Komet Trailer ramp Lever Jack
Old November 2nd 10, 05:45 PM posted to rec.aviation.soaring
SoaringXCellence
Default Komet Trailer ramp Lever Jack
On Nov 2, 10:25*am, n7ly wrote:
On Nov 2, 10:24*am, Tony wrote:
I've been occasionally thinking about the best way to set up a
fuselage dolly for a fixed gear glider. *All I can say after seeing
your video is "DUH!"
Tony - this looks a lot like mine. Been using it for a long time.
Another advantage is that I don't have to bend over to raise the
plane, just step on the handle. On soft ground you can have an added
advantage - with a plywood ramp shaped like a T. *The top of the T has
enough foot print for the rollers, while the long part of the T is
long enough to roll the gear onto. It helps get the wheel out of the
mud. *Trailer is at Sunflower. * *Dennis
I just sold my Grob 103 setup with a fuselage jack that worked in a
similar way but also locked to the aircraft for loading onto the
trailer. Check with Coastal Soaring for pictures if you want to
build one.
Old November 2nd 10, 08:18 PM posted to rec.aviation.soaring
bildan
trailer. *Check with Coastal Soaring for *pictures if you want to
build one.
Consider this an extension of the ramp idea.
If a fuselage in a jackable dolly can be rolled completely off the
ramp and about 15 feet away from the tailgate, maneuvering the wing
roots off the trailer is much easier - especially if the ramp is
removed once it is not needed.
If a one-man dolly is to be used, it can be placed ahead of the nose
so the wing root can be swung across in front of the nose and then
walked to the fuselage without the past-the-tail do-si-do otherwise
required. This minimizes wing dolly rolling on rough ground.
Old November 4th 10, 02:22 AM posted to rec.aviation.soaring
SP
I replaced the broken double scissor jack on my 1979 Komet with a
motorcycle jack available from:
http://www.t-motorsports.com/product...-mlift-mh8054/
I cut off the tabs on the base plate and mounted the jack to the
fuselage dolly rails with a heavy duty piano hinge I got from McMaster
Carr. It works great and it's not expensive. I can send pics to anyone
interested.
Steve
Old November 4th 10, 03:35 AM posted to rec.aviation.soaring
Steve,
I replaced the scissor jack on my HP-14 trailer ramp with one of these motorcycle jacks shortly after you mentioned it in an earlier post. I had a chance to test it on a trip to Logan. It works great!!!
It is a STRONG, a bit heavy and the best solution I have discovered to date. I'm replacing the rod/socket provided raise and lower the jack with a socket and a swivel ratchet drive.
"SP" wrote in message ...
fuselage dolly for a fixed gear glider. All I can say after seeing
interested.
Steve
Trailer Ramp Jack - NO SCREWS - follow up Tim Taylor Soaring 13 July 17th 12 10:26 PM
WTB: Cobra Trailer Ramp Jack - US Gary Emerson Soaring 1 June 21st 09 01:34 AM
Komet Trailer Ramp Jack - NO SCREWS [email protected] Soaring 7 April 23rd 08 05:39 AM
Ramp jack for Komet Trailer [email protected] Soaring 8 April 2nd 08 05:37 PM
Double scissor jack for trailer ramp? Bullwinkle Soaring 15 January 18th 06 05:18 PM
