#31
Some of us will have multiple FLARM units for gliders and tow planes.
There will be times when I do not need my FLARM unit and will be willing to loan it to a pilot for a contest. A loaner list can be provided by the RC so a pilot without FLARM can make the contacts to procure a unit for a contest. Assuming FLARM meets expectations, most serious, safety-minded pilots will have one in the future. Seems simple. If I understand it correctly, we are telling our customers they would only need to have an extra display (butterfly?) to move the FLARM unit from one aircraft to another. Many glider pilots will want to move the FLARM from their glider to their power plane. Tom Knauff Knauff & Grove Soaring Supplies |
#32
On Nov 18, 11:09*am, Tom wrote:
If I understand it correctly, we are telling our customers they would only need to have an extra display (butterfly?) to move the FLARM unit from one aircraft to another. Many glider pilots will want to move the FLARM from their glider to their power plane. Loaner units will be portable PowerFLARM, which includes a display. 2nd picture he http://www.gliderpilot.org/Flarm-WhatIsIt Best Regards, Dave |
#33
On Nov 18, 8:09*am, Tom wrote:
Some of us will have multiple FLARM units for gliders and tow planes. There will be times when I do not need my FLARM unit and will be willing to loan it to a pilot for a contest. A loaner list can be provided by the RC so a pilot without FLARM can make the contacts to procure a unit for a contest. Assuming FLARM meets expectations, most serious, safety-minded pilots will have one in the future. Seems simple. If I understand it correctly, we are telling our customers they would only need to have an extra display (butterfly?) to move the FLARM unit from one aircraft to another. Many glider pilots will want to move the FLARM from their glider to their power plane. Tom Knauff Knauff & Grove Soaring Supplies You are talking about the remote mounted brick and not the portable unit? (or why is an external display needed at all?) Planning on moving a brick does not seem a good idea at all. It will involve removing two SMA antenna connections (not exactly known for their durability), the power connector, the display RJ45 connector, undoing whatever way you have the brick mounted etc. And reconnecting all this on the other aircraft. Where do you easily install the brick on a typical power aircraft? If owners want to move the device get a portable unit. If they want an installed look they need to purchase two bricks. Two separate units also avoids hassles with resetting ICAO ID and other information. Darryl |
#34
On Nov 18, 8:51*am, Darryl Ramm wrote:
On Nov 18, 8:09*am, Tom wrote: Some of us will have multiple FLARM units for gliders and tow planes. There will be times when I do not need my FLARM unit and will be willing to loan it to a pilot for a contest. A loaner list can be provided by the RC so a pilot without FLARM can make the contacts to procure a unit for a contest. Assuming FLARM meets expectations, most serious, safety-minded pilots will have one in the future. Seems simple. If I understand it correctly, we are telling our customers they would only need to have an extra display (butterfly?) to move the FLARM unit from one aircraft to another. Many glider pilots will want to move the FLARM from their glider to their power plane. Tom Knauff Knauff & Grove Soaring Supplies You are talking about the remote mounted brick and not the portable unit? (or why is an external display needed at all?) Planning on moving a brick does not seem a good idea at all. It will involve removing two SMA antenna connections (not exactly known for their durability), the power connector, the display RJ45 connector, undoing whatever way you have the brick mounted etc. And reconnecting all this on the other aircraft. Where do you easily install the brick on a typical power aircraft? If owners want to move the device get a portable unit. If they want an installed look they need to purchase two bricks. Two separate units also avoids hassles with resetting ICAO ID and other information. Darryl Sigh, I'll try again... this would involve removing 3 (not 2) SMA connectors - Flarm antenna, 1090ES antenna and the GPS antenna. The USB cable for the USB memory stick The power connector The display RJ-45 connector Unfastening the brick itself Reverse at the other end. On the power aircraft you may want to have a connector pre-wired in to attach the PowerFLARM audio out to the audio panel or to the aux in of the headset if it has an aux in. Moving the portable unit would involve unscrewing it or lifting it off the 3M "mushroom" tape. Removing the external power connector if one was used and removing the audio connection if one was used (in a power aircraft or motorglider). Darryl |
#35
Hi Dale,
I did not mean to imply that you did not understand the scope of it. I applaud what you were offering. I'm sorry to hear that you backed-out of your offer due to the lack of support of your specific agenda - but I don't blame you for backing out at all. But I do agree with the contest committee. Best Regards, Paul Remde "DaleKramer" wrote in message ... Paule, I am aware that the scope of what I volunteered to do was enormous. I think the level of support that I received was partly because enough people knew that I would have been able to accomplish what I started if I had just received the RC support the way that I received popular support from the silent majority. Dale |
#36
On 11/18/2010 6:43 AM, Mike the Strike wrote:
I also have some concerns about a rental program requiring the temporary installation of a unit. I like stuff bolted to my panel and I like to be fully familiar with electronics before I fly in a demanding contest. I am not sure that having a significant number of pilots in a contest with a loose device Velcroed or duck-taped to the glider and having them read the user manual in a gaggle is the best way to proceed. Don't worry about the device being "loose": the 3M "mushroom" tape is fully capable of keeping the unit in place under 20 G+ forces, based on the testing of my SPOT mounting, which uses less than 2 sq. inches of the stuff. Note that Mountain High has supplied the stuff for over a decade to mount their oxygen controllers of similar weight and size, with no problems I'm aware of, including the two EDS units I've used over 15 years now. Come'on - reading a manual in the cockpit? I haven't used Flarm, but since it's not required for flying the glider or for performing the task, it'll be "turn it on and forget about it till it squawks". If it squawks too much, the pilot will just turn if off (or mute it) and continue like he has for years, no more safety risk than before, and then educate himself after he's landed. These are not primary contest devices, like the flight computer! -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
#37
On Nov 18, 12:33*pm, Eric Greenwell wrote:
On 11/18/2010 6:43 AM, Mike the Strike wrote: I also have some concerns about a rental program requiring the temporary installation of a unit. *I Don't worry about the device being "loose": the 3M "mushroom" tape is fully capable of keeping the unit in place under 20 G+ forces, based on the testing of my SPOT mounting, My latest info is that there will be some nifty easy mounting devices for the regular Power Flarm. Among others, a L shaped bracket that uses this super-velcro to hook to the canopy rail, and a suction-cup system like Cambridge provided with the model 20. And more on the way. They seem to get the idea that installation is important! John Cochrane |
#38
On Nov 18, 10:33*am, Eric Greenwell wrote:
On 11/18/2010 6:43 AM, Mike the Strike wrote: I also have some concerns about a rental program requiring the temporary installation of a unit. *I like stuff bolted to my panel and I like to be fully familiar with electronics before I fly in a demanding contest. *I am not sure that having a significant number of pilots in a contest with a loose device Velcroed or duck-taped to the glider and having them read the user manual in a gaggle is the best way to proceed. Don't worry about the device being "loose": the 3M "mushroom" tape is fully capable of keeping the unit in place under 20 G+ forces, based on the testing of my SPOT mounting, which uses less than 2 sq. inches of the stuff. Note that Mountain High has supplied the stuff for over a decade to mount their oxygen controllers of similar weight and size, with no problems I'm aware of, including the two EDS units I've used over 15 years now. Come'on - reading a manual in the cockpit? I haven't used Flarm, but since it's not required for flying the glider or for performing the task, it'll be "turn it on and forget about it till it squawks". If it squawks too much, the pilot will just turn if off (or mute it) and continue like he has for years, no more safety risk than before, and then educate himself after he's landed. These are not primary contest devices, like the flight computer! -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz I disagree. There will need to be training/study for use of a PowerFLARM and the last thing I would want a contest pilot trying to do is sort all this out on a contest day - Dale I believe understands this and was planning appropriate assistance/training etc. (now moot I guess). e.g. you better worry about the different types of warnings, how to dismiss nuisance alerts (e.g. PCAS in a gaggle) and not others. What the different symbols on the map screen mean. Whether to put the device in Nearest, Contest, etc. mode. How to confirm it is working correctly, has a GPS signal, etc. How to register on FLARMnet and load a FLARMnet database. How to correctly set ICAO address and other information, (especially if you also have a Mode S transponder to help with other pilot's PowerFLARM do PCAS/Flarm deduplication) and other information etc. Butterfly may be emphasizing the ease of use of PowerFLARM and I expect them to do a good job making these relatively easy to use but I get very worried when I see comments like it will be "turn it on and forget until it squawks" type device--that thinking could lead to dangerous situations. I hope pilots, especially contest pilots will add PowerFLARM items to their pre-contest/flight checklist. Over the years I've added things like "GPS OK/acquired" and "task entered and declared (if needed)" to my pre-flight (i.e. before your are in the cockpit) checklist. Darryl |
#39
Having been a Flarm user for years I can tell you it is a install and
forget device. The portable device(for initial contest use) will probably not be integrated into your PDA so you would just make sure you have good batteries, mount it with the EZ-lock or what ever and turn it on. It will see other Flarm units in the area, and it will give you collision avoidence alerts when you go flying. Pretty much right out of the box. Yes, setting the ICAO address is good but in the rental contest situation it is not necessary. Don't make this harder than it has to be. Get the rental units to the Contest staff (along with lots of EZ-lock strips and batteries) and have them hand them out. Have a safety meeting with training on what to expect from the Flarm unit and how to install/operate and go fly. The first time I saw Flarm was when it was installed in a club plane I was flying. Did a winch launch, got a warning, looked at the display (for probably a second) and then looked out to see the glider that the Flarm was warning me about. SOLD! I would have seen this plane but Flarm saw it first. From that point forward I will not fly without a working Flarm unit. Some lessons he Flarm works and alerts you to Flarm equipped planes you have not seen (yet). I hadn't been "trained" on Flarm but when I saw the display I knew where to look. I have yet to meet a glider pilot who does not "Get" the Flarm concept after flying with Flarm. (of course some still haven't bought a unit yet but I don't know anybody who doesn't fly with one) PEER PRESSURE WORKS WELL. Get the Flarms into the contests, get them into club planes, then you'll get them into the other planes. You may not (ok, probably don't) agree with all of this but until you fly with Flarm you don't know what your missing! Litterally! Ask anyone who has flown with Flarm. John Cochrane? Bob |
#40
On 11/18/2010 11:24 AM, Darryl Ramm wrote:
On Nov 18, 10:33 am, Eric wrote: Come'on - reading a manual in the cockpit? I haven't used Flarm, but since it's not required for flying the glider or for performing the task, it'll be "turn it on and forget about it till it squawks". If it squawks too much, the pilot will just turn if off (or mute it) and continue like he has for years, no more safety risk than before, and then educate himself after he's landed. These are not primary contest devices, like the flight computer! I disagree. There will need to be training/study for use of a PowerFLARM and the last thing I would want a contest pilot trying to do is sort all this out on a contest day - Dale I believe understands this and was planning appropriate assistance/training etc. (now moot I guess). e.g. you better worry about the different types of warnings, how to dismiss nuisance alerts (e.g. PCAS in a gaggle) and not others. What the different symbols on the map screen mean. Whether to put the device in Nearest, Contest, etc. mode. How to confirm it is working correctly, has a GPS signal, etc. How to register on FLARMnet and load a FLARMnet database. How to correctly set ICAO address and other information, (especially if you also have a Mode S transponder to help with other pilot's PowerFLARM do PCAS/Flarm deduplication) and other information etc. Butterfly may be emphasizing the ease of use of PowerFLARM and I expect them to do a good job making these relatively easy to use but I get very worried when I see comments like it will be "turn it on and forget until it squawks" type device--that thinking could lead to dangerous situations. I hope pilots, especially contest pilots will add PowerFLARM items to their pre-contest/flight checklist. Over the years I've added things like "GPS OK/acquired" and "task entered and declared (if needed)" to my pre-flight (i.e. before your are in the cockpit) checklist. Darryl I agree completely that a pilot should learn how to use it while on the ground to get full use out of the unit, but my impression is somebody can be handed one, given a 5 minute basic introduction, then go flying. He'll know enough to turn the unit on/off, to mute it, and to be to know where to look when the unit signals a conflict with another glider. That's just for the first flight. He'll know more before the next flight, and so on. I just don't see any reason to think pilots will be so involved in the unit, they will be less safe during the course of the first few flights than without it, and I still think it's nonsense to talk about "reading the manual" in flight. It's not a flight computer! You are not trying to navigate with it, not trying optimize your turn within a turnpoint area, not trying to locate and center lift, not distracting yourself by talking on the radio. It just sits there, like my MRX pcas unit, until there is a potential problem. I'm just parroting what the guys that use them tell us. Why not believe them? All the other stuff - Flarmnet, database, ADS-B, ICAO address - is that necessary for it to provide it's primary function in a contest, which is to warn pilots of potential conflicts with other gliders? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
OLC 2011 | dhaluza | Soaring | 12 | October 22nd 10 12:02 AM |
OLC Scoring for 2011 | robert hunter | Soaring | 23 | October 21st 10 11:34 PM |
OLC Scoring for 2011 | Mike the Strike | Soaring | 9 | October 17th 10 03:41 AM |
2011 15M Nationals | Andy[_10_] | Soaring | 10 | August 19th 10 05:23 PM |
2011 USA 18M Nationals | 5 ugly | Soaring | 3 | August 18th 10 04:52 AM |
