![]() - Show quoted text - If the pilot hadn't rejected some weak lift (by US standards) and then glid in a straight line rather than faffing around, he might have made it back! Derek C Let's see if I can put the same observation a bit more politely. In part, as this sort of video makes a great training tool for aspiring cross country pilots. Lessons learned? One big one, of course, is that stretching final glides for the last 2-3 miles at very low altitudes is a coffin corner, and this pilot made the right decision not to try it. The wisdom of "glid in a straight line" depends very much on terrain and altitude. Mc 0 + 10 feet and unlandable terrain makes it a bad idea. But, as Derek points out, the beginning part of the video shows a lot of waffling around in 10 - 20 degree bank, with the vario showing all sorts of lift possibilities, while the pilot chats on the radio. I see those surges on the vario and push the mouse hard to one side. Now, perhaps "turn the radio off" is extreme. It is potentially a good idea to notify others of your predicament and imminent chance of landing out. But then "I'm too busy to talk" might be a better idea, and focus really hard on catching those scraps of lift, with accurate aggressive thermaling and decent bank angles -- while of course also looking hard at the fields below. There is a maxim, "don't leave any lift below X feet," which applies too, and the pilot said as much at the end of the flight. I have also suffered bouts of impatience in scratch thermaling, and spent many pleasant hours in farmer's fields bemoaning it afterwards. John Cochrane |
On Oct 19, 1:36*pm, John Cochrane
wrote: - Show quoted text - If the pilot hadn't rejected some weak lift (by US standards) and then glid in a straight line rather than faffing around, he might have made it back! Derek C Let's see if I can put the same observation a bit more politely. In part, as this sort of video makes a great training tool for aspiring cross country pilots. Lessons learned? One big one, of course, is that stretching final glides for the last 2-3 miles at very low altitudes is a coffin corner, and this pilot made the right decision not to try it. The wisdom of "glid in a straight line" depends very much on terrain and altitude. Mc 0 + 10 feet and unlandable terrain makes it a bad idea. But, as Derek points out, the beginning part of the video shows a lot of waffling around in 10 - 20 degree bank, with the vario showing all sorts of lift possibilities, while the pilot chats on the radio. I see those surges on the vario and push the mouse hard to one side. Now, perhaps "turn the radio off" is extreme. It is potentially a good idea to notify others of your predicament and imminent chance of landing out. But then "I'm too busy to talk" might be a better idea, and focus really hard on catching those scraps of lift, with accurate aggressive thermaling and decent bank angles -- while of course also looking hard at the fields below. There is a maxim, "don't leave any lift below X feet," which applies too, and the pilot said as much at the end of the flight. I have also suffered bouts of impatience in scratch thermaling, and spent many pleasant hours in farmer's fields bemoaning it afterwards. John Cochrane Judging by the angle of the sun, it' was quite late in the day and the thernals would be getting weak. The pilot was probably tired and hadn't quite changed gear into scratching mode. Add to that he is trying to thermal, talk on the radio, calculate his final glide, and pick fields, all at the same time. He never once completes a turn in the lift he does encounter, so we can't tell whether a climb was possible or not. I must admit that I have sometimes made the same errors at the end of a flight, due to a combination of tiredness and overload. Yesterday I retrieved a friend who got a bit carried away by mid October thermals in the UK and got into the same situation as Bruno. He landed in about the biggest field I have ever seen about 4 miles out, rather than risk a very marginal glide back to site. Derek C |
Short field landing Haiti | Gulfside | Instrument Flight Rules | 0 | February 24th 10 06:54 PM |
Short field landing Lake Providence LA (0M8) with ATC COMS - Video | A Lieberma[_2_] | Owning | 0 | July 21st 09 12:06 AM |
Off-Field landing | Casey Wilson | Piloting | 14 | January 13th 06 04:13 AM |
Soft-field landing in C172 | Magnus | Piloting | 24 | March 28th 04 04:58 PM |
Now THIS is a short field landing | John Harlow | Piloting | 8 | March 16th 04 10:42 PM |
