On Oct 28, 11:20*pm, Mike Schumann
wrote: On 10/29/2010 12:51 AM, Andy wrote: On Oct 28, 9:19 pm, *wrote: Also, to clarify, ADS-B does no path estimation of its own. That function either would have to be added into an ADS-B unit by the OEM, similar to the way Flarm does today - unlikely to be done in a glider- specific way IMO - OR, it would have to be done by a separate external device, perhaps a navigation computer/software like Oudie, WinPilot, SN-10. For it to be effective manufacturers would all have to agree to use the same algorithm, which also seems unlikely, unless they all adopt the Flarm algorithm. That seems somewhat unlikely too, since I don't think Flarm would want to start splintering how their algorithms get used by splitting out the Flarm link technology from the collision algorithm (which would have to be modified to accommodate the differences in how path estimations get generated - with unpredictable results). PLUS the external device OEM's would have to adapt to using ADS-B inputs - another standards issue. No matter how hard I try, it seems highly improbable that you will be able to stitch together a satisfactory collision avoidance system for gliders using ADS-B technology developed for general aviation. You'd have to be satisfied with the simple functionality offered by ADS-B - which would be fine if you *generally come into conflict with GA and airliners more often than other gliders, but there are a bunch of us for whom the opposite is true. Then the problem becomes some gliders using Flarm and others using ADS-B, you lose some of the Flarm benefits of path estimation for the non-Flarm gliders. 9B 9B You are probably correct that no one is going to beat FLARM in an optimized collision avoidance solution for high density glider environments. *That's obviously their focus and they are good at it. However, most recreational, non-contest pilots, primarily need a system that will reliably alert them to other aircraft in their general vicinity. *If I enter a thermal and know that there are 3 other aircraft in the area, and I only see two, I'm going to abort and go elsewhere. *A contest pilot obviously wants more data. What is interesting about the Parowan situation is that this was not a gaggle of gliders. *It was two gliders who apparently did not have a proper appreciation that they were near each other. *A simple graphical display that showed their relative positions, with a very simple collision avoidance algorithm, or some form of auditory announcement could have prevented this accident. *That's not to say that the FLARM simulation was not impressive. -- Mike Schumann I played back the igc files from all the gliders flying that day and can say that your speculation is not really supported by the facts. Actually there were a number of gliders in that thermal - as it turns out I passed right by it about a minute after the collision. There was also a lot of non-thermalling traffic going in both directions at the time, mostly within a pretty narrow altitude band within a thousand feet or two of cloud base under a long cloud street. An issue in these kinds of situations is that you can fixate on a couple of gliders a bit higher in the thermal and miss the one entering on a collision course with you at nearly the same time. A cruder collision system has the potential to false alarm on too many non-threats and on multiple gliders in the vicinity, making it hard for the pilot to sort out which one is the real threat. Or it can falsely identify a non-threat and mask the one that is really the problem. At this point I'm not at all sure why you'd pick straight ADS-B (especially UAT) over something like PowerFlarm. The arguments keep changing and hard as I try I can't find one that holds water when I really run through all the issues. I think ADS-B in the long run is a decent upgrade over PCAS, but PowerFlarm is more cost efficient and more effective as a collision warning system, plus it has ADS-B in and PCAS build in. Also, I'll bet dollars to donuts that PowerFlarm gets FCC approval well prior to ADS-B getting out from under the STC requirement. 9B |
On 10/29/2010 4:11 AM, Andy wrote:
On Oct 28, 11:20 pm, Mike wrote: On 10/29/2010 12:51 AM, Andy wrote: On Oct 28, 9:19 pm, wrote: Also, to clarify, ADS-B does no path estimation of its own. That function either would have to be added into an ADS-B unit by the OEM, similar to the way Flarm does today - unlikely to be done in a glider- specific way IMO - OR, it would have to be done by a separate external device, perhaps a navigation computer/software like Oudie, WinPilot, SN-10. For it to be effective manufacturers would all have to agree to use the same algorithm, which also seems unlikely, unless they all adopt the Flarm algorithm. That seems somewhat unlikely too, since I don't think Flarm would want to start splintering how their algorithms get used by splitting out the Flarm link technology from the collision algorithm (which would have to be modified to accommodate the differences in how path estimations get generated - with unpredictable results). PLUS the external device OEM's would have to adapt to using ADS-B inputs - another standards issue. No matter how hard I try, it seems highly improbable that you will be able to stitch together a satisfactory collision avoidance system for gliders using ADS-B technology developed for general aviation. You'd have to be satisfied with the simple functionality offered by ADS-B - which would be fine if you generally come into conflict with GA and airliners more often than other gliders, but there are a bunch of us for whom the opposite is true. Then the problem becomes some gliders using Flarm and others using ADS-B, you lose some of the Flarm benefits of path estimation for the non-Flarm gliders. 9B 9B You are probably correct that no one is going to beat FLARM in an optimized collision avoidance solution for high density glider environments. That's obviously their focus and they are good at it. However, most recreational, non-contest pilots, primarily need a system that will reliably alert them to other aircraft in their general vicinity. If I enter a thermal and know that there are 3 other aircraft in the area, and I only see two, I'm going to abort and go elsewhere. A contest pilot obviously wants more data. What is interesting about the Parowan situation is that this was not a gaggle of gliders. It was two gliders who apparently did not have a proper appreciation that they were near each other. A simple graphical display that showed their relative positions, with a very simple collision avoidance algorithm, or some form of auditory announcement could have prevented this accident. That's not to say that the FLARM simulation was not impressive. -- Mike Schumann I played back the igc files from all the gliders flying that day and can say that your speculation is not really supported by the facts. Actually there were a number of gliders in that thermal - as it turns out I passed right by it about a minute after the collision. There was also a lot of non-thermalling traffic going in both directions at the time, mostly within a pretty narrow altitude band within a thousand feet or two of cloud base under a long cloud street. An issue in these kinds of situations is that you can fixate on a couple of gliders a bit higher in the thermal and miss the one entering on a collision course with you at nearly the same time. A cruder collision system has the potential to false alarm on too many non-threats and on multiple gliders in the vicinity, making it hard for the pilot to sort out which one is the real threat. Or it can falsely identify a non-threat and mask the one that is really the problem. At this point I'm not at all sure why you'd pick straight ADS-B (especially UAT) over something like PowerFlarm. The arguments keep changing and hard as I try I can't find one that holds water when I really run through all the issues. I think ADS-B in the long run is a decent upgrade over PCAS, but PowerFlarm is more cost efficient and more effective as a collision warning system, plus it has ADS-B in and PCAS build in. Also, I'll bet dollars to donuts that PowerFlarm gets FCC approval well prior to ADS-B getting out from under the STC requirement. 9B Contrary to what everyone seems to think, I am not fundamentally opposed to PowerFLARM. I understand the sophistication of its collision avoidance logic, and it is very impressive and useful. I totally get the necessity for reducing false alarms, so that the alarms that are issued are meaningful. My disappointment with PowerFLARM is the lack of a clear plan to take advantage of the extensive ADS-B ground station infrastructure that will cover much of the US in the next year or so, to provide the same level of collision avoidance to transponder equipped GA and commercial traffic that is available between PowerFLARM equipped gliders. Granted, the PCAS capability built into PowerFLARM gives you some level of protection, but you have no information on relative direction of the threat, and a very crude estimate of its range. I find it very difficult to understand how PowerFLARM will be able to suppress PCAS initiated alarms from Mode C transponder equipped gliders in a gaggle, while simultaneously still generating PCAS alarms from other GA aircraft that also in the area. The built-in 1090ES ADS-B In capability is great, but that doesn't provide any ground station originated data unless you are transmitting ADS-B out. The new Trig Mode S transponders provide this capability, but require a GPS source. Is PowerFLARM going to provide this, or what is the plan for glider pilots to end up with a complete ADS-B compatible solution? -- Mike Schumann |
On Oct 29, 11:32*am, Mike Schumann
wrote: On 10/29/2010 4:11 AM, Andy wrote: On Oct 28, 11:20 pm, Mike wrote: On 10/29/2010 12:51 AM, Andy wrote: On Oct 28, 9:19 pm, * *wrote: Also, to clarify, ADS-B does no path estimation of its own. That function either would have to be added into an ADS-B unit by the OEM, similar to the way Flarm does today - unlikely to be done in a glider- specific way IMO - OR, it would have to be done by a separate external device, perhaps a navigation computer/software like Oudie, WinPilot, SN-10. For it to be effective manufacturers would all have to agree to use the same algorithm, which also seems unlikely, unless they all adopt the Flarm algorithm. That seems somewhat unlikely too, since I don't think Flarm would want to start splintering how their algorithms get used by splitting out the Flarm link technology from the collision algorithm (which would have to be modified to accommodate the differences in how path estimations get generated - with unpredictable results). PLUS the external device OEM's would have to adapt to using ADS-B inputs - another standards issue. No matter how hard I try, it seems highly improbable that you will be able to stitch together a satisfactory collision avoidance system for gliders using ADS-B technology developed for general aviation. You'd have to be satisfied with the simple functionality offered by ADS-B - which would be fine if you *generally come into conflict with GA and airliners more often than other gliders, but there are a bunch of us for whom the opposite is true. Then the problem becomes some gliders using Flarm and others using ADS-B, you lose some of the Flarm benefits of path estimation for the non-Flarm gliders. 9B 9B You are probably correct that no one is going to beat FLARM in an optimized collision avoidance solution for high density glider environments. *That's obviously their focus and they are good at it. However, most recreational, non-contest pilots, primarily need a system that will reliably alert them to other aircraft in their general vicinity. *If I enter a thermal and know that there are 3 other aircraft in the area, and I only see two, I'm going to abort and go elsewhere. *A contest pilot obviously wants more data. What is interesting about the Parowan situation is that this was not a gaggle of gliders. *It was two gliders who apparently did not have a proper appreciation that they were near each other. *A simple graphical display that showed their relative positions, with a very simple collision avoidance algorithm, or some form of auditory announcement could have prevented this accident. *That's not to say that the FLARM simulation was not impressive. -- Mike Schumann I played back the igc files from all the gliders flying that day and can say that your speculation is not really supported by the facts. Actually there were a number of gliders in that thermal - as it turns out I passed right by it about a minute after the collision. There was also a lot of non-thermalling traffic going in both directions at the time, mostly within a pretty narrow altitude band within a thousand feet or two of cloud base under a long cloud street. An issue in these kinds of situations is that you can fixate on a couple of gliders a bit higher in the thermal and miss the one entering on a collision course with you at nearly the same time. *A cruder collision system has the potential to false alarm on too many non-threats and on multiple gliders in the vicinity, making it hard for the pilot to sort out which one is the real threat. Or it can falsely identify a non-threat and mask the one that is really the problem. At this point I'm not at all sure why you'd pick straight ADS-B (especially UAT) over something like PowerFlarm. The arguments keep changing and hard as I try I can't find one that holds water when I really run through all the issues. I think ADS-B in the long run is a decent upgrade over PCAS, but PowerFlarm is more cost efficient and more effective as a collision warning system, plus it has ADS-B in and PCAS build in. Also, I'll bet dollars to donuts that PowerFlarm gets FCC approval well prior to ADS-B getting out from under the STC requirement. 9B Contrary to what everyone seems to think, I am not fundamentally opposed to PowerFLARM. *I understand the sophistication of its collision avoidance logic, and it is very impressive and useful. *I totally get the necessity for reducing false alarms, so that the alarms that are issued are meaningful. My disappointment with PowerFLARM is the lack of a clear plan to take advantage of the extensive ADS-B ground station infrastructure that will cover much of the US in the next year or so, to provide the same level of collision avoidance to transponder equipped GA and commercial traffic that is available between PowerFLARM equipped gliders. Granted, the PCAS capability built into PowerFLARM gives you some level of protection, but you have no information on relative direction of the threat, and a very crude estimate of its range. *I find it very difficult to understand how PowerFLARM will be able to suppress PCAS initiated alarms from Mode C transponder equipped gliders in a gaggle, while simultaneously still generating PCAS alarms from other GA aircraft that also in the area. The built-in 1090ES ADS-B In capability is great, but that doesn't provide any ground station originated data unless you are transmitting ADS-B out. *The new Trig Mode S transponders provide this capability, but require a GPS source. *Is PowerFLARM going to provide this, or what is the plan for glider pilots to end up with a complete ADS-B compatible solution? -- Mike Schumann Somewhere earlier in this thread someone noted that they were planning on doing that soon. I plan on doing it myself, except that the $4K pricetag means it will take a while to save up for it. Also, the TSO fiasco throws a big question mark over the ADS-B out part of the equation. My plane (ASW-19) is type certified in the US, so the TSO requirement applies to me. -- Matt |
Mike, I think you do not understand the fundamental difference between
ADS-B and FLARM. ADS-B is designed for aircraft that do not want to fly close to each other, and want/need long range situational awareness. Thats probably where the whole ground station setup comes from - with all it's disadvantages (coverage, latency, accuracy, etc.) It's a great system for IFR traffic, and for GA flyers out sightseeing, but it sucks for gliders in a gaggle or running a ridge. FLARM, on the other hand, is specifically designed for aircraft (gliders, helicopters) that often want to fly close to each other, safely. In a gaggle, running a ridge, heading for the really nice Cu near the glider field, on the Whites - gliders inherently will congregate to find the best lift. That is the threat environment FLARM is designed to cope with. And it's a proven item. In a perfect world, there would be a SuperFLARM that would add some sort of ADS-B in/out capability, so the benefits of both would be present. But until then, FLARM addresses the immediate concern of many, if not most glider pilots the best. A PowerFLARM, combined with a mode s transponder, gives a glider most of the useful threat warning capability of a full up ADS-B setup, and all the advantages of FLARM - if FLARM is widely adopted by the US soaring community. But if no-one gets ADS-b in their gliders (show of hands out there?), then it's of no use in preventing the biggest historical threat - glider on glider collisions. I'm planning on getting a PowerFLARM next season to replace my PCAS. I hope you will to, while waiting for your ADS-B to be installed. Kirk 66 |
On 10/29/2010 11:37 AM, kirk.stant wrote:
Mike, I think you do not understand the fundamental difference between ADS-B and FLARM. ADS-B is designed for aircraft that do not want to fly close to each other, and want/need long range situational awareness. Thats probably where the whole ground station setup comes from - with all it's disadvantages (coverage, latency, accuracy, etc.) It's a great system for IFR traffic, and for GA flyers out sightseeing, but it sucks for gliders in a gaggle or running a ridge. FLARM, on the other hand, is specifically designed for aircraft (gliders, helicopters) that often want to fly close to each other, safely. In a gaggle, running a ridge, heading for the really nice Cu near the glider field, on the Whites - gliders inherently will congregate to find the best lift. That is the threat environment FLARM is designed to cope with. And it's a proven item. In a perfect world, there would be a SuperFLARM that would add some sort of ADS-B in/out capability, so the benefits of both would be present. But until then, FLARM addresses the immediate concern of many, if not most glider pilots the best. A PowerFLARM, combined with a mode s transponder, gives a glider most of the useful threat warning capability of a full up ADS-B setup, and all the advantages of FLARM - if FLARM is widely adopted by the US soaring community. But if no-one gets ADS-b in their gliders (show of hands out there?), then it's of no use in preventing the biggest historical threat - glider on glider collisions. I'm planning on getting a PowerFLARM next season to replace my PCAS. I hope you will to, while waiting for your ADS-B to be installed. Kirk 66 I think that you have a fundamental misunderstanding of ADS-B. ADS-B is a general purpose system that is designed to permit aircraft to announce their position and velocity vectors to anyone who is interested. For all practical purposes, it has the same accuracy, latency, etc. of FLARM based systems. It doesn't make any difference if aircraft are flying in close proximity or not. FLARM does the same thing and then adds another layer of collision detection logic on top of that, which is specifically optimized for the glider world. There is no reason that the same logic could not also be added on-top of an ADS-B based position sensing technology. In fact, PowerFLARM claims to be doing this using their 1090ES IN capability, if the user has ADS-B Out installed. The ground station ADS-B infrastructure is being deployed for 4 reasons: 1. To provide translation of ADS-B transmissions between UAT and 1090ES (an unfortunate necessity due to the FAA's decision to go with 2 ADS-B formats in the US) 2. To transmit TIS-B data. This lets ADS-B IN equipped aircraft see the position and altitude of Mode C and S Transponder equipped aircraft which are not yet outfitted with ADS-B transmitters. 3. To transmit additional weather and NOTAM information. 4. To detect ADS-B equipped aircraft so that they can be displayed on ATC radar displays. -- Mike Schumann |
Mike, you have just confirmed what I just suspected. Again, ADS-b is
designed for keeping airplanes that want to stay apart, apart. And yes, I understand exactly what the ground infrastructure is for, and it's not gliders - It's for IFR air traffic control and GA planes working their way through bad weather, checking on the latest NOTAMs at their destination. Sure, "someone" could develop software and hardware to use ADS-b to do what FLARM has been doing for the past 10 years, BUT THE CHANCE OF THAT HAPPENING IN THE NEAR FUTURE IS A CLOSE APPROXIMATION OF ZERO! Can't you understand that this isn't a zero sum game? NOTHING prevents you from having FLARM now (in Europe) or next year (in the US, hopefully) and later, if and when ADS-b becomes affordable and useable in a glider cockpit, installing ADS-b in their glider. And that even if the FAA gave a free UAT to every aircraft out there, FLARM would still be useful in the glider community? The two systems overlap each other, but occupy different requirement niches. Kirk 66 |
On 10/29/2010 12:33 PM, kirk.stant wrote:
Mike, you have just confirmed what I just suspected. Again, ADS-b is designed for keeping airplanes that want to stay apart, apart. And yes, I understand exactly what the ground infrastructure is for, and it's not gliders - It's for IFR air traffic control and GA planes working their way through bad weather, checking on the latest NOTAMs at their destination. Sure, "someone" could develop software and hardware to use ADS-b to do what FLARM has been doing for the past 10 years, BUT THE CHANCE OF THAT HAPPENING IN THE NEAR FUTURE IS A CLOSE APPROXIMATION OF ZERO! Can't you understand that this isn't a zero sum game? NOTHING prevents you from having FLARM now (in Europe) or next year (in the US, hopefully) and later, if and when ADS-b becomes affordable and useable in a glider cockpit, installing ADS-b in their glider. And that even if the FAA gave a free UAT to every aircraft out there, FLARM would still be useful in the glider community? The two systems overlap each other, but occupy different requirement niches. Kirk 66 The ground infrastructure is for EVERYONE! Glider pilots are probably not as interested in weather or NOTAMs. They are interested in seeing Mode C / S equipped aircraft (both GA and Jets) in their vicinity. This is the BIG reason you should care about ADS-B ground stations. The PowerFLARM proponents claim that it will handled 1090ES ADS-B Inputs. Does this include TIS-B data? What is the plan for PowerFLARM equipped aircraft to transmit ADS-B Out data so that the TIS-B data is visible? If PowerFLARM can do that, then it will be a killer product, not just for the glider world, but also for GA in the US. -- Mike Schumann |
On Oct 29, 11:30*am, Mike Schumann
wrote: On 10/29/2010 12:33 PM, kirk.stant wrote: Mike, you have just confirmed what I just suspected. *Again, ADS-b is designed for keeping airplanes that want to stay apart, apart. *And yes, I understand exactly what the ground infrastructure is for, and it's not gliders - It's for IFR air traffic control and GA planes working their way through bad weather, checking on the latest NOTAMs at their destination. Sure, "someone" could develop software and hardware to use ADS-b to do what FLARM has been doing for the past 10 years, BUT THE CHANCE OF THAT HAPPENING IN THE NEAR FUTURE IS A CLOSE APPROXIMATION OF ZERO! Can't you understand that this isn't a zero sum game? *NOTHING prevents you from having FLARM now (in Europe) or next year (in the US, hopefully) and later, if and when ADS-b becomes affordable and useable in a glider cockpit, installing ADS-b in their glider. *And that even if the FAA gave a free UAT to every aircraft out there, FLARM would still be useful in the glider community? The two systems overlap each other, but occupy different requirement niches. Kirk 66 The ground infrastructure is for EVERYONE! *Glider pilots are probably not as interested in weather or NOTAMs. *They are interested in seeing Mode C / S equipped aircraft (both GA and Jets) in their vicinity. *This is the BIG reason you should care about ADS-B ground stations. The PowerFLARM proponents claim that it will handled 1090ES ADS-B Inputs. *Does this include TIS-B data? *What is the plan for PowerFLARM equipped aircraft to transmit ADS-B Out data so that the TIS-B data is visible? *If PowerFLARM can do that, then it will be a killer product, not just for the glider world, but also for GA in the US. -- Mike Schumann Ground infrastructure, once it is deployed and in-service, is for everybody within the coverage volume of that infrastructure and who is properly equipped to use it. Unfortunately those requirements will exclude many gliders and popular glider locations which may makes it less useful than the combination of Flarm (esp. for glider threats) and PCAS (esp. for GA threats) in PowerFLARM for many of us - assuming we can get good mutual equipage of Flarm products within the glider community. But that seems off to a good start. As has been discussed on r.a.s. already Flarm have talked about PowerFLARM having a software update in 2011 that will support TIS-B. Since this is of any interest in the USA only, requires currently expensive and difficult to install ADS-B data-out equipment, and TIS-B capability has limited deployment today I hope Flarm does not waste any time working on TIS-B support before the product ships. It is easy to understand why TIS-B needs more work - TIS-B service data has relatively high positional uncertainty compared to Flarm or ADS-B direct data because the target information is from an SSR radar (or multilateration) source and radar scan time delays and position extrapolation induced errors. Some traffic displays might well just ignore all this and treat the position of a TIS-B threat as if it is highly precise and that could be a problem when you get close.... who knows how all those third party PDA traffic display/processor devices handle this today. I expect with Flarms focus on the glider market they will work to get this right for our use. To see threat aircraft via TIS-B the GBT ground infrastructure needs to be deployed and integrated into the appropriate enroute and terminal radar facilities and the threat aircraft need to to be within that SSR radar coverage and your glider needs to be equipped with ADS- B data-out (so the ADS-B ground infrastructure knows you are there) and you obviously need some form of ADS-B data-in and TIS-B capable traffic display/threat processing (PowerFLARM will do the later two after the software update). If you do all that you will "see" TIS-B data for all transponder equipped threats within +/-3,500' and a 15nm cylinder around your aircraft's position. You may also see other TIS-B "threats" within service volumes around other ADS-B data-out equipped "client" aircraft but pilots really must not rely on that. I point it out to explain to people why you may see a TIS-B threat on an ADS-B data-in only system and that threat may magically appear and dissapear from the display (but still be a very real threat)--if that happens with PowerFLARM when used without ADS-B data-out at least the PCAS should be screaming at you as the threat gets close. TIS-B requires the deployment of FAA ground infrasttucutre and integration of that with the appropriate radar facilities (enroute and terminal facilities are rolled out differently). That won't be complete for several more years. Pilots need to understand the situation for their local area -- is TIS-B available and from enroute and/or terminal radar and what are the coverage volumes for those services. I have no doubt that the directional and longer range capabilites of TIS-B compared to PCAS is a nice thing. But given the current cost and other issues around equipping with ADS-B data-out as well as ADS-B data-in to receive TIS-B service makes this impractical at least for the near future for most glider pilots. Most of my time talking with pilots about TIS-B is to correct misunderstandings they have, for example assuming that ADS-B data-in alone will provide TIS-B in their cockpit. Given the limited SSR coverage in many places we fly gliders and lack of GBT (ADS-B ground based transceiver) coverage at many GA airports and many popular gliding locations I do not see TIS-B as a replacement for PCAS. I've seen lots of alerts on my Zaon MRX when definitively outside of SSR coverage (presumably those transponders were being interrogated by TCAS/TCAD equipped aircraft). A bit of the irony then is that the PowerFLARM by being 1090ES not UAT based can easily include PCAS capability and if a pilots wants to install 1090ES data- out in future (as prices fall, products become more practical and installation issues go away as they will) then that is a great option. Also just to point out a timing issue -- worrying about TIS-B for gliders only makes sense if adoption becomes important within a certain time window - for most after ~2013 as widescale TIS-B service infrastructure deploy but before 2020 since after that TIS-B service is expcted be turned off since the assumption is it won't be needed as all those transponder equipped aircraft will be transmitting ADS-B data-out and link-layer conversion vis ADS-R will provide all that is needed. ADS-R will provide wider area and more accurate coverage than TIS-B. I hope cost and install issues do decrease - I want to play with all this with 1090ES data-out from a Trig TT21 in my (certified) glider with PowerFLARM doing 1090ES data-in. In discussing ADS-B ground infrastructure being "for everybody" it is also worth noting that most deployments of ADS-B ground infrastructure in the USA today do not include the ADS-R service yet and this "critical service" (in FAA speak) will take several more years to roll out widely. So if you have a UAT receiver you won't see any of those 1090ES data-out equipped airliners etc. who are amongst the early ADS- B data-out adopters and of interest to many of us in location like Reno. With a PowerFLARM with 1090ES data-in we see those directly, but similarly those of us with PowerFLARM and its 1090ES data-in won't see anybody with UAT data-out (until the ADS-R service is locally available and then only when we are within coverage of the GBT - and that will have significant coverage gaps for us to worry about, especially close to terrain). Again with any complex system like this the devil is in the practical details... Darryl |
Flarm in the US | Steve Freeman | Soaring | 163 | August 15th 10 12:12 AM |
Reflections on good and evil | [email protected] | Piloting | 6 | April 18th 06 08:48 PM |
FLARM | Robert Hart | Soaring | 50 | March 16th 06 11:20 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
B29 - "Necessary Evil" | Matt Tauber | Military Aviation | 30 | August 28th 03 10:35 AM |
