Pawnee CO problem
Old September 8th 10, 02:27 AM posted to rec.aviation.soaring
Kurt[_3_]
Default Pawnee CO problem
We have 2 Pawnee's, both 235 HP fixed prop. One has a problem with
carbon monoxide. We have checked everything, to include a new
muffler, tailpipe, exhaust manifolds. We have taped up openings,
stuffed foam in the gear leg openings etc. Still, we get CO in the
cockpit. We even put a small scoop on the left side to direct "clean"
air into the cockpit. We have tried to duplicate everyting on this
Pawnee as is on our other one...the one wihout the problem. Neither
has a heater. Has anyone encountered this before? If so, how did you
solve the problem?
Thanks
Kurt
Old September 8th 10, 03:35 AM posted to rec.aviation.soaring
Andy[_1_]
On Sep 7, 6:27*pm, Kurt wrote:
We have 2 Pawnee's, both 235 HP fixed prop. *One has a problem with
carbon monoxide. *
Are you using the same measurement instrument in both aircraft? (not
the same type but actually the same instrument)
I fly 2 Pawnees at my club but I don't think either has a CO monitor.
Maybe I'll borrow one for my next tow duty.
Andy
Old September 8th 10, 04:10 AM posted to rec.aviation.soaring
ray conlon
carbon monoxide. *
Andy
Mix up a big bucket of soapy water using dishwashing detergent, get a
rubber ball that fits the exhaust stack outlet to plug it, with the
mags COLD, and the engine cut off by leaning the mixture, wet down the
exhaust system, have a couple of guys hold the prop,remove one spark
plug per jug and do a "compession check" with the exhaust valve open,
if you have cracks, just look for the bubles...
Old September 12th 10, 02:47 AM posted to rec.aviation.soaring
carbon monoxide. *We have checked everything, to include a new
muffler, tailpipe, exhaust manifolds. *We have taped up openings,
stuffed foam in the gear leg openings etc. *Still, we get CO in the
cockpit. *We even put a small scoop on the left side to direct "clean"
air into the cockpit. *We have tried to duplicate everyting on this
Pawnee as is on our other one...the one wihout the problem. *Neither
has a heater. *Has anyone encountered this before? *If so, how did you
solve the problem?
Thanks
Kurt
Old September 12th 10, 02:48 AM posted to rec.aviation.soaring
solve the problem?
Thanks
Kurt
ok - I'll try again - Kurt - change the angle of the exhaust. Lengthen
the exhaust. I've had this problem.
Jayne
Old September 14th 10, 09:17 AM posted to rec.aviation.soaring
John Smith
BTiz wrote:
have stated an issue with CO smell during the winter months.
CO doesn't smell.
We'll put a CO2 detector in the cockpit this winter.
Actually, CO2 is nontoxic. You'd better install a CO detector.
Old September 15th 10, 05:31 AM posted to rec.aviation.soaring
BTiz
On Sep 14, 1:17*am, John Smith wrote:
CO doesn't smell.
Now where did that "2" pop in from...
thanx... roger on the CO
To Pawnee or not to Pawnee...that is the question... Travis Beach Soaring 56 March 24th 14 06:21 AM
Pawnee AD /SB 25/53/03 sugarbush Soaring 1 June 13th 09 12:41 AM
Looking for Pawnee [email protected] Soaring 1 July 13th 08 12:35 AM
To Pawnee or not to Pawnee...that is the question... Travis Beach Soaring 4 October 17th 07 01:31 PM
Pawnee Damien Dyer Soaring 2 November 2nd 04 05:35 PM
