FLARM.....for good, or evil??
Old October 29th 10, 12:07 AM posted to rec.aviation.soaring
Mike Schumann
Default FLARM.....for good, or evil??
On 10/28/2010 6:14 PM, Dave Nadler wrote:
On Oct 28, 2:14 pm, Eric wrote:
This projected path is a key element to the system working properly.
Without it, each FLARM unit would have to calculate the path of every
nearby glider; with it, each unit only has to calculate one path - it's
own. Potentially, it could be using a much higher position rate than
once a second to calculate it's projected path. In any case, the result
is much better than you might think for a system that transmits once a
second.
You may be underestimating the value of transmitting the projected path.
When another glider is first detected, your unit has only one position
report and can not determine the flight path from that single point, and
it will take several more precious seconds to determine the flight path
of the potential threat; however, because the projected path is
transmitted every second, your unit immediately knows it.
It would be interesting to get more detailed information on the exact
algorithms that FLARM uses in it's collision threat analysis and
compare this to the actual unit performance in situations where
gliders are flying at close distances in formation or in gaggles.
This could also help pilots understand the limitations of these
systems so they don't develop a false sense of security in situations
where these systems are not reliable.
I'm sure the developers have tested their algorithms with thousands of
simulations using IGC files from gliders in many situations. The Parowan
accident simulation at
http://www.gliderpilot.org/Flarm-Par...dairSimulation
shows what can be done. It would be interesting, informative, and
entertaining if there was a website or application that would let us run
IGC files we select in a simulation like this. I'm curious about how
Flarm would react in a few situations I've encountered. Doing
simulations on a pilot's own files might be more persuasive of the value
of Flarm than even the most well-written explanations, and much more
easily understood than the algorithms themselves.
If you watch the Parowan simulation carefully, you will see that
the collision alarm sounds BEFORE the straight-line trajectories
intersect. This is because one of the gliders is circling, and the
projected trajectory (circling) shows a collision SECONDS
before the straight-line trajectories intersect.
These additional seconds can be a life-saver.
Hope that helps clarify,
Best Regards, Dave "YO electric"
I totally understand the advantage of using the expected trajectory in
computing the collision threat. The Parowan situation is an example of
a case where an ADS-B based system, with a sophisticated trajectory
algorithm in the receiving system would have been just as effective as
FLARM. Note: I am aware that such a system probably doesn't exist yet,
so let's not start a flame war over that issue.
Mike Schumann
Old October 29th 10, 05:19 AM posted to rec.aviation.soaring
Andy[_10_]
On Oct 28, 4:07*pm, Mike Schumann
second.
computing the collision threat. *The Parowan situation is an example of
FLARM. *Note: *I am aware that such a system probably doesn't exist yet,
Mike Schumann
Actually I don't think that's necessarily true Mike. There potentially
is a difference in some critical situations between each aircraft
estimating the other aircraft's projected path and having each
aircraft send the other it's on-board estimated path. In the first
case there is no way to close the loop on path estimation differences
between the two aircraft - that is, my estimate of where you are going
can differ from your estimate of where you are going, and vice versa.
It may in fact be better to exchange projected paths to take the
biases out of the system. There also may be lag effects on projected
flight path changes due to maneuvering. It's quite possible that my
onboard system will be faster to include maneuvering effects on the
projected path than trying to piece it together from simple GPS
location and velocity transmissions.
The thing I found particularly impressive about the Parowan
demonstration was how both Flarm units gave nearly identical,
complementary warnings. I'm not sure that would have been the case
using ADS-B on-board estimations of the other glider's path. It's even
worse if the two ADS-B systems use different algorithms. Flarm and
PowerFlarm solve this problem.
9B
Old October 29th 10, 05:51 AM posted to rec.aviation.soaring
Andy[_10_]
On Oct 28, 9:19*pm, Andy wrote:
Also, to clarify, ADS-B does no path estimation of its own. That
function either would have to be added into an ADS-B unit by the OEM,
similar to the way Flarm does today - unlikely to be done in a glider-
specific way IMO - OR, it would have to be done by a separate external
device, perhaps a navigation computer/software like Oudie, WinPilot,
SN-10. For it to be effective manufacturers would all have to agree to
use the same algorithm, which also seems unlikely, unless they all
adopt the Flarm algorithm. That seems somewhat unlikely too, since I
don't think Flarm would want to start splintering how their algorithms
get used by splitting out the Flarm link technology from the collision
algorithm (which would have to be modified to accommodate the
differences in how path estimations get generated - with unpredictable
results). PLUS the external device OEM's would have to adapt to using
ADS-B inputs - another standards issue.
No matter how hard I try, it seems highly improbable that you will be
able to stitch together a satisfactory collision avoidance system for
gliders using ADS-B technology developed for general aviation. You'd
have to be satisfied with the simple functionality offered by ADS-B -
which would be fine if you generally come into conflict with GA and
airliners more often than other gliders, but there are a bunch of us
for whom the opposite is true. Then the problem becomes some gliders
using Flarm and others using ADS-B, you lose some of the Flarm
benefits of path estimation for the non-Flarm gliders.
9B
9B
Old October 29th 10, 07:20 AM posted to rec.aviation.soaring
Mike Schumann
9B
9B
You are probably correct that no one is going to beat FLARM in an
optimized collision avoidance solution for high density glider
environments. That's obviously their focus and they are good at it.
However, most recreational, non-contest pilots, primarily need a system
that will reliably alert them to other aircraft in their general
vicinity. If I enter a thermal and know that there are 3 other aircraft
in the area, and I only see two, I'm going to abort and go elsewhere. A
contest pilot obviously wants more data.
What is interesting about the Parowan situation is that this was not a
gaggle of gliders. It was two gliders who apparently did not have a
proper appreciation that they were near each other. A simple graphical
display that showed their relative positions, with a very simple
collision avoidance algorithm, or some form of auditory announcement
could have prevented this accident. That's not to say that the FLARM
simulation was not impressive.
Mike Schumann
Old October 29th 10, 10:11 AM posted to rec.aviation.soaring
Andy[_10_]
On Oct 28, 11:20*pm, Mike Schumann
which would be fine if you *generally come into conflict with GA and
9B
9B
environments. *That's obviously their focus and they are good at it.
vicinity. *If I enter a thermal and know that there are 3 other aircraft
in the area, and I only see two, I'm going to abort and go elsewhere. *A
gaggle of gliders. *It was two gliders who apparently did not have a
proper appreciation that they were near each other. *A simple graphical
could have prevented this accident. *That's not to say that the FLARM
Mike Schumann
I played back the igc files from all the gliders flying that day and
can say that your speculation is not really supported by the facts.
Actually there were a number of gliders in that thermal - as it turns
out I passed right by it about a minute after the collision. There was
also a lot of non-thermalling traffic going in both directions at the
time, mostly within a pretty narrow altitude band within a thousand
feet or two of cloud base under a long cloud street.
An issue in these kinds of situations is that you can fixate on a
couple of gliders a bit higher in the thermal and miss the one
entering on a collision course with you at nearly the same time. A
cruder collision system has the potential to false alarm on too many
non-threats and on multiple gliders in the vicinity, making it hard
for the pilot to sort out which one is the real threat. Or it can
falsely identify a non-threat and mask the one that is really the
problem.
At this point I'm not at all sure why you'd pick straight ADS-B
(especially UAT) over something like PowerFlarm. The arguments keep
changing and hard as I try I can't find one that holds water when I
really run through all the issues. I think ADS-B in the long run is a
decent upgrade over PCAS, but PowerFlarm is more cost efficient and
more effective as a collision warning system, plus it has ADS-B in and
PCAS build in.
Also, I'll bet dollars to donuts that PowerFlarm gets FCC approval
well prior to ADS-B getting out from under the STC requirement.
9B
Old October 29th 10, 04:32 PM posted to rec.aviation.soaring
Mike Schumann
On 10/29/2010 4:11 AM, Andy wrote:
On Oct 28, 11:20 pm, Mike
9B
9B
Mike Schumann
problem.
PCAS build in.
9B
Contrary to what everyone seems to think, I am not fundamentally opposed
to PowerFLARM. I understand the sophistication of its collision
avoidance logic, and it is very impressive and useful. I totally get
the necessity for reducing false alarms, so that the alarms that are
issued are meaningful.
My disappointment with PowerFLARM is the lack of a clear plan to take
advantage of the extensive ADS-B ground station infrastructure that will
cover much of the US in the next year or so, to provide the same level
of collision avoidance to transponder equipped GA and commercial traffic
that is available between PowerFLARM equipped gliders.
Granted, the PCAS capability built into PowerFLARM gives you some level
of protection, but you have no information on relative direction of the
threat, and a very crude estimate of its range. I find it very
difficult to understand how PowerFLARM will be able to suppress PCAS
initiated alarms from Mode C transponder equipped gliders in a gaggle,
while simultaneously still generating PCAS alarms from other GA aircraft
that also in the area.
The built-in 1090ES ADS-B In capability is great, but that doesn't
provide any ground station originated data unless you are transmitting
ADS-B out. The new Trig Mode S transponders provide this capability,
but require a GPS source. Is PowerFLARM going to provide this, or what
is the plan for glider pilots to end up with a complete ADS-B compatible
solution?
Mike Schumann
Old October 29th 10, 04:52 PM posted to rec.aviation.soaring
mattm[_2_]
On Oct 29, 11:32*am, Mike Schumann
9B
9B
Mike Schumann
entering on a collision course with you at nearly the same time. *A
problem.
PCAS build in.
9B
to PowerFLARM. *I understand the sophistication of its collision
avoidance logic, and it is very impressive and useful. *I totally get
threat, and a very crude estimate of its range. *I find it very
ADS-B out. *The new Trig Mode S transponders provide this capability,
but require a GPS source. *Is PowerFLARM going to provide this, or what
solution?
Mike Schumann
Somewhere earlier in this thread someone noted that they were planning
on doing that soon. I plan on doing it myself, except that the $4K
pricetag
means it will take a while to save up for it. Also, the TSO fiasco
throws
a big question mark over the ADS-B out part of the equation. My plane
(ASW-19) is type certified in the US, so the TSO requirement applies
to me.
-- Matt
Old October 29th 10, 05:37 PM posted to rec.aviation.soaring
kirk.stant
Mike, I think you do not understand the fundamental difference between
ADS-B and FLARM.
ADS-B is designed for aircraft that do not want to fly close to each
other, and want/need long range situational awareness. Thats probably
where the whole ground station setup comes from - with all it's
disadvantages (coverage, latency, accuracy, etc.) It's a great system
for IFR traffic, and for GA flyers out sightseeing, but it sucks for
gliders in a gaggle or running a ridge.
FLARM, on the other hand, is specifically designed for aircraft
(gliders, helicopters) that often want to fly close to each other,
safely. In a gaggle, running a ridge, heading for the really nice Cu
near the glider field, on the Whites - gliders inherently will
congregate to find the best lift. That is the threat environment
FLARM is designed to cope with. And it's a proven item.
In a perfect world, there would be a SuperFLARM that would add some
sort of ADS-B in/out capability, so the benefits of both would be
present. But until then, FLARM addresses the immediate concern of
many, if not most glider pilots the best. A PowerFLARM, combined with
a mode s transponder, gives a glider most of the useful threat warning
capability of a full up ADS-B setup, and all the advantages of FLARM -
if FLARM is widely adopted by the US soaring community.
But if no-one gets ADS-b in their gliders (show of hands out there?),
then it's of no use in preventing the biggest historical threat -
glider on glider collisions.
I'm planning on getting a PowerFLARM next season to replace my PCAS.
I hope you will to, while waiting for your ADS-B to be installed.
Kirk
66
Flarm in the US Steve Freeman Soaring 163 August 15th 10 12:12 AM
Reflections on good and evil [email protected] Piloting 6 April 18th 06 08:48 PM
FLARM Robert Hart Soaring 50 March 16th 06 11:20 PM
B29 - "Necessary Evil" Matt Tauber Military Aviation 30 August 28th 03 10:35 AM
