On Sep 9, 2:02*pm, "kirk.stant" wrote:
But it's not that simple. *How does the scorer know where you declared your intention to abort? *The person that won the day was also thinking of aborting at the first turn and followed a similar route back to yours. Conditions then improved and he made a large detour to get back toward the second turnpoint. *Maybe you would have done the same thing. How would you have cancelled your intention to abort? I think the FAI rules would have handled this situation just fine. You would have been scores as landing out at the class C boundary and the distance on that leg would have been scored as progress toward the second turnpoint. Andy How does the scorer know where to score to if someone aborts normally? *Doesn't the scoring program look for the farthest logger point in the direction of the next turnpoint (that isn't actually reached) to determine how to score distance, after it determines that the task wasn't completed? *Then it would seem easy to not assess a violation for any airspace incursion after that point is determined. The scorer shouldn't have to do anything. But I admit I'm assuming a lot about Winscore, so may very well be completely wrong about this. Kirk I can definitely lay out some tasks in relation to restricted areas (like Class C's) where the pilot would be required to backtrack away from the next turnpoint (and home) to avoid the -100 point outcome if s/he abandoned the task and elected to traverse the restricted area. This would require careful piloting to ensure that your greatest progress towards the next turnpoint was outside the restricted area. To make this really obvious imagine that the second to last turn is across a Class C from home and the last turn is a steering turn just 20 miles abeam of the finish. You'd have to do some clever trigonometry to figure out how to cross the Class C after making the second to last turn in order to get home without making progress towards the final turn within the restricted area. 9B |
On Sep 10, 1:11*am, SoaringMaps Team wrote:
On Sep 9, 2:02*pm, "kirk.stant" wrote: But it's not that simple. *How does the scorer know where you declared your intention to abort? *The person that won the day was also thinking of aborting at the first turn and followed a similar route back to yours. Conditions then improved and he made a large detour to get back toward the second turnpoint. *Maybe you would have done the same thing. How would you have cancelled your intention to abort? I think the FAI rules would have handled this situation just fine. You would have been scores as landing out at the class C boundary and the distance on that leg would have been scored as progress toward the second turnpoint. Andy How does the scorer know where to score to if someone aborts normally? *Doesn't the scoring program look for the farthest logger point in the direction of the next turnpoint (that isn't actually reached) to determine how to score distance, after it determines that the task wasn't completed? *Then it would seem easy to not assess a violation for any airspace incursion after that point is determined. The scorer shouldn't have to do anything. But I admit I'm assuming a lot about Winscore, so may very well be completely wrong about this. Kirk I can definitely lay out some tasks in relation to restricted areas (like Class C's) where the pilot would be required to backtrack away from the next turnpoint (and home) to avoid the -100 point outcome if s/he abandoned the task and elected to traverse the restricted area. This would require careful piloting to ensure that your greatest progress towards the next turnpoint was outside the restricted area. To make this really obvious imagine that the second to last turn is across a Class C from home and the last turn is a steering turn just 20 miles abeam of the finish. *You'd have to do some clever trigonometry to figure out how to cross the Class C after making the second to last turn in order to get home without making progress towards the final turn within the restricted area. 9B But this answer displays some of the wisdom of current policy. We don't allow flight in or over class C because it would give a competitive advantage to those having a transponder. Originally, it seemed like "but the race is over, so there's no competitive advantage" was a good argument. But in this and a previous example, it's clear that being able to press on while keeping the option alive to glide home over the class C is a definite competitive advantage. Bottom line, though: Given the amount of complaining from many people about complex rules, carving out an airspace exception to fly over class C as "self retrieve" doesn't seem like a good idea. For a non-sanctioned contest, make up your own rules and do whatever you want. If a sanctioned contest really wants to do this, they should apply for a rules waiver. It might make sense at El Tiro given the very odd geometry of the Tucson class C relative to El Tiro and the soaring area. That lets you adapt rules to local conditions without us having to write some nightmare into the rules that apply to everyone. John Cochrane |
![]() I can definitely lay out some tasks in relation to restricted areas (like Class C's) where the pilot would be required to backtrack away from the next turnpoint (and home) to avoid the -100 point outcome if s/he abandoned the task and elected to traverse the restricted area. This would require careful piloting to ensure that your greatest progress towards the next turnpoint was outside the restricted area. To make this really obvious imagine that the second to last turn is across a Class C from home and the last turn is a steering turn just 20 miles abeam of the finish. *You'd have to do some clever trigonometry to figure out how to cross the Class C after making the second to last turn in order to get home without making progress towards the final turn within the restricted area. 9B But this answer displays some of the wisdom of current policy. We don't allow flight in or over class C because it would give a competitive advantage to those having a transponder. Originally, it seemed like "but the race is over, so there's no competitive advantage" was a good argument. But in this and a previous example, it's clear that being able to press on while keeping the option alive to glide home over the class C is a definite competitive advantage. Bottom line, though: Given the amount of complaining from many people about complex rules, carving out an airspace exception to fly over class C as "self retrieve" doesn't seem like a good idea. Ok I can see the logic in that. Bottom line, know the rules, but do what is safe. Fun discussion, I learned a lot (only slightly painfully!). But we are racing again at El Tiro this weekend, so this time I'll be more careful! Cheers, Kirk |
On Sep 10, 6:45*am, John Cochrane
wrote: On Sep 10, 1:11*am, SoaringMaps Team wrote: On Sep 9, 2:02*pm, "kirk.stant" wrote: But it's not that simple. *How does the scorer know where you declared your intention to abort? *The person that won the day was also thinking of aborting at the first turn and followed a similar route back to yours. Conditions then improved and he made a large detour to get back toward the second turnpoint. *Maybe you would have done the same thing. How would you have cancelled your intention to abort? I think the FAI rules would have handled this situation just fine. You would have been scores as landing out at the class C boundary and the distance on that leg would have been scored as progress toward the second turnpoint. Andy How does the scorer know where to score to if someone aborts normally? *Doesn't the scoring program look for the farthest logger point in the direction of the next turnpoint (that isn't actually reached) to determine how to score distance, after it determines that the task wasn't completed? *Then it would seem easy to not assess a violation for any airspace incursion after that point is determined. The scorer shouldn't have to do anything. But I admit I'm assuming a lot about Winscore, so may very well be completely wrong about this. Kirk I can definitely lay out some tasks in relation to restricted areas (like Class C's) where the pilot would be required to backtrack away from the next turnpoint (and home) to avoid the -100 point outcome if s/he abandoned the task and elected to traverse the restricted area. This would require careful piloting to ensure that your greatest progress towards the next turnpoint was outside the restricted area. To make this really obvious imagine that the second to last turn is across a Class C from home and the last turn is a steering turn just 20 miles abeam of the finish. *You'd have to do some clever trigonometry to figure out how to cross the Class C after making the second to last turn in order to get home without making progress towards the final turn within the restricted area. 9B But this answer displays some of the wisdom of current policy. We don't allow flight in or over class C because it would give a competitive advantage to those having a transponder. Originally, it seemed like "but the race is over, so there's no competitive advantage" was a good argument. But in this and a previous example, it's clear that being able to press on while keeping the option alive to glide home over the class C is a definite competitive advantage. Bottom line, though: Given the amount of complaining from many people about complex rules, carving out an airspace exception to fly over class C as "self retrieve" doesn't seem like a good idea. For a non-sanctioned contest, make up your own rules and do whatever you want. If a sanctioned contest really wants to do this, they should apply for a rules waiver. It might make sense at El Tiro given the very odd geometry of the Tucson class C relative to El Tiro and the soaring area. That lets you adapt rules to local conditions without us having to write some nightmare into the rules that apply to everyone. John Cochrane Agreed. Adding an exception to the rule would create a fair amount of complexity in rule language, pilot decision-making AND scoring - that's a triple negative. The case I was illustrating to make the point was of a pilot who heads for home across restricted airspace thinking he's okay because he abandoned the task but accidentally makes some additional progress towards the next turn and gets minus 100 points anyway. The case of pilots who can head out over tiger country on the far side of restricted airspace because they have an "out" that another pilot without a transponder doesn't have is another issue that speaks to fairness. There is an analogous situation in the current rules. At the Sports Nationals this year there was one task where a courseline choice that took you out over a lot of unlandable terrain got you to much better conditions and higher overall speeds. Most (but not all) of the guys who went there had motors. I spoke to one pilot about how he thought about the landout options out there and he said "I didn't". Despite lots of rules to try to level the playing field the thought of a dicey outlanding 100 miles from home in the middle of the desert does affect decision-making. I'm not convinced there's anything to be done about it - just pointing it out. You could imagine use of the motor requiring that you be marked back some of the distance made on course to that point so as to compensate for the additional distance made into questionable areas that a motor affords you. Of course the problem with that is that it creates a disincentive for pilots with motors to use them. 9B |
On Sep 10, 9:06*am, Andy wrote:
There is an analogous situation in the current rules. At the Sports Nationals this year there was one task where a courseline choice that took you out over a lot of unlandable terrain got you to much better conditions and higher overall speeds. Most (but not all) of the guys who went there had motors. I spoke to one pilot about how he thought about the landout options out there and he said "I didn't". There is no doubt in my mind that having a motor offers a huge advantage in some contest situations. But don't change the rules, I'm thinking of going over to the dark side. Andy (GY) |
On Sep 10, 9:39Â*am, Andy wrote:
On Sep 10, 9:06Â*am, Andy wrote: There is an analogous situation in the current rules. At the Sports Nationals this year there was one task where a courseline choice that took you out over a lot of unlandable terrain got you to much better conditions and higher overall speeds. Most (but not all) of the guys who went there had motors. I spoke to one pilot about how he thought about the landout options out there and he said "I didn't". There is no doubt in my mind that having a motor offers a huge advantage in some contest situations. Â*But don't change the rules, I'm thinking of going over to the dark side. Andy (GY) The advantage of the motor is supposed to be offset with the handicap value, at least for Sports Classâ™*. In the other classes the price you pay for a motor is it's own handicap! Mike "Would like to experience the Dark side!" Bamberg |
On Sep 10, 3:02Â*pm, SoaringXCellence wrote:
On Sep 10, 9:39Â*am, Andy wrote: On Sep 10, 9:06Â*am, Andy wrote: There is an analogous situation in the current rules. At the Sports Nationals this year there was one task where a courseline choice that took you out over a lot of unlandable terrain got you to much better conditions and higher overall speeds. Most (but not all) of the guys who went there had motors. I spoke to one pilot about how he thought about the landout options out there and he said "I didn't". There is no doubt in my mind that having a motor offers a huge advantage in some contest situations. Â*But don't change the rules, I'm thinking of going over to the dark side. Andy (GY) The advantage of the motor is supposed to be offset with the handicap value, at least for Sports Classâ™*. Â*In the other classes the price you pay for a motor is it's own handicap! Mike "Would like to experience the Dark side!" Bamberg I'd have to check, but I think the only adjustment is for the additional wing loading from the weight of the engine. 9B |
On Sep 10, 3:28Â*pm, Andy wrote:
On Sep 10, 3:02Â*pm, SoaringXCellence wrote: On Sep 10, 9:39Â*am, Andy wrote: On Sep 10, 9:06Â*am, Andy wrote: There is an analogous situation in the current rules. At the Sports Nationals this year there was one task where a courseline choice that took you out over a lot of unlandable terrain got you to much better conditions and higher overall speeds. Most (but not all) of the guys who went there had motors. I spoke to one pilot about how he thought about the landout options out there and he said "I didn't". There is no doubt in my mind that having a motor offers a huge advantage in some contest situations. Â*But don't change the rules, I'm thinking of going over to the dark side. Andy (GY) The advantage of the motor is supposed to be offset with the handicap value, at least for Sports Classâ™*. Â*In the other classes the price you pay for a motor is it's own handicap! Mike "Would like to experience the Dark side!" Bamberg I'd have to check, but I think the only adjustment is for the additional wing loading from the weight of the engine. 9B Andy, You're right, I just looked at the handicap list and didn't see any difference for the model with or without the motor. Maybe we need a proposal! Mike |
Fed: Planes flying in "commercial" airspace must get GPS | Mxsmanic | Piloting | 66 | June 4th 10 12:54 PM |
(USA) US/Mexico "airspace" (boundary) files available | Tuno | Soaring | 4 | March 27th 10 07:17 PM |
On Sharing airspace with "non-rated UAV "pilots" | vaughn | Piloting | 15 | March 15th 09 04:08 PM |
"Fly Baby, you violated Class B Airspace" | Ron Wanttaja | Piloting | 27 | September 5th 07 08:30 PM |
Aviation Conspiracy: Connecticut To Get "Creamed" By Airspace Redesign Change? | Free Speaker | General Aviation | 0 | August 8th 06 02:42 PM |
