solar glider video
Old September 19th 10, 11:09 PM posted to rec.aviation.soaring
Peter Scholz[_2_]
Default solar glider video
Some nice video of Klaus Ohlmann soaring in the I_Care 2 solar glider
near Serres (France)
www.youtube.com/watch?v=iO03XNnT84U
Peter Scholz
ASW 24
JE
Old September 20th 10, 03:18 AM posted to rec.aviation.soaring
ContestID67[_2_]
Very interesting configuration. The first thing I noticed was the
oversized surfaces in the tail. The second thing I thought was "But
there is no motor, why the heck is this thing solar in the first
place???".
Only then did I notice that the motor was in the tail (I was looking
for the standard boom mounted unit). So that has something to do with
the overrsized tail surfaces. Aerodynamic or structural or both?
But what is the advantage of the motor in the tail? I can think of
one disadvantage - you can't retract it.
Old September 20th 10, 04:39 AM posted to rec.aviation.soaring
Marc Ramsey[_3_]
A perfectly sensible configuration for an electric motorglider, saves the
weight and complexity of the retraction mechanism, negligible drag with
the propeller blades folded back. The only surprise (to me, anyway) is
that this setup hasn't shown up on any non-solar electric motorgliders,
yet...
Marc
Old September 20th 10, 01:01 PM posted to rec.aviation.soaring
Paul Remde
It is a very interesting and elegant design.
However, putting all the weight of the electric motor so far back in the
tail must be balanced in the nose - by a longer nose that would otherwise be
necessary.
Paul Remde
"Marc Ramsey" wrote in message
yet...
Marc
Old September 20th 10, 01:06 PM posted to rec.aviation.soaring
Dave Nadler
On Sep 19, 11:39*pm, Marc Ramsey
But what is the advantage of the motor in the tail? * I can think of
the propeller blades folded back. *The only surprise (to me, anyway) is
yet...
Marc
See:
http://www.lange-aviation.com/htm/en...ntares_h3.html
Old September 20th 10, 03:51 PM posted to rec.aviation.soaring
cernauta
On Mon, 20 Sep 2010 03:39:19 +0000, Marc Ramsey
somewhere, I've seen a proposal for a motorglider with the prop in the
same position, driven by a traditional engine (in the fuselage) via
hydraulic transmission (pump, hi-pressure lines all the way to the top
of the tail, propeller).
Just can't remember anything more. It must have been a long time.
Aldo
Old September 20th 10, 04:47 PM posted to rec.aviation.soaring
Grider Pirate
necessary.
Paul Remde
.... which dictates a larger vertical stab.
Old September 21st 10, 05:12 AM posted to rec.aviation.soaring
Kevin
Aldo
The University of Stuttgart has a hydrogen powered experimental ship
based on the Pipistrel Taurus that has this same basic configuration.
http://www.pipistrel.si/news/hydroge...r-construction
Old September 21st 10, 02:40 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
the weight and complexity of the retraction mechanism, negligible drag
with the propeller blades folded back. The only surprise (to me,
anyway) is that this setup hasn't shown up on any non-solar electric
motorgliders,
There's also the Windex 1200 http://www.windex.se It is a motor glider
with a conventional motor mounted on front of the fin in a tractor
configuration and the same claimed glide performance as a Standard
Cirrus. It seems to have become commercial rather than a home build in
1999.
Does anybody know why they chose that configuration?
The website stopped being updated in 2001. Has anything happened since?
Has anybody seen one in the flesh?
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
New Glider Safety Video Tom[_9_] Soaring 0 March 27th 10 08:10 PM
A well-done Glider video Michael[_7_] Soaring 5 December 7th 09 05:03 PM
Solar Flight Much more interesting than Hilarious Video Richard[_1_] Soaring 0 December 5th 08 04:07 PM
What Kind of Glider in this Video? ContestID67 Soaring 5 April 16th 08 12:45 AM
Very cool glider video! Nik Piloting 2 November 29th 05 05:44 PM
