On Oct 23, 6:48*pm, Mike Schumann
wrote: On 10/23/2010 7:56 PM, Darryl Ramm wrote: On Oct 23, 4:02 pm, Mike wrote: On 10/23/2010 3:43 PM, Andy wrote: On Oct 22, 7:58 am, John wrote: I think the answer to everything is more complexity????? *Adding a 3rd collision avoidance technology is more complexity. *If I was running the the FAA, we'd have a single ADS-B technology period. *That's simplicity. It seems that Darryl has consumed so much Koolaid that he's starting to hallucinate. -- Mike Schumann But you're not running the FAA, the FAA is running the FAA. And the way they are running it, if Flarm or similar devices were to add ADS-B out or operate through the ADS-B protocol rather than low-power direct radio, it would cost them thousands of more dollars, many more amps, plus interminable certification delays. It's not happening; Powerflarm is here and now -- you can see the jets, you get superb collision avoidance with other gliders and towplanes that install it, and if you add a mode-S transponder the jets can see you. It makes perfect sense to separate the "in" and glider-glider box (not certified) from the much more expensive and certified "out" and "jet sees you" box. I just can't understand the fuss. Who is drinking the koolaid here? John Cochrane Amen. *The Navworx "simple solution" transceiver draws nearly 1 amp at 12 volts WITHOUT a display, doesn't integrate with any existing soaring computers, doesn't do glider flight path projection that is essential to glider-glider collision avoidance and doesn't directly receive 1090ES data-out signals for the multitude of areas where that's what you need because the ground station coverage isn't designed for the places glider fly. Oh, and it costs $2500 but doesn't include PCAS. So it solves exactly ZERO of the problems that currently matter to glider pilots and, IMO, is likely to lose out to 1090ES in the long run because of the aforementioned regulatory requirements. PowerFlarm plus a Trig 21 is a great way to go because it solves actual problems we have today and PowerFlarm alone is a pretty good improvement overall and adequate if you don't fly near a major commercial airport. Seems simple enough to me. 9B You can argue all of these points ad nauseum, but your credibility goes out the window when you say that PowerFlarm is here and now. *It has not been FCC approved, is not available for sale in the US and is not shipping. *When it is, go ahead and push it all you want. *In the mean time, the Navworx box is shipping. *Yes, it may not be the ideal solution; it may not integrate with glide computers; it may draw more power than you want; it may be too expensive. *But it is here and now, unlike PowerFlarm. -- Mike Schumann I hope most people can work out that your thought process around collision avoidance technology lacks any practicality of foundation in reality. But since this involves saftey I'll keep pointing out the obvious. So something is coming that will meet many of our needs much better than anything else, and especially for glider-glider collision threats will be absolutely better than anything else, but it is not here yet so instead of waiting we should use something that likely will meet very few needs? And still be relatively expensive. And there is unlikely to every be a business case for finishing/tailoring that product for the needs of the USA glider market. And how exactly do you solve the current STC installation requirement? Who will fund the development of the STC approval for installation in gliders? In past discussions with Bill Moffitt, President of NavWorx he seemed a pretty reasonable guy and his impression of PowerFLARM technology for the glider market seemed to me to be pretty positive. So that just confuses me, do NavWorx share you unbridled enthusiasm for pushing their current UAT products into glider applications? NavWorx's UAT receivers have an interesting potential market as FIS-B receivers and their transceivers have an interesting potential market as add-on ADS- B devices for aircraft owners who want to keep their Mode C transponder. I suspect they don't need the distraction of trying to develop products to meet the need of the tiny USA glider market. Darryl I am not arguing that Navworx is the ideal solution for gliders. *What I object to is the assertions in this thread that PowerFlarm is the ultimate solution, better than all others, and that it is currently available. It is NOT currently available, and any claims to the contrary are false. * It may be available in the relatively near future, and when it is, it may be the best solution available for a certain segment of the glider population. *That doesn't guarantee that it will be the best solution out there in a year or two or three. Everyone has to make their own decisions on what they are going to buy and when they are going to do that. *That is a very personal decision based on everyone's personal threat environment or their risk tolerance. -- Mike Schumann I think it's pretty clear - Mike admits that when PowerFlarm gets FCC approval he will unequivocally support it as the optimal solution for gliders. His arguments to-date have been uniformly based on PowarFlarm's pending approval. Mike, are you going to change your argument or be consistent? 9B |
On 10/24/2010 2:39 AM, Andy wrote:
On Oct 23, 6:48 pm, Mike wrote: On 10/23/2010 7:56 PM, Darryl Ramm wrote: On Oct 23, 4:02 pm, Mike wrote: On 10/23/2010 3:43 PM, Andy wrote: On Oct 22, 7:58 am, John wrote: I think the answer to everything is more complexity????? Adding a 3rd collision avoidance technology is more complexity. If I was running the the FAA, we'd have a single ADS-B technology period. That's simplicity. It seems that Darryl has consumed so much Koolaid that he's starting to hallucinate. -- Mike Schumann But you're not running the FAA, the FAA is running the FAA. And the way they are running it, if Flarm or similar devices were to add ADS-B out or operate through the ADS-B protocol rather than low-power direct radio, it would cost them thousands of more dollars, many more amps, plus interminable certification delays. It's not happening; Powerflarm is here and now -- you can see the jets, you get superb collision avoidance with other gliders and towplanes that install it, and if you add a mode-S transponder the jets can see you. It makes perfect sense to separate the "in" and glider-glider box (not certified) from the much more expensive and certified "out" and "jet sees you" box. I just can't understand the fuss. Who is drinking the koolaid here? John Cochrane Amen. The Navworx "simple solution" transceiver draws nearly 1 amp at 12 volts WITHOUT a display, doesn't integrate with any existing soaring computers, doesn't do glider flight path projection that is essential to glider-glider collision avoidance and doesn't directly receive 1090ES data-out signals for the multitude of areas where that's what you need because the ground station coverage isn't designed for the places glider fly. Oh, and it costs $2500 but doesn't include PCAS. So it solves exactly ZERO of the problems that currently matter to glider pilots and, IMO, is likely to lose out to 1090ES in the long run because of the aforementioned regulatory requirements. PowerFlarm plus a Trig 21 is a great way to go because it solves actual problems we have today and PowerFlarm alone is a pretty good improvement overall and adequate if you don't fly near a major commercial airport. Seems simple enough to me. 9B You can argue all of these points ad nauseum, but your credibility goes out the window when you say that PowerFlarm is here and now. It has not been FCC approved, is not available for sale in the US and is not shipping. When it is, go ahead and push it all you want. In the mean time, the Navworx box is shipping. Yes, it may not be the ideal solution; it may not integrate with glide computers; it may draw more power than you want; it may be too expensive. But it is here and now, unlike PowerFlarm. -- Mike Schumann I hope most people can work out that your thought process around collision avoidance technology lacks any practicality of foundation in reality. But since this involves saftey I'll keep pointing out the obvious. So something is coming that will meet many of our needs much better than anything else, and especially for glider-glider collision threats will be absolutely better than anything else, but it is not here yet so instead of waiting we should use something that likely will meet very few needs? And still be relatively expensive. And there is unlikely to every be a business case for finishing/tailoring that product for the needs of the USA glider market. And how exactly do you solve the current STC installation requirement? Who will fund the development of the STC approval for installation in gliders? In past discussions with Bill Moffitt, President of NavWorx he seemed a pretty reasonable guy and his impression of PowerFLARM technology for the glider market seemed to me to be pretty positive. So that just confuses me, do NavWorx share you unbridled enthusiasm for pushing their current UAT products into glider applications? NavWorx's UAT receivers have an interesting potential market as FIS-B receivers and their transceivers have an interesting potential market as add-on ADS- B devices for aircraft owners who want to keep their Mode C transponder. I suspect they don't need the distraction of trying to develop products to meet the need of the tiny USA glider market. Darryl I am not arguing that Navworx is the ideal solution for gliders. What I object to is the assertions in this thread that PowerFlarm is the ultimate solution, better than all others, and that it is currently available. It is NOT currently available, and any claims to the contrary are false. It may be available in the relatively near future, and when it is, it may be the best solution available for a certain segment of the glider population. That doesn't guarantee that it will be the best solution out there in a year or two or three. Everyone has to make their own decisions on what they are going to buy and when they are going to do that. That is a very personal decision based on everyone's personal threat environment or their risk tolerance. -- Mike Schumann I think it's pretty clear - Mike admits that when PowerFlarm gets FCC approval he will unequivocally support it as the optimal solution for gliders. His arguments to-date have been uniformly based on PowarFlarm's pending approval. Mike, are you going to change your argument or be consistent? 9B When the product is FCC approved, and you can get a datasheet and a manual then we can have a discussion on the pluses and minuses. I am open minded to any solution that not only addresses glider on glider threats, but also glider / GA and glider / airliners threats. -- Mike Schumann |
On 10/24/2010 7:10 AM, Mike Schumann wrote:
I think it's pretty clear - Mike admits that when PowerFlarm gets FCC approval he will unequivocally support it as the optimal solution for gliders. His arguments to-date have been uniformly based on PowarFlarm's pending approval. Mike, are you going to change your argument or be consistent? 9B When the product is FCC approved, and you can get a datasheet and a manual then we can have a discussion on the pluses and minuses. I am open minded to any solution that not only addresses glider on glider threats, but also glider / GA and glider / airliners threats. It's not like PowerFlarm is a completely new, untested concept, or that the people bringing it to market are unknown ciphers. They've done this before, to the tune of 10,000+ installations, and it's reasonable to assume they'll do it again, so there is simply no point not to have the discussion NOW. Your recalcitrance on this makes you look very unreasonable, and casts doubt your arguments, deserved or not. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
On 10/25/2010 12:46 AM, Eric Greenwell wrote:
On 10/24/2010 7:10 AM, Mike Schumann wrote: I think it's pretty clear - Mike admits that when PowerFlarm gets FCC approval he will unequivocally support it as the optimal solution for gliders. His arguments to-date have been uniformly based on PowarFlarm's pending approval. Mike, are you going to change your argument or be consistent? 9B When the product is FCC approved, and you can get a datasheet and a manual then we can have a discussion on the pluses and minuses. I am open minded to any solution that not only addresses glider on glider threats, but also glider / GA and glider / airliners threats. It's not like PowerFlarm is a completely new, untested concept, or that the people bringing it to market are unknown ciphers. They've done this before, to the tune of 10,000+ installations, and it's reasonable to assume they'll do it again, so there is simply no point not to have the discussion NOW. Your recalcitrance on this makes you look very unreasonable, and casts doubt your arguments, deserved or not. I'm not opposed to having a discussion about future products. I've participated in these before. My objection is in misrepresenting future products as things that currently exist, while simultaneously disparaging products that currently do exist as being "future" products. -- Mike Schumann |
On Oct 25, 6:10*am, Mike Schumann
wrote: On 10/25/2010 12:46 AM, Eric Greenwell wrote: On 10/24/2010 7:10 AM, Mike Schumann wrote: I think it's pretty clear - Mike admits that when PowerFlarm gets FCC approval he will unequivocally support it as the optimal solution for gliders. His arguments to-date have been uniformly based on PowarFlarm's pending approval. Mike, are you going to change your argument or be consistent? 9B When the product is FCC approved, and you can get a datasheet and a manual then we can have a discussion on the pluses and minuses. I am open minded to any solution that not only addresses glider on glider threats, but also glider / GA and glider / airliners threats. It's not like PowerFlarm is a completely new, untested concept, or that the people bringing it to market are unknown ciphers. They've done this before, to the tune of 10,000+ installations, and it's reasonable to assume they'll do it again, so there is simply no point not to have the discussion NOW. Your recalcitrance on this makes you look very unreasonable, and casts doubt your arguments, deserved or not. I'm not opposed to having a discussion about future products. *I've participated in these before. *My objection is in misrepresenting future products as things that currently exist, while simultaneously disparaging products that currently do exist as being "future" products. -- Mike Schumann- Hide quoted text - - Show quoted text - Mike, You (and others of course) are invited to the PASCO safety seminar this Saturday in Oakland http://www.pacificsoaring.org/board/...Flyer-2010.pdf to see the PowerFlarm in your own eyes and ask Urs Rothacher, the PoweFlarm designer, any question you may still have. Ramy |
Build your own PowerFLARM! | Darryl Ramm | Soaring | 51 | August 19th 10 06:39 PM |
KDR-510 question (VDL Mode 2 receiver?) | Filip Zawadiak | Owning | 0 | June 30th 04 04:16 PM |
KDR-510 question (VDL Mode 2 receiver?) | Filip Zawadiak | Piloting | 0 | June 30th 04 04:16 PM |
KDR-510 question (VDL Mode 2 receiver?) | Filip Zawadiak | Products | 0 | June 30th 04 04:16 PM |
Question on missing Mode-C | Ray Bengen | Owning | 10 | March 2nd 04 11:59 PM |
