Racing airspace "violation" question
Old September 8th 10, 06:36 PM posted to rec.aviation.soaring
Mike the Strike
Default Racing airspace "violation" question
On Sep 8, 10:07*am, John Cochrane
On Sep 8, 10:50*am, LOV2AV8 wrote:
As long as we're discussing a rules change and not a score change for
the day. *Many other contestants aborted at the first turn point
rather than the second turn point because of the Class C airspace
conflict with getting home.
Randy
What day of what contest was this? What was the issue with going
around class C? How was it impossible to continue the course,
impossible to go around class C, but easy to go over? I'm not being
hostile, I'd just like to go look at the task and results. Stated in
the abstract it all seems so unlikely, so it would be good to know the
practical circumstance.
John Cochrane
This was the first day of the Southwest Soaring Championships flown
from Tucson Soaring Club. The CD set a long and challenging task that
proved too long, mostly because of a late start. Only one contestant
completed the task, three landed out and the rest (including me)
abandoned.
We routinely fly over Tucson Class C as it's often the quickest and
safest way home from tiger country.
Mike
Old September 8th 10, 08:08 PM posted to rec.aviation.soaring
Marc Ramsey[_3_]
abandoned.
And since no one is mentioned it yet, it is perfectly legal to overfly a
Class C without a transponder and without being in radio contact with the
tower, as long as you are above 10000 ft MSL. This is a fairly common
move in the western half of the US...
Marc
Old September 8th 10, 08:51 PM posted to rec.aviation.soaring
Darryl Ramm
On Sep 8, 12:08*pm, Marc Ramsey
from Tucson Soaring Club. *The CD set a long and challenging task that
proved too long, mostly because of a late start. *Only one contestant
abandoned.
tower, as long as you are above 10000 ft MSL. *This is a fairly common
Marc
Marc beat me to that. And before anybody challenges him please
carefully read 14 CFR 91.215. This seems to be a common point of
confusion. But it would be much better if people actually have
transponders near Class C or B airspace to begin with.
I am not commenting on whether what the contest rules should or should
not allow overflight. I can see a reason for now wanting contestants
to try to overfly the top of class C or 10,000 MSL and fall into it.
And personally (since John stirred the pot there) I would hope that if
the SSA is going to run contests near Class C airspace then maybe they
ought to consider the need to require transponders in gliders (ouch I
can hear keyboards being pounded out there...).
Darryl
Old September 9th 10, 12:36 AM posted to rec.aviation.soaring
Chip Bearden[_2_]
I absolutely agree with the SSA Board's zero-tolerance attitude
towards rules violations.
On the other hand, there are controlled, restricted, and/or prohibited
areas in every contest envelope I've flown in and we routinely assign
tasks that require us to exercise our piloting abilities to remain
clear of this closed airspace. Thanks to GPS loggers, enforcement is
easy, as evidenced by Rule 10.12.1 "Tasks should be set to avoid
flight through closed airspace or areas of high-density traffic." This
somewhat nebulous guidance gives the CD the flexibility to set tasks
even when a straight line between two specific points within turn area
cylinders passes through such airspace. An airspace infraction is easy
to spot on the trace and the consequences for busting this rule are
straightforward and dire. The expansion of closed airspace to include
all airspace above it is, as our Rules Committee reps have said, a
simple way to deal with attempts to cross closed airspace that fail
due to sink or miscalculated glides.
However, I have to take issue with the reasoning that anyone
questioning whether this rule ought to be changed for flights
involving a return from an abandoned task is championing leniency for
violations. As far as I'm concerned, an FAA airspace violation during
a flight that originates from a contest launch should be penalized the
same whether it's outbound on the scorable portion or inbound on the
non-scorable return portion. What's different is the pilot's incentive
to shave the margin a little more closely in the pursuit of speed
points on the scorable portion. Yeah, one could argue that a pilot
might push a little farther before turning around and then be
compelled to fly just as aggressively to return before legal sunset
(or a storm) and thereby be incentivized to take chances with airspace
but, in the words of one of our Rules Committee guys, that seems
pretty remote.
I think we should explore allowing a pilot to overfly Class C and
other closed airspace on the way home after abandoning a task if it's
legal without a transponder or radio contact. I realize this opens the
door to "well, if it's legal for him to go over, why not let me go
through 'cause I've got the required equipment and expertise and it
doesn't give me any extra contest points." But so be it.
Let me ask a different question: would an aero retrieve be permitted
to overfly a Class C on the way back to the contest site without
penalty? I hope so. Yet that flight is also clearly in the scope of an
SSA sanctioned contest. How about a motorglider that lands part way
around, then launches again and motors back, overflying a Class C in
the process?
As long as I'm making trouble, let me offer the notion that
practically speaking, there may be a solution on days such as the one
described here in Rule 5.6.2.4 "Closed airspace is considered closed
at all times, except as specifically announced by the CD." As I read
this, a CD could announce on a questionable day that it was OK to
overfly closed airspace returning from an abandoned task.
Speaking of CDs, I'm reminded of the one a few years ago who decided
to go the extra mile, so to speak, and declared (as per Rule 5.6.2.3)
that all the airspace UNDER the overlying layers of Class C airspace
would also be closed. When queried about the fact that this excluded a
few small airports as potential landing sites, the CD breezily
informed the assembled pilots that there were plenty of fields
available in that area if they had to land out. That this CD was
related to the owner of a local fiberglass repair shop was not thought
to be a factor in this ruling.
Chip Bearden
ASW 24 "JB"
USA
Old September 9th 10, 01:45 AM posted to rec.aviation.soaring
John Cochrane[_2_]
Randy
John Cochrane
abandoned.
Mike
I'm still trying to get a sense of whether "this was a real problem"
or whether this is some hypothetical question.
The SSA contest report says this was an area task from El Tiro to
Amado, southwest of Tucson, with a 25 mile circle around Amado. The
direct courseline to Amado doesn't intersect the Tucson class C,
though it does come close; the Tucson class C is east of courseline.
Looking at the chart, I would have flown the line of high ground even
further west of courseline, ending up at Keystone peak or thereabouts.
My options would have been the line of airports, Ruby Star, Flying
Diamond, Ryan, Taylor, all again a bit west of courseline and heading
right back to El Tiro and the second turnpoint. I just don't see how
anyone could have gotten stuck behind the Tucson class C. And it looks
like the CD did a good job of setting a course that really didn't
cause a problem.
So, tell the story. Where were you guys that you really felt this was
the only safe option? How did you get there? Or is this all
hypothetical?
There is a lot of complaining around here about rules being too
complicated. Carving out an exception for class C overflights in
abandoned tasks is certainly going to be complicated. So it matters
whether this is a real problem, or just the beginning of winter what-
ifs.
John Cochrane
Old September 9th 10, 03:25 AM posted to rec.aviation.soaring
Andy[_10_]
On Sep 8, 5:45*pm, John Cochrane
Randy
John Cochrane
abandoned.
Mike
like the CD did *a good job of setting a course that really didn't
cause a problem.
hypothetical?
ifs.
John Cochrane
John,
I think you've mistaken the Southwest Soaring Championships (a non-
sanctioned local contest) with the Region 9 that was also held at El
Tiro. The task in question was:
ID Name Distance (Miles) Radius
106 106 Waterman 0.00 5.0
62 062 MtWshngt 77.13
12 012 Benson 126.93
13 013 Biospher 176.85
1 001 EL TIRO 209.27 1.0
I have a few recollections of making long final glides to El Tiro from
the east. Given the distances involved a long, flat glide would
occasionally get you close to the top of the Class C and in that
instance going around could run you out of glide distance.
Disclaimer: My recollection is decades old and based on the old ARSA
configuration at Tucson IIRC.
9B
Old September 9th 10, 12:47 PM posted to rec.aviation.soaring
John Cochrane[_2_]
Randy
John Cochrane
abandoned.
Mike
cause a problem.
hypothetical?
ifs.
John Cochrane
John,
* ID * Name * * * * * * * * Distance (Miles) * Radius
* *106 * 106 Waterman * * * * * 0.00 * * * * * * *5.0
* * 62 * 062 MtWshngt * * * * *77.13
* * 12 * 012 Benson * * * * * 126.93
* * 13 * 013 Biospher * * * * 176.85
* * *1 * 001 EL TIRO * * * * *209.27 * * * * * * *1.0
9B
Well, if it's non-sanctioned, go ahead and make your own rules, or
exceptions!
John Cochrane
Old September 9th 10, 02:09 PM posted to rec.aviation.soaring
kirk.stant
On Sep 9, 6:47*am, John Cochrane
Randy
John Cochrane
abandoned.
Mike
further west of courseline, ending up at Keystone peak or thereabouts..
cause a problem.
hypothetical?
ifs.
John Cochrane
John,
9B
exceptions!
John Cochrane- Hide quoted text -
- Show quoted text -
Ok, just to makes things clear:
The task was a speed task, first turnpoint way south of Tucson (Mt
Washington, I think, near Nogales), second turnpont Benson (east of
Tucson, directly across the Class C from El Tiro), then Biosphere
(north of Tucson), then El Tiro. By the time I got near Benson, the
day was dying and I decided to abort the task rather than head up into
a possible landout. At that point, I found a climb that allowed me to
get well above the Class C and gave me final glide back to El Tiro. I
contacted approach, overflew the "closed airspace", and landed back at
El Tiro.
I understand (and agree with completely) the rule about no overflying
closed airspace WHEN ON TASK. And I have no problem with losing my
score and getting penalized for this flight, because I misinterpreted
the rule that is clear as currently written and decided to take what I
considered a safe and legal route home. My question was about whether
the rule should be amended IN THE FUTURE to allow legal overflight (or
even, with clearance, flight through) controlled airspace during part
of a contest flight that is no longer "on task" i.e. an aborted return
from a task as there is no competitive benefit for doing so (unless
one considers avoiding a long retrieve a competitive advantage ;^).
Up side? Safety, convenience, full use of the airspace we are allowed
to use, etc. Downside? Scoring complication, rule complication, more
chances for airspace violation.
My opinion is that it's ultimately the pilot's, not the SSA's, job to
comply with the FARs - since it's the pilot that gets hammered if he
gets a violation, no the SSA. And scoring complication is a software
issue, nowadays - we already score to the point of a task abort, so
"added complication" seems a bit of a stretch. I totally support the
SSA requirement to stay out of closed airspace when on task, since a
pilot should not be tasked through airspace that he may not be able to
legally fly through, or require equipment he may not have.
Anyway, I just thought this situation was interesting enough to
warrant some discussion - especially since it is a bit of a regional
problem (I can't see this being a problem back East!).
Cheers,
Kirk
66
Old September 9th 10, 06:39 PM posted to rec.aviation.soaring
Andy[_1_]
closed airspace WHEN ON TASK. *And I have no problem with losing my
considered a safe and legal route home. *My question was about whether
But it's not that simple. How does the scorer know where you declared
your intention to abort? The person that won the day was also
thinking of aborting at the first turn and followed a similar route
back to yours. Conditions then improved and he made a large detour to
get back toward the second turnpoint. Maybe you would have done the
same thing. How would you have cancelled your intention to abort?
I think the FAI rules would have handled this situation just fine.
You would have been scores as landing out at the class C boundary and
the distance on that leg would have been scored as progress toward the
second turnpoint.
Andy
Old September 9th 10, 10:02 PM posted to rec.aviation.soaring
kirk.stant
But it's not that simple. *How does the scorer know where you declared
your intention to abort? *The person that won the day was also
get back toward the second turnpoint. *Maybe you would have done the
second turnpoint.
Andy
How does the scorer know where to score to if someone aborts
normally? Doesn't the scoring program look for the farthest logger
point in the direction of the next turnpoint (that isn't actually
reached) to determine how to score distance, after it determines that
the task wasn't completed? Then it would seem easy to not assess a
violation for any airspace incursion after that point is determined.
The scorer shouldn't have to do anything.
But I admit I'm assuming a lot about Winscore, so may very well be
completely wrong about this.
Kirk
Fed: Planes flying in "commercial" airspace must get GPS Mxsmanic Piloting 66 June 4th 10 12:54 PM
(USA) US/Mexico "airspace" (boundary) files available Tuno Soaring 4 March 27th 10 07:17 PM
On Sharing airspace with "non-rated UAV "pilots" vaughn Piloting 15 March 15th 09 04:08 PM
"Fly Baby, you violated Class B Airspace" Ron Wanttaja Piloting 27 September 5th 07 08:30 PM
Aviation Conspiracy: Connecticut To Get "Creamed" By Airspace Redesign Change? Free Speaker General Aviation 0 August 8th 06 02:42 PM
