#41
On Oct 25, 6:32 am, Mike Schumann
wrote: [snip] Again the devil is in the details. Where is the STC that allows a NavWorx ADS600-B to be installed in a certified glider to comply with the new FAA STC requirements announced this August? (yes an experiential glider can get away without this). The NavWorx ADS600-B transceiver is TSO as a UAT transceiver but its built in GPS source does not meet the TSO-C145/C146 WAAS GPS requirements to drive ADS-B data-out for the 2020 carriage mandate. The NavWorx products were intended to have one of these higher end GPS systems connected to it to meet the full 2020 carriage mandates for powered aircraft but be usable now without that (which could easily double or more their cost today and increase power consumption). And that certainly seemed a good idea (and still doable for experimental aircraft) but it looks like the FAA may have other ideas for certified aircraft... since the FAA recently instituted this new STC requirement it is not clear to me whether the FAA has any intention of allowing STC approval for an install that does not meet the 2020 carriage mandate requirements. And even if gliders were not otherwise required to meet those GPS requirements. I've just about given up trying to navigate this FAA mess, but then I'm not pushing people to adopt ADS-B data-out now -- but Mike you are so maybe you can explain this actual situation here. Will the FAA allow a STC to be developed for install in a glider with a non-TSO-C145/C146 WAAS GPS? And who is funding the development of that STC for installation of a NavWorx ADS600-B UAT in a certified glider? Which gliders? Or any idea when the FAA plans to drop the STC requirement and allow field approval/337 installs? TIS-B will likely work well where there will be good GBT (ADS-B base station) and radar coverage and with classic GA style aircraft separation. But there won't be TIS-B coverage in many critical areas such as many GA airport traffic patterns and other areas where I worry about GA traffic - again that's not an overall slight on TIS-B but pilots need to look at this coverage where they fly and be aware as well when the TIS-B support is rolling out for their en-route (pretty soon for most people) and approach/TRACON radar coverage (now for a very few, over the next few years for most). If you just fly a glider like a GA aircraft and never fly close to other glider etc. then things are simpler, but most of us end up flying in ways that cause some specific traffic display/threat warning challenges. Again this UAT solution relies on a third party display/ warning system that processes data from the UAT transceiver. That system likely needs to be optimized/designed for the type of flying gliders do, and the applies to TIS-B data as well. To see why... consider the case of flying within a short distance of other gliders who are transponder equipped. This is not necessarily in the same thermal, it could be a fraction of a mile or so away. But there is more uncertainty with a SSR derived location data pumped through TIS-B than there is with a GPS location based ADS-B direct or ADS-R (relay) signal. Just how the traffic display/threat warning system handles that situation might be critical but its may be something that only somebody designing a system for gliders will worry about. In many cases when a TIS-B based systems sees your glider buddy getting close the best it may be be able to do is just throw up it hands and say "threat nearby at altitude xxxx" it won't be able to give direction data. And you don't want it to keep false warning you about your glider buddies so you want some way to suppress that warning unless they get really close (hopefully with an altitude and range margins you can set) and an easy way to suppress recurring warnings and you want those settings separate for TIS-B than ADS-B direct/ADS-R. The devil again, is in the details. Who is going to get this right for UAT traffic display/threat warning for a glider cockpit? I believe that TIS-B is a useful add-on service for some GA folks who can afford it and fly in the right areas. I'm more dubious that is is financially justified in gliders now. This stuff may be interesting to pilots if they can manage to legally install a UAT transceiver and third party display/processor system, afford the thousands of dollars purchase and install cost (could be over $5k or more with TSO GPS and all the STC driven costs?), can power the system (over 1 amp with display and TSO complaint GPS) and they need to check out that traffic display/threat processing system indeed will meet the needs of their glider cockpit/flying environment. Mike if these things are here now and do TIS-B so well to solve the GA traffic concerns you have mentioned so the obvious question is have you purchased a NavWorx ADS600-Receiver? How have you legally installed it in your glider? What traffic/display hardware are you using and how well does it handle things like TIS-B when flying near and thermalling with transponder equipped gliders or other UAT equipped gliders? Seems like a research project not a product ready to sell (to the glider market) to me. Darryl From what I see on the Navworx web site, the ADS600-B is NOT TSO'd, even though it is FCC approved. I'm don't claim to be an expert on FAA issues regarding installation of equipment in aircraft, so I have no idea what that means. I suspect that the current non TSO'd Navworx box will not meet the 2020 ADS-B rule. I suspect that you could install it in a certified glider as a portable device, like you would a Garmin 496, without any trouble (FAA trouble that is). However, the unit obviously doesn't look like it was designed for this. I don't know what the ramifications are of a permanent install. Oh right the NavWorx ADS600-B is not TSO'ed just "designed to be" well they better get cracking on that if they expect the FAA to let it be installed in any certified aircraft under the current "need a STC" requirement. I don't believe the FAA will grant a STC for a ADS-B data- out device that is not already TSO'ed. The FAA is obviously being paranoid/covering their ass on all ADS-B data-out compliance stuff. So the market for the ADS600-B appears to be experimental aircraft only until they develop TSO and STC approvals. Presuming a small company can afford to do all that, maybe they just focus on experimental. They have FreeFlight coming with competitive products - based on the Mitre prototype (but be ready for the sticker shock, especially if it is an install in a certified glider that looks like it requires an STC/ TSO'ed product) and FreeFlight is certainly pursuing full TSO approval and differentiates their TSO and non TSO products for the experiential and cerrified markets. No talk from FreeFlight of "portable" installs. And FreeFlight has experience with STC approvals for their (expensive) TSO'ed GPS units so presumably that likely helps them push ahead on TSO approval for their ADS-B products. I'll drop them an email and get their take on the TSO and STC approval situation of their and the NavWorx products. How the hell do you connect an ADS-B transceiver requiring a connection to the aircraft's static line and call it a portable install? It would be interesting to have the FAAs take on that. The ADS600-B was clearly designed for fixed install. It needs antennas and a external power etc. How does all that get packaged for a portable install? And some of those issues are what the SSA was supposed to be working on. Where is that research project at? The portable installs that NavWorx talk about are likely their portable ADS-B *receiver* products that come with a stub antenna and no need to connect to ships static designed to stick on the top of an aircraft's glareshield (but no ADS-B data-out no reliable TIS-B/ADS-R, ....). I expect the market now for those receivers is as FIS-B (e.g. weather, TFR) receivers. You are certainly correct that installation of this kind of equipment in a glider (or any aircraft), at this stage of the product / regulatory life cycle should be treated as a research project. The same applies to PowerFlarm when it initially starts shipping. No the regulatory quagmire that I'm pointing out does not apply *at all* to the PowerFLARM. The whole point of not doing an ADS-B data-out device was to avoid this mess. An approach that some other ADS-B companies like SkyRadar is also taking. PowerFLARM was developed for our market, Flarm have thousands and thousands of existing units in the market and that company already has done the research (real academic R&D not just software/hardware development) to build the products to meets our technical market needs I've talked about before. I suspect most pilots who want PowerFLARM today share my views on this - which is I want it for the Flarm and PCAS capability, and ADS-B data-in is icing on the cake for now and I don't have high expectations for ADS-B overall since it is still in its early days and there is very little data-out equipage. There will be enough hairy bits around ADS-B that any ADS-B product is going to need to be improved over time. I want to make sure the company to do that will still be around to do so and has any technical and financial interest in meeting the technical needs of the glider market. So to try to summarize the situation with the NavWorx ADS600-B I'll state the following and anybody can coorectly with factual data... No TSO, No STC so no install in any certified glider No known work to establish an STC for certified glider installs Pesky things like 1 amp power consumption for a systems install No threat/processing display system intended for glider applications (e.g. suitable false alarm reduction, compatibility with popular flight computers/soaring software, no contest/stealth mode, no IGC flight recorder, ...) No vendor or third party company developing a threat/processing display system intended for glider applications No vendor experience or any vendor commitment for developing products for the glider market No installs in any gliders (let me know if there are...) No purchase himself of a ADS600-B by Mike Schumann Glad this is the "simple" and "available now" solution we all apparently need. BTW I have a bridge for sale if anybody is interested. Darryl |
#42
Why haven't we started selling ringside tickets to these? Or at least
get a TV deal going on? I say we get one of those UFC Octagons and throw Darryl and Mike into the ring to see which one emerges victorious! "Two men enter, one man leaves..." It'd be a hell of a lot more entertaining than all the political debates & ads on TV right now... --Noel |
#43
![]() "noel.wade" wrote in message ... Why haven't we started selling ringside tickets to these? Or at least get a TV deal going on? I say we get one of those UFC Octagons and throw Darryl and Mike into the ring to see which one emerges victorious! "Two men enter, one man leaves..." It'd be a hell of a lot more entertaining than all the political debates & ads on TV right now... --Noel I agree. This series has extended well past the point were learning and understanding occurs. Like religion and politics each has established their position and have anchored it in concrete so it will withstand the onslaught of other's opinions. Wayne |
#44
Like Betamax and VHS, the market will decide.
At 17:55 25 October 2010, Wayne Paul wrote: "noel.wade" wrote in message = ...= Why haven't we started selling ringside tickets to these? Or at least get a TV deal going on? =20 I say we get one of those UFC Octagons and throw Darryl and Mike into the ring to see which one emerges victorious! "Two men enter, one man leaves..." =20 It'd be a hell of a lot more entertaining than all the political debates & ads on TV right now... =20 --Noel I agree. This series has extended well past the point were learning and = understanding occurs. Like religion and politics each has established = their position and have anchored it in concrete so it will withstand the = onslaught of other's opinions. Wayne |
#45
On Oct 25, 10:40*am, "noel.wade" wrote:
Why haven't we started selling ringside tickets to these? *Or at least get a TV deal going on? I say we get one of those UFC Octagons and throw Darryl and Mike into the ring to see which one emerges victorious! *"Two men enter, one man leaves..." It'd be a hell of a lot more entertaining than all the political debates & ads on TV right now... --Noel Noel, sorry you are late it already is being arranged and its a lucha libre tag-team event. Dave Nadler, John Cochrane and myself are out shopping for costumes right now (but Dave is having a bit of a problem finding tights in his size). Not sure how tag-team works when you are up against a single opponent. Mike might come as "UAT man" but I hear plans to do that are on hold pending costume approval by the FAA. -- Sorry to inflict this on folks here, but it is a saftey issue (and we have had several glider pilots killed in mid-air collisions in the USA this year). And collision avoidance and especially ADS-B stuff can be confusingly complex, and suffering from a pile of misinformation that needs to be corrected. Darryl |
#46
Nadler, Cochrane and myself are out shopping for costumes right now
(but Dave is having a bit of a problem finding tights in his size). Not sure how tag-team works when you are up against a single opponent. *Mike might come as "UAT man" but I hear plans to do that are on hold pending costume approval by the FAA. Soooo, should we expect to see you guys in full attire at the upcoming PASCO seminar/Halloween banquet? Do you think UAT man's costume will be approved by the 30th? I will be very disappoint if not... -Paul |
#47
On 10/25/2010 12:02 PM, Darryl Ramm wrote:
On Oct 25, 6:32 am, Mike wrote: [snip] Again the devil is in the details. Where is the STC that allows a NavWorx ADS600-B to be installed in a certified glider to comply with the new FAA STC requirements announced this August? (yes an experiential glider can get away without this). The NavWorx ADS600-B transceiver is TSO as a UAT transceiver but its built in GPS source does not meet the TSO-C145/C146 WAAS GPS requirements to drive ADS-B data-out for the 2020 carriage mandate. The NavWorx products were intended to have one of these higher end GPS systems connected to it to meet the full 2020 carriage mandates for powered aircraft but be usable now without that (which could easily double or more their cost today and increase power consumption). And that certainly seemed a good idea (and still doable for experimental aircraft) but it looks like the FAA may have other ideas for certified aircraft... since the FAA recently instituted this new STC requirement it is not clear to me whether the FAA has any intention of allowing STC approval for an install that does not meet the 2020 carriage mandate requirements. And even if gliders were not otherwise required to meet those GPS requirements. I've just about given up trying to navigate this FAA mess, but then I'm not pushing people to adopt ADS-B data-out now -- but Mike you are so maybe you can explain this actual situation here. Will the FAA allow a STC to be developed for install in a glider with a non-TSO-C145/C146 WAAS GPS? And who is funding the development of that STC for installation of a NavWorx ADS600-B UAT in a certified glider? Which gliders? Or any idea when the FAA plans to drop the STC requirement and allow field approval/337 installs? TIS-B will likely work well where there will be good GBT (ADS-B base station) and radar coverage and with classic GA style aircraft separation. But there won't be TIS-B coverage in many critical areas such as many GA airport traffic patterns and other areas where I worry about GA traffic - again that's not an overall slight on TIS-B but pilots need to look at this coverage where they fly and be aware as well when the TIS-B support is rolling out for their en-route (pretty soon for most people) and approach/TRACON radar coverage (now for a very few, over the next few years for most). If you just fly a glider like a GA aircraft and never fly close to other glider etc. then things are simpler, but most of us end up flying in ways that cause some specific traffic display/threat warning challenges. Again this UAT solution relies on a third party display/ warning system that processes data from the UAT transceiver. That system likely needs to be optimized/designed for the type of flying gliders do, and the applies to TIS-B data as well. To see why... consider the case of flying within a short distance of other gliders who are transponder equipped. This is not necessarily in the same thermal, it could be a fraction of a mile or so away. But there is more uncertainty with a SSR derived location data pumped through TIS-B than there is with a GPS location based ADS-B direct or ADS-R (relay) signal. Just how the traffic display/threat warning system handles that situation might be critical but its may be something that only somebody designing a system for gliders will worry about. In many cases when a TIS-B based systems sees your glider buddy getting close the best it may be be able to do is just throw up it hands and say "threat nearby at altitude xxxx" it won't be able to give direction data. And you don't want it to keep false warning you about your glider buddies so you want some way to suppress that warning unless they get really close (hopefully with an altitude and range margins you can set) and an easy way to suppress recurring warnings and you want those settings separate for TIS-B than ADS-B direct/ADS-R. The devil again, is in the details. Who is going to get this right for UAT traffic display/threat warning for a glider cockpit? I believe that TIS-B is a useful add-on service for some GA folks who can afford it and fly in the right areas. I'm more dubious that is is financially justified in gliders now. This stuff may be interesting to pilots if they can manage to legally install a UAT transceiver and third party display/processor system, afford the thousands of dollars purchase and install cost (could be over $5k or more with TSO GPS and all the STC driven costs?), can power the system (over 1 amp with display and TSO complaint GPS) and they need to check out that traffic display/threat processing system indeed will meet the needs of their glider cockpit/flying environment. Mike if these things are here now and do TIS-B so well to solve the GA traffic concerns you have mentioned so the obvious question is have you purchased a NavWorx ADS600-Receiver? How have you legally installed it in your glider? What traffic/display hardware are you using and how well does it handle things like TIS-B when flying near and thermalling with transponder equipped gliders or other UAT equipped gliders? Seems like a research project not a product ready to sell (to the glider market) to me. Darryl From what I see on the Navworx web site, the ADS600-B is NOT TSO'd, even though it is FCC approved. I'm don't claim to be an expert on FAA issues regarding installation of equipment in aircraft, so I have no idea what that means. I suspect that the current non TSO'd Navworx box will not meet the 2020 ADS-B rule. I suspect that you could install it in a certified glider as a portable device, like you would a Garmin 496, without any trouble (FAA trouble that is). However, the unit obviously doesn't look like it was designed for this. I don't know what the ramifications are of a permanent install. Oh right the NavWorx ADS600-B is not TSO'ed just "designed to be" well they better get cracking on that if they expect the FAA to let it be installed in any certified aircraft under the current "need a STC" requirement. I don't believe the FAA will grant a STC for a ADS-B data- out device that is not already TSO'ed. The FAA is obviously being paranoid/covering their ass on all ADS-B data-out compliance stuff. So the market for the ADS600-B appears to be experimental aircraft only until they develop TSO and STC approvals. Presuming a small company can afford to do all that, maybe they just focus on experimental. They have FreeFlight coming with competitive products - based on the Mitre prototype (but be ready for the sticker shock, especially if it is an install in a certified glider that looks like it requires an STC/ TSO'ed product) and FreeFlight is certainly pursuing full TSO approval and differentiates their TSO and non TSO products for the experiential and cerrified markets. No talk from FreeFlight of "portable" installs. And FreeFlight has experience with STC approvals for their (expensive) TSO'ed GPS units so presumably that likely helps them push ahead on TSO approval for their ADS-B products. I'll drop them an email and get their take on the TSO and STC approval situation of their and the NavWorx products. How the hell do you connect an ADS-B transceiver requiring a connection to the aircraft's static line and call it a portable install? It would be interesting to have the FAAs take on that. The ADS600-B was clearly designed for fixed install. It needs antennas and a external power etc. How does all that get packaged for a portable install? And some of those issues are what the SSA was supposed to be working on. Where is that research project at? The portable installs that NavWorx talk about are likely their portable ADS-B *receiver* products that come with a stub antenna and no need to connect to ships static designed to stick on the top of an aircraft's glareshield (but no ADS-B data-out no reliable TIS-B/ADS-R, ....). I expect the market now for those receivers is as FIS-B (e.g. weather, TFR) receivers. You are certainly correct that installation of this kind of equipment in a glider (or any aircraft), at this stage of the product / regulatory life cycle should be treated as a research project. The same applies to PowerFlarm when it initially starts shipping. No the regulatory quagmire that I'm pointing out does not apply *at all* to the PowerFLARM. The whole point of not doing an ADS-B data-out device was to avoid this mess. An approach that some other ADS-B companies like SkyRadar is also taking. PowerFLARM was developed for our market, Flarm have thousands and thousands of existing units in the market and that company already has done the research (real academic R&D not just software/hardware development) to build the products to meets our technical market needs I've talked about before. I suspect most pilots who want PowerFLARM today share my views on this - which is I want it for the Flarm and PCAS capability, and ADS-B data-in is icing on the cake for now and I don't have high expectations for ADS-B overall since it is still in its early days and there is very little data-out equipage. There will be enough hairy bits around ADS-B that any ADS-B product is going to need to be improved over time. I want to make sure the company to do that will still be around to do so and has any technical and financial interest in meeting the technical needs of the glider market. So to try to summarize the situation with the NavWorx ADS600-B I'll state the following and anybody can coorectly with factual data... No TSO, No STC so no install in any certified glider No known work to establish an STC for certified glider installs Pesky things like 1 amp power consumption for a systems install No threat/processing display system intended for glider applications (e.g. suitable false alarm reduction, compatibility with popular flight computers/soaring software, no contest/stealth mode, no IGC flight recorder, ...) No vendor or third party company developing a threat/processing display system intended for glider applications No vendor experience or any vendor commitment for developing products for the glider market No installs in any gliders (let me know if there are...) No purchase himself of a ADS600-B by Mike Schumann Glad this is the "simple" and "available now" solution we all apparently need. BTW I have a bridge for sale if anybody is interested. Darryl There you go again jumping to conclusions. Whoever said that the Navworx transceiver was designed for portable installations? Their web site doesn't say that, nor did I ever suggest that. My only comment was that one possible way to install this type of device in a certified glider was as a portable device, with the kaviat that the Navworx box did not appear to be designed with that in mind. Just for the record, I am not buying an ADS600-B for a variety of reasons, some of which have been discussed at length in this thread. It's a little bit frustrating that I am being vilified by a number of people for suggesting that the soaring community should be putting the heat on the FAA to solve the ADS-B mess so that we can move ahead and get products that are affordable and meet the GA / Soaring communities needs to market. Instead, what we have is a bunch of people who's view is that the PowerFLARM savior has come and that their 50% solution is good enough, so everything is going to be OK. -- Mike Schumann |
#48
Dear Mike,
if you are really interested in why there is a reaction to your posts, you might want to read back through them. They do border on the offensive at times, And perhaps it is you who are doing the jumping: your comment "what we have is a bunch of people who's view is that the PowerFLARM savior has come and that their 50% solution is good enough" is a pretty good leap. What we have is a bunch of people who think that IF powerflarm is available by next season and IF enough people get them, we stand a very good chance of one or two or three fewer dead glider pilots. Anyway, I personally think there was value in the discussion, even if it went on a little long. It is an important topic and your comments certainly pointed out all the possible downsides of PowerFlarm vs ADS- B. In my mind immediate large scale adoption of Powerflarm (assuming the product becomes available) followed by the development a practical ADS-B option in the future is a best-case scenario. I think where you are ending up at odds with pretty much everyone is the idea that powerflarm will push ADS-B aside. Perhaps Powerflarm will just be a step to ADS-B. In any case, the real issue is glider pilots dying. In Europe Flarm seems to be helping glider pilots live, and that is the fact that has gotten our attention. see you up there, fly safe, Brian Glad this is the "simple" and "available now" solution we all apparently need. BTW I have a bridge for sale if anybody is interested. Darryl There you go again jumping to conclusions. *Whoever said that the Navworx transceiver was designed for portable installations? *Their web site doesn't say that, nor did I ever suggest that. *My only comment was that one possible way to install this type of device in a certified glider was as a portable device, with the kaviat that the Navworx box did not appear to be designed with that in mind. Just for the record, I am not buying an ADS600-B for a variety of reasons, some of which have been discussed at length in this thread. It's a little bit frustrating that I am being vilified by a number of people for suggesting that the soaring community should be putting the heat on the FAA to solve the ADS-B mess so that we can move ahead and get products that are affordable and meet the GA / Soaring communities needs to market. *Instead, what we have is a bunch of people who's view is that the PowerFLARM savior has come and that their 50% solution is good enough, so everything is going to be OK. -- Mike Schumann |
#49
OK enough is enough. If you guys want to argue, do it by private email instead of on a global forum.
"Mike Schumann" wrote in message ... On 10/25/2010 12:02 PM, Darryl Ramm wrote: On Oct 25, 6:32 am, Mike wrote: [snip] Again the devil is in the details. Where is the STC that allows a NavWorx ADS600-B to be installed in a certified glider to comply with the new FAA STC requirements announced this August? (yes an experiential glider can get away without this). The NavWorx ADS600-B transceiver is TSO as a UAT transceiver but its built in GPS source does not meet the TSO-C145/C146 WAAS GPS requirements to drive ADS-B data-out for the 2020 carriage mandate. The NavWorx products were intended to have one of these higher end GPS systems connected to it to meet the full 2020 carriage mandates for powered aircraft but be usable now without that (which could easily double or more their cost today and increase power consumption). And that certainly seemed a good idea (and still doable for experimental aircraft) but it looks like the FAA may have other ideas for certified aircraft... since the FAA recently instituted this new STC requirement it is not clear to me whether the FAA has any intention of allowing STC approval for an install that does not meet the 2020 carriage mandate requirements. And even if gliders were not otherwise required to meet those GPS requirements. I've just about given up trying to navigate this FAA mess, but then I'm not pushing people to adopt ADS-B data-out now -- but Mike you are so maybe you can explain this actual situation here. Will the FAA allow a STC to be developed for install in a glider with a non-TSO-C145/C146 WAAS GPS? And who is funding the development of that STC for installation of a NavWorx ADS600-B UAT in a certified glider? Which gliders? Or any idea when the FAA plans to drop the STC requirement and allow field approval/337 installs? TIS-B will likely work well where there will be good GBT (ADS-B base station) and radar coverage and with classic GA style aircraft separation. But there won't be TIS-B coverage in many critical areas such as many GA airport traffic patterns and other areas where I worry about GA traffic - again that's not an overall slight on TIS-B but pilots need to look at this coverage where they fly and be aware as well when the TIS-B support is rolling out for their en-route (pretty soon for most people) and approach/TRACON radar coverage (now for a very few, over the next few years for most). If you just fly a glider like a GA aircraft and never fly close to other glider etc. then things are simpler, but most of us end up flying in ways that cause some specific traffic display/threat warning challenges. Again this UAT solution relies on a third party display/ warning system that processes data from the UAT transceiver. That system likely needs to be optimized/designed for the type of flying gliders do, and the applies to TIS-B data as well. To see why... consider the case of flying within a short distance of other gliders who are transponder equipped. This is not necessarily in the same thermal, it could be a fraction of a mile or so away. But there is more uncertainty with a SSR derived location data pumped through TIS-B than there is with a GPS location based ADS-B direct or ADS-R (relay) signal. Just how the traffic display/threat warning system handles that situation might be critical but its may be something that only somebody designing a system for gliders will worry about. In many cases when a TIS-B based systems sees your glider buddy getting close the best it may be be able to do is just throw up it hands and say "threat nearby at altitude xxxx" it won't be able to give direction data. And you don't want it to keep false warning you about your glider buddies so you want some way to suppress that warning unless they get really close (hopefully with an altitude and range margins you can set) and an easy way to suppress recurring warnings and you want those settings separate for TIS-B than ADS-B direct/ADS-R. The devil again, is in the details. Who is going to get this right for UAT traffic display/threat warning for a glider cockpit? I believe that TIS-B is a useful add-on service for some GA folks who can afford it and fly in the right areas. I'm more dubious that is is financially justified in gliders now. This stuff may be interesting to pilots if they can manage to legally install a UAT transceiver and third party display/processor system, afford the thousands of dollars purchase and install cost (could be over $5k or more with TSO GPS and all the STC driven costs?), can power the system (over 1 amp with display and TSO complaint GPS) and they need to check out that traffic display/threat processing system indeed will meet the needs of their glider cockpit/flying environment. Mike if these things are here now and do TIS-B so well to solve the GA traffic concerns you have mentioned so the obvious question is have you purchased a NavWorx ADS600-Receiver? How have you legally installed it in your glider? What traffic/display hardware are you using and how well does it handle things like TIS-B when flying near and thermalling with transponder equipped gliders or other UAT equipped gliders? Seems like a research project not a product ready to sell (to the glider market) to me. Darryl From what I see on the Navworx web site, the ADS600-B is NOT TSO'd, even though it is FCC approved. I'm don't claim to be an expert on FAA issues regarding installation of equipment in aircraft, so I have no idea what that means. I suspect that the current non TSO'd Navworx box will not meet the 2020 ADS-B rule. I suspect that you could install it in a certified glider as a portable device, like you would a Garmin 496, without any trouble (FAA trouble that is). However, the unit obviously doesn't look like it was designed for this. I don't know what the ramifications are of a permanent install. Oh right the NavWorx ADS600-B is not TSO'ed just "designed to be" well they better get cracking on that if they expect the FAA to let it be installed in any certified aircraft under the current "need a STC" requirement. I don't believe the FAA will grant a STC for a ADS-B data- out device that is not already TSO'ed. The FAA is obviously being paranoid/covering their ass on all ADS-B data-out compliance stuff. So the market for the ADS600-B appears to be experimental aircraft only until they develop TSO and STC approvals. Presuming a small company can afford to do all that, maybe they just focus on experimental. They have FreeFlight coming with competitive products - based on the Mitre prototype (but be ready for the sticker shock, especially if it is an install in a certified glider that looks like it requires an STC/ TSO'ed product) and FreeFlight is certainly pursuing full TSO approval and differentiates their TSO and non TSO products for the experiential and cerrified markets. No talk from FreeFlight of "portable" installs. And FreeFlight has experience with STC approvals for their (expensive) TSO'ed GPS units so presumably that likely helps them push ahead on TSO approval for their ADS-B products. I'll drop them an email and get their take on the TSO and STC approval situation of their and the NavWorx products. How the hell do you connect an ADS-B transceiver requiring a connection to the aircraft's static line and call it a portable install? It would be interesting to have the FAAs take on that. The ADS600-B was clearly designed for fixed install. It needs antennas and a external power etc. How does all that get packaged for a portable install? And some of those issues are what the SSA was supposed to be working on. Where is that research project at? The portable installs that NavWorx talk about are likely their portable ADS-B *receiver* products that come with a stub antenna and no need to connect to ships static designed to stick on the top of an aircraft's glareshield (but no ADS-B data-out no reliable TIS-B/ADS-R, ....). I expect the market now for those receivers is as FIS-B (e.g. weather, TFR) receivers. You are certainly correct that installation of this kind of equipment in a glider (or any aircraft), at this stage of the product / regulatory life cycle should be treated as a research project. The same applies to PowerFlarm when it initially starts shipping. No the regulatory quagmire that I'm pointing out does not apply *at all* to the PowerFLARM. The whole point of not doing an ADS-B data-out device was to avoid this mess. An approach that some other ADS-B companies like SkyRadar is also taking. PowerFLARM was developed for our market, Flarm have thousands and thousands of existing units in the market and that company already has done the research (real academic R&D not just software/hardware development) to build the products to meets our technical market needs I've talked about before. I suspect most pilots who want PowerFLARM today share my views on this - which is I want it for the Flarm and PCAS capability, and ADS-B data-in is icing on the cake for now and I don't have high expectations for ADS-B overall since it is still in its early days and there is very little data-out equipage. There will be enough hairy bits around ADS-B that any ADS-B product is going to need to be improved over time. I want to make sure the company to do that will still be around to do so and has any technical and financial interest in meeting the technical needs of the glider market. So to try to summarize the situation with the NavWorx ADS600-B I'll state the following and anybody can coorectly with factual data... No TSO, No STC so no install in any certified glider No known work to establish an STC for certified glider installs Pesky things like 1 amp power consumption for a systems install No threat/processing display system intended for glider applications (e.g. suitable false alarm reduction, compatibility with popular flight computers/soaring software, no contest/stealth mode, no IGC flight recorder, ...) No vendor or third party company developing a threat/processing display system intended for glider applications No vendor experience or any vendor commitment for developing products for the glider market No installs in any gliders (let me know if there are...) No purchase himself of a ADS600-B by Mike Schumann Glad this is the "simple" and "available now" solution we all apparently need. BTW I have a bridge for sale if anybody is interested. Darryl There you go again jumping to conclusions. Whoever said that the Navworx transceiver was designed for portable installations? Their web site doesn't say that, nor did I ever suggest that. My only comment was that one possible way to install this type of device in a certified glider was as a portable device, with the kaviat that the Navworx box did not appear to be designed with that in mind. Just for the record, I am not buying an ADS600-B for a variety of reasons, some of which have been discussed at length in this thread. It's a little bit frustrating that I am being vilified by a number of people for suggesting that the soaring community should be putting the heat on the FAA to solve the ADS-B mess so that we can move ahead and get products that are affordable and meet the GA / Soaring communities needs to market. Instead, what we have is a bunch of people who's view is that the PowerFLARM savior has come and that their 50% solution is good enough, so everything is going to be OK. -- Mike Schumann |
#50
On Oct 25, 12:28*pm, brianDG303 wrote:
Dear Mike, if you are really interested in why there is a reaction to your posts, you might want to read back through them. They do border on the offensive at times, And perhaps it is you who are doing the jumping: your comment "what we have is a bunch of people who's view is that the PowerFLARM savior has come and that their 50% solution is good enough" is a pretty good leap. What we have is a bunch of people who think that IF powerflarm is available by next season and IF enough people get them, we stand a very good chance of one or two or three fewer dead glider pilots. Anyway, I personally think there was value in the discussion, even if it went on a little long. It is an important topic and your comments certainly pointed out all the possible downsides of PowerFlarm vs ADS- B. In my mind immediate large scale adoption of Powerflarm (assuming the product becomes available) followed by the development a practical ADS-B option in the future is a best-case scenario. I think where you are ending up at odds with pretty much everyone is the idea that powerflarm will push ADS-B aside. Perhaps Powerflarm will just be a step to ADS-B. In any case, the real issue is glider pilots dying. In Europe Flarm seems to be helping glider pilots live, and that is the fact that has gotten our attention. see you up there, fly safe, Brian It's a classic case of someone with an engineering background debating someone with a legal background - one is an analyst the other is an advocate. One is deductive, the other is inductive (e.g. facts - analysis - answer vs. answer - supporting facts and analysis). Both have their place in the world. You just have to decide which thought process makes the most sense in any given situation because they aren't equally valid in every case. I do agree that this is an important safety issue so direct debate on the details of such a complex topic are entirely appropriate, even if it gets a bit heated. I'm thankful we have people in the community who are willing to drill into all the butt-numbing details and explain it to the rest of us. It's important. 9B |
Build your own PowerFLARM! | Darryl Ramm | Soaring | 51 | August 19th 10 06:39 PM |
KDR-510 question (VDL Mode 2 receiver?) | Filip Zawadiak | Owning | 0 | June 30th 04 04:16 PM |
KDR-510 question (VDL Mode 2 receiver?) | Filip Zawadiak | Piloting | 0 | June 30th 04 04:16 PM |
KDR-510 question (VDL Mode 2 receiver?) | Filip Zawadiak | Products | 0 | June 30th 04 04:16 PM |
Question on missing Mode-C | Ray Bengen | Owning | 10 | March 2nd 04 11:59 PM |
