At 16:07 19 September 2010, kirk.stant wrote:
On Sep 18, 6:52=A0pm, " wrote: Please explain further........how is the correct landing procedure for a 2-33 going to result in a high energy landing in a Grob? IMHO....the correct landing procedure for a 2-33 (low energy, slow speed, nose high, tail low, etc) will result in a similar low energy landing in a Grob..........this would be a short runway landing, with little or no need for brakes...... Cookie So, when you are teaching landings to a student in a 2-33, do you first sit him in the front seat, level the wings, then hold the nose up until the tailwheel is on the ground and say "this is your landing attitude"? Do you do that in a G-103? Didn't think so. Where that tailwheel is relative to the ground is the difference. The landing angle of attack is probably about the same, but a student who learns to land on the main in a 2-33, nice and slow, but never touching the tailwheel, then who transfers that technique to the G-103, is a prime candidate for high energy landing problems. It's not a killer problem - but it needs to be taught correctly! Kirk I did exactly that when teaching students to land a G103 except I would push down on the tail so that they could see the picture in front of them. The correct attitude is that where the main wheel and tailwheel touch the ground at the same time. The glider should then be kept running on the main and tailwheel for as long as possible, directional control is lost when the glider goes nosewheel down. |
On Sep 19, 9:30*am, Don Johnstone wrote
: I did exactly that when teaching students to land a G103 except I would push down on the tail so that they could see the picture in front of them.. The correct attitude is that where the main wheel and tailwheel touch the ground at the same time. The glider should then be kept running on the main and tailwheel for as long as possible, directional control is lost when the glider goes nosewheel down. What is interesting is when you compare 4 different gliders: With a 2-33 (nosedragger), you have to pull the nose up until the tail touches, then lower it until it's at the correct landing attitude (you establish the range of available touchdown angle of attack). With a Blanik (taildragger), you have to raise the tail a little bit to show the desired touchdown angle. With a K-21 (nosedragger), you pull the nose up until the tail is on the ground, and finally, with a DG-1000 (taildragger), you just level the wings. Again, it's the gear configuration that is important, and why it's important is something the student needs to understand. Cheers Kirk |
On Sep 19, 1:35*pm, "kirk.stant" wrote:
On Sep 19, 9:30*am, Don Johnstone wrote : I did exactly that when teaching students to land a G103 except I would push down on the tail so that they could see the picture in front of them. The correct attitude is that where the main wheel and tailwheel touch the ground at the same time. The glider should then be kept running on the main and tailwheel for as long as possible, directional control is lost when the glider goes nosewheel down. What is interesting is when you compare 4 different gliders: *With a 2-33 (nosedragger), you have to pull the nose up until the tail touches, then lower it until it's at the correct landing attitude (you establish the range of available touchdown angle of attack). *With a Blanik (taildragger), you have to raise the tail a little bit to show the desired touchdown angle. *With a K-21 (nosedragger), you pull the nose up until the tail is on the ground, and finally, with a DG-1000 (taildragger), you just level the wings. Again, it's the gear configuration that is important, and why it's important is something the student needs to understand. Cheers Kirk OK.....But the same BASIC technique works for all these gliders............LOW ENERGY LANDING....... Cookie |
![]() OK.....But the same BASIC technique works for all these gliders............LOW ENERGY LANDING....... Cookie A proper low energy landing involves a two point (or arguably tail first) touchdown. You cannot teach this in a 2-33. The euro's laugh at us because a not insignificant amount of owners of the newest glass ships still can't do a proper low energy landing. If you feel the need to comment so strongly to this thread you may wish to reveal your real identity. Otherwise we'll have to assume you are Lennie the Lurker (and if you don't know who this is, you haven't been in soaring, or at least on RAS, long enough to comment on these issues) |
Kevin Christner wrote:
A proper low energy landing involves a two point (or arguably tail first) touchdown. You cannot teach this in a 2-33. The euro's laugh at us because a not insignificant amount of owners of the newest glass ships still can't do a proper low energy landing. I followed this discussion for a while now and frankly, I don't understand all the fuss. I have never been shown any paritcular landing attitude, because this would be meaningless as every glider is different. I've just been told to flare that beast, and keep it flying as long as possible until it ceases to fly. Ths means increasing the angle of attack as the speed decays until the glider falls out of the air. Properly built gliders will do so in a two point attitude, some more accurate, some less accurate. That's all I've been taught and that's how I've been doing it for years. Frankly, I couldn't even tell you the landing attitude. |
At 16:03 20 September 2010, John Smith wrote:
I followed this discussion for a while now and frankly, I don't understand all the fuss. I have never been shown any paritcular landing attitude, because this would be meaningless as every glider is different. I've just been told to flare that beast, and keep it flying as long as possible until it ceases to fly. Ths means increasing the angle of attack as the speed decays until the glider falls out of the air. Properly built gliders will do so in a two point attitude, some more accurate, some less accurate. That's all I've been taught and that's how I've been doing it for years. Frankly, I couldn't even tell you the landing attitude. At last a sensible post on this subject. The way all gliders should be landed. |
On Sep 20, 10:49*am, Kevin Christner
wrote: OK.....But the same BASIC technique works for all these gliders............LOW ENERGY LANDING....... Cookie A proper low energy landing involves a two point (or arguably tail first) touchdown. *You cannot teach this in a 2-33. *The euro's laugh at us because a not insignificant amount of owners of the newest glass ships still can't do a proper low energy landing. If you feel the need to comment so strongly to this thread you may wish to reveal your real identity. *Otherwise we'll have to assume you are Lennie the Lurker (and if you don't know who this is, you haven't been in soaring, or at least on RAS, long enough to comment on these issues) I agree that a proper low energy landing in MOST gliders is two point or there about. Although the 2-33 does not usually land two point, I still can, do, and have taught low energy landings in 2-33, and the same techniques carry on to other gliders, with minimum fuss...I do not allow my students in the 2-33 to do "fly it on landings". It has been my experience that those who land a 2-33 properly, land any glider properly. I have also seen glider pilots who never flew a 2-33 but still manage to land improperly. Its not the glider....its the pilot!! Owners of the newest glass ships who can't land them properly, should seek additional training....but this is a "pilot problem" not an "aircraft problem". My whole point is in response to the post that implied that a guy wrecked a Grob, because he learned in a 2-33.......This is a far fetched conclusion at best...........The guy wrecked the Grob because he didn't know how to land, period, regardless of the aircraft. I'm not a huge fan of the 2-33......but please don't blame the poor glider for things that are not its fault....... BTW.....I've seen some of those "Euros" fly ........Some are great pilots, but they have their share of pilots who can't land too............ As for your second paragraph: My name is Bob Cook, everyone who knows me, knows me as "Cookie"......To anybody who doesn't know me, it doesn't matter squat what my name is.......Now if you want to comapare "years in gliding" or hours, or experience or whatever, we can go tit for tat........but that is meaningless.......... Cookie |
![]() wrote in message ... snip OK.....But the same BASIC technique works for all these gliders............LOW ENERGY LANDING....... This is a fascinating and slightly scary discussion. I was taught in the UK the BGA way, and the only kind of landing I have been taught is the fully-held off one - ultimately the glider mushes onto the ground. Flying on is not considered good as it's all too easy to end up airborne again if there are lumps and bumps, and the average grass strip or field usually has plenty of those. Landing in less than 200m is not hard in just about any glass ship so long as approach speed control was good and there was at least 1/2 airbrake used. The touchdown is either main wheel and tail wheel/skid at the same time or tail slightly first. Then it's right back with the stick (which is just about where it will be if the landing was really held off) to help keep the ship on the ground, and also to keep the tail wheel/skid planted as long as possible on things like K21s to aid directional stability if there is a cross-wind. Is this what US folks mean by a low-energy landing? If not, what is meant? |
On 9/20/2010 11:02 AM, Surfer! wrote:
wrote in message ... snip OK.....But the same BASIC technique works for all these gliders............LOW ENERGY LANDING....... This is a fascinating and slightly scary discussion. I was taught in the UK the BGA way, and the only kind of landing I have been taught is the fully-held off one - ultimately the glider mushes onto the ground. Descriptive details snipped Is this what US folks mean by a low-energy landing? If not, what is meant? What you've described is *my* (U.S.) idea of a low-energy landing. As to much of this discussion, kids can you say, "Nuance is difficult to describe in short paragraphs!" :-) My own take is: KISS (Keep It Simple, Stupid). The principles *are* simple...the devil's in the descriptive details. I'm sure someone will correct me if I've overlooked an oddball-configured glider somewhere, but 'the vast majority of gliders' (including 2-33s, even those withOUT spring tailwheels) will perform nice, low-energy touchdowns if successfully landed about an inch in the air...meaning that if they quit flying 'way up there', nothing's going to get hurt or broken from the fall. Actual fuselage attitude falls out in the wash... True for nose-draggers and taildraggers. Guessing wildly - and not excusing failure to practice low-energy technique when conditions permit - perhaps one reason some western U.S. glider pilots rationalize skill in performing low-energy landings isn't 'crucial' is because it's the norm in these parts for strong, gusting (often, cross)winds to be present unless landing near dusk, away from any thunderstorms. One's view of the desirability of a fully held-off landing (especially on paved runways) probably varies inversely proportionally with the strength of the gusting crosswind! My personal record for touchdown speed was a 65+ knot, wheeled-on touchdown (75+ knot final to maintain a 'reasonable crab angle') in a direct crosswind of 25-35 knots onto the only (narrow, sans-lights) pavement around - it was that or hassle with an OFL and a post-sundown retrieve in the same winds (from a distant T-storm)...15-meter, flapped, no-spoilers ship. About 20-feet of lateral downwind displacement occurred in the roll-out, despite (post-touchdown) full downwind rudder, a negative-flap-planted tail wheel, maximum wheel braking and (eventually) an intentionally dragging downwind tip. A held-off landing under the circumstances wasn't seriously considered. Bob W. |
![]() Quote:
Colin Last edited by Ventus_a : September 20th 10 at 10:19 PM. Reason: updated info |
Club Class Gliders | Sam Giltner[_1_] | Soaring | 4 | December 3rd 08 03:28 AM |
Basic Training Gliders | Derek Copeland | Soaring | 35 | December 26th 05 02:19 PM |
Basic Training Gliders | Justin Craig | Soaring | 0 | December 6th 05 10:07 PM |
Soaring club close to NYC, with high-performance gliders | City Dweller | Soaring | 9 | September 29th 05 11:55 AM |
