Caution - Arizona Airspace and Borders
Old September 9th 10, 03:22 PM posted to rec.aviation.soaring
Andy[_1_]
Default Caution - Arizona Airspace and Borders
On Sep 9, 7:14*am, John Cochrane
So why not just send John Leibacher the right file? He does an amazing
job of quickly posting files to the turnpoint exchange.
Because I do not have the right to distribute the data except, as
scorer, to participants in the contest.
It's a long story and I don't have time now.
Andy
Old September 9th 10, 03:39 PM posted to rec.aviation.soaring
Darryl Ramm
Andy
And it will become the wrong file on the next update.
Darryl
Old September 9th 10, 05:02 PM posted to rec.aviation.soaring
Mike the Strike
Andy
Darryl
I was the one who discovered the problem when I nicked an airspace
boundary during a recent contest. It's a complex area near the
international border with several MOAs and restricted military
training areas. In examining the data, I find the US/Mexico border is
displaced about 1 nautical mile south of the actual border (perhaps
because the data are based on ADIZ data). SeeYou and SeeYou mobile
clearly show the border in the wrong place. Two MOAs that are
adjacent to the border are correctly shown. The whole southern border
of Arizona is shown at latitude 31 degrees 19 minutes instead of 31
degrees 20 minutes. This 1 minute difference may be the ADIZ border
definition, but I am not sure. I am sure that the indicated border is
in the wrong place (it's obvious if you look at Nogales, for example).
Andy (our scorer) finds that scoring programs do not properly display
the border at all. Clearly, the use of closed polygons to display
lines has some problems.
Our two concerns a
1) There are errors in the database that show airspace boundaries in
the wrong place.
2) Scoring programs (Winscore, for example) handle the airspace files
differently than the navigation problems (such as SeeYou Mobile) and
may plot garbage. The result may be penalizing pilots for airspace
violations that did not occur, or vice-versa.
One major message, though, is to take the warnings on the files
seriously - do NOT use them for navigation purposes! That's what
charts are for.
Mike
Old September 9th 10, 05:41 PM posted to rec.aviation.soaring
Andy[_1_]
the border at all. *Clearly, the use of closed polygons to display
Not quite true. The airspace file the scorer is using depicts the
border in a way that I believe to be correct.
I used Cambridge Aero Explorer Plus to display both airspace sources
and have emailed you the screen captures. I used Aero Explorer Plus
because it was created by Byars and depicts the airspace in the same
way as Winscore. The program has the ability to overlay multiple
airspace files which Winscore (to the best of my knowledge) does not.
Anyone else wanting to see the screen captures is welcome to drop me
an email.
Andy
Old September 9th 10, 07:27 PM posted to rec.aviation.soaring
Eric Greenwell
charts are for.
How do you compare an IGC file to a paper chart? Can the pilot state "I
was legal according to my paper chart" and get away with it? I thought
the standard for contests was the pilot flew according to the turnpoint
and airspace files the contest provided, so pilots, scoring program, and
the contest managers were all using the same data.
Eric Greenwell - Washington State, USA (netto to net to email me)
Old September 9th 10, 08:09 PM posted to rec.aviation.soaring
Mike the Strike
On Sep 9, 11:27*am, Eric Greenwell wrote:
On 9/9/2010 9:02 AM, Mike the Strike wrote: One major message, though, is to take the warnings on the files
seriously - do NOT use them for navigation purposes! *That's what
charts are for.
Eric:
That's the rub. No official airspace file has been either defined or
given to contestants.
We have the situation where the scorer is using files he developed
himself and the rest of us are using files from the Turnpoint Exchange
that are not deemed "official". Who knows what the CD is using!
We didn't think that this was a big problem until we ran into the
latest glitch, now we are going to address the issue!
Mike
Old September 9th 10, 09:54 PM posted to rec.aviation.soaring
kirk.stant
charts are for.
Eric:
That's the rub. *No official airspace file has been either defined or
that are not deemed "official". *Who knows what the CD is using!
Mike
And just to throw some more fuel on this fire, as pilots we are
responsible for navigating with reference to approved data, which
means Sectional charts or VFR GPSs with up to date navigation data
(say a Garmin with current cycle data loaded). So what happens if the
scoring program, using non-official airspace data, shows a violation,
and the pilot proves, somehow, that he used his up to date VFR Garmin
and/or sectional and did not bust the airspace? Who is right? The
pilot is right as far as the FAA is concerned, but wrong in Winscores
mind?
Oh boy, this is going to be fun!
Kirk
66
Old September 10th 10, 01:55 AM posted to rec.aviation.soaring
5Z
(say a Garmin with current cycle data loaded). *So what happens if the
and/or sectional and did not bust the airspace? Who is right? *The
mind?
For scoring there needs to be a single source of digital information,
whether it matches reality or not, that is what the pilots and scorer
should use. This file IMHO, should be available a "reasonable" time
before the first contest day.
As for FAA, the pilot is responsible for that issue using "APPROVED"
information. So if the contest says the restricted airspace is bigger
than reality, then that is what it is as far as the contest is
concerned. If the airspace file is in error the other way, then it is
up to the pilot to use other, official, means to stay legal. Again,
IMHO, airspace boundaries for scoring are just that, SCORING
boundaries, not "real" airspace boundaries.
Yes, that means that a pilot could violate FAA airspace and get a
valid score, but if that happens, I see no reason against someone
submitting a protest AGAINST THE PILOT or pilots involved, but not
against the competition. These boundaries are not to be used for
navigation, just for scoring.
-Tom
Wichita Airspace Question and overlapping airspace Owen[_4_] Piloting 1 February 14th 07 09:35 PM
Caution Wake Turbulence [email protected] Instrument Flight Rules 7 November 29th 06 04:14 AM
FLAPS-Caution Steve Leonard Soaring 0 August 27th 05 04:10 AM
Phoenix Arizona airspace Andy Soaring 0 August 3rd 05 12:24 AM
caution - wake turbulence John Harlow Piloting 1 June 4th 04 04:40 PM
