FLARM.....for good, or evil??
Old October 28th 10, 07:14 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default FLARM.....for good, or evil??
On 10/28/2010 7:29 AM, Mike Schumann wrote:
On 10/27/2010 11:16 PM, Eric Greenwell wrote:
This projected path is a key element to the system working properly.
Without it, each FLARM unit would have to calculate the path of every
nearby glider; with it, each unit only has to calculate one path - it's
own. Potentially, it could be using a much higher position rate than
once a second to calculate it's projected path. In any case, the result
is much better than you might think for a system that transmits once a
second.
Does ADS-B transmit a projected path, or just position?
I'm not an expert on either FLARM or ADS-B. I believe that ADS-B
currently only transmits absolute position. Future enhancements might
transmit trajectory, which would be most useful for aircraft with
Flight Management Systems where the trajectory is well defined and
could be used by the ATC system for airspace management.
Regardless of whether or not the trajectory is transmitted, a
sophisticated receiving system (either FLARM or ADS-B based), can
remember each aircraft's position data and compute it's current
trajectory. While a glider might be moving 75 ft / sec, this is
obviously in a relatively forward direction.
You may be underestimating the value of transmitting the projected path.
When another glider is first detected, your unit has only one position
report and can not determine the flight path from that single point, and
it will take several more precious seconds to determine the flight path
of the potential threat; however, because the projected path is
transmitted every second, your unit immediately knows it.
Neither the transmitting nor the receiving FLARM or ADS-B system can
predict an abrupt change in course that a pilot flying manually might
command. However, every aircraft has physical limits on roll rates,
etc. that restrain the potential change in direction that can occur
within the one second update interval of these systems. As a result,
the systems can, theoretically, compute a pear shaped threat envelope
for each aircraft and limit collision warnings to those situations
where these envelopes intersect.
It would be interesting to get more detailed information on the exact
algorithms that FLARM uses in it's collision threat analysis and
compare this to the actual unit performance in situations where
gliders are flying at close distances in formation or in gaggles.
This could also help pilots understand the limitations of these
systems so they don't develop a false sense of security in situations
where these systems are not reliable.
I'm sure the developers have tested their algorithms with thousands of
simulations using IGC files from gliders in many situations. The Parowan
accident simulation at
http://www.gliderpilot.org/Flarm-Par...dairSimulation
shows what can be done. It would be interesting, informative, and
entertaining if there was a website or application that would let us run
IGC files we select in a simulation like this. I'm curious about how
Flarm would react in a few situations I've encountered. Doing
simulations on a pilot's own files might be more persuasive of the value
of Flarm than even the most well-written explanations, and much more
easily understood than the algorithms themselves.
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz
Old October 28th 10, 07:32 PM posted to rec.aviation.soaring
Mike Schumann
second.
gliders are flying at close distances in formation or in gaggles. This
could also help pilots understand the limitations of these systems so
they don't develop a false sense of security in situations where these
There's no question that FLARM or ADS-B based systems could have easily
prevented the Parowan mid-air. My question is how much you can rely on
this type of equipment to accurately warn you of collisions when you are
flying in gaggles.
Obviously knowing the relative position of other gliders in the gaggle
is helpful. I would be very skeptical, however, of putting my faith in
FLARM or any other system to accurately warn me of a collision with
another glider that was in the same thermal, near my altitude, that was
in my blind spot.
Transmitting the project path of the aircraft is really only beneficial
if the equipment on board the transmitting aircraft has some added
information that is not available to the receiver on the transmitting
aircraft's intent.
With both FLARM and ADS-B systems, the initial visibility of the other
aircraft occurs way before there is any collision threat, so the
receiver should have no difficulty computing the project path of the
other aircraft. ADS-B actually transmits the category of aircraft (i.e.
glider, balloon, etc...) so the receiver can get a pretty good hint on
the type of maneuvers that can be expected.
Mike Schumann
Old October 28th 10, 08:36 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
easily prevented the Parowan mid-air. My question is how much you can
rely on this type of equipment to accurately warn you of collisions
when you are flying in gaggles.
in FLARM or any other system to accurately warn me of a collision with
was in my blind spot.
This situation is addressed at
http://www.gliderpilot.org/FlarmFlig...andPerformance
where it states that the human eye is better than Flarm. I don't think
anyone has claimed Flarm is better in every possible situation, and
users and Flarm itself repeatedly state you must still look outside to
have the best protection; however, I believe Flarm will indicate there
is a glider behind you, something a pilot might not always be aware of,
so it still has value in this situation.
beneficial if the equipment on board the transmitting aircraft has
some added information that is not available to the receiver on the
transmitting aircraft's intent.
(i.e. glider, balloon, etc...) so the receiver can get a pretty good
hint on the type of maneuvers that can be expected.
I can think of three situations where the time involved can be reduced:
1) two gliders approaching head on. At 100 knots each - a 200 knot
closing speed - that's only 18 seconds or so to collision. How many
seconds of warning do you lose while collecting enough points to make a
good estimate of the projected paths - 5 seconds, 10 seconds? I don't
know, but I'd prefer to know sooner than later.
2) Ridge or mountain flying, where the transmissions are blocked by the
terrain. Once they round the corner of the ridge, there may not be
enough time to calculate a projected path.
3) shortened range due to signal blockage by the wings or fuselage.
Old October 29th 10, 12:03 AM posted to rec.aviation.soaring
Mike Schumann
The proper logic on unexpectedly seeing a new target close by without
have a chance to compute trajectory is to use a worse case scenario.
Granted, having the trajectory as part of the transmission would be
helpful in this instance.
Mike Schumann
Old October 29th 10, 03:38 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
And which way do you turn, when you don't know where the threat is going?
Old October 29th 10, 07:02 AM posted to rec.aviation.soaring
Mike Schumann
It appears that ADS-B does transmit the location as well as the
instantaneous velocity vector each second, so if you have a graphical
display, you will be able to see the orientation and physical location
of the aircraft immediately. It doesn't currently transmit any turn
rate info. I don't know if it gives you any data on rate of climb /
descent.
A basic FLARM unit, without a graphical display, won't give you any
hints of which direction the target is moving in. It will only give you
a rough idea of where the threat target is, so you have to use your eyes
and judgment to take evasive action.
I suspect that a graphical display is primarily useful to identify the
location and course info for aircraft in your area before you get into
an alarm condition. Once the alarm goes off, you should probably be
looking outside. (Not having flown with these types of units, others
probably have better insights into this).
Mike Schumann
Old October 28th 10, 08:39 PM posted to rec.aviation.soaring
John Smith
flying in gaggles.
In gaggles: Not at all. Period. Simply not possible - and not
necessairy, either.
Old October 28th 10, 07:45 PM posted to rec.aviation.soaring
John Smith
I tend to assume that if there is one thing that the developers want to
keep, then it's this algorithm. ;-)
But from real life experience, it seem's to work pretty well.
It would be interesting, informative, andentertaining if there was
a website or application that would let us runIGC files we select
Entertaining... well... but educative indeed. And it would provide the
FLARM developers with a huge test crew for free.
Old October 28th 10, 11:14 PM posted to rec.aviation.soaring
Dave Nadler
second.
gliders are flying at close distances in formation or in gaggles. *
If you watch the Parowan simulation carefully, you will see that
the collision alarm sounds BEFORE the straight-line trajectories
intersect. This is because one of the gliders is circling, and the
projected trajectory (circling) shows a collision SECONDS
before the straight-line trajectories intersect.
These additional seconds can be a life-saver.
Hope that helps clarify,
Best Regards, Dave "YO electric"
Old October 29th 10, 12:07 AM posted to rec.aviation.soaring
Mike Schumann
second.
I totally understand the advantage of using the expected trajectory in
computing the collision threat. The Parowan situation is an example of
a case where an ADS-B based system, with a sophisticated trajectory
algorithm in the receiving system would have been just as effective as
FLARM. Note: I am aware that such a system probably doesn't exist yet,
so let's not start a flame war over that issue.
Mike Schumann
Flarm in the US Steve Freeman Soaring 163 August 15th 10 12:12 AM
Reflections on good and evil [email protected] Piloting 6 April 18th 06 08:48 PM
FLARM Robert Hart Soaring 50 March 16th 06 11:20 PM
B29 - "Necessary Evil" Matt Tauber Military Aviation 30 August 28th 03 10:35 AM
