V-8 powered Seabee
Old November 2nd 03, 08:24 AM
Barnyard BOb --
On Fri, 31 Oct 2003 05:38:20 GMT, "Bruce A. Frank"
And my counterpoint is....
If this was an AIRCOOLED powered aircraft,
the failure could not possibly happen.
Keep on spinning away...
with talk of minimal damage, etcetera --
but, far too many times aircraft are totaled
and occupants do not walk away when
forced to land off airport. And sadly, when
it comes to landing on highways, they tend to
take their share of traffic innocents with them.
Barnyard BOb -- KISS - keeping it simple, stoopid
Yep, you are correct, BOb. Lycomings and Continentals never fail and of
the infinitesimal small number that might, no one will ever even get
hurt.
Flying is an especially unforgiving activity. No one alive is more
keenly aware that Lycoming and Continental have yet to produce
the perfect piston engine. Once again you miss the point and insult
me with your bias, naivete, arrogance, inexperience and verbal
gymnastics.
It is not from a lack of concentrated, concerted and systematic
efforts over the last 50 years that the perfect aircraft engine has
not been born of the aircraft engine industry. However, for you to
continue denying or inferring that these certified engines and their
marvelous records do not currently blow away anything you are
producing in your backyard is to deny reality and is the epitome
of arrogance and "dastardly" in its own right.
If you want to experiment with auto conversions
and do it without any lip from me..... IT'S EASY!!!!
Cease your dastardly propaganda concerning certified engines.
By definition, certified engines have PROVEN to be the least risk
to life and limb. No amount of spin can change this. Period.
LET ME REPEAT....
Barnyard BOb -- over 50 years of successful flight
Old October 30th 03, 02:40 PM
Barnyard BOb --
Some years ago a company was building Ford engines for installation in
homebuilts. They did a couple of experiments of running the engine, with
a prop, without coolant. On both occasions the broken-in engines ran for
30+ minutes. Both stopped due to expansion of the pistons in the bores.
When the engines cooled the coolant systems were filled and the engines
started. Both ran and turned the prop at the same rpm. But also both
engine's head gaskets were shot and the metallurgy of both the heads and
the pistons had changed to the point of all having to be relegated to
the scrap pile. Crank and rod bearings were still in good condition.
Bruce A. Frank
What RPM?
What power level?
Unless producing realistic in-flight power....
is there value in this exercise beyond PR?
Barnyard BOb --
What PR? As I read it, if you're cooling system fails you basically have
enough time to set it down then you're looking at a new engine.
Eric
I sincerely and most humbly apologize.
My generosity was aimed to cut these defunct folks some slack.
However, I have no problem seeing it your way. g
Barnyard BOb --
Old October 30th 03, 03:15 PM
Eric Miller
"Barnyard BOb --" wrote I sincerely and most humbly
apologize.
Barnyard BOb --
I think that's called "damning with faint praise" =D
Eric
Old October 30th 03, 03:34 PM
Russell Kent
apologize.
Barnyard BOb --
N.B. the above should read "feint praise"
feint:
(n.) 1. a false show; sham 2. a pretended blow or attack intended to
take the opponent off his guard, as in boxing or warfare
(vi., vt.) 1. to delivery such a blow or attack
This message is intended to educate, not mock or degrade.
Russell Kent
Old October 30th 03, 06:45 PM
Eric Miller
"Russell Kent" wrote in message
feint:
Russell Kent
The correct expression and spelling is "faint praise"; the praise isn't
false (a feint) it's weak (faint).
Notice that faint is an adjective while feint is not.
http://www.cuyamaca.net/bruce.thomps...aintpraise.asp
http://dictionary.reference.com/search?q=faint
Eric
Old October 30th 03, 11:22 PM
Barnyard BOb --
feint:
Russell Kent
Eric
Could this be characterized as...
1. A battle of nits by wits
2. Vice versa
3, or, who cares about wit nits
4. or, vice versa g
Barnyard BOb -- phaking a phaint pheint
Old October 31st 03, 05:19 PM
Russell Kent
feint:
Russell Kent
Interesting. I'm now equally uncertain as to which is the proper phrase. I
can see where one might use "faint (weak) praise" or "feint (false or
deceptive) praise". A brief Google search failed to turn up a definitive
page. Numerous usages exist for both forms.
Irrelevant. Red is a noun. What part of speech does "red" play in the phrase
"roll out the red carpet"? It's an adjective, or more properly an adjectival
noun. So "feint" would be functioning as an adjectival noun for "praise".
As I am uncertain which form is the proper one, I retract my earlier
correction.
Russell Kent
human powered flight patrick timony Home Built 10 September 16th 03 03:38 AM
Illusive elastic powered Ornithopter Mike Hindle Home Built 6 September 15th 03 03:32 PM
Pre-Rotator Powered by Compressed Air? nuke Home Built 8 July 30th 03 12:36 PM
Powered Parachute Plans MJC Home Built 4 July 15th 03 07:29 PM
Powered Parachute Plans- correction Cy Galley Home Built 0 July 11th 03 03:43 AM
