or AS-H26.
The funnel sounds a bit 70s. I don't like to support one wing full
of water on a wing stand either, as I've seen people squash the foam
core that way.
This set of bags doesn't vacuum as well as others. Perhaps they just
need removing/replacing using the correct facial expressions and
abusive phrases? Would it help to drill more holes in the inner pipes?
The factory bags are vented and fill easily, but look like water bed
material. After having a similar bag break in flight - filling the
cockpit with water - there's a preference to use heavy duty bags. At
least the factory bags are not shower curtains as removed from the 4
and the 17!
Somebody may know how to vent the Smileys...
Old September 7th 10, 12:55 PM posted to rec.aviation.soaring
T8
On Sep 7, 1:25*am, JS wrote:
* The funnel sounds a bit 70s. I don't like to support one wing full
core that way.
That's avoided by putting the stand at the tip only. It helps to have
a stand that can go a foot or two higher than normal. As second wing
fills, it will drop to the ground.
Good luck on your project.
-T8
OLC Smiley Face BravoCharlie Soaring 5 July 22nd 09 10:27 PM
Fuselage Vents Ken Kochanski (KK) Soaring 29 August 20th 08 06:59 PM
Smiley face on OLC entry flying_monkey Soaring 3 April 16th 07 06:43 PM
Smiley Bags Ramy Soaring 4 January 25th 07 12:06 AM
Smiley Creek, ID Fastglasair Home Built 0 June 16th 04 10:07 PM
