taller battery holder/clips for Ventus 2?
Old October 3rd 10, 01:09 AM posted to rec.aviation.soaring
Todd
Default taller battery holder/clips for Ventus 2?
Larger batteries means a change in weight.
Do not forget to update the W&B.
You never know when you will get ramped by some FAA guy who will
notice the non-factory issued battery straps. It can be a very
slippery slope from there
Old October 3rd 10, 02:37 PM posted to rec.aviation.soaring
Andy[_1_]
Well that's an interesting observation. Do you update your basic
weight and balance data when you load water? Is your weight and
balance then invalid when you dump before landing?
My official weight and balance data does not include the batteries
since they are not required equipment. I consider batteries to be
optional/variable as are pilot mass and arm, water ballast mass and
arm, drinking water, and trim disks. All these are calculated on
page 2 of my W/B spreadsheet and do not appear in the weight and
balance data that was submitted for airworthiness inspection and
carried in the cockpit.
Page 2 of my weight and balance spread sheets allows selection of 1,
or 2, or zero batteries. If I change the battery type and mass I
would update the protected battery mass data on that sheet, but no FAA
inspected data would change.
I understand the situation may be different in countries ruled by
EASA.
Andy
L13A Type certificate holder Bruce Soaring 7 August 19th 10 07:01 PM
Wave Alert and record holder caught cheating? bumper Soaring 2 March 15th 09 09:23 AM
FA: Beech aircraft yoke chart holder (Garhawk) Karl Geng, N1DL Products 0 January 28th 05 08:07 PM
New Video Clips To Watch P.Naton Soaring 1 April 30th 04 11:26 PM
