On Sep 23, 8:24*am, Bruce Hoult wrote:
On Sep 23, 5:26*pm, Derek C wrote: Lasham bought a couple of DG1000s as all round trainers. However in practice they are mostly only used for advanced cross-country training. From a basic instructional point of view they are too complicated (tail weights etc), too difficult to get in and out of, That's why we got two of the fixed undercarriage version. *Much much easier to get in and out, no possibility of wheel up landings, only very slightly more expensive than an ASK21, and still far better performance than an ASK21 or Grob. *Pretty similar to the 18m Janus we sold to finance them, but without the flaps, horrid control balance, or CofG hook. http://soar.co.nz/dgsmall.JPG and have awful ground handling (we have the 2 wheel version - the tail weights a ton). The fixed undercarriage version is a lot lighter on the tail. Optimum CofG sees it essentially balanced on the main wheel, and very light on either the tail or nose wheel. We don't faf about with the weights much. Most of the time we have 4 or 5 kg in the tail and just leave them there, giving a similar cockpit load range to any other glider. But the option is there if you want it and we certainly do it if there's going to be an extra large or small person in the front. They spin rather too well and lose a lot of height in the process. Sure, but it's not as if it's without a lot of warning! *I've done plenty of *time in small and bumpy thermals in ours and never had any problem. You're very clearly into inefficient mushing and buffeting long before there's a wing drop. The three wheeler version also has issues, including much longer take off and landing runs (due to the small angle of incidence of the wing to the fuselage) and the possibility of tail damage from snatched winch launches slamming the tail wheel onto the ground. The DG1000 is lovely to fly and is very docile right down to the stall, at which point it can drop a wing and depart into a spin without much warning. The spin can go flat and take some time to recover. It is not a glider you would want to deliberately spin much below 3000ft. People with very short or very long arms have problems operating the retractable undercarriage. It is difficult to lock down and we have had numerous undercarriage collapses on touchdown when pilots have failed to do so properly. There is no obvious detent to ensure that the U/C is locked down. The latest versions have an electrically operated retractable undercarriage,which says it all! On the plus side it has very powerful airbrakes and K13 trained pilots have no difficulty (apart from the U/C) in converting to it, unlike our Duo Discus which tends to run away with them on approach. Derek C |
The ASK 13 is probably the best and simplest glider to operate effectively
as a twoseat trainer. not necassarily the best for prepping pilots to fly slippery glass single seaters. However it does exactly what it says on the tin and if, you can fly a K13 well and accurately then you can prpobably fly most other gliders too that the potential pilot will progress to next. At 22:23 23 September 2010, Derek C wrote: On Sep 23, 8:24=A0am, Bruce Hoult wrote: On Sep 23, 5:26=A0pm, Derek C wrote: Lasham bought a couple of DG1000s as all round trainers. However in practice they are mostly only used for advanced cross-country training. From a basic instructional point of view they are too complicated (tail weights etc), too difficult to get in and out of, That's why we got two of the fixed undercarriage version. =A0Much much easier to get in and out, no possibility of wheel up landings, only very slightly more expensive than an ASK21, and still far better performance than an ASK21 or Grob. =A0Pretty similar to the 18m Janus we sold to finance them, but without the flaps, horrid control balance, or CofG hook. http://soar.co.nz/dgsmall.JPG and have awful ground handling (we have the 2 wheel version - the tail weights a ton). The fixed undercarriage version is a lot lighter on the tail. Optimum CofG sees it essentially balanced on the main wheel, and very light on either the tail or nose wheel. We don't faf about with the weights much. Most of the time we have 4 or 5 kg in the tail and just leave them there, giving a similar cockpit load range to any other glider. But the option is there if you want it and we certainly do it if there's going to be an extra large or small person in the front. They spin rather too well and lose a lot of height in the process. Sure, but it's not as if it's without a lot of warning! =A0I've done plenty of =A0time in small and bumpy thermals in ours and never had any problem. You're very clearly into inefficient mushing and buffeting long before there's a wing drop. The three wheeler version also has issues, including much longer take off and landing runs (due to the small angle of incidence of the wing to the fuselage) and the possibility of tail damage from snatched winch launches slamming the tail wheel onto the ground. The DG1000 is lovely to fly and is very docile right down to the stall, at which point it can drop a wing and depart into a spin without much warning. The spin can go flat and take some time to recover. It is not a glider you would want to deliberately spin much below 3000ft. People with very short or very long arms have problems operating the retractable undercarriage. It is difficult to lock down and we have had numerous undercarriage collapses on touchdown when pilots have failed to do so properly. There is no obvious detent to ensure that the U/C is locked down. The latest versions have an electrically operated retractable undercarriage,which says it all! On the plus side it has very powerful airbrakes and K13 trained pilots have no difficulty (apart from the U/C) in converting to it, unlike our Duo Discus which tends to run away with them on approach. Derek C |
Jon Arnold wrote: The ASK 13 is probably the best and simplest glider to operate effectively as a twoseat trainer. not necassarily the best for prepping pilots to fly slippery glass single seaters. However it does exactly what it says on the tin and if, you can fly a K13 well and accurately then you can prpobably fly most other gliders too that the potential pilot will progress to next. About the only thing keeping the ASK-7 and -13's from being the best trainers for the money is that their cockpits were not designed for the "modern" physique. |
On Nov 5, 8:58*am, Berry wrote:
About the only thing keeping the ASK-7 and -13's from being the best trainers for the money is that their cockpits were not designed for the "modern" physique. Well, I have a "modern" physique (love that euphemism!), and I fit in our K-13 just fine. The back seat of a 2-33, OTOH, is painful. I totally agree that the K-13 is a great primary trainer. It suffers, in the US at least, from being made from first-generation composites (i.e. wood and fabric), which is absurd in most parts of the US where it will outlast it's pilots! And, as the original poster mentioned, requires a bit of conversion when moving up to more slippery glass. Perhaps we can import a bunch of K-13s from Europe to replace our grounded Blanik L-13s? Maybe we should convince someone to put the 2-32 back in production - now there is a glider with room for the well fed pilot & passenger(s)! And it spins! Kirk 66 |
Club Class Gliders | Sam Giltner[_1_] | Soaring | 4 | December 3rd 08 03:28 AM |
Basic Training Gliders | Derek Copeland | Soaring | 35 | December 26th 05 02:19 PM |
Basic Training Gliders | Justin Craig | Soaring | 0 | December 6th 05 10:07 PM |
Soaring club close to NYC, with high-performance gliders | City Dweller | Soaring | 9 | September 29th 05 11:55 AM |
