Mystery aircraft: Help needed
Old February 4th 04, 01:34 AM
Kevin Brooks
"Andreas Parsch" wrote in message
Hi,
a friend and I are unable to identify the WW2-era aircraft on this photo
(no
caption or context available):
http://www.designation-systems.net/mystery.jpg
We think that the aircraft (obviously a glider) is connected to the U.S.
Navy's GLOMB ("Glider Bomb") program for remotely controlled gliders used
as surface-attack missiles. Several types of gliders were used in this
program, some (heavily??) modified from existing types, others
newly-designed. Unfortunately, the information on GLOMB in out sources is
incomplete and partially inconsistent, and we couldn't come up with a
really plausible ID for the aircraft.
Andreas, the thing appears to resemble the Taylorcraft XTG-5 training
glider, albeit with a tricycle undercarriage. See:
http://www.ww2gp.org/training.htm. The Navy/Marine Corps had a similar
aircraft (the LNR-1, also LNT-1), which is referenced at
http://www.aero-web.org/specs/taylorcr/xlnt-1.htm, but no picture was
available. Note that Taylorcraft did manufacture the LBT-1 GLOMB
(http://www.history.navy.mil/avh-1910/APP21.PDF). Forgive me if you already
knew all of this...
Brooks
So, any input would be much appreciated. Perhaps someone has that same
_with_ a caption ;-).
Thanks in advance!
Andreas
Old February 4th 04, 07:57 AM
Andreas Parsch
"appears to resemble" is exactly the problem here ;-) (see also my
other reply on this thread), because at a closer look, it differs in
all essential details. Most notably the tailplane and wing strut
arrangement, which would most likely remain essentially unmodified in
a landing gear modification.
See:
knew all of this...
I did, but no problem at all - if the a/c isn't immediately
identified, it show at least that I was not completely blind :-).
Andreas
Old February 4th 04, 10:10 AM
robert arndt
"Kevin Brooks" wrote in message ...
Hi,
(no
Similar to a TG-6A training glider:
http://www.pointvista.com/WW2GliderP...TG6caption.jpg
Rob
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
