Flarm and stealth
Old October 28th 10, 11:51 PM posted to rec.aviation.soaring
Jerzy
Default Flarm and stealth
On Oct 28, 5:53*pm, Peter Scholz
Am 28.10.2010 21:53, John Cochrane wrote:
As the US gets ready for the arrival of flarm, a big question on many
US pilot's minds is, what about stealth mode? From an armchair
piloting point of view, it seems that seeing gliders in a several km
range, with *climb rates attached, could be a major competitive
issue. *With this in mind, whether to require stealth mode in
competitions is being actively debated.
I'd like to hear from our European friends with lots of contest
experience, just how this is playing out. Do you find that non-stealth
displays are in fact very useful? Where stealth mode is either not
required or not enforced (WGC), is it becoming de rigeur to have a
secondary display and follow the gaggle with your flarm? Or are the
theoretical advantages overstated, and in the real world flarm
leeching isn't that big an issue; you're better off looking out the
window and seeing who is racked up in a tight turn?
Where stealth mode is required, is it being enforced, and how much of
a pain is that proving to be? Certainly the obvious protocol,
involving cockpit checks for hidden flarms, daily submission of flight
logs, and penalties for absence of such logs, seems rather onerous.
Thanks in advance. We are fortunate to have your experience so we
don't have to rethink this all from scratch!
John Cochrane
In the (regional) competitions that I attended, there was no requirement
of Flarm stealth mode, and almost all pilots had their Flarm configured
in open mode. So everyone was in fact free to hide himself from others
at the cost of not receiving tactical informations himself.
I have no knowledge of a competition here in Germany where the rules
required stealth mode, but there may have been such competitions that
I'm not aware of. Others might want to jump in here.
I have the butterfly display installed in my glider, and I personally
found it quite useful to get the information if a glider circling 3km in
front of me actually had a strong or weak lift, or to get the info that
in 10km distance there was a lift that I could reach straight on,
without having seen the glider that send out the signal.
In competitions this info might be (relatively) less valuable, because
one (at least me) always tends to be in the proximity of a few other
competitors, so normally the Flarm tactical information is only used to
confirm my decision made on 'gut feeling'.
It is much more valuale on normal X/C flights, where I often get
information about thermals 10-15km ahead. This quite often lead to
decisions that I probably wouldn't have made without that information.
Peter Scholz
ASW24 JE- Hide quoted text -
- Show quoted text -
I had Flarm connected to ClearNav during 2010 WGC it worked perfect,
most 18 meter class pilots didn't have stealth mode, climb rate of
gliders was useless. The most important part was that I could see on
the screen gliders behind me and in my blind spots in addition to
warning about collision. It was eye opener how many gliders I didn't
see till Flarm warning. Flying in thermal with 50+ gliders was no
problem, no excessive warnings, just as needed.
Jerzy XG
Old October 28th 10, 11:54 PM posted to rec.aviation.soaring
Dave Nadler
John Cochrane
Peter Scholz
gliders *was useless. The most important part was that I could see on
Jerzy XG
Thanks Jerzy - Can you tell us if you had "competition mode" set ?
Best Regards, Dave "YO electric"
Old October 29th 10, 12:41 AM posted to rec.aviation.soaring
Jerzy
John Cochrane
decisions that I probably wouldn't have made without that information..
Peter Scholz
Jerzy XG
Best Regards, Dave "YO electric"- Hide quoted text -
I didn't set competition mode
Jerzy
Old October 29th 10, 01:01 AM posted to rec.aviation.soaring
Andrej Kolar[_3_]
whether to require stealth mode in competitions is being actively debated.
This is how Flarm works:
1. If you see another Flarm then the other Flarm sees you.
2. If you are in stealth mode then others don't see you but you also
don't see others (but you do still get the alarm when there is
immediate danger of collision)
Given the above it is actually pilot's decision whether he will choose
stealth mode or not. If he doesn't he has the opportunity to see what
others are doing. If he does enable stealth mode then he doesn't see
the other gliders around him.
I would say that 90% of the pilots in competition leaves Flarm in
normal mode. I certainly do. Either way it's not a problem and both is
completely fair for all pilots involved.
Andrej Kolar
glider pilots use
http://www.naviter.com
Old October 29th 10, 06:16 AM posted to rec.aviation.soaring
RW[_2_]
John Cochrane
Peter Scholz
Jerzy XG
Dave,
In Parowan in blue and over Nevada unlandable desert, Flarm would
improve safety( many gliders got damaged).But for all other occasions
this idea would get more pilots buy Power Flarm.
Win, win situation.
GPS made us safer,Flarm can make us safer,pilots reports can make us
safer,infrared thermal vision would make us safer,Power Flarm with
transponder would make us safer..
I think WGC (both in Szeged and in Prievidza) didn't force anybody
to use stealth mode was to increase safety.
I don't have Flarm yet.
Ryszard
Flarm in the US Steve Freeman Soaring 163 August 15th 10 12:12 AM
Chinese J-XX ''stealth fighter''. - File 1 of 1 - Chinese J-XX ''stealth fighter''.jpg (1/1) Troy[_2_] Aviation Photos 10 June 10th 08 01:41 PM
IGC FLARM DLL [email protected] Soaring 1 March 25th 08 11:27 AM
FLARM Robert Hart Soaring 50 March 16th 06 11:20 PM
FLARM John Galloway Soaring 9 November 27th 04 07:16 AM
