Ethanol fuel and deteriorating composite fuel tanks
Old November 18th 10, 06:10 PM posted to rec.aviation.soaring
Mark Jardini
Default Ethanol fuel and deteriorating composite fuel tanks
aren't most of last decade birds built with epoxy resin?
Old November 18th 10, 06:20 PM posted to rec.aviation.soaring
Darryl Ramm
Yes, but what the glider is made of does not dictate what the fuel
tanks is made of. And a fuel tank might well have a special fuel-proof
lining even if the tank is made of other resin. Check with the
manufacturer, and check if they believe the aircraft should use
alcohol blend fuels. And many motorgliders also have aux fuel stored
in the wings - in flexible bags not hard tanks.
Darryl
It's time to mount the fuel tanks Lou Home Built 1 March 31st 07 07:07 PM
Leaking Fiberglass Fuel Tanks [email protected] Home Built 0 January 2nd 07 01:10 AM
Ethanol & capacitance fuel-level sensors Adam Aulick Home Built 4 May 20th 06 03:28 PM
Fuel Tanks C172 [email protected] Owning 1 May 2nd 06 05:45 AM
Epoxy for Fuel Tanks Doug Palmer Home Built 1 April 12th 06 02:53 AM
