On 10/27/2010 5:33 PM, Mike Schumann wrote:
On 10/27/2010 3:48 PM, Eric Greenwell wrote: On 10/27/2010 7:20 AM, wrote: in "awareness mode", of course a led will indicate where the closer glider is, but still alarms will only be triggered when a deviation makes the collision a real possibility. aldo cernezzi Since the GPS accuracy is probably much poorer than 10 feet, when a glider comes within 10 feet, I figure the FLARM should consider that a collision, no? I don't know what Flarm does in that case, but my guess is the *relative* accuracy is much better than the *absolute* accuracy. If that's true, then each glider might have position errors of much more than 10 feet, but they'll have nearly the same errors, giving a more accurate separation distance. Maybe someone more familiar with GPS in this situation can jump in here and tell us? Even if the relative GPS position computed by each glider has 0 error, you still have the problem that at 50 Knots, each aircraft is moving ~ 75 ft / second. With FLARM (or ADS-B) only transmitting positions every second, you can't rely on these technologies to protect you from random course changes that the systems can't possibly predict, if you are in close proximity. FLARM does more than transmit positions: it transmits the projected path of it's glider. Here's what I understand will happen: when the pilot makes a course change, a new path is calculated and compared to the paths Flarm has received from nearby gliders. If this new path puts it on a collision course with any of them, the pilot is warned "immediately", meaning it does not have to wait one second. The new path will be transmitted within one second, so the nearby gliders can update the other glider's path in their database. It might actually be more sophisticated than that, such as transmitting a new path sooner if the amount of change is "large", but I don't know what the algorithms are. This projected path is a key element to the system working properly. Without it, each FLARM unit would have to calculate the path of every nearby glider; with it, each unit only has to calculate one path - it's own. Potentially, it could be using a much higher position rate than once a second to calculate it's projected path. In any case, the result is much better than you might think for a system that transmits once a second. Does ADS-B transmit a projected path, or just position? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
On Oct 27, 8:16*pm, Eric Greenwell wrote:
On 10/27/2010 5:33 PM, Mike Schumann wrote: On 10/27/2010 3:48 PM, Eric Greenwell wrote: On 10/27/2010 7:20 AM, wrote: in "awareness mode", of course a led will indicate where the closer glider is, but still alarms will only be triggered when a deviation makes the collision a real possibility. aldo cernezzi Since the GPS accuracy is probably much poorer than 10 feet, when a glider comes within 10 feet, I figure the FLARM should consider that a collision, no? I don't know what Flarm does in that case, but my guess is the *relative* accuracy is much better than the *absolute* accuracy. If that's true, then each glider might have position errors of much more than 10 feet, but they'll have nearly the same errors, giving a more accurate separation distance. Maybe someone more familiar with GPS in this situation can jump in here and tell us? Even if the relative GPS position computed by each glider has 0 error, you still have the problem that at 50 Knots, each aircraft is moving ~ 75 ft / second. *With FLARM (or ADS-B) only transmitting positions every second, you can't rely on these technologies to protect you from random course changes that the systems can't possibly predict, if you are in close proximity. FLARM does more than transmit positions: it transmits the projected path of it's glider. Here's what I understand will happen: when the pilot makes a course change, a new path is calculated and compared to the paths Flarm has received from nearby gliders. If this new path puts it on a collision course with any of them, the pilot is warned "immediately", meaning it does not have to wait one second. The new path will be transmitted within one second, so the nearby gliders can update the other glider's path in their database. It might actually be more sophisticated than that, such as transmitting a new path sooner if the amount of change is "large", but I don't know what the algorithms are. This projected path is a key element to the system working properly. Without it, each FLARM unit would have to calculate the path of every nearby glider; with it, each unit only has to calculate one path - it's own. Potentially, it could be using a much higher position rate than once a second to calculate it's projected path. In any case, the result is much better than you might think for a system that transmits once a second. Does ADS-B transmit a projected path, or just position? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz That's my understanding as well - the Flarm algorithm looks at a range of potential paths that the glider might maneuver to and calculates potential collisions on the basis of all potential paths within that maneuvering envelope. I expect within a couple of seconds the path assumes a fair amount of potential maneuvering while over a longer period of time it would limit extreme maneuvering assumptions to be closer to an extrapolation of the current path/turn rate. Because it understands your trun rate it works well in thermals. I have not heard anything about similar capabilities for ADS-B and I am confident that it doesn't extrapolate with a glider performance envelope in mind, since it isn't designed explicitly for gliders. I would think ADS-B would be particularly challenged in predicting likely collisions in thermals - much more so than Flarm. 9B |
On Oct 28, 1:11*am, Andy wrote:
On Oct 27, 8:16*pm, Eric Greenwell wrote: On 10/27/2010 5:33 PM, Mike Schumann wrote: On 10/27/2010 3:48 PM, Eric Greenwell wrote: On 10/27/2010 7:20 AM, wrote: in "awareness mode", of course a led will indicate where the closer glider is, but still alarms will only be triggered when a deviation makes the collision a real possibility. aldo cernezzi Since the GPS accuracy is probably much poorer than 10 feet, when a glider comes within 10 feet, I figure the FLARM should consider that a collision, no? I don't know what Flarm does in that case, but my guess is the *relative* accuracy is much better than the *absolute* accuracy. If that's true, then each glider might have position errors of much more than 10 feet, but they'll have nearly the same errors, giving a more accurate separation distance. Maybe someone more familiar with GPS in this situation can jump in here and tell us? Even if the relative GPS position computed by each glider has 0 error, you still have the problem that at 50 Knots, each aircraft is moving ~ 75 ft / second. *With FLARM (or ADS-B) only transmitting positions every second, you can't rely on these technologies to protect you from random course changes that the systems can't possibly predict, if you are in close proximity. FLARM does more than transmit positions: it transmits the projected path of it's glider. Here's what I understand will happen: when the pilot makes a course change, a new path is calculated and compared to the paths Flarm has received from nearby gliders. If this new path puts it on a collision course with any of them, the pilot is warned "immediately", meaning it does not have to wait one second. The new path will be transmitted within one second, so the nearby gliders can update the other glider's path in their database. It might actually be more sophisticated than that, such as transmitting a new path sooner if the amount of change is "large", but I don't know what the algorithms are. This projected path is a key element to the system working properly. Without it, each FLARM unit would have to calculate the path of every nearby glider; with it, each unit only has to calculate one path - it's own. Potentially, it could be using a much higher position rate than once a second to calculate it's projected path. In any case, the result is much better than you might think for a system that transmits once a second. Does ADS-B transmit a projected path, or just position? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz That's my understanding as well - the Flarm algorithm looks at a range of potential paths that the glider might maneuver to and calculates potential collisions on the basis of all potential paths within that maneuvering envelope. *I expect within a couple of seconds the path assumes a fair amount of potential maneuvering while over a longer period of time it would limit extreme maneuvering assumptions to be closer to an extrapolation of the current path/turn rate. Because it understands your trun rate it works well in thermals. I have not heard anything about similar capabilities for ADS-B and I am confident that it doesn't extrapolate with a glider performance envelope in mind, since it isn't designed explicitly for gliders. I would think ADS-B would be particularly challenged in predicting likely collisions in thermals - much more so than Flarm. 9B- Hide quoted text - - Show quoted text - I hadn't really considered how the projected flight path system works before. But after thinking about it for a bit it has a lot of potentional. How much the Flarm actually uses I do not know. But it would be possible for the Flarm to actually learn the possible flight paths for a given glider and dynamically adjust it's algorithm for where the glider might be able to go from that. Even without that I can see that gliders could get very close but have potential flight paths that would make colliding impossible and as a result would not create a collision alarm. Brian |
On Thu, 28 Oct 2010 06:53:27 -0700 (PDT), Brian
wrote: I hadn't really considered how the projected flight path system works before. But after thinking about it for a bit it has a lot of potentional. How much the Flarm actually uses I do not know. Flarm uses ONLY projected flight paths to calculate a collision probability. Even without that I can see that gliders could get very close but have potential flight paths that would make colliding impossible and as a result would not create a collision alarm. This is exactly how Flarm works. Flarm doesn't care about distances - as long as Flarm doesn't detect a potential collision cource, you can fly very close to each other without getting a warning - even if you are circling. Andreas |
On Oct 28, 7:32*am, Andreas Maurer wrote:
On Thu, 28 Oct 2010 06:53:27 -0700 (PDT), Brian wrote: I hadn't really considered how the projected flight path system works before. But after thinking about it for a bit it has a lot of potentional. How much the Flarm actually uses I do not know. Flarm uses ONLY projected flight paths to calculate a collision probability. Even without that I can see that gliders could get very close but have potential flight paths that would make colliding impossible and as a result would not create a collision alarm. This is exactly how Flarm works. Flarm doesn't care about distances - as long as Flarm doesn't detect a potential collision cource, you can fly very close to each other without getting a warning - even if you are circling. Andreas I think that's the secret for how you make it useful in thermals - if the system knows you are circling it can do a better job predicting your curved flight path and potential threats along that path. I presume that if you assume the full maneuvering envelope of each glider you'd generate a lot of warnings, so it would make sense to assume something more limited that strikes a balance between false positive warnings and missing potential maneuvers that could create a threat with little advanced notice. Think of a glider pulling up into a thermal as a good example. I assume that Flarm does all this based on the following explanation where an expanding projected flight path envelope is depicted: http://www.gliderpilot.org/Flarm-WhatDoesItDo As to ADS-B - without some algorithm for projecting flight paths the only warning you can realistically generate is a proximity warning. Even warning only for declining separation distance is a crude form of relative path prediction, just not a very useful one - particularly for glider operations with multiple targets and circling flight. 9B |
On Oct 28, 8:47 am, Andy wrote:
On Oct 28, 7:32 am, Andreas Maurer wrote: On Thu, 28 Oct 2010 06:53:27 -0700 (PDT), Brian wrote: I hadn't really considered how the projected flight path system works before. But after thinking about it for a bit it has a lot of potentional. How much the Flarm actually uses I do not know. Flarm uses ONLY projected flight paths to calculate a collision probability. Even without that I can see that gliders could get very close but have potential flight paths that would make colliding impossible and as a result would not create a collision alarm. This is exactly how Flarm works. Flarm doesn't care about distances - as long as Flarm doesn't detect a potential collision cource, you can fly very close to each other without getting a warning - even if you are circling. Andreas I think that's the secret for how you make it useful in thermals - if the system knows you are circling it can do a better job predicting your curved flight path and potential threats along that path. I presume that if you assume the full maneuvering envelope of each glider you'd generate a lot of warnings, so it would make sense to assume something more limited that strikes a balance between false positive warnings and missing potential maneuvers that could create a threat with little advanced notice. Think of a glider pulling up into a thermal as a good example. I assume that Flarm does all this based on the following explanation where an expanding projected flight path envelope is depicted: http://www.gliderpilot.org/Flarm-WhatDoesItDo As to ADS-B - without some algorithm for projecting flight paths the only warning you can realistically generate is a proximity warning. Even warning only for declining separation distance is a crude form of relative path prediction, just not a very useful one - particularly for glider operations with multiple targets and circling flight. 9B Just to give a flavor ADS-B data-out systems as mandated for 2020 in the USA for power aircraft (basically where a transponder is required today) will put out the following data Aircraft ICAO ID (can be made anonymous for a UAT on VFR flight) Aircraft callsign/flight number (not required for VFR flight) Time of applicability GPS Lattitude GPS Longitude GPS altitude Airborne/on-surface status Northbound ground velocity component while airborne (from GPS) Eastbound ground velocity component while airborne (from GPS) Heading while on the surface Ground speed while on the surface Pressure altitude Vertical rate (may be pressure or GPS based) GPS uncertainty/integrity (which needs information form a fancy TSO- C145 class WAAS GPS) Ident (equivalent to transponder ident/SPI) Distress/Emergency status ADS-B data-in/display capability TCAS equipage/status This is a simplified list and there is various other status/validity data as well. There is also the concept in ADS-B messages of an estimated position, and even estimated velocity. But AFAIK this is not intended for fancy manoeuvrings predictions - it is more intended to allow different parts of the ADS-B infrastructure to project position or velocity updated to a single time of applicability. There is space for future expansion and as an example there is long-term work underway to look at an ADS-B based replacement for TCAS that could well utilize extra data transmission than that above, but think well post 2020 for this to actually happen. My brain hurts enough thinking about ADS-B as is. --- BTW my suspicion is given that the FAA currently requires a STC for any installation for ADS-B data out that it is currently not possible to install any ADS-B data-out system in the USA in any certified aircraft (including gliders) that only meets a subset of the 2020 mandate requirements (ie. does not include all the stuff above). Which I expect the FAA would also require fully TSO-C154c/DO-282B (UAT) TSO- C166b/DO-260B (1090ES) and with the corresponding TSO-C145 level GPS. Experimental aircraft are another question since an STC cannot apply to them. This STC restriction hopefully is short-term as its is going to have a chilling effect on ADS-B data-out adoption in general aviation and gliders. Besides some more complex issues you can start to see even simple installation concerns that are probably causing this current STC requirement, such as squat switch/or other on-ground detection, needs to have a single squawk code and ident button across any installed transponder(s) and ADS-B data-out devices, ability to transmit a distress/emergency code, ability to turn off the ADS-B transmissions if requested, etc. Darryl |
![]() "Darryl Ramm" wrote in message ... On Oct 28, 8:47 am, Andy wrote: Just to give a flavor ADS-B data-out systems as mandated for 2020 in the USA for power aircraft (basically where a transponder is required today) will put out the following data Aircraft ICAO ID (can be made anonymous for a UAT on VFR flight) Aircraft callsign/flight number (not required for VFR flight) Time of applicability GPS Lattitude GPS Longitude GPS altitude Airborne/on-surface status Northbound ground velocity component while airborne (from GPS) Eastbound ground velocity component while airborne (from GPS) Heading while on the surface Ground speed while on the surface Pressure altitude Vertical rate (may be pressure or GPS based) GPS uncertainty/integrity (which needs information form a fancy TSO- C145 class WAAS GPS) Ident (equivalent to transponder ident/SPI) Distress/Emergency status ADS-B data-in/display capability TCAS equipage/status This is a simplified list and there is various other status/validity data as well. There is also the concept in ADS-B messages of an estimated position, and even estimated velocity. But AFAIK this is not intended for fancy manoeuvrings predictions - it is more intended to allow different parts of the ADS-B infrastructure to project position or velocity updated to a single time of applicability. There is space for future expansion and as an example there is long-term work underway to look at an ADS-B based replacement for TCAS that could well utilize extra data transmission than that above, but think well post 2020 for this to actually happen. My brain hurts enough thinking about ADS-B as is. --- BTW my suspicion is given that the FAA currently requires a STC for any installation for ADS-B data out that it is currently not possible to install any ADS-B data-out system in the USA in any certified aircraft (including gliders) that only meets a subset of the 2020 mandate requirements (ie. does not include all the stuff above). Which I expect the FAA would also require fully TSO-C154c/DO-282B (UAT) TSO- C166b/DO-260B (1090ES) and with the corresponding TSO-C145 level GPS. Experimental aircraft are another question since an STC cannot apply to them. This STC restriction hopefully is short-term as its is going to have a chilling effect on ADS-B data-out adoption in general aviation and gliders. Besides some more complex issues you can start to see even simple installation concerns that are probably causing this current STC requirement, such as squat switch/or other on-ground detection, needs to have a single squawk code and ident button across any installed transponder(s) and ADS-B data-out devices, ability to transmit a distress/emergency code, ability to turn off the ADS-B transmissions if requested, etc. Darryl The following is not directed at any individual, it is simply an observation. Even the old Garmin 12XL provides a lot more information in it's NMEA sentences the most of us realize. It is data output sentences are fully compliant with NMEA 0183 ver 2.0. The following link give an example of the data provided by "GPS engines" to software developer thus minimizing the amount of calculation required in display devices. http://www8.garmin.com/support/pdf/NMEA_0183.pdf As I watch these PowerFLARM discussion it is apparent that many assume that things provided by the GPS must be created by the FLARM software. Let us accept the fact that the PowerFLARM is just an upgrade of previous units that have been proven effective in increasing glider flight safety. Respectfully, Wayne |
On 10/27/2010 11:16 PM, Eric Greenwell wrote:
On 10/27/2010 5:33 PM, Mike Schumann wrote: On 10/27/2010 3:48 PM, Eric Greenwell wrote: On 10/27/2010 7:20 AM, wrote: in "awareness mode", of course a led will indicate where the closer glider is, but still alarms will only be triggered when a deviation makes the collision a real possibility. aldo cernezzi Since the GPS accuracy is probably much poorer than 10 feet, when a glider comes within 10 feet, I figure the FLARM should consider that a collision, no? I don't know what Flarm does in that case, but my guess is the *relative* accuracy is much better than the *absolute* accuracy. If that's true, then each glider might have position errors of much more than 10 feet, but they'll have nearly the same errors, giving a more accurate separation distance. Maybe someone more familiar with GPS in this situation can jump in here and tell us? Even if the relative GPS position computed by each glider has 0 error, you still have the problem that at 50 Knots, each aircraft is moving ~ 75 ft / second. With FLARM (or ADS-B) only transmitting positions every second, you can't rely on these technologies to protect you from random course changes that the systems can't possibly predict, if you are in close proximity. FLARM does more than transmit positions: it transmits the projected path of it's glider. Here's what I understand will happen: when the pilot makes a course change, a new path is calculated and compared to the paths Flarm has received from nearby gliders. If this new path puts it on a collision course with any of them, the pilot is warned "immediately", meaning it does not have to wait one second. The new path will be transmitted within one second, so the nearby gliders can update the other glider's path in their database. It might actually be more sophisticated than that, such as transmitting a new path sooner if the amount of change is "large", but I don't know what the algorithms are. This projected path is a key element to the system working properly. Without it, each FLARM unit would have to calculate the path of every nearby glider; with it, each unit only has to calculate one path - it's own. Potentially, it could be using a much higher position rate than once a second to calculate it's projected path. In any case, the result is much better than you might think for a system that transmits once a second. Does ADS-B transmit a projected path, or just position? I'm not an expert on either FLARM or ADS-B. I believe that ADS-B currently only transmits absolute position. Future enhancements might transmit trajectory, which would be most useful for aircraft with Flight Management Systems where the trajectory is well defined and could be used by the ATC system for airspace management. Regardless of whether or not the trajectory is transmitted, a sophisticated receiving system (either FLARM or ADS-B based), can remember each aircraft's position data and compute it's current trajectory. While a glider might be moving 75 ft / sec, this is obviously in a relatively forward direction. Neither the transmitting nor the receiving FLARM or ADS-B system can predict an abrupt change in course that a pilot flying manually might command. However, every aircraft has physical limits on roll rates, etc. that restrain the potential change in direction that can occur within the one second update interval of these systems. As a result, the systems can, theoretically, compute a pear shaped threat envelope for each aircraft and limit collision warnings to those situations where these envelopes intersect. It would be interesting to get more detailed information on the exact algorithms that FLARM uses in it's collision threat analysis and compare this to the actual unit performance in situations where gliders are flying at close distances in formation or in gaggles. This could also help pilots understand the limitations of these systems so they don't develop a false sense of security in situations where these systems are not reliable. -- Mike Schumann |
On 10/28/2010 7:29 AM, Mike Schumann wrote:
On 10/27/2010 11:16 PM, Eric Greenwell wrote: This projected path is a key element to the system working properly. Without it, each FLARM unit would have to calculate the path of every nearby glider; with it, each unit only has to calculate one path - it's own. Potentially, it could be using a much higher position rate than once a second to calculate it's projected path. In any case, the result is much better than you might think for a system that transmits once a second. Does ADS-B transmit a projected path, or just position? I'm not an expert on either FLARM or ADS-B. I believe that ADS-B currently only transmits absolute position. Future enhancements might transmit trajectory, which would be most useful for aircraft with Flight Management Systems where the trajectory is well defined and could be used by the ATC system for airspace management. Regardless of whether or not the trajectory is transmitted, a sophisticated receiving system (either FLARM or ADS-B based), can remember each aircraft's position data and compute it's current trajectory. While a glider might be moving 75 ft / sec, this is obviously in a relatively forward direction. You may be underestimating the value of transmitting the projected path. When another glider is first detected, your unit has only one position report and can not determine the flight path from that single point, and it will take several more precious seconds to determine the flight path of the potential threat; however, because the projected path is transmitted every second, your unit immediately knows it. Neither the transmitting nor the receiving FLARM or ADS-B system can predict an abrupt change in course that a pilot flying manually might command. However, every aircraft has physical limits on roll rates, etc. that restrain the potential change in direction that can occur within the one second update interval of these systems. As a result, the systems can, theoretically, compute a pear shaped threat envelope for each aircraft and limit collision warnings to those situations where these envelopes intersect. It would be interesting to get more detailed information on the exact algorithms that FLARM uses in it's collision threat analysis and compare this to the actual unit performance in situations where gliders are flying at close distances in formation or in gaggles. This could also help pilots understand the limitations of these systems so they don't develop a false sense of security in situations where these systems are not reliable. I'm sure the developers have tested their algorithms with thousands of simulations using IGC files from gliders in many situations. The Parowan accident simulation at http://www.gliderpilot.org/Flarm-Par...dairSimulation shows what can be done. It would be interesting, informative, and entertaining if there was a website or application that would let us run IGC files we select in a simulation like this. I'm curious about how Flarm would react in a few situations I've encountered. Doing simulations on a pilot's own files might be more persuasive of the value of Flarm than even the most well-written explanations, and much more easily understood than the algorithms themselves. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
On 10/28/2010 2:14 PM, Eric Greenwell wrote:
On 10/28/2010 7:29 AM, Mike Schumann wrote: On 10/27/2010 11:16 PM, Eric Greenwell wrote: This projected path is a key element to the system working properly. Without it, each FLARM unit would have to calculate the path of every nearby glider; with it, each unit only has to calculate one path - it's own. Potentially, it could be using a much higher position rate than once a second to calculate it's projected path. In any case, the result is much better than you might think for a system that transmits once a second. Does ADS-B transmit a projected path, or just position? I'm not an expert on either FLARM or ADS-B. I believe that ADS-B currently only transmits absolute position. Future enhancements might transmit trajectory, which would be most useful for aircraft with Flight Management Systems where the trajectory is well defined and could be used by the ATC system for airspace management. Regardless of whether or not the trajectory is transmitted, a sophisticated receiving system (either FLARM or ADS-B based), can remember each aircraft's position data and compute it's current trajectory. While a glider might be moving 75 ft / sec, this is obviously in a relatively forward direction. You may be underestimating the value of transmitting the projected path. When another glider is first detected, your unit has only one position report and can not determine the flight path from that single point, and it will take several more precious seconds to determine the flight path of the potential threat; however, because the projected path is transmitted every second, your unit immediately knows it. Neither the transmitting nor the receiving FLARM or ADS-B system can predict an abrupt change in course that a pilot flying manually might command. However, every aircraft has physical limits on roll rates, etc. that restrain the potential change in direction that can occur within the one second update interval of these systems. As a result, the systems can, theoretically, compute a pear shaped threat envelope for each aircraft and limit collision warnings to those situations where these envelopes intersect. It would be interesting to get more detailed information on the exact algorithms that FLARM uses in it's collision threat analysis and compare this to the actual unit performance in situations where gliders are flying at close distances in formation or in gaggles. This could also help pilots understand the limitations of these systems so they don't develop a false sense of security in situations where these systems are not reliable. I'm sure the developers have tested their algorithms with thousands of simulations using IGC files from gliders in many situations. The Parowan accident simulation at http://www.gliderpilot.org/Flarm-Par...dairSimulation shows what can be done. It would be interesting, informative, and entertaining if there was a website or application that would let us run IGC files we select in a simulation like this. I'm curious about how Flarm would react in a few situations I've encountered. Doing simulations on a pilot's own files might be more persuasive of the value of Flarm than even the most well-written explanations, and much more easily understood than the algorithms themselves. There's no question that FLARM or ADS-B based systems could have easily prevented the Parowan mid-air. My question is how much you can rely on this type of equipment to accurately warn you of collisions when you are flying in gaggles. Obviously knowing the relative position of other gliders in the gaggle is helpful. I would be very skeptical, however, of putting my faith in FLARM or any other system to accurately warn me of a collision with another glider that was in the same thermal, near my altitude, that was in my blind spot. Transmitting the project path of the aircraft is really only beneficial if the equipment on board the transmitting aircraft has some added information that is not available to the receiver on the transmitting aircraft's intent. With both FLARM and ADS-B systems, the initial visibility of the other aircraft occurs way before there is any collision threat, so the receiver should have no difficulty computing the project path of the other aircraft. ADS-B actually transmits the category of aircraft (i.e. glider, balloon, etc...) so the receiver can get a pretty good hint on the type of maneuvers that can be expected. -- Mike Schumann |
Flarm in the US | Steve Freeman | Soaring | 163 | August 15th 10 12:12 AM |
Reflections on good and evil | [email protected] | Piloting | 6 | April 18th 06 08:48 PM |
FLARM | Robert Hart | Soaring | 50 | March 16th 06 11:20 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
B29 - "Necessary Evil" | Matt Tauber | Military Aviation | 30 | August 28th 03 10:35 AM |
