wings came off
Old September 20th 10, 11:11 PM posted to rec.aviation.soaring
Berry[_2_]
Default wings came off
"hinterland" wrote:
http://www.ledauphine.com/isere-sud/...aneur-se-dislo
que-en-plein-vol
What sort of glider was that? Wings looked sort of like an Lo-100, but
the fuselage looked like a pod-and-boom affair. One of the wings
appeared to chop off the tailboom as the fuselage was tumbling.
Good thing it was equipped with a ballistic chute. I think it might have
been hard to get out of with it tumbling like that and not too high
either.
Old September 20th 10, 11:42 PM posted to rec.aviation.soaring
Markus Graeber
It was the new Archaeopteryx high tech hang glider/microlift glider
(http://www.ruppert-composite.ch/english/index.html):
L/D 28:1, VNE 130 kph, + 5.3 g/- 2.65 g, and, as demonstrated, a
balistic recovery chute :-) Very interesting concept that puts it
between a hang glider and a full fledged glider as we know it.
The pilot was doing acro, after some spinning he was coming out of his
second loop and must have pulled a little too hard on the stick during
recovery... Here a better view of the sequence of events:
http://www.youtube.com/watch?v=AgOR5PLTn84
Markus
On Sep 20, 5:11*pm, Berry wrote:
*"hinterland" wrote:
http://www.ledauphine.com/isere-sud/...are-un-planeur...
que-en-plein-vol
either.
Old September 21st 10, 12:59 AM posted to rec.aviation.soaring
Westbender
balistic recovery chute :-) *Very interesting concept that puts it
Markus
http://www.ledauphine.com/isere-sud/...are-un-planeur....
que-en-plein-vol
either.- Hide quoted text -
- Show quoted text -
Looks to me like the first loop would have been pulling more G's than
the second. Higher speed, harder pull. Perhaps the damage was done on
the first one.
Old September 21st 10, 08:51 PM posted to rec.aviation.soaring
Larry Goddard
"Westbender" wrote in message
Markus
que-en-plein-vol
the first one.
Before the loops, I noticed that he did a rather significant negative
pushover.... Wonder if that might have weakened something...
Larry
Old September 22nd 10, 12:24 PM posted to rec.aviation.soaring
Derek C
Markus
que-en-plein-vol
the first one.
Larry- Hide quoted text -
Just looked like a normal push over to gain speed for an aerobatic
manouevre to me. This is a foot launched glider, so must be much more
lightly built than a normal glider.
Derek C
Old September 20th 10, 11:46 PM posted to rec.aviation.soaring
Mike the Strike
que-en-plein-vol
either.
Since Coupe Icare is primarily a hang-glider/paraglider event, I think
it is safe to assume that this was an ultralight, possibly foot-
launched aircraft.
No doubt we will be further enlightened by our European colleagues in
due course.
Mike
Mike
Old September 21st 10, 12:37 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
due course.
Here you go: http://www.ruppert-composite.ch/english/
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old September 21st 10, 12:49 AM posted to rec.aviation.soaring
Mike the Strike
que-en-plein-vol
either.
launched aircraft.
due course.
Mike
Mike
Indeed it was an Archaeopteryx - the schedule had two of them flying
there. Good photos and video on their website:
Hope that their naming it after an extinct Jurassic flying dinosaur
didn't jinx it!
Mike
Old September 21st 10, 07:05 PM posted to rec.aviation.soaring
Berry[_2_]
In article
que-en-plein-vol
either.
launched aircraft.
due course.
Mike
Mike
Ah, I see now. Thanks.
Pretty little machine. Must be great fun to soar those microlift
machines. Not so good for aerobatics, apparently.
Hey, make these gliders cheap enough and we'll have a new "extreme
sport" with competitors vying to produce the most spectacular in-flight
breakup.
Old September 21st 10, 07:10 PM posted to rec.aviation.soaring
Bart[_4_]
sport" *with competitors vying to produce the most spectacular in-flight
breakup.
If they use weak links instead of spar pins, the aircraft could even
be reused!
B.
hey Bob, don't look. There are no wings :-) Glenn[_2_] Aviation Photos 2 May 19th 08 04:43 PM
PC-9 with all the wings :-) Glenn[_2_] Aviation Photos 1 August 19th 07 01:52 AM
X-Wings and Canard Rotor Wings. Charles Gray Rotorcraft 1 March 22nd 05 12:26 AM
wings mark Owning 18 February 7th 04 10:07 AM
What it took to get wings in WW II. ArtKramr Military Aviation 29 July 16th 03 07:42 AM
