![]() Some years ago a company was building Ford engines for installation in homebuilts. They did a couple of experiments of running the engine, with a prop, without coolant. On both occasions the broken-in engines ran for 30+ minutes. Both stopped due to expansion of the pistons in the bores. When the engines cooled the coolant systems were filled and the engines started. Both ran and turned the prop at the same rpm. But also both engine's head gaskets were shot and the metallurgy of both the heads and the pistons had changed to the point of all having to be relegated to the scrap pile. Crank and rod bearings were still in good condition. Bruce A. Frank ++++++++++++++++++++++++++++++++++++++++++ What RPM? What power level? Unless producing realistic in-flight power.... is there value in this exercise beyond PR? Barnyard BOb -- What PR? As I read it, if you're cooling system fails you basically have enough time to set it down then you're looking at a new engine. Eric +++++++++++++++++++++++++++++++++++++++++ I sincerely and most humbly apologize. My generosity was aimed to cut these defunct folks some slack. However, I have no problem seeing it your way. g Barnyard BOb -- |
"Barnyard BOb --" wrote I sincerely and most humbly
apologize. My generosity was aimed to cut these defunct folks some slack. However, I have no problem seeing it your way. g Barnyard BOb -- I think that's called "damning with faint praise" =D Eric |
Eric Miller wrote:
"Barnyard BOb --" wrote I sincerely and most humbly apologize. My generosity was aimed to cut these defunct folks some slack. However, I have no problem seeing it your way. g Barnyard BOb -- I think that's called "damning with faint praise" =D N.B. the above should read "feint praise" feint: (n.) 1. a false show; sham 2. a pretended blow or attack intended to take the opponent off his guard, as in boxing or warfare (vi., vt.) 1. to delivery such a blow or attack This message is intended to educate, not mock or degrade. Russell Kent |
"Russell Kent" wrote in message
... Eric Miller wrote: I think that's called "damning with faint praise" =D N.B. the above should read "feint praise" feint: (n.) 1. a false show; sham 2. a pretended blow or attack intended to take the opponent off his guard, as in boxing or warfare (vi., vt.) 1. to delivery such a blow or attack This message is intended to educate, not mock or degrade. Russell Kent The correct expression and spelling is "faint praise"; the praise isn't false (a feint) it's weak (faint). Notice that faint is an adjective while feint is not. http://www.cuyamaca.net/bruce.thomps...aintpraise.asp http://dictionary.reference.com/search?q=faint Eric |
![]() I think that's called "damning with faint praise" =D N.B. the above should read "feint praise" feint: (n.) 1. a false show; sham 2. a pretended blow or attack intended to take the opponent off his guard, as in boxing or warfare (vi., vt.) 1. to delivery such a blow or attack This message is intended to educate, not mock or degrade. Russell Kent The correct expression and spelling is "faint praise"; the praise isn't false (a feint) it's weak (faint). Notice that faint is an adjective while feint is not. Eric ++++++++++++++++++++++++++++++++++++++ Could this be characterized as... 1. A battle of nits by wits 2. Vice versa 3, or, who cares about wit nits 4. or, vice versa g Barnyard BOb -- phaking a phaint pheint |
Eric Miller wrote:
"Russell Kent" wrote in message ... Eric Miller wrote: I think that's called "damning with faint praise" =D N.B. the above should read "feint praise" feint: (n.) 1. a false show; sham 2. a pretended blow or attack intended to take the opponent off his guard, as in boxing or warfare (vi., vt.) 1. to delivery such a blow or attack This message is intended to educate, not mock or degrade. Russell Kent The correct expression and spelling is "faint praise"; the praise isn't false (a feint) it's weak (faint). Notice that faint is an adjective while feint is not. http://www.cuyamaca.net/bruce.thomps...aintpraise.asp http://dictionary.reference.com/search?q=faint Interesting. I'm now equally uncertain as to which is the proper phrase. I can see where one might use "faint (weak) praise" or "feint (false or deceptive) praise". A brief Google search failed to turn up a definitive page. Numerous usages exist for both forms. Notice that faint is an adjective while feint is not. Irrelevant. Red is a noun. What part of speech does "red" play in the phrase "roll out the red carpet"? It's an adjective, or more properly an adjectival noun. So "feint" would be functioning as an adjectival noun for "praise". As I am uncertain which form is the proper one, I retract my earlier correction. Russell Kent |
Russell Kent wrote:
Irrelevant. Red is a noun. What part of speech does "red" play in the phrase "roll out the red carpet"? It's an adjective, or more properly an adjectival noun. So "feint" would be functioning as an adjectival noun for "praise". And everyone knows that no air-cooled noun has ever suffered a catastrophic loss of coolant. Water-cooled nouns are killers, however, and should never be used in the same sentence as an aviation-related noun. To do so tempts fate...and BOb. Dave 'but can you say it in Klingonese?' Hyde |
Russell Kent wrote:
Interesting. I'm now equally uncertain as to which is the proper phrase. I can see where one might use "faint (weak) praise" or "feint (false or deceptive) praise". A brief Google search failed to turn up a definitive page. Numerous usages exist for both forms. AltaVista shows 96 occurrences of "feint praise" and 10,447 occurrences of "faint praise" across the web. While popular usage is certainly not always an accurate measure of correctness, it can sometimes provide reasonable clues when authoritative sources are lacking. The adjectival form of "feint", meaning "feigned", is archaic (1). Many expressions, however, use archaic words. The best clue in this particular case is in the phrase itself. While one could "damn" with faint (weak) praise, one would likely only "deceive" with feigned (false) praise. IMO, the phrase just doesn't make much sense using "feint". It could be argued that one could damn with excessive or effusive feint (feigned) praise, but that is more than the phrase in question suggests. Bartlett's Familiar Quotes has this, Damn with faint praise, assent with civil leer, And, without sneering, teach the rest to sneer; -- Alexander Pope, Epistle to Dr. Arbuthnot [1734]. Prologue to Imitations of Horace, l. 193 Notice that faint is an adjective while feint is not. Irrelevant. Red is a noun. What part of speech does "red" play in the phrase "roll out the red carpet"? It's an adjective, or more properly an adjectival noun. So "feint" would be functioning as an adjectival noun for "praise". All my dictionaries show red as both a noun and an adjective. Your use of "red" simply uses its common adjective form. An example of an adjectival noun would be the word "village" in the phrase "village idiot". I expect Barnyard Bob could have a field day with that opening. ![]() As a last resort in resolving such issues, I have found the newsgroup alt.usage.english quite helpful. David O -- http://www.AirplaneZone.com 1: Webster's Third New International Dictionary - Unabridged |
David O wrote:
All my dictionaries show red as both a noun and an adjective. Your use of "red" simply uses its common adjective form. An example of an adjectival noun would be the word "village" in the phrase "village idiot". I expect Barnyard Bob could have a field day with that opening. ![]() Oy. Touche', touche'. I should've chosen a *correct* example of my point. As a last resort in resolving such issues, I have found the newsgroup alt.usage.english quite helpful. Your subtle, and Dave Hyde's less so :-), point taken. I'm happy to let this sub-thread die. Russell Kent |
In article , Russell Kent wrote:
Eric Miller wrote: "Russell Kent" wrote in message ... Eric Miller wrote: I think that's called "damning with faint praise" =D N.B. the above should read "feint praise" feint: (n.) 1. a false show; sham 2. a pretended blow or attack intended to take the opponent off his guard, as in boxing or warfare (vi., vt.) 1. to delivery such a blow or attack This message is intended to educate, not mock or degrade. Russell Kent The correct expression and spelling is "faint praise"; the praise isn't false (a feint) it's weak (faint). Notice that faint is an adjective while feint is not. http://www.cuyamaca.net/bruce.thomps...aintpraise.asp http://dictionary.reference.com/search?q=faint Interesting. I'm now equally uncertain as to which is the proper phrase. I can see where one might use "faint (weak) praise" or "feint (false or deceptive) praise". A brief Google search failed to turn up a definitive page. Numerous usages exist for both forms. The correct form *is* "faint praise". With faint having the meaning of 'lacking in conviction'. A 'feint' is a deception that is *intended*to*be*believed*. Something that is intended to mis-direct, distract, draw attention _away_ from the real issue. What Juan Jiminez routinely does. grin 'Faint praise' is issued with the intent that it *NOT* be believed. The intent is that you believe the _opposite_ of what was actually said. By stating it with a market 'lack of conviction', one calls attention to the falsity of the statement. Marc Anthony's speech on the death of Caesar is the archtypical example of 'damning with faint praise' -- "..For Brutus is an _honorable_man_. So are they *all*, _honorable_men_...." The _last_ thing Marc Anthony wanted was for people to "believe him". He _is_ 'praising' them, with the _intent_ of being 'not believed'. |
human powered flight | patrick timony | Home Built | 10 | September 16th 03 03:38 AM |
Illusive elastic powered Ornithopter | Mike Hindle | Home Built | 6 | September 15th 03 03:32 PM |
Pre-Rotator Powered by Compressed Air? | nuke | Home Built | 8 | July 30th 03 12:36 PM |
Powered Parachute Plans | MJC | Home Built | 4 | July 15th 03 07:29 PM |
Powered Parachute Plans- correction | Cy Galley | Home Built | 0 | July 11th 03 03:43 AM |
