Penguins!
Buzzards etc have a much lower wing loading than we do so they'll climb in small, weak thermals. With their high wingloading then penguins can't afford to stop for anything but the best. Rarely seen soaring, but that's 'cos their inter-thermal speeds are much higher (Wing loading again), and there's not many other pilots flying in Antarctica to see them. KN |
![]() "Kevin Neave" wrote in message ... Penguins! Buzzards etc have a much lower wing loading than we do so they'll climb in small, weak thermals. With their high wingloading then penguins can't afford to stop for anything but the best. Rarely seen soaring, but that's 'cos their inter-thermal speeds are much higher (Wing loading again), and there's not many other pilots flying in Antarctica to see them. KN I think the Golden Eagle should be added to the mix of great thermaling birds. Though not as common as Buteos we often fly with them over the mountains of Idaho. One should not over look the beauty of a flock of thermaling pelicans with their white bodies and wings with black tips. Wayne http://www.soaridaho.com/ |
Turkey Vultures are excellent soaring birds, but have a very low wing
loading and use microlift near the ground, which is often patchy and disorganized. They typically don't soar very high because they eat carrion, which they locate by smell (Just Google it if it sounds too unlikely). They are generally not much use to glider pilots for these reasons. Vultures that locate prey visually soar higher and appear to thermal better. These include Africa's Cape Vulture and the American Black Vulture, both of which I've found like to join gliders in thermals. Most eagles and largish hawks soar very well, as do storks and herons. Their L/D is actually worse than most modern sailplanes, but their advantage lies in slower flying speeds that translates into tighter turning circles and having a very sensitive vario. Mike |
On 11/15/2010 8:50 AM, Mike the Strike wrote:
Turkey Vultures...Snip...typically don't soar very high because they eat carrion, Which reminds me...why don't we see Turkey Vultures on commercial airliners much anymore? .. .. .. .. .. .. .. .. .. .. Wait for it... .. .. .. .. .. .. .. .. .. Too many restrictions on carrion luggage!!! Please...no need to thank me. |
On Nov 15, 9:24*am, Bob Whelan wrote:
On 11/15/2010 8:50 AM, Mike the Strike wrote: Turkey Vultures...Snip...typically don't soar very high because they eat carrion, Which reminds me...why don't we see Turkey Vultures on commercial airliners much anymore? . . . . . . . . . . Wait for it... . . . . . . . . . Too many restrictions on carrion luggage!!! Please...no need to thank me. Oh, MY, DOG! Yer' KILLIN' me! Good one Bob |
One obvious master of the master class has not yet been
mentioned: the Frigate Bird. I have seen them soaring over water on calm days, seen them wings tucked forward and gliding well into a 35 knt wind. They are on the wing all day, mate on the wing, not only are they the best soaring birds by a LONG way, they have by far the best l/d. Just look at their wing form - they are all about aspect ratio and going places. They not only out-soar all other forms of soaring birds, but steal their food from them as well! (hence the name, also called Man o' War birds). Incidentally, having glid with pelligoons many times in the Caribbean, I can vouch that pelicans and hang gliders have about the same l/d and sink rate. However, they are much better at diving into water, although I did try that once, but it is a hard way to make a living. anyway, Frigate birds rule! bwBB |
mentioned: *the Frigate Bird. They not only out-soar all other forms of soaring birds, but steal their food from them as well! (hence the name, also called Man o' War birds). Well, another obvious bird not mentioned is the Albatross, which has the highest aspect of all birds (higher aspect then Frigatebirds, which hold the title for the lowest span loading, no doubt contributing to their ninja-like agility...). Sorry Frigates, but the Alby is the true unequivocal champion of *soaring, although in spirit of the OP's question, the Frigatebird may out perform it in a thermal ... Albatross circumnavigate the globe though, no doubt expertly working thermals the rare occasions they're available, but mostly use orthographic and different of modes of dynamic soaring (as do Frigatebirds) for their constant open water X/C trips, living life 'on the wing' stopping only to raise chicks from time to time. Frigatebirds are indeed amazing, and are definitely beautiful birds to share the air with as well as to watch from the ground. So far I have only soared with Frigatebirds, (Hawaii), but very much look forward to the day I share the air with an Alby... (not the bronze statue, although that'd be swell too ![]() They're both Peligoonformes though ![]() -Paul |
Got Big Thermals? | Bob D | Soaring | 14 | July 29th 09 02:34 AM |
Deadly Thermals!!!! | JGalban | Piloting | 6 | September 15th 07 03:30 AM |
Using thermals to climb? | Kees Mies | Piloting | 41 | April 27th 04 02:29 PM |
perfect thermals | Mike Stramba | Soaring | 0 | October 7th 03 07:09 AM |
