![]() "sid" wrote in message m... "Kevin Brooks" wrote in message Not nearly as big a gulf as you characterize. ISR assets are now enmeshed in tactical operations. Yes, but again, their exposure is an order of magnitude less than that experienced by MC-130's and AC-130's. Sure. In the last few conflicts as the Lexington institue piece made clear, but what about a few years down the road? At least two of your Lexington Institute "pieces" have endorsed the ACS and E-10, with their commercial aircraft platforms--what does this say about your theory that using commercial derivitive platforms is unacceptable? http://www.lexingtoninstitute.org/defense/031218.asp http://www.lexingtoninstitute.org/defense/031211.asp SOF platforms like the Combat Talon and Spectre operate in airspace that is much more dangerous than that experienced by the E-8 or ARL-M's. With long range SAM and AAW systems readily available for export its not something that can be counted on. You may have missed this little article in a December issue of AW&ST: "Russian guided-weapons builder Novator is continuing to work, albeit slowly, on an ultralong-range air-to-air missile, with a version on offer for export to a select customer set. Designated article 172, the weapon was included on a model of the Su-35 derivative of the Sukhoi Su-27 Flanker, on display during the Dubai air show. The export version, known as the 172S1, has a 300-km. (186-mi.) range, compared with 400 km. for the original version specified by the Russian air force. The missile, which is also referred to (perhaps erroneously) as the KS-172, is intended to engage specific high-value targets such as airborne warning and control aircraft, air-to-ground surveillance and tanker platforms." What was there to miss? The acknowlegement that the pace of development on this rather strange weapon is "slow"? How would it be targeted? 300 to 400 km is an awful long way for a fighter radar to "see", much less target. - Aerial refueling tankers penetrated to support ISR I know of one report of a KC-135 going *towards* Baghdad at one point, but did it enter within range of the surviving Iraqi AD assets? Doubt it. There were public reports of tanker assets going "downtown". The commanding general flew one mission purportedly to allay tanker crews' fears. Sure--going "downtown" after the IADS, or what was left of it pre-war, was further destroyed. We lost *one* aircraft over Baghdad--an A-10 to an SA-7/SA-18, IIRC. How much of a threat do you think that SA-18 was to any KC-135's orbiting at 25K or so feet? To illustrate further, here are some comments on the expected use the of the ACS: http://www.defensenews.com/conferenc...3/2409450.html ...As one of the first systems to the fight, ACS will provide early intelligence that could help shape the first stages of battle,[LtCol] Hinsdale said Nov. 18 during a Defense News Media Group conference, ISR Integration 2003: The Net-Centric Vision, in Arlington, Va. For instance, it could warn forces if their port of entry has been compromised "before we put our sons and daughters in harm's way." ... Obviously to be done using oblique imaging or UAV's reporting to the aircraft--you don't think they intend to conduct overflights of an enemy possessing an decent IADS, do you? And against an S-300(or equivalent) capapble opponent? Then you use your UAV's--that is what they are for, to go where manned platforms shouldn't/can't. They may have to be risked to get the job done. I don't see the USAF placing its RC-135's at great immediate risk, nor do I see the EP-3's doing that. As to ACS, remember that it is intended to replace ARL-M (and the remaining RC-12's)--that "L" means low, as in "low intensity". Nobody is going to be sortying them into an IADS environment. Period. "UAV Wrangling" from aircraft is still in the early stages. Given budget realities its likely going to be a capapbility somewhere up the "spiral". Until then the standoff ranges will be measured for the aircraft. Let's get this straight--you see a strong potential of AAM's that can engage our E-10's at 300-400 km, but you think managing an existing UAV from an airborne operator's station is too tough to handle? I find that a bit hard to digest. As I mentioned in previous posts, the aircraft in question make fine civil transports, but shoot at them and you have death traps. No, you have to *hit* them in order to make them a "deathtrap". How many KC-135's, KC-10's, E-8's, EP-3's, or ARL-M's have been hit during combat operations to date? None. How many have even been shot *at*? Again, AFAIK, none. As improtant as these aircraft are bcoming to our operational doctrine, and as few of them as there are or will be, these vulnerable aircraft will offer a rich target for an opponent with a big payback no matter the cost to neutralize them. Looks like Novator for one is already moving in on the business. I would not be buying too much stock in that enterprise just yet. Since they are not going into the hot part of the bad guy's threat envelope, why do they need to be survivable in terms of enemy weapons effects? Because it appears the threats will be reaching out to them. Your argument that this is the case is less than convincing so far. Later attempts to back engineer vulnerability improvements into former transports have proven less than sucessful and expensive. The P-3 comes to mind. None of which have been lost due to combat operations, IIRC. Two P-3s were lost in 1968 to ground fire actually. Likely because of vulenrability to hydrodynamic ram after a small caliber round hit them. Same vulnerabilty that turned the DHL 'bus into a roman candle after a small shrapnel hit. Same vulnerability that all civil transports share. Checking around, there was one confirmed shoot-down of a P-3 in SEA (both following incidents VP-26 Orions). One was an "unknown" (may have very well gone down due to accident), the other took a burst of .50 cal while doing a *low level* pass over a suspect LCM, which set set no. 4 engine on fire. The crew apparently tried to put as much distance between them and the bad guys as possible before attempting to ditch, and the wing snapped in the vicinity of the aforementioned fire. Note that these guys were doing visual recon from low level--they did not have the super synthetic aperture radars we have today. The EP-3 does not conduct low level missions, nor do the ARL-M/RC-12. So what is the applicability of the loss of one P-3 that got hammered by .50 cal (which can be tough on any airframe, even those designed to military specs--my brother lost a UH-1 Dustoff bird during Lam Son 719 to a .50 cal, and more than a couple of A-1's, etc., were allegedly brought down by 12.7mm and *below* calibers) to current programs like the E-10 and ACS? Since the SOF platforms operate in an entirely different threat environment, I fail to see the connection to programs like ACS. Remember that the ACS platform will be one of the current flock of business jets (Gulfstream and Bombadier being major competititors for that role right now). The E-10 is going to use a 767 platform. Now why do you think you know something about the unsuitability of these systems that the combined brain power of the USAF, USN, and US Army don't? Read through this selection of links and you will see that vulnerabilty is a perennial back burner issue...Until losses bring it front an center. Great--for aircraft going into the thick of the combat. E-10 and ACS won't be. Brooks http://www.dtic.mil/ndia/aircraft/ This one in particular discusses historical lapses in this regard: http://www.dtic.mil/ndia/aircraft/8.pdf |
"Kevin Brooks" wrote in message ...
"sid" wrote in message m... "Kevin Brooks" wrote in message Not nearly as big a gulf as you characterize. ISR assets are now enmeshed in tactical operations. At least two of your Lexington Institute "pieces" have endorsed the ACS and E-10, with their commercial aircraft platforms--what does this say about your theory that using commercial derivitive platforms is unacceptable? http://www.lexingtoninstitute.org/defense/031218.asp http://www.lexingtoninstitute.org/defense/031211.asp One "piece" does advocate the E-10. The other is a bit of an oblique endorsement of the G-450 over the EMB-145. It doesn't advocate civil airframes for the mission per se. Neither bears any real relationshop to the ISR lessons learned presentation. "Russian guided-weapons builder Novator is continuing to work, albeit slowly, on an ultralong-range air-to-air missile, with a version on offer for export to a select customer set. referred to (perhaps erroneously) as the KS-172, is intended to engage specific high-value targets such as airborne warning and control aircraft, air-to-ground surveillance and tanker platforms." What was there to miss? The acknowlegement that the pace of development on this rather strange weapon is "slow"? How would it be targeted? 300 to 400 km is an awful long way for a fighter radar to "see", much less target. The fact that there is a market for the capability to counter our ISR assets and someone that is working on providing that capability is not something to be missed. Sure--going "downtown" after the IADS, or what was left of it pre-war, was further destroyed. We lost *one* aircraft over Baghdad--an A-10 to an SA-7/SA-18, IIRC. How much of a threat do you think that SA-18 was to any KC-135's orbiting at 25K or so feet? This is one of the accounts: "In a risky bid to extend strike missions by making it easier for planes to refuel, he ordered tanker aircraft -- which are relatively vulnerable, because they lack their own warning radar and armaments -- to venture into Iraqi airspace, even though Iraq's dense air defense network had not been eliminated." Apparently this was early, before dominance was assured. I'll see if I can find the AW$ST issue that reported the story. Do you think that mag is a somewhat credible source? To illustrate further, here are some comments on the expected use the of the ACS: http://www.defensenews.com/conferenc...3/2409450.html ...As one of the first systems to the fight, ACS will provide early intelligence that could help shape the first stages of battle,[LtCol] Hinsdale said Nov. 18 during a Defense News Media Group conference, ISR Integration 2003: The Net-Centric Vision, in Arlington, Va. For instance, it could warn forces if their port of entry has been compromised "before we put our sons and daughters in harm's way." ... Obviously to be done using oblique imaging or UAV's reporting to the aircraft--you don't think they intend to conduct overflights of an enemy possessing an decent IADS, do you? Well, if it has to be done...The OP-2E story is a bit of a cuationary tale. It appears that there are (or at least were when this was written)real issues with just such analysis abot the survivability of these programs: http://www.fas.org/irp/program/collect/SIGINTWP.pdf Let's get this straight--you see a strong potential of AAM's that can engage our E-10's at 300-400 km, but you think managing an existing UAV from an airborne operator's station is too tough to handle? I find that a bit hard to digest. I don't think its too hard to handle; our flawed budget process may not get the capability to the warfighters in a timely fashion. Regardless of when we field an operationally workable airborne controlled UAV force the GMTI 767-400 and the ACS configured EMB-145 or G-450 are expected to use onboard sensors. for decades to come. In the years ahead their vulnerabilities could well be exploited. No, you have to *hit* them in order to make them a "deathtrap". How many KC-135's, KC-10's, E-8's, EP-3's, or ARL-M's have been hit during combat operations to date? None. How many have even been shot *at*? Again, AFAIK, none. So? That proves we have been up against inept opponents in recent scraps thats all. As an FYI the Navy is moving the P-3s away from the overland tactical support role. Two P-3s were lost in 1968 to ground fire actually. Likely because of vulenrability to hydrodynamic ram after a small caliber round hit them. Same vulnerabilty that turned the DHL 'bus into a roman candle after a small shrapnel hit. Same vulnerability that all civil transports share. Checking around, there was one confirmed shoot-down of a P-3 in SEA (both following incidents VP-26 Orions). One was an "unknown" (may have very well gone down due to accident), the other took a burst of .50 cal while doing a *low level* pass over a suspect LCM, which set set no. 4 engine on fire. The crew apparently tried to put as much distance between them and the bad guys as possible before attempting to ditch, and the wing snapped in the vicinity of the aforementioned fire. Note that these guys were doing visual recon from low level--they did not have the super synthetic aperture radars we have today. The EP-3 does not conduct low level missions, nor do the ARL-M/RC-12. So what is the applicability of the loss of one P-3 that got hammered by .50 cal (which can be tough on any airframe, even those designed to military specs--my brother lost a UH-1 Dustoff bird during Lam Son 719 to a .50 cal, and more than a couple of A-1's, etc., were allegedly brought down by 12.7mm and *below* calibers) to current programs like the E-10 and ACS? The unknown was almost certainly shot down. Also, if you read the account of the second carefully you will see it wasn't an engine fire but an uncontrollable fuel tank fire. They weren't trying to ditch, but instead make a small field on an island which they had a visual on. The wing burned through as they were about to land. Hydrodynamic ram killed that airplane and its crew. The navy tried an abortive program to mitigate the effects with foam in the tanks but it was a mess and they took the foam back out. The 767 EMB-145 and G-450 have no protection whatsoever against hydrodynamic ram fires. Not that it imposssible to engineer in though: http://jas.jcs.mil/news/newsletter_2000_spring.htm Did you read this BTW: http://www.dtic.mil/ndia/aircraft/8.pdf In it you will see where a lack of recognition to vulnerability issues caused the loss of many aircraft in Vietnam. Great--for aircraft going into the thick of the combat. E-10 and ACS won't be. They threat will be reaching out to them in the next few years. |
![]() "sid" wrote in message om... "Kevin Brooks" wrote in message ... "sid" wrote in message m... "Kevin Brooks" wrote in message Not nearly as big a gulf as you characterize. ISR assets are now enmeshed in tactical operations. At least two of your Lexington Institute "pieces" have endorsed the ACS and E-10, with their commercial aircraft platforms--what does this say about your theory that using commercial derivitive platforms is unacceptable? http://www.lexingtoninstitute.org/defense/031218.asp http://www.lexingtoninstitute.org/defense/031211.asp One "piece" does advocate the E-10. The other is a bit of an oblique endorsement of the G-450 over the EMB-145. It doesn't advocate civil airframes for the mission per se. They sure do seem to advocate the use of those commercial airframes in both cases. Neither bears any real relationshop to the ISR lessons learned presentation. "Russian guided-weapons builder Novator is continuing to work, albeit slowly, on an ultralong-range air-to-air missile, with a version on offer for export to a select customer set. referred to (perhaps erroneously) as the KS-172, is intended to engage specific high-value targets such as airborne warning and control aircraft, air-to-ground surveillance and tanker platforms." What was there to miss? The acknowlegement that the pace of development on this rather strange weapon is "slow"? How would it be targeted? 300 to 400 km is an awful long way for a fighter radar to "see", much less target. The fact that there is a market for the capability to counter our ISR assets and someone that is working on providing that capability is not something to be missed. The fact that the USAF,USN, USA, etc., are not going to place those assets in a situation of undue risk is patently obvious. The fact that your Russian "super AAM" is nothing more than a concept at present does not change that. Sure--going "downtown" after the IADS, or what was left of it pre-war, was further destroyed. We lost *one* aircraft over Baghdad--an A-10 to an SA-7/SA-18, IIRC. How much of a threat do you think that SA-18 was to any KC-135's orbiting at 25K or so feet? This is one of the accounts: "In a risky bid to extend strike missions by making it easier for planes to refuel, he ordered tanker aircraft -- which are relatively vulnerable, because they lack their own warning radar and armaments -- to venture into Iraqi airspace, even though Iraq's dense air defense network had not been eliminated." Apparently this was early, before dominance was assured. I'll see if I can find the AW$ST issue that reported the story. Do you think that mag is a somewhat credible source? Credible, yes. But what does he mean by "eliminated"? We know that they continued to pop off MANPADS even as the troops and marines entered into the city--but again, those MANPADS were no threat to the tankers. To illustrate further, here are some comments on the expected use the of the ACS: http://www.defensenews.com/conferenc...3/2409450.html ...As one of the first systems to the fight, ACS will provide early intelligence that could help shape the first stages of battle,[LtCol] Hinsdale said Nov. 18 during a Defense News Media Group conference, ISR Integration 2003: The Net-Centric Vision, in Arlington, Va. For instance, it could warn forces if their port of entry has been compromised "before we put our sons and daughters in harm's way." .... Obviously to be done using oblique imaging or UAV's reporting to the aircraft--you don't think they intend to conduct overflights of an enemy possessing an decent IADS, do you? Well, if it has to be done...The OP-2E story is a bit of a cuationary tale. "The OP-2E story"?? It appears that there are (or at least were when this was written)real issues with just such analysis abot the survivability of these programs: http://www.fas.org/irp/program/collect/SIGINTWP.pdf Let's get this straight--you see a strong potential of AAM's that can engage our E-10's at 300-400 km, but you think managing an existing UAV from an airborne operator's station is too tough to handle? I find that a bit hard to digest. I don't think its too hard to handle; our flawed budget process may not get the capability to the warfighters in a timely fashion. That would be the same "flawed process" that has enabled us to leap ahead of every other nation in the world in terms of these capabilities? Regardless of when we field an operationally workable airborne controlled UAV force the GMTI 767-400 and the ACS configured EMB-145 or G-450 are expected to use onboard sensors. for decades to come. In the years ahead their vulnerabilities could well be exploited. What vulnerabilities? The supposed vulnerability to a missile that has yet been built, guided by a system not yet developed, while engaging in overflights through an IADS that just won't happen? Not much of a "vulnerability" you have illustrated there. No, you have to *hit* them in order to make them a "deathtrap". How many KC-135's, KC-10's, E-8's, EP-3's, or ARL-M's have been hit during combat operations to date? None. How many have even been shot *at*? Again, AFAIK, none. So? That proves we have been up against inept opponents in recent scraps thats all. Ummm...no, that could also be proof that we don't place these assets into a position where they are readily engaged. As an FYI the Navy is moving the P-3s away from the overland tactical support role. What? Two P-3s were lost in 1968 to ground fire actually. Likely because of vulenrability to hydrodynamic ram after a small caliber round hit them. Same vulnerabilty that turned the DHL 'bus into a roman candle after a small shrapnel hit. Same vulnerability that all civil transports share. Checking around, there was one confirmed shoot-down of a P-3 in SEA (both following incidents VP-26 Orions). One was an "unknown" (may have very well gone down due to accident), the other took a burst of .50 cal while doing a *low level* pass over a suspect LCM, which set set no. 4 engine on fire. The crew apparently tried to put as much distance between them and the bad guys as possible before attempting to ditch, and the wing snapped in the vicinity of the aforementioned fire. Note that these guys were doing visual recon from low level--they did not have the super synthetic aperture radars we have today. The EP-3 does not conduct low level missions, nor do the ARL-M/RC-12. So what is the applicability of the loss of one P-3 that got hammered by .50 cal (which can be tough on any airframe, even those designed to military specs--my brother lost a UH-1 Dustoff bird during Lam Son 719 to a .50 cal, and more than a couple of A-1's, etc., were allegedly brought down by 12.7mm and *below* calibers) to current programs like the E-10 and ACS? The unknown was almost certainly shot down. Got some proof of that? And again--we no longer plan to use *any* of these platforms in a direct visual recon role like they were used for in Market Time. So how does this apply to supporting your assertions? Also, if you read the account of the second carefully you will see it wasn't an engine fire but an uncontrollable fuel tank fire. They weren't trying to ditch, but instead make a small field on an island which they had a visual on. Gee, the VP-26 vet who wrote up the description I read must have had all of his facts wrong. He indicated that the engine was lost, and the fire was in that vicinity--whether or not it also involved the fuel tankage is a moot point. The wing burned through as they were about to land. Hydrodynamic ram killed that airplane and its crew. FYI, *any* airplane with an uncontrolled fire in its engine/wing is susceptable to subsequent structural failure. And you ignored the fact that aircraft designed exclusively for military use have also been lost to .50 cal and below hits--so where is this much greater vulnerability of the P-3 in view of that fact? The navy tried an abortive program to mitigate the effects with foam in the tanks but it was a mess and they took the foam back out. The 767 EMB-145 and G-450 have no protection whatsoever against hydrodynamic ram fires. Not that it imposssible to engineer in though: http://jas.jcs.mil/news/newsletter_2000_spring.htm Did you read this BTW: http://www.dtic.mil/ndia/aircraft/8.pdf In it you will see where a lack of recognition to vulnerability issues caused the loss of many aircraft in Vietnam. I also note that in the first few sentences the authors identify the difference between "susceptability" and "vulnerability"--the latter does not come into play if the former is controlled such that hits don't occur--which will be the predominant environment that the ACS and E-10 will operate in. Great--for aircraft going into the thick of the combat. E-10 and ACS won't be. They threat will be reaching out to them in the next few years. So you say. Now go back and tell us what *you* think the "L" in ARL-M means. Brooks |
The fact that the USAF,USN, USA, etc., are not going to place those assets in a situation of undue risk is patently obvious. The fact that your Russian "super AAM" is nothing more than a concept at present does not change that. Gee, I thought that the ISR assets were expected to assist in the conduct of a war. Recent experiences aside, wars are slam full of "undue risk". Thats whole issue here, while SOF aircraft are thought of, and built as, warplanes, the Boeings, Embraers, and Gulfstreams contemplated for these roles have no such engineering. Fact is they are very vulnerable platforms that are being considered for vital missions and that potential adversaries are building weapons to field against. Yet these aircraft will be expected to take part in warfare. As few platforms that the ISR force has or will have, and as important as they are to the conduct of contemporary and contemplated US military ops, a capable opponent will find them juicy targets and he can buy the equipment to do something about it. A commander may well be forced to put these aircraft into areas of "undue risk" to get the job done (as was done with the OP-2Es), or risk not getting the job done at all. That some AF units seem to be exempt from the possibility of taking enemy fire has been a long term inherent cultural issue apparently. I'm not the only one to say it either: http://www.airpower.maxwell.af.mil/a...jun/cahoon.htm C-17 drivers just recently went through combat certification for the first time. The question begs, why weren't they treated as warfighters all along? Sure, its not a real problem today, it won't be next year either, but then again the ACS and E-10 won't be fielded until how many years down the road? By the time they are operational, and S-400 s-300 equipped opponent could well render them impotent. This is not being planned for. Apparently you missed this part of this "piece"?: http://www.fas.org/irp/program/collect/SIGINTWP.pdf "ADA Susceptibility: GR/CS and ARL susceptibility to SA 10 and SA 12 threats was the cornerstone of the argument to eliminate them from the system. While it is true that they are susceptible to the threats, they are no less so than many of the retained systems. Rivet Joint,EP3, ES3, all retained by the study, fly at altitudes similar to Army systems. Their survivability will require stand-off as well. GR/CS normally flies in the same vicinity as JSTARS and AWACS, two targets an enemy would likely pursue with more vigor than an RC12. Discussions made it clear that the entire air campaign was not considered in the analysis. In fact, constraints of the ADA threat were not uniformly applied. Had it been so, many other platforms would have to become HAPs as well (JSTARS, AWACS)." As an FYI those SAM systems have advertised standoff ranges greater than that of JSTARS and ACS. I'm not the only one thinking of this either: http://www.aiaa.org/aerospace/Articl...hiveIssueID=22 "For example, the standoff range for defending against SAMs [surface-to-air missiles] is changing, and you will have to go to space. Then you may want to move JSTARS [Joint Surveillance and Target Attack Radar System] and AWACS [Airborne Warning and Control System] capabilities into space. So past elements that have given situational awareness in the theater may involve trade-ups." "In a risky bid to extend strike missions by making it easier for planes to refuel, he ordered tanker aircraft -- which are relatively vulnerable, because they lack their own warning radar and armaments -- to venture into Iraqi airspace, even though Iraq's dense air defense network had not been eliminated." Credible, yes. But what does he mean by "eliminated"? We know that they continued to pop off MANPADS even as the troops and marines entered into the city--but again, those MANPADS were no threat to the tankers. So why were they concerned. Obviously the longer range threat had not been rendered below the "undue threat" threshold. What vulnerabilities? The supposed vulnerability to a missile that has yet been built, guided by a system not yet developed, while engaging in overflights through an IADS that just won't happen? Not much of a "vulnerability" you have illustrated there. You are wrong about this. Besides, you mean susceptability here??? My beef is vulnerability issues, there is a difference. But to the point, the S-300 and S-400 are entirely capapble of countering our ISR assets. Thats a fact.: http://www.house.gov/pitts/initiativ...ew-brief-9.htm (the google cached version works) "The Russians sold the SA-10 (Russian designation S-300, NATO:Grumble) to China, and recently agreed to sell them to Iran. The Russians are aggressively marketing these systems and China may also build versions for export, just as they did with the single digit SAMs. Several more countries may acquire and field these systems within the next 10 years. The major factor preventing proliferation is the high price tag of these systems. However, the Russians are also developing and selling improvement kits to the single digit SAMs to provide near double-digit SAMs performance at a fraction of the cost.' 'In short, the battlefield 10 years from now may be a far more dangerous place than today, and it will take a toll on our pilots if we do not act to mitigate the increased threat." As an FYI the Navy is moving the P-3s away from the overland tactical support role. What? Yes. P-3s(Not talking about EP-3s) and MMA will not be used in the overland role due to vulenrability issues. Did you miss this as well? http://www.lexingtoninstitute.org/defense/111803ISR.pdf "However, Navy leadership removing P-3 from overland missions in hostile airspace due to survivability concerns." Gee, the VP-26 vet who wrote up the description I read must have had all of his facts wrong. He indicated that the engine was lost, and the fire was in that vicinity--whether or not it also involved the fuel tankage is a moot point. Here's what it says. Note the "unclear" part: "Several rounds ripped into the outer portion of their starboard wing, knocking out #4 engine and starting a fire. They pulled the emergency handle and succeeded in feathering the prop, but could not extinguish the flames. It was unclear whether the fire originated from the engine nacelle or from within the wing itself." I will standby this statement. The wing burned through as they were about to land. Hydrodynamic ram killed that airplane and its crew. FYI, *any* airplane with an uncontrolled fire in its engine/wing is susceptable to subsequent structural failure. And you ignored the fact that aircraft designed exclusively for military use have also been lost to .50 cal and below hits--so where is this much greater vulnerability of the P-3 in view of that fact? Any civil transport, such as this one was (before being modified), is terribly vulnerable: http://www.concordesst.com/accident/...es/flames1.jpg But much can be done to mitigate the effects. And is being done on "War"planes: http://jas.jcs.mil/news/pdf/2003_fall.pdf "When it comes to providing aircraft fuel system ballis-tic tolerance capability, it is necessary to understand that protecting from a catastrophic explosion in a fuel tank ullage cannot be accomplished solely with self-sealing fuel cells. To provide the desired level of ballistic tolerance requires a hand-in-hand compli-mentary approach which incorpo-rates both self-sealing fuel cells and OBIGGS. Ultimately, it is necessary to incorporate the appropriate fuel system requirements verbiage requir-ing a self-sealing capability and that damage from certain high explosive incendiary and/or armor piercing incendiary rounds must not cause catastrophic explosion. This will drive a solution, which provides the proper level of survivability protec-tion for both permanently mounted and auxiliary internal fuel cells." I also note that in the first few sentences the authors identify the difference between "susceptability" and "vulnerability"--the latter does not come into play if the former is controlled such that hits don't occur--which will be the predominant environment that the ACS and E-10 will operate in. Glad you found out the difference between the two. I think you fit firmly in the camp described below. Its a very wrong and hubris filled view, but I'll let some much more credible sources speak make the case: http://jas.jcs.mil/news/pdf/2003_fall.pdf If you took a poll of operators in the fleet and asked them what they wanted most on their aircraft, they would say— 1)advanced sensors, 2)range and speed, 3)long range and very accurate weapons, 4)low observable technology, and 50)vulnerability reduction. Yes that was number 50, not number 5. There are two reasons for this. First, vulnerability reduction technology is not very sexy. A cool new radar that can identify a target at 500 miles is always preferable to a fuel tank liner. And second, most operators just assume that basic vulnerability reduction features such as fire protection and redundancy are a given in aircraft design. If you asked an operator if he would prefer target ID at only 400 miles while guaranteeing he would not burn up in flight because of a fuel leak, you might get a different answer. http://jas.jcs.mil/news/pdf/2001_summer.pdf "Vietnam and the experience of the 1973 Arab-Israeli war clearly rattled the confidence of those who felt that high-performance military aircraft were relatively invulnerable to enemy defenses simply on the basis of high transonic or supersonic dash speed, or because of perceived pilot excellence. Both of these translated into technological and cultural hubris and numerous aircrew paid the price for such delusions." ....But that fact hints at the survivability battles yet to come. The history of military aviation has witnessed a seesaw battle between the offensive power of the airplane and the defensive snap of its victims. In an era— • When the size of deployed coalition air power forces is likely to shrink, • When future aircraft production runs may be measured in dozens rather than several hundred or several thousand, • When potential opponents will have little difficulty in acquiring advanced Flanker-equivalent threat aircraft and the weapons systems for those aircraft to hold air and surface targets hostage, • When the SA-10 equivalent weapon will undoubtedly become the common currency of air defense in much the same fashion that the SA-2 was in the '60's and the SA-6 in the '70's and onwards, and The challenge for those having responsibility to ensure the survivability of our joint service aerospace forces is, if anything, even more demanding than it has been in the past. |
![]() "sid" wrote in message om... "Kevin Brooks" wrote in message The fact that the USAF,USN, USA, etc., are not going to place those assets in a situation of undue risk is patently obvious. The fact that your Russian "super AAM" is nothing more than a concept at present does not change that. Gee, I thought that the ISR assets were expected to assist in the conduct of a war. On our terms. Recent experiences aside, wars are slam full of "undue risk". Undue risk is what you avoid. Which is why they won't be sending ACS and the E-10 into IADS environments. Thats whole issue here, while SOF aircraft are thought of, and built as, warplanes, the Boeings, Embraers, and Gulfstreams contemplated for these roles have no such engineering. Please point to the "special engineering" that sets an AFSOC CN 235/295 apart from one of those Gulfstreams. Fact is they are very vulnerable platforms that are being considered for vital missions and that potential adversaries are building weapons to field against. Big jump from that Russian firm "slowly" pursuing a very long range AAM program to "are building". Yet these aircraft will be expected to take part in warfare. As few platforms that the ISR force has or will have, and as important as they are to the conduct of contemporary and contemplated US military ops, a capable opponent will find them juicy targets and he can buy the equipment to do something about it. Look, we are NOT sending them into contested airspace, OK? Period. Now, tell me which foe these systems will be used against that we will not acheive air superiority/dominance over in very short order? A commander may well be forced to put these aircraft into areas of "undue risk" to get the job done (as was done with the OP-2Es), or risk not getting the job done at all. There is that strange "OP-2E's" you keep ranting about... And again, we are not going to send these assets in against "undue risk". That some AF units seem to be exempt from the possibility of taking enemy fire has been a long term inherent cultural issue apparently. I'm not the only one to say it either: http://www.airpower.maxwell.af.mil/a...jun/cahoon.htm C-17 drivers just recently went through combat certification for the first time. The question begs, why weren't they treated as warfighters all along? Meaningless. ACS and E-10 are not airlifters. Airlifters may indeed have to drop down into a MANPADS/AAA threat environment to perform their mission--ACS and the E-10 do not. Sure, its not a real problem today, it won't be next year either, but then again the ACS and E-10 won't be fielded until how many years down the road? By the time they are operational, and S-400 s-300 equipped opponent could well render them impotent. Quick! Call the Pentagon and tell them you have discovered the flaw in the plans that so many professionals have been developing for decades now! This is not being planned for. Apparently you missed this part of this "piece"?: http://www.fas.org/irp/program/collect/SIGINTWP.pdf "ADA Susceptibility: GR/CS and ARL susceptibility to SA 10 and SA 12 threats was the cornerstone of the argument to eliminate them from the system. While it is true that they are susceptible to the threats, they are no less so than many of the retained systems. Rivet Joint,EP3, ES3, all retained by the study, fly at altitudes similar to Army systems. Their survivability will require stand-off as well. GR/CS normally flies in the same vicinity as JSTARS and AWACS, two targets an enemy would likely pursue with more vigor than an RC12. Discussions made it clear that the entire air campaign was not considered in the analysis. In fact, constraints of the ADA threat were not uniformly applied. Had it been so, many other platforms would have to become HAPs as well (JSTARS, AWACS)." As an FYI those SAM systems have advertised standoff ranges greater than that of JSTARS and ACS. I'm not the only one thinking of this either: http://www.aiaa.org/aerospace/Articl...hiveIssueID=22 "For example, the standoff range for defending against SAMs [surface-to-air missiles] is changing, and you will have to go to space. Then you may want to move JSTARS [Joint Surveillance and Target Attack Radar System] and AWACS [Airborne Warning and Control System] capabilities into space. So past elements that have given situational awareness in the theater may involve trade-ups." I don't know where you get these ideas, but the E-8 JSTARS surveillance range reportedly reaches out to around 250 km--SA-10/12 manage what, maybe 90 km? "In a risky bid to extend strike missions by making it easier for planes to refuel, he ordered tanker aircraft -- which are relatively vulnerable, because they lack their own warning radar and armaments -- to venture into Iraqi airspace, even though Iraq's dense air defense network had not been eliminated." Credible, yes. But what does he mean by "eliminated"? We know that they continued to pop off MANPADS even as the troops and marines entered into the city--but again, those MANPADS were no threat to the tankers. So why were they concerned. Obviously the longer range threat had not been rendered below the "undue threat" threshold. That is not what the evidence indicates. In fact, were any longer range systems used to engage the KC's? Nope--the threat was ameliorated. What vulnerabilities? The supposed vulnerability to a missile that has yet been built, guided by a system not yet developed, while engaging in overflights through an IADS that just won't happen? Not much of a "vulnerability" you have illustrated there. You are wrong about this. Besides, you mean susceptability here??? My beef is vulnerability issues, there is a difference. Hint--vulnerability is not an issue if susceptability is controlled. But to the point, the S-300 and S-400 are entirely capapble of countering our ISR assets. Thats a fact.: http://www.house.gov/pitts/initiativ...ew-brief-9.htm (the google cached version works) "The Russians sold the SA-10 (Russian designation S-300, NATO:Grumble) to China, and recently agreed to sell them to Iran. The Russians are aggressively marketing these systems and China may also build versions for export, just as they did with the single digit SAMs. Several more countries may acquire and field these systems within the next 10 years. The major factor preventing proliferation is the high price tag of these systems. However, the Russians are also developing and selling improvement kits to the single digit SAMs to provide near double-digit SAMs performance at a fraction of the cost.' 'In short, the battlefield 10 years from now may be a far more dangerous place than today, and it will take a toll on our pilots if we do not act to mitigate the increased threat." Sorry, not a "fact". Fact--SA-10 has a reported max range around 90 km, and the E-8 can stand off well beyond that and map the terrain well beyond that out-of-range S-300. As an FYI the Navy is moving the P-3s away from the overland tactical support role. What? Yes. P-3s(Not talking about EP-3s) and MMA will not be used in the overland role due to vulenrability issues. Did you miss this as well? http://www.lexingtoninstitute.org/defense/111803ISR.pdf "However, Navy leadership removing P-3 from overland missions in hostile airspace due to survivability concerns." Note the "in hostile airspace" bit. And BTW, we are not discussing P-3's or MMA--we are discussing ACS and E-10, along with the K-767, right? Gee, the VP-26 vet who wrote up the description I read must have had all of his facts wrong. He indicated that the engine was lost, and the fire was in that vicinity--whether or not it also involved the fuel tankage is a moot point. Here's what it says. Note the "unclear" part: "Several rounds ripped into the outer portion of their starboard wing, knocking out #4 engine and starting a fire. They pulled the emergency handle and succeeded in feathering the prop, but could not extinguish the flames. It was unclear whether the fire originated from the engine nacelle or from within the wing itself." I will standby this statement. Who cares what you are standing by? The guy who reported the incident did not even know what the root cause (engine or wing/fuel tank fire) was, but you do, huh? The wing burned through as they were about to land. Hydrodynamic ram killed that airplane and its crew. FYI, *any* airplane with an uncontrolled fire in its engine/wing is susceptable to subsequent structural failure. And you ignored the fact that aircraft designed exclusively for military use have also been lost to ..50 cal and below hits--so where is this much greater vulnerability of the P-3 in view of that fact? Any civil transport, such as this one was (before being modified), is terribly vulnerable: http://www.concordesst.com/accident/...es/flames1.jpg But much can be done to mitigate the effects. And is being done on "War"planes: http://jas.jcs.mil/news/pdf/2003_fall.pdf "When it comes to providing aircraft fuel system ballis-tic tolerance capability, it is necessary to understand that protecting from a catastrophic explosion in a fuel tank ullage cannot be accomplished solely with self-sealing fuel cells. To provide the desired level of ballistic tolerance requires a hand-in-hand compli-mentary approach which incorpo-rates both self-sealing fuel cells and OBIGGS. Ultimately, it is necessary to incorporate the appropriate fuel system requirements verbiage requir-ing a self-sealing capability and that damage from certain high explosive incendiary and/or armor piercing incendiary rounds must not cause catastrophic explosion. This will drive a solution, which provides the proper level of survivability protec-tion for both permanently mounted and auxiliary internal fuel cells." Control the susceptability. I.e, the "L" in ARL-M... I also note that in the first few sentences the authors identify the difference between "susceptability" and "vulnerability"--the latter does not come into play if the former is controlled such that hits don't occur--which will be the predominant environment that the ACS and E-10 will operate in. Glad you found out the difference between the two. I think you fit firmly in the camp described below. Its a very wrong and hubris filled view, but I'll let some much more credible sources speak make the case: http://jas.jcs.mil/news/pdf/2003_fall.pdf FYI, I stopped going to your sources shortly after determining that you were twisting the position of the Lexington Institute in regards to the viability of using commercial airframes in roles such as ACS and E-10. snip How can you be so verbose and still fail to answer the question regarding what you think that "L" in ARL means? Brooks |
FYI, I stopped going to your sources shortly after determining that you were twisting the position of the Lexington Institute in regards to the viability of using commercial airframes in roles such as ACS and E-10. Never, not once, have you cited any references, at least I've offered up SOMETHING to supoort my case. You say I twisted what Lexington Institute has to say. You are completely wrong. In the ISR lessons learned, Dr. Thompson was addressing ISR as it stood this summer in light of recent experiences. You've ignored the "lessons unlearned" part quite well. In the ACS paper, of the two platforms, he very much sided against the EMB(and I couldn't agree with him more), but he figures cost will be the driver in the program which means the EMB may well end up the choice. He never stated an opinion one way or the other about using civil airframes. Ditto for the paper on the E-10. As a matter of fact, he is stressing the importance of fielding the radar and not really even broaching what airframe(more on theat later) it will be on. Those two papers had a very narrow focus. You are putting more into them than they offer. At least I've cited references, most of which are .mil. When are you going to back up your "facts" with anything other than your derisive retorts? Please point to the "special engineering" that sets an AFSOC CN 235/295 apart from one of those Gulfstreams. As one whose day job involves aviation safety and aircraft engineering, I can say a whole lot about this....but I won't bore you. In a nutshell, what the CN-235 has going for it is its very simplicity. Also its relatively clandestine use-its not emitting, nor loitering for long periods on station like the ACS and E-10 will-certainly helps in reducing its suceptability as well. I knew some SOF types when I lived near Hurlburt some years ago, and they hated that airplane by the way. In their words, "What a piece of crap". IIRC there is talk of replacing them...but I won't twist anything for you. Not much is written about the AX yet, but I'll wager a bet that it certainly will benefit from survivability analysis and engineering. Wanna put some cash on it? Fact is they are very vulnerable platforms that are being considered for vital missions and that potential adversaries are building weapons to field against. Big jump from that Russian firm "slowly" pursuing a very long range AAM program to "are building". The Novator AAM is in slow development. The S-300 S-400 are no joke systems. Its explicitly stated they are intended to be employed against AWACS. No twisting from me here Kevin. Read it for yourself... http://www.aeronautics.ru/s400triumph.htm "While the Triumph[S-400] SAM system is capable of firing older 48N6E missiles, it will use a brand new missile currently in final stages of development. This new missile would feature a combination of semi-active/active homing, an effective range of up to 400km and it will be capable of hitting new-generation air-to-surface missiles and AWACS aircraft." Look, we are NOT sending them into contested airspace, OK? Period. There is that strange "OP-2E's" you keep ranting about... And again, we are not going to send these assets in against "undue risk". Some guys whose remains finally made it home to Arlington recently were certainly ordered into contested airspace in their ISR assets...Even in the face of "undue risk". The job had to get done. Thats what war-real war-is about Kevin. You seem to be suffering from a fairly bad bout of "Victory Disease" Kevin, this may help you get over it: http://www.army.mil/prof_writing/vol...03/9_03_5.html That some AF units seem to be exempt from the possibility of taking enemy fire has been a long term inherent cultural issue apparently. I'm not the only one to say it either: http://www.airpower.maxwell.af.mil/a...jun/cahoon.htm You didn't bother to read this I presume...Go ahead. Learn something new Kevin. Its an old paper, but pertinent to the debate. C-17 drivers just recently went through combat certification for the first time. The question begs, why weren't they treated as warfighters all along? Meaningless. ACS and E-10 are not airlifters. Airlifters may indeed have to drop down into a MANPADS/AAA threat environment to perform their mission--ACS and the E-10 do not. Whats not meaningless is the fact...yes Fact...the AF was caught off guard about the need to consider the C-17 a warplane and its operators warfighters. From AvWeek Jan.5'04: "The C-130 community has had a weapons instructor course (WIC) for many years. But no one expected the C-17 force to [come] under fire very often...." Judging from what was written in 1983 all the way to what was written in 2004, the AF has a relatively poor track record at figuring out which of their assets may be getting shot at down the road. Quick! Call the Pentagon and tell them you have discovered the flaw in the plans that so many professionals have been developing for decades now! From whats written below its a topic of offical debate, but mostly classified apparently...As it should be. My guess is that the Budgeteering and Powerpointing Prowess is most important in acquisitions right now. Suriviablity analysis is not getting the attention it needs. http://www.fas.org/irp/program/collect/SIGINTWP.pdf "ADA Susceptibility: GR/CS and ARL susceptibility to SA 10 and SA 12 threats was the cornerstone of the argument to eliminate them from the system. While it is true that they are susceptible to the threats, they are no less so than many of the retained systems. Rivet Joint,EP3, ES3, all retained by the study, fly at altitudes similar to Army systems. Their survivability will require stand-off as well. GR/CS normally flies in the same vicinity as JSTARS and AWACS, two targets an enemy would likely pursue with more vigor than an RC12. Discussions made it clear that the entire air campaign was not considered in the analysis. In fact, constraints of the ADA threat were not uniformly applied. Had it been so, many other platforms would have to become HAPs as well (JSTARS, AWACS)." I don't know where you get these ideas, but the E-8 JSTARS surveillance range reportedly reaches out to around 250 km--SA-10/12 manage what, maybe 90 km? Since I'm sure you didn't open up the link on the S-400 , here is what it says: http://www.aeronautics.ru/s300site.htm KEY CHARACTERISTICS S-300PMU1 S-300MU2 S-400 Range, km (max) 150 200 400 Altitude, km (max) 25-27 25+ 25+ Altitude, km (min) 10 10 10 So why were they concerned. Obviously the longer range threat had not been rendered below the "undue threat" threshold. That is not what the evidence indicates. In fact, were any longer range systems used to engage the KC's? Nope--the threat was ameliorated. We know that after the fact. With tankers going "forward". , maybe its time they need some WICs as well. And why stop there include the ISR folks as well. As an FYI the whole point about the E-10 could well be moot: http://www.aviationnow.com/avnow/new...s/02094wna.xml My beef is that these airframes represent easy kills and the COTS culture is ignoring the problem. The threat to them while airborne isn't there today, but some guys who mean us ill will are working hard on that problem. Easy kills on the tarmac are another issue as well and certainly possible today. A few bits of shrapnel and its Buh-Bye shiny new 767-400. An airframe that can be expected to take a measured amount of battle damage is a necessity for ALL military aircraft. The problem is, in order to save costs, this analysis is not getting done. It'll cost lives down the road too, just like past times when vulnerability issues were ignored. What the DOD and the manufacturers should do is subject these airframes to some rigourous survivability analysis. To digress a bit, the MMA is expected to retain the low level recce and sub attack mission, so the MMA really needs the benefit of such analysis as well. Modify FAR PART 125 and MIL-STD-1530A damage tolerance standards to include the spectre of the MANPADS threat, and spread the total costs over civil and military production alike. I'm off the soapbox. And, oh yes, I DO know what the "L" in ARL means... sid |
![]() "sid" wrote in message om... "Kevin Brooks" wrote in message ... rant snipped Look, we are NOT sending them into contested airspace, OK? Period. There is that strange "OP-2E's" you keep ranting about... And again, we are not going to send these assets in against "undue risk". Some guys whose remains finally made it home to Arlington recently were certainly ordered into contested airspace in their ISR assets...Even in the face of "undue risk". The job had to get done. Thats what war-real war-is about Kevin. Are you talking about the DASH-7 ARL that punched into a freakin' mountainside? Geeze, just what kind of damage tolerance are you demanding? snip I don't know where you get these ideas, but the E-8 JSTARS surveillance range reportedly reaches out to around 250 km--SA-10/12 manage what, maybe 90 km? Since I'm sure you didn't open up the link on the S-400 , here is what it says: http://www.aeronautics.ru/s300site.htm KEY CHARACTERISTICS S-300PMU1 S-300MU2 S-400 Range, km (max) 150 200 400 Altitude, km (max) 25-27 25+ 25+ Altitude, km (min) 10 10 10 Uhmmm...isn't S-400 the ABM derivitive? Which explains it longer range--against targets waaay upstairs in their radar horizon at that range? As to the others....250 km is greater than either of them. Now, how often are you going to see those systems up near the FLOT? That's right--pretty much never. Talk about being an ATACMS magnet... snip My beef is that these airframes represent easy kills and the COTS culture is ignoring the problem. The threat to them while airborne isn't there today, but some guys who mean us ill will are working hard on that problem. Easy kills on the tarmac are another issue as well and certainly possible today. A few bits of shrapnel and its Buh-Bye shiny new 767-400. An airframe that can be expected to take a measured amount of battle damage is a necessity for ALL military aircraft. Oh, gee whiz, what about those C-40's? And those aircraft specified to go into low threat areas? I guess you would discount the future use of CRAF assets as well, right? What with all of those nasty super long range AAM's...oops, that's right, they are just ghostware. snip And, oh yes, I DO know what the "L" in ARL means... I don't think you do, from the angle of your rants. It does NOT mean "low altitude", nor does it mean "low chance of surviving its mission". Brooks sid |
... Look, we are NOT sending them into contested airspace, OK? Period. There is that strange "OP-2E's" you keep ranting about... And again, we are not going to send these assets in against "undue risk". Some guys whose remains finally made it home to Arlington recently were certainly ordered into contested airspace in their ISR assets...Even in the face of "undue risk". The job had to get done. Thats what war-real war-is about Kevin. Are you talking about the DASH-7 ARL that punched into a freakin' mountainside? Geeze, just what kind of damage tolerance are you demanding? Hate to disappoint you but...No, I'm not talking about what happened in Colombia at all. Laos actually. Since you are spouting all these "facts", I thought you'd know all about it. Uhmmm...isn't S-400 the ABM derivitive? Which explains it longer range--against targets waaay upstairs in their radar horizon at that range? As to the others....250 km is greater than either of them. Now, how often are you going to see those systems up near the FLOT? That's right--pretty much never. Talk about being an ATACMS magnet... On your last point, its a matter of active concern. The radars and targeting systems for these systems are bit tougher to counter. Be honest, did you ever think the Serbs were capable of shooting down that F-117 before it happend Kevin? Paycheck says no. Of course I don't expect you to open this: http://www.airpower.maxwell.af.mil/a...pietrucha.html Everyone seems to understand the S-400's threat against aircraft...except you. Oh yeah, have you checked out anything on "Three Attacks Three Defenses?" Oh, gee whiz, what about those C-40's? And those aircraft specified to go into low threat areas? I guess you would discount the future use of CRAF assets as well, right? What with all of those nasty super long range AAM's...oops, that's right, they are just ghostware. C-17s were expected to be in low threat areas...until recently. I should have phrased my statement (which I'm sure you will misconstrue as a rant) to say ALL aircraft involved in the active conduct of a battle...even the ones that traditionally have operated on the periphery. For C-40s et all, thats where the changes to Part-25 (typo'd as 125 earlier)and MIL-STD-1530A come in. MANPADS is now a threat to ALL transport category aircraft. Speaking of CRAF(which isn't instituted right now BTW)... Even though it wasn't a flight under DOD auspicies, DHL-and eventually LLoyds of London-have paid dearly for operating in a hot war zone. By the Grace of God only that crew and aircraft didn't end up in a smoking hole, and Thank God too that it was empty and not carrying 300 or so of our finest. Yes I know it was freight dog, so don't get all ****y about that little "fact". Did you see the size of the shrapnel hole where the fragment entered the bottom of the wing and started that hydrodynamic ram created fire? Its really small so look carefully. http://gallery.colofinder.net/dhl-ai...le12042003a010 I wonder what a S-400 warhead would do to a similarly engineered EMB-145? Novator's product is a bit more than ghostware, but I don't want to disturb any of your "facts". And, oh yes, I DO know what the "L" in ARL means... I don't think you do, from the angle of your rants. It does NOT mean "low altitude", nor does it mean "low chance of surviving its mission". LOL!! I worked for the operator that had the DASH-7s before the Army got them(I've moved on since). Regardless, the ACS won't have an "L" attached. Its expected to be"one of the first to the fight". |
![]() "sid" wrote in message om... "Kevin Brooks" wrote in message ... Look, we are NOT sending them into contested airspace, OK? Period. There is that strange "OP-2E's" you keep ranting about... And again, we are not going to send these assets in against "undue risk". Some guys whose remains finally made it home to Arlington recently were certainly ordered into contested airspace in their ISR assets...Even in the face of "undue risk". The job had to get done. Thats what war-real war-is about Kevin. Are you talking about the DASH-7 ARL that punched into a freakin' mountainside? Geeze, just what kind of damage tolerance are you demanding? Hate to disappoint you but...No, I'm not talking about what happened in Colombia at all. Laos actually. Since you are spouting all these "facts", I thought you'd know all about it. We have not lost an ARL in Laos. Uhmmm...isn't S-400 the ABM derivitive? Which explains it longer range--against targets waaay upstairs in their radar horizon at that range? As to the others....250 km is greater than either of them. Now, how often are you going to see those systems up near the FLOT? That's right--pretty much never. Talk about being an ATACMS magnet... On your last point, its a matter of active concern. The radars and targeting systems for these systems are bit tougher to counter. Be honest, did you ever think the Serbs were capable of shooting down that F-117 before it happend Kevin? Paycheck says no. Hand it over. Anybody with have a brain knows that stealth is not completely infallible, and that golden BB's do exist. The F-117 is a tough enough target to acquire and hit--but it is not *impossible*. Of course I don't expect you to open this: http://www.airpower.maxwell.af.mil/a...pietrucha.html Everyone seems to understand the S-400's threat against aircraft...except you. Uhmmm...note that scenario has them facing F-15E's, not E-10's or ARL's? Gee, wonder why... As to the realism of that particular threat...a single ATACMS battery sitting in that same UAE territory can drill your S-400 site each time the radar gets flipped on. Joint operations is a wonderful thing, isn't it? snip Oh, gee whiz, what about those C-40's? And those aircraft specified to go into low threat areas? I guess you would discount the future use of CRAF assets as well, right? What with all of those nasty super long range AAM's...oops, that's right, they are just ghostware. C-17s were expected to be in low threat areas...until recently. I should have phrased my statement (which I'm sure you will misconstrue as a rant) to say ALL aircraft involved in the active conduct of a battle...even the ones that traditionally have operated on the periphery. For C-40s et all, thats where the changes to Part-25 (typo'd as 125 earlier)and MIL-STD-1530A come in. MANPADS is now a threat to ALL transport category aircraft. Oh, no! We have to scrap all of our airliners NOW! Build new ones that meet your lofty criteria for survivability, right? Speaking of CRAF(which isn't instituted right now BTW)... Even though it wasn't a flight under DOD auspicies, DHL-and eventually LLoyds of London-have paid dearly for operating in a hot war zone. By the Grace of God only that crew and aircraft didn't end up in a smoking hole, and Thank God too that it was empty and not carrying 300 or so of our finest. Yes I know it was freight dog, so don't get all ****y about that little "fact". No, the "fact" you conveniently ignore is that it WAS a civil aircraft, it WAS hit by a MANPADS, and...it did not fall apart! It actually *survived*. Not a good example to support your "commercial airframes can't handle modern combat requirements" sermon, now is it? snip I wonder what a S-400 warhead would do to a similarly engineered EMB-145? Probably the same thing it would do if it hit any *military* aircraft--blow it to hell and back. You are trying to compare the effects of a MANPADS strike (which we now know is survivable on the part of a commercial aircraft, thanks again for the example) to that of a big honking warhead like what is carried on the S-300/400 class weapons?! Novator's product is a bit more than ghostware, but I don't want to disturb any of your "facts". Then tell us where it is--when is the first testflight? What kind of guidance system will it use? Come on now--give us the specifics on this new uber-weapon. And, oh yes, I DO know what the "L" in ARL means... I don't think you do, from the angle of your rants. It does NOT mean "low altitude", nor does it mean "low chance of surviving its mission". LOL!! I worked for the operator that had the DASH-7s before the Army got them(I've moved on since). Regardless, the ACS won't have an "L" attached. Its expected to be"one of the first to the fight". I hate to tell you this, but the ARL also serves in that role--or did you think we deployed them to Korea for grins and giggles? The key is *where* it conducts its "fight"...yep, somewhere well to the rear of the FLOT, with due regard to any potential threat systems that *could* cause it problems if it moved into their envelope. This has been loads of fun, but in the end it sounds a bit like that fellow's one-man crusade against those eee-vil oil companies who stole his kool-aid/gas formula that gives him 100 miles to the gallon, and can't understand *why* the mainstream tech world just can't seem to grasp the importance of his discovery... So adios, and have a nice day--we can revisit this the day we start trying to penetrate the bad guys' IADS with those ERJ's.... Brooks |
... Hate to disappoint you but...No, I'm not talking about what happened in Colombia at all. Laos actually. Since you are spouting all these "facts", I thought you'd know all about it. We have not lost an ARL in Laos. Yeah. I know that. Apparently you are unaware of the ISR assets we DID lose in Laos. Hand it over. Anybody with have a brain knows that stealth is not completely infallible, and that golden BB's do exist. The F-117 is a tough enough target to acquire and hit--but it is not *impossible*. I only have your word for it and so far your words have not been substantiated or proven particularly reliable. Do you think we are the only ones pursuing innovative networked targeting systems? You are showing more signs of that "Voctory Disease". Of course I don't expect you to open this: http://www.airpower.maxwell.af.mil/a...pietrucha.html Everyone seems to understand the S-400's threat against aircraft...except you. Uhmmm...note that scenario has them facing F-15E's, not E-10's or ARL's? Gee, wonder why... As to the realism of that particular threat...a single ATACMS battery sitting in that same UAE territory can drill your S-400 site each time the radar gets flipped on. Joint operations is a wonderful thing, isn't it? Excellent!! You did open a link. I urge you to open the others as well...especially those dealing with surviviability. Whatever you think of my points here, there is wealth of good stuff there. I'm heartened that you now know the difference between "vulnerability" and "susceptability" Networked systems, that certainly wont be fielded by 2006, is what it takes to defeat that kind of threat. What is expected to serve as the nexus for the networked systems? Why our airborne ISR assets of course. Neutralize them and we have a big problem. Our potential adversaries are aware of this and have stated they want to counter those assets in a big way. Once you get done doing the research on ISR asset losses in Laos, read up on Three Attacks Three Defenses For C-40s et all, thats where the changes to Part-25 (typo'd as 125 earlier)and MIL-STD-1530A come in. MANPADS is now a threat to ALL transport category aircraft. Oh, no! We have to scrap all of our airliners NOW! Build new ones that meet your lofty criteria for survivability, right? Thats silly Kevin. What CAN be done is to harden those civil airframes destined for military use to a measured level. Then leverage at least some of those enhancements (whatever analysis shows to be the best) into new construction aircraft. On the civil side, all thats being proposed are pork riddled expensive countermeasure sets. IF you were to read up on survivability, you would see a balance between susceptability and vulnerability is what it takes for sucess. The big problem is the analysis is not getting done for aircraft that will sorely need the protection one day. No, the "fact" you conveniently ignore is that it WAS a civil aircraft, it WAS hit by a MANPADS, and...it did not fall apart! It actually *survived*. Not a good example to support your "commercial airframes can't handle modern combat requirements" sermon, now is it? Didn't ignore it one bit. It was a very small piece of shrapnel that caused that winfg to burn almost all the way off. Because this aircraft landed means little. It had no hydraulics (and no manual reversion), and the left after spar was burned 85 to 90 pct through. The fact that airplane landed really doesn't say much except that it was a calm day, the aircraft was empty and light, and the captain had just recently been reviewing the United DC-10 no hydraulics landing. If it had been windy, or if the airplane had been heavier, or if the captain had not thought about how to maneuver with engines only, the story would have been different. They were really, really lucky. An aircraft that had been built to take at least some damage which is what these people are all about making sure happens: http://jas.jcs.mil/main.htm would have had a whole lot better chance at making it back alive. I hate to tell you this, but the ARL also serves in that role--or did you think we deployed them to Korea for grins and giggles? The key is *where* it conducts its "fight"...yep, somewhere well to the rear of the FLOT, with due regard to any potential threat systems that *could* cause it problems if it moved into their envelope. Essentially a cold war type deployment prior to the initiation of hostilities. You are exhibiting more symptoms of the Victory Disease. http://www.army.mil/prof_writing/vol...03/9_03_5.html With a projected SAR/MTI range of 120 km (in flat terrain) ACS would be well within range of S-300 S-400 threats. On a parting note. Did you see where the E-10 isn't likely to be built anytime soon anyway? |
Magneto/comm interference on TKM MX-R Narco 120 replacement | Eugene Wendland | Home Built | 5 | January 13th 04 02:17 PM |
Canada to order replacement for the Sea King | Ed Majden | Military Aviation | 3 | December 18th 03 07:02 PM |
Replacement for C130? | John Penta | Military Aviation | 24 | September 29th 03 07:11 PM |
Narco MK 16 replacement | SoulReaver714 | Aviation Marketplace | 1 | September 23rd 03 04:38 PM |
Hellfire Replacement | Eric Moore | Military Aviation | 6 | July 2nd 03 02:22 AM |
