On Oct 27, 1:45*pm, Darryl Ramm wrote:
Just one point -- before the 4800 baud comment scares a bunch of people. Existing Flarm products support 4800 baud NMEA output and I see no reason that the PowerFLARM would not - it is an obvious need, its the industry standard/default NMEA baud rate, and would break lots of things if it didn't. Its easy to configure Flarm Baud rates (e.g with the Flarm tool). The default rate on Flarm products has been 19200 baud and I assume the PowerFLARM will be the same, if you change it to 4800 baud the device cannot put the Flarm traffic data into the NMEA stream (4800 baud is too slow to do this) but then if you have a device that can only work at 4800 baud it is not going to know what to do with the Flarm NMEA traffic data anyhow. I'll confirm this after I steal a PowerFLARM from Urs on Saturday :-) Darryl Correct, baud rate(s) are easily configurable... Best Regards, Dave |
P-51 Question | David Pride[_2_] | Aviation Photos | 3 | February 10th 08 09:53 AM |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
STC question | John Galban | Owning | 1 | August 9th 03 01:00 AM |
