![]() Some years ago a company was building Ford engines for installation in homebuilts. They did a couple of experiments of running the engine, with a prop, without coolant. On both occasions the broken-in engines ran for 30+ minutes. Both stopped due to expansion of the pistons in the bores. When the engines cooled the coolant systems were filled and the engines started. Both ran and turned the prop at the same rpm. But also both engine's head gaskets were shot and the metallurgy of both the heads and the pistons had changed to the point of all having to be relegated to the scrap pile. Crank and rod bearings were still in good condition. Bruce A. Frank ++++++++++++++++++++++++++++++++++++++++++ What RPM? What power level? Unless producing realistic in-flight power.... is there value in this exercise beyond PR? Barnyard BOb -- |
"Barnyard BOb --" wrote in message
... Some years ago a company was building Ford engines for installation in homebuilts. They did a couple of experiments of running the engine, with a prop, without coolant. On both occasions the broken-in engines ran for 30+ minutes. Both stopped due to expansion of the pistons in the bores. When the engines cooled the coolant systems were filled and the engines started. Both ran and turned the prop at the same rpm. But also both engine's head gaskets were shot and the metallurgy of both the heads and the pistons had changed to the point of all having to be relegated to the scrap pile. Crank and rod bearings were still in good condition. Bruce A. Frank ++++++++++++++++++++++++++++++++++++++++++ What RPM? What power level? Unless producing realistic in-flight power.... is there value in this exercise beyond PR? Barnyard BOb -- What PR? As I read it, if you're cooling system fails you basically have enough time to set it down then you're looking at a new engine. Eric |
On Thu, 30 Oct 2003 12:45:26 GMT, "Eric Miller"
wrote: "Barnyard BOb --" wrote in message .. . Some years ago a company was building Ford engines for installation in homebuilts. They did a couple of experiments of running the engine, with a prop, without coolant. On both occasions the broken-in engines ran for 30+ minutes. Both stopped due to expansion of the pistons in the bores. When the engines cooled the coolant systems were filled and the engines started. Both ran and turned the prop at the same rpm. But also both engine's head gaskets were shot and the metallurgy of both the heads and the pistons had changed to the point of all having to be relegated to the scrap pile. Crank and rod bearings were still in good condition. Bruce A. Frank ++++++++++++++++++++++++++++++++++++++++++ What RPM? What power level? Unless producing realistic in-flight power.... is there value in this exercise beyond PR? Barnyard BOb -- What PR? As I read it, if you're cooling system fails you basically have enough time to set it down then you're looking at a new engine. Eric So far, I've not read of any reported catastrophic coolant losses in the Ford powered airplanes. There have been instances (I've read of two in Bruce's newletter) in which the head gasket began leaking. This resulted in pressure readings that were abnormal, and the pilots in both instances noticed them. The airplanes were flown back to their home fields and the head gaskets were replaced. In one instance, the airplane was a fair distance from the field. Inflight coolant temperatures did not change much, it was the pressure when the engine was shut down that got the pilot's attention. When you think about it, where where might a catastrophic leak occur and how? Could a hose burst? A hole develop in the radiator? Those things normally don't just blow up and spew out everything, they leak very slowly at first, and a thorough preflight should include looking for signs of coolant leakage I'd think. When you put together a water cooled auto conversion, you use premium hoses and radiators, right? You don't install aged and hardened parts do you? Well I'm not going to anyway. Corky Scott |
"Corky Scott" wrote
"Eric Miller" wrote: What PR? As I read it, if you're cooling system fails you basically have enough time to set it down then you're looking at a new engine. Eric So far, I've not read of any reported catastrophic coolant losses in the Ford powered airplanes. There have been instances (I've read of two in Bruce's newletter) in which the head gasket began leaking. This resulted in pressure readings that were abnormal, and the pilots in both instances noticed them. The airplanes were flown back to their home fields and the head gaskets were replaced. In one instance, the airplane was a fair distance from the field. Inflight coolant temperatures did not change much, it was the pressure when the engine was shut down that got the pilot's attention. When you think about it, where where might a catastrophic leak occur and how? Could a hose burst? A hole develop in the radiator? Those things normally don't just blow up and spew out everything, they leak very slowly at first, and a thorough preflight should include looking for signs of coolant leakage I'd think. When you put together a water cooled auto conversion, you use premium hoses and radiators, right? You don't install aged and hardened parts do you? Well I'm not going to anyway. Corky Scott I wasn't implying that a catastrophic coolant failure was a likely event, but rather that this was an unlikely PR angle. Eric |
There has been one incident where there was a sudden and complete loss
of coolant. The builder had capped an unused hose connection on the block by folding a short length of heater hose in half and hose clamping everything in place. Though the engine's head gaskets had not been set up as recommended the plane had more than 800 hours on the meter. The builder had no problems to this point because of his procedure of fully bring the engine to temp before requiring take off power. This day he neglected his own warm up rules and took off before full saturation. The head gasket blew pressuring the coolant system. The pressure peak blew the clamped hose plug and instantly emptied the coolant from the engine. After trying to find a hole between traffic on a couple of highways the pilot was flying parallel to traffic on his intended landing highway when the engine quit. Flight time since loss of coolant at that point was 15 minutes. The pilot and passenger in the Mustang II skidded on top of a fence beside the road for several yards then tipped over into a water filled ditch. Because of the recently installed roll over structure he and his passenger walked away. The plane had minimal damage and was quickly repaired. The engine when disassembled was found to have not seized. Nothing wrong could be found in the engine. After several days of running the engine the builder finally discovered that the culprit was a water caused short in the ignition system and steps were take to eliminate that weak point. This incident is the only instantaneous loss of coolant of which I am aware. Point is that sudden loss of coolant does not suddenly stop the engines power making capability ....as would loss of fuel or loss of oil in this or any other engine. Corky Scott wrote: On Thu, 30 Oct 2003 12:45:26 GMT, "Eric Miller" wrote: "Barnyard BOb --" wrote in message .. . Some years ago a company was building Ford engines for installation in homebuilts. They did a couple of experiments of running the engine, with a prop, without coolant. On both occasions the broken-in engines ran for 30+ minutes. Both stopped due to expansion of the pistons in the bores. When the engines cooled the coolant systems were filled and the engines started. Both ran and turned the prop at the same rpm. But also both engine's head gaskets were shot and the metallurgy of both the heads and the pistons had changed to the point of all having to be relegated to the scrap pile. Crank and rod bearings were still in good condition. Bruce A. Frank ++++++++++++++++++++++++++++++++++++++++++ What RPM? What power level? Unless producing realistic in-flight power.... is there value in this exercise beyond PR? Barnyard BOb -- What PR? As I read it, if you're cooling system fails you basically have enough time to set it down then you're looking at a new engine. Eric So far, I've not read of any reported catastrophic coolant losses in the Ford powered airplanes. There have been instances (I've read of two in Bruce's newletter) in which the head gasket began leaking. This resulted in pressure readings that were abnormal, and the pilots in both instances noticed them. The airplanes were flown back to their home fields and the head gaskets were replaced. In one instance, the airplane was a fair distance from the field. Inflight coolant temperatures did not change much, it was the pressure when the engine was shut down that got the pilot's attention. When you think about it, where where might a catastrophic leak occur and how? Could a hose burst? A hole develop in the radiator? Those things normally don't just blow up and spew out everything, they leak very slowly at first, and a thorough preflight should include looking for signs of coolant leakage I'd think. When you put together a water cooled auto conversion, you use premium hoses and radiators, right? You don't install aged and hardened parts do you? Well I'm not going to anyway. Corky Scott -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| *------------------------------**----* \(-o-)/ AIRCRAFT PROJECTS CO. \___/ Manufacturing parts & pieces / \ for homebuilt aircraft, 0 0 TIG welding While trying to find the time to finish mine. |
On Thu, 30 Oct 2003 15:52:33 GMT, "Bruce A. Frank"
wrote: After trying to find a hole between traffic on a couple of highways the pilot was flying parallel to traffic on his intended landing highway when the engine quit. Flight time since loss of coolant at that point was 15 minutes. The pilot and passenger in the Mustang II skidded on top of a fence beside the road for several yards then tipped over into a water filled ditch. Because of the recently installed roll over structure he and his passenger walked away. The plane had minimal damage and was quickly repaired. The engine when disassembled was found to have not seized. Nothing wrong could be found in the engine. After several days of running the engine the builder finally discovered that the culprit was a water caused short in the ignition system and steps were take to eliminate that weak point. +++++++++++++++++++++++++++++++++++++++++ And my counterpoint is.... If this was an AIRCOOLED powered aircraft, the failure could not possibly happen. Keep on spinning away... with talk of minimal damage, etcetera -- but, far too many times aircraft are totaled and occupants do not walk away when forced to land off airport. And sadly, when it comes to landing on highways, they tend to take their share of traffic innocents with them. Barnyard BOb -- KISS - keeping it simple, stoopid |
On Thu, 30 Oct 2003 10:22:14 -0600, Barnyard BOb --
wrote: On Thu, 30 Oct 2003 15:52:33 GMT, "Bruce A. Frank" wrote: After trying to find a hole between traffic on a couple of highways the pilot was flying parallel to traffic on his intended landing highway when the engine quit. Flight time since loss of coolant at that point was 15 minutes. The pilot and passenger in the Mustang II skidded on top of a fence beside the road for several yards then tipped over into a water filled ditch. Because of the recently installed roll over structure he and his passenger walked away. The plane had minimal damage and was quickly repaired. The engine when disassembled was found to have not seized. Nothing wrong could be found in the engine. After several days of running the engine the builder finally discovered that the culprit was a water caused short in the ignition system and steps were take to eliminate that weak point. +++++++++++++++++++++++++++++++++++++++++ And my counterpoint is.... If this was an AIRCOOLED powered aircraft, the failure could not possibly happen. Keep on spinning away... with talk of minimal damage, etcetera -- Barnyard BOb -- KISS - keeping it simple, stoopid I recall Bill Phillips posting a story about test flying an RV (6 I think) on it's initial flight. Bill agreed to make the flight for the builder. The builder went with Bill on the flight, if I remember correctly, although that fact doesn't matter in terms of the story. The engine was a brand new Lycoming, again, if I remember correctly. It blew out the front seal of the engine while in flight and emptied all the oil everywhere, including the windshield. Bill managed to get it down amidst a rock strewn opening in the desert, with minimal damage to the airplane and engine. This was an air cooled engine, he did not have 15 minutes to get it down. Corky Scott PS, I don't see Bruce's post as a "spin" on the subject. Applying a spin to a story implies twisting the facts to better suit an agenda or to explain away ill thought through utterances. What Bruce was doing was showing that yes in fact there had been a sudden and catastrophic loss of coolant in a Ford powered airplane, after I'd said I did not know of such an incident. That the engine was not damaged, even after flying for 15 additional minutes after loosing all it's coolant isn't "spin". It's what actually happened. |
![]() Barnyard BOb -- wrote: And my counterpoint is.... If this was an AIRCOOLED powered aircraft, the failure could not possibly happen. Keep on spinning away... with talk of minimal damage, etcetera -- but, far too many times aircraft are totaled and occupants do not walk away when forced to land off airport. And sadly, when it comes to landing on highways, they tend to take their share of traffic innocents with them. Barnyard BOb -- KISS - keeping it simple, stoopid Yep, you are correct, BOb. Lycomings and Continentals never fail and of the infinitesimal small number that might, no one will ever even get hurt. This wasn't a point/counter point discussion. I was clarifying a fact for Corky. I would hate to leave out a piece of information so that you might say I was "spinning" the facts. A sin(spin?)of omission. Oh, wait, you say I am spinning the facts now! Obviously you are still besting me at every turn. How dastardly of you. Maybe one of these days I'll consider this "fight" worth some indulgence of my time. But for now I'll leave others the pleasure and just "spin" a few facts once in a while. -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| |
On Fri, 31 Oct 2003 05:38:20 GMT, "Bruce A. Frank"
wrote: Barnyard BOb -- wrote: And my counterpoint is.... If this was an AIRCOOLED powered aircraft, the failure could not possibly happen. Keep on spinning away... with talk of minimal damage, etcetera -- but, far too many times aircraft are totaled and occupants do not walk away when forced to land off airport. And sadly, when it comes to landing on highways, they tend to take their share of traffic innocents with them. Barnyard BOb -- KISS - keeping it simple, stoopid Yep, you are correct, BOb. Lycomings and Continentals never fail and of the infinitesimal small number that might, no one will ever even get hurt. This wasn't a point/counter point discussion. I was clarifying a fact for Corky. I would hate to leave out a piece of information so that you might say I was "spinning" the facts. A sin(spin?)of omission. Oh, wait, you say I am spinning the facts now! Obviously you are still besting me at every turn. How dastardly of you. Maybe one of these days I'll consider this "fight" worth some indulgence of my time. But for now I'll leave others the pleasure and just "spin" a few facts once in a while. +++++++++++++++++++++++++++++++++++++++++++ If your remarks are for Corky... send him a private email. Otherwise, your remarks here are fair game for one and all. IF you and Corky ever ACTUALLY FLY your conversions..... maybe your FACTS? will take on a more realistic perspective. So far, you vocal RAH conversion advocates are ALL TALK and NO WALK. ALL HAT. NO CATTLE. You guys point to what you believe are 'successes' defined by some 'shoot from the hip' criteria. MOSTLY what I see is...BULL****, so the flags go up. If this is "BESTING" you, so be it. I make no apologies. Worth YOUR indulgence? Pardon me all to hell, your majesty. While you and Corky just talk, talk, talk.... I continue to walk my walk - just like I have for 50 flight years. Why should I give a rat's ass if you never INDULGE me, again? When you two scare the **** out of yourselves sufficiently, AND YOU WILL, I believe you may 'indulge' me... ....IF you survive your follies and your egos. Barnyard BOb -- over 50 years of flight. |
Well I had my medical with the doctor that owns one of the subject
planes today. In our short conversation I asked what specific problems he'd had with the conversion. He says the only problem has been with the computer setting the fuel mixture too rich. They had a lot of trouble sorting that out and are now running without using the O2 sensors. He and his father have owned this plane for many years origionally with the franklin engine and later with a lycoming. He was ready to sell the plane due to poor performance off the water and slow climb rates but since doing the conversion he is very happy with the performance now. His takeoff distances are greatly reduced, cruise has increased by 5mph, climb rates are as high as 1500fpm. ( instead of 100fpm with the franklin on a hot day ) and his fuel burn has dropped from 12 to 8.8gph. on autofeul. Drew Dalgleish |
human powered flight | patrick timony | Home Built | 10 | September 16th 03 03:38 AM |
Illusive elastic powered Ornithopter | Mike Hindle | Home Built | 6 | September 15th 03 03:32 PM |
Pre-Rotator Powered by Compressed Air? | nuke | Home Built | 8 | July 30th 03 12:36 PM |
Powered Parachute Plans | MJC | Home Built | 4 | July 15th 03 07:29 PM |
Powered Parachute Plans- correction | Cy Galley | Home Built | 0 | July 11th 03 03:43 AM |
