Aircraft Takeoff speeds
Old January 30th 04, 10:44 PM
John Carrier
The F4E carrying dispensers for the CBU38 (? antitank munitions) on
the inboard pylons rotated at 196 but that was a CG problem. FWIW we
got one batch of F104 tires that were built and designed to someone's
erroneous specifications (built to a newly specified design) and we
were throwing treads off brand new tires on a light-loaded zipper -
only gun ammo and 2xAIM9s aboard. That was interesting . . . Shortly
thereafter the specs were changed to a performance criterion and the
problems disappeared.
The Phantoms I flew had a tire speed limit of 190. The aircraft would take
off no flap at about 175. It's true that unstick was a problem with
forward CG, I just find it amazing it required that much speed in the
configuration you describe.
CQ fuel weight cat shots required full aft stick ... typical fighter mission
(single centerline and 2x2 missiles) full aft and then a wrist rotation
forward of that.
Of all the aircraft I've flown, only the F-4 and the TA-4 had an issue with
T/O rotation. The F-8 required very little (obvious from its
configuration).
R / John
Old January 30th 04, 11:30 PM
Pete
"Tarver Engineering" wrote in message
"WaltBJ" wrote in message
snip
Tires are built for much higher speeds -
and you can buy them for your car. A waste of money unless you have
the right car, though.
I don't think so, do you have a reference for the car tire?
While not *over* 200mph, this is close.
(Y) rated - tested to 186+mph
http://www.tirerack.com/tires/tirete...eral/speed.htm
Seeing as there are cars that can and will do 200+, it would stand to reason
that there are tires built for them.
http://www.fantasycars.com/McLaren_F1/mclaren_f1.html
Pete
Old January 31st 04, 01:34 AM
Tarver Engineering
"Pete" wrote in message
snip
I believe this tire contains rubber and would not be suitable for space
vehicles.
reason
Pete
Old January 31st 04, 07:59 AM
John Mullen
snip
vehicles.
reason
Funny it doesn't say anything here about them not being made of rubber
http://aviation.webmichelin.com/about/space.html
John
Old January 31st 04, 08:25 AM
Tarver Engineering
"John Mullen" wrote in message
snip
vehicles.
reason
Noone cares what you don't know, Mullen.
Old January 31st 04, 01:07 PM
John Mullen
snip
vehicles.
reason
ISWYM. I certainly don't have such massive ignorance as you, splappy.
John
Old January 31st 04, 03:14 PM
boomer
can you guys take your "tire war" to another thread please, jeeze.
snip
vehicles.
reason
John
Old January 31st 04, 03:58 PM
John Mullen
m...
snip
vehicles.
reason
John
Can you not top-post. Jeez.
John
Old January 31st 04, 04:04 PM
Tarver Engineering
Such sweet irony.
Let's see now, a troll of ram doesn't know something, so I must not know it.
Bwahahahahahahaha
Old January 31st 04, 11:19 PM
boomer
I started the thread, I'll do as I like. Contribute or start your OWN thread
m...
snip
have
space
vehicles.
to
reason
John
John
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
