On 10/28/2010 11:32 AM, Mike Schumann wrote:
There's no question that FLARM or ADS-B based systems could have easily prevented the Parowan mid-air. My question is how much you can rely on this type of equipment to accurately warn you of collisions when you are flying in gaggles. Obviously knowing the relative position of other gliders in the gaggle is helpful. I would be very skeptical, however, of putting my faith in FLARM or any other system to accurately warn me of a collision with another glider that was in the same thermal, near my altitude, that was in my blind spot. This situation is addressed at http://www.gliderpilot.org/FlarmFlig...andPerformance where it states that the human eye is better than Flarm. I don't think anyone has claimed Flarm is better in every possible situation, and users and Flarm itself repeatedly state you must still look outside to have the best protection; however, I believe Flarm will indicate there is a glider behind you, something a pilot might not always be aware of, so it still has value in this situation. Transmitting the project path of the aircraft is really only beneficial if the equipment on board the transmitting aircraft has some added information that is not available to the receiver on the transmitting aircraft's intent. With both FLARM and ADS-B systems, the initial visibility of the other aircraft occurs way before there is any collision threat, so the receiver should have no difficulty computing the project path of the other aircraft. ADS-B actually transmits the category of aircraft (i.e. glider, balloon, etc...) so the receiver can get a pretty good hint on the type of maneuvers that can be expected. I can think of three situations where the time involved can be reduced: 1) two gliders approaching head on. At 100 knots each - a 200 knot closing speed - that's only 18 seconds or so to collision. How many seconds of warning do you lose while collecting enough points to make a good estimate of the projected paths - 5 seconds, 10 seconds? I don't know, but I'd prefer to know sooner than later. 2) Ridge or mountain flying, where the transmissions are blocked by the terrain. Once they round the corner of the ridge, there may not be enough time to calculate a projected path. 3) shortened range due to signal blockage by the wings or fuselage. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
On 10/28/2010 3:36 PM, Eric Greenwell wrote:
On 10/28/2010 11:32 AM, Mike Schumann wrote: There's no question that FLARM or ADS-B based systems could have easily prevented the Parowan mid-air. My question is how much you can rely on this type of equipment to accurately warn you of collisions when you are flying in gaggles. Obviously knowing the relative position of other gliders in the gaggle is helpful. I would be very skeptical, however, of putting my faith in FLARM or any other system to accurately warn me of a collision with another glider that was in the same thermal, near my altitude, that was in my blind spot. This situation is addressed at http://www.gliderpilot.org/FlarmFlig...andPerformance where it states that the human eye is better than Flarm. I don't think anyone has claimed Flarm is better in every possible situation, and users and Flarm itself repeatedly state you must still look outside to have the best protection; however, I believe Flarm will indicate there is a glider behind you, something a pilot might not always be aware of, so it still has value in this situation. Transmitting the project path of the aircraft is really only beneficial if the equipment on board the transmitting aircraft has some added information that is not available to the receiver on the transmitting aircraft's intent. With both FLARM and ADS-B systems, the initial visibility of the other aircraft occurs way before there is any collision threat, so the receiver should have no difficulty computing the project path of the other aircraft. ADS-B actually transmits the category of aircraft (i.e. glider, balloon, etc...) so the receiver can get a pretty good hint on the type of maneuvers that can be expected. I can think of three situations where the time involved can be reduced: 1) two gliders approaching head on. At 100 knots each - a 200 knot closing speed - that's only 18 seconds or so to collision. How many seconds of warning do you lose while collecting enough points to make a good estimate of the projected paths - 5 seconds, 10 seconds? I don't know, but I'd prefer to know sooner than later. 2) Ridge or mountain flying, where the transmissions are blocked by the terrain. Once they round the corner of the ridge, there may not be enough time to calculate a projected path. 3) shortened range due to signal blockage by the wings or fuselage. The proper logic on unexpectedly seeing a new target close by without have a chance to compute trajectory is to use a worse case scenario. Granted, having the trajectory as part of the transmission would be helpful in this instance. -- Mike Schumann |
On 10/28/2010 4:03 PM, Mike Schumann wrote:
On 10/28/2010 3:36 PM, Eric Greenwell wrote: I can think of three situations where the time involved can be reduced: 1) two gliders approaching head on. At 100 knots each - a 200 knot closing speed - that's only 18 seconds or so to collision. How many seconds of warning do you lose while collecting enough points to make a good estimate of the projected paths - 5 seconds, 10 seconds? I don't know, but I'd prefer to know sooner than later. 2) Ridge or mountain flying, where the transmissions are blocked by the terrain. Once they round the corner of the ridge, there may not be enough time to calculate a projected path. 3) shortened range due to signal blockage by the wings or fuselage. The proper logic on unexpectedly seeing a new target close by without have a chance to compute trajectory is to use a worse case scenario. Granted, having the trajectory as part of the transmission would be helpful in this instance. And which way do you turn, when you don't know where the threat is going? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
My question is how much you can rely on this type of equipment to accurately warn you of collisions when you are flying in gaggles. In gaggles: Not at all. Period. Simply not possible - and not necessairy, either. |
On 10/28/2010 7:29 AM, Mike Schumann wrote: It would be interesting to get more detailed information on the exact algorithms that FLARM uses in it's collision threat analysis I tend to assume that if there is one thing that the developers want to keep, then it's this algorithm. ;-) But from real life experience, it seem's to work pretty well. It would be interesting, informative, andentertaining if there was a website or application that would let us runIGC files we select in a simulation like this. Entertaining... well... but educative indeed. And it would provide the FLARM developers with a huge test crew for free. |
On Oct 28, 2:14*pm, Eric Greenwell wrote:
This projected path is a key element to the system working properly. Without it, each FLARM unit would have to calculate the path of every nearby glider; with it, each unit only has to calculate one path - it's own. Potentially, it could be using a much higher position rate than once a second to calculate it's projected path. In any case, the result is much better than you might think for a system that transmits once a second. ... You may be underestimating the value of transmitting the projected path. When another glider is first detected, your unit has only one position report and can not determine the flight path from that single point, and it will take several more precious seconds to determine the flight path of the potential threat; however, because the projected path is transmitted every second, your unit immediately knows it. It would be interesting to get more detailed information on the exact algorithms that FLARM uses in it's collision threat analysis and compare this to the actual unit performance in situations where gliders are flying at close distances in formation or in gaggles. * This could also help pilots understand the limitations of these systems so they don't develop a false sense of security in situations where these systems are not reliable. I'm sure the developers have tested their algorithms with thousands of simulations using IGC files from gliders in many situations. The Parowan accident simulation at http://www.gliderpilot.org/Flarm-Par...dairSimulation shows what can be done. It would be interesting, informative, and entertaining if there was a website or application that would let us run IGC files we select in a simulation like this. I'm curious about how Flarm would react in a few situations I've encountered. Doing simulations on a pilot's own files might be more persuasive of the value of Flarm than even the most well-written explanations, and much more easily understood than the algorithms themselves. If you watch the Parowan simulation carefully, you will see that the collision alarm sounds BEFORE the straight-line trajectories intersect. This is because one of the gliders is circling, and the projected trajectory (circling) shows a collision SECONDS before the straight-line trajectories intersect. These additional seconds can be a life-saver. Hope that helps clarify, Best Regards, Dave "YO electric" |
On 10/28/2010 6:14 PM, Dave Nadler wrote:
On Oct 28, 2:14 pm, Eric wrote: This projected path is a key element to the system working properly. Without it, each FLARM unit would have to calculate the path of every nearby glider; with it, each unit only has to calculate one path - it's own. Potentially, it could be using a much higher position rate than once a second to calculate it's projected path. In any case, the result is much better than you might think for a system that transmits once a second. ... You may be underestimating the value of transmitting the projected path. When another glider is first detected, your unit has only one position report and can not determine the flight path from that single point, and it will take several more precious seconds to determine the flight path of the potential threat; however, because the projected path is transmitted every second, your unit immediately knows it. It would be interesting to get more detailed information on the exact algorithms that FLARM uses in it's collision threat analysis and compare this to the actual unit performance in situations where gliders are flying at close distances in formation or in gaggles. This could also help pilots understand the limitations of these systems so they don't develop a false sense of security in situations where these systems are not reliable. I'm sure the developers have tested their algorithms with thousands of simulations using IGC files from gliders in many situations. The Parowan accident simulation at http://www.gliderpilot.org/Flarm-Par...dairSimulation shows what can be done. It would be interesting, informative, and entertaining if there was a website or application that would let us run IGC files we select in a simulation like this. I'm curious about how Flarm would react in a few situations I've encountered. Doing simulations on a pilot's own files might be more persuasive of the value of Flarm than even the most well-written explanations, and much more easily understood than the algorithms themselves. If you watch the Parowan simulation carefully, you will see that the collision alarm sounds BEFORE the straight-line trajectories intersect. This is because one of the gliders is circling, and the projected trajectory (circling) shows a collision SECONDS before the straight-line trajectories intersect. These additional seconds can be a life-saver. Hope that helps clarify, Best Regards, Dave "YO electric" I totally understand the advantage of using the expected trajectory in computing the collision threat. The Parowan situation is an example of a case where an ADS-B based system, with a sophisticated trajectory algorithm in the receiving system would have been just as effective as FLARM. Note: I am aware that such a system probably doesn't exist yet, so let's not start a flame war over that issue. -- Mike Schumann |
On Oct 28, 4:07*pm, Mike Schumann
wrote: On 10/28/2010 6:14 PM, Dave Nadler wrote: On Oct 28, 2:14 pm, Eric *wrote: This projected path is a key element to the system working properly. Without it, each FLARM unit would have to calculate the path of every nearby glider; with it, each unit only has to calculate one path - it's own. Potentially, it could be using a much higher position rate than once a second to calculate it's projected path. In any case, the result is much better than you might think for a system that transmits once a second. ... You may be underestimating the value of transmitting the projected path. When another glider is first detected, your unit has only one position report and can not determine the flight path from that single point, and it will take several more precious seconds to determine the flight path of the potential threat; however, because the projected path is transmitted every second, your unit immediately knows it. It would be interesting to get more detailed information on the exact algorithms that FLARM uses in it's collision threat analysis and compare this to the actual unit performance in situations where gliders are flying at close distances in formation or in gaggles. This could also help pilots understand the limitations of these systems so they don't develop a false sense of security in situations where these systems are not reliable. I'm sure the developers have tested their algorithms with thousands of simulations using IGC files from gliders in many situations. The Parowan accident simulation at http://www.gliderpilot.org/Flarm-Par...dairSimulation shows what can be done. It would be interesting, informative, and entertaining if there was a website or application that would let us run IGC files we select in a simulation like this. I'm curious about how Flarm would react in a few situations I've encountered. Doing simulations on a pilot's own files might be more persuasive of the value of Flarm than even the most well-written explanations, and much more easily understood than the algorithms themselves. If you watch the Parowan simulation carefully, you will see that the collision alarm sounds BEFORE the straight-line trajectories intersect. This is because one of the gliders is circling, and the projected trajectory (circling) shows a collision SECONDS before the straight-line trajectories intersect. These additional seconds can be a life-saver. Hope that helps clarify, Best Regards, Dave "YO electric" I totally understand the advantage of using the expected trajectory in computing the collision threat. *The Parowan situation is an example of a case where an ADS-B based system, with a sophisticated trajectory algorithm in the receiving system would have been just as effective as FLARM. *Note: *I am aware that such a system probably doesn't exist yet, so let's not start a flame war over that issue. -- Mike Schumann Actually I don't think that's necessarily true Mike. There potentially is a difference in some critical situations between each aircraft estimating the other aircraft's projected path and having each aircraft send the other it's on-board estimated path. In the first case there is no way to close the loop on path estimation differences between the two aircraft - that is, my estimate of where you are going can differ from your estimate of where you are going, and vice versa. It may in fact be better to exchange projected paths to take the biases out of the system. There also may be lag effects on projected flight path changes due to maneuvering. It's quite possible that my onboard system will be faster to include maneuvering effects on the projected path than trying to piece it together from simple GPS location and velocity transmissions. The thing I found particularly impressive about the Parowan demonstration was how both Flarm units gave nearly identical, complementary warnings. I'm not sure that would have been the case using ADS-B on-board estimations of the other glider's path. It's even worse if the two ADS-B systems use different algorithms. Flarm and PowerFlarm solve this problem. 9B |
On Oct 28, 9:19*pm, Andy wrote:
Also, to clarify, ADS-B does no path estimation of its own. That function either would have to be added into an ADS-B unit by the OEM, similar to the way Flarm does today - unlikely to be done in a glider- specific way IMO - OR, it would have to be done by a separate external device, perhaps a navigation computer/software like Oudie, WinPilot, SN-10. For it to be effective manufacturers would all have to agree to use the same algorithm, which also seems unlikely, unless they all adopt the Flarm algorithm. That seems somewhat unlikely too, since I don't think Flarm would want to start splintering how their algorithms get used by splitting out the Flarm link technology from the collision algorithm (which would have to be modified to accommodate the differences in how path estimations get generated - with unpredictable results). PLUS the external device OEM's would have to adapt to using ADS-B inputs - another standards issue. No matter how hard I try, it seems highly improbable that you will be able to stitch together a satisfactory collision avoidance system for gliders using ADS-B technology developed for general aviation. You'd have to be satisfied with the simple functionality offered by ADS-B - which would be fine if you generally come into conflict with GA and airliners more often than other gliders, but there are a bunch of us for whom the opposite is true. Then the problem becomes some gliders using Flarm and others using ADS-B, you lose some of the Flarm benefits of path estimation for the non-Flarm gliders. 9B 9B |
On Oct 28, 10:29*am, Mike Schumann
wrote: I'm not an expert on either FLARM or ADS-B... -- Mike Schumann Finally, something we can all agree on ;-) See ya, Dave "YO electric" |
Flarm in the US | Steve Freeman | Soaring | 163 | August 15th 10 12:12 AM |
Reflections on good and evil | [email protected] | Piloting | 6 | April 18th 06 08:48 PM |
FLARM | Robert Hart | Soaring | 50 | March 16th 06 11:20 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
B29 - "Necessary Evil" | Matt Tauber | Military Aviation | 30 | August 28th 03 10:35 AM |
