![]() You spend enough to buy a house on your motorglider and are trying to save a few bucks on fuel? |
In article Jim writes:
You spend enough to buy a house on your motorglider and are trying to save a few bucks on fuel? Avoiding 100LL is often not about trying to save money. If you spent that much money on the motorglider, you probably want to feed it the best fuel for it, which may not be 100LL. I don't know about the engines used in motorgliders, but the Rotax engines used in many of the light sport aircraft "prefer" mogas over 100LL, as the lead content results in shorter service intervals for things like oil changes, gearbox servicing, and possible engine overhaul. Alan |
Rotax specifically say that 100ll should only be used if 95 ron
unleaded is unavailable due to increased wear and unsuitability to their 2 stroke engines. We have never used 100ll in our 505 due to this advice from Rotax. The sooner an unleaded aviation petrol spec is agreed and the fuel widely available the better. This would also be of great help to the large number of light aircraft powered by engines originally designed to use 80/87. At 07:11 19 November 2010, Alan wrote: In article Jim writes: You spend enough to buy a house on your motorglider and are trying to save a few bucks on fuel? Avoiding 100LL is often not about trying to save money. If you spent that much money on the motorglider, you probably want to feed it the best fuel for it, which may not be 100LL. I don't know about the engines used in motorgliders, but the Rotax engines used in many of the light sport aircraft "prefer" mogas over 100LL, as the lead content results in shorter service intervals for things like oil changes, gearbox servicing, and possible engine overhaul. Alan |
On Nov 19, 5:29*am, Nigel Cottrell wrote:
Rotax specifically say that 100ll should only be used if 95 ron unleaded is unavailable due to increased wear and unsuitability to their 2 stroke engines. We have never used 100ll in our 505 due to this advice from Rotax. The sooner an unleaded aviation petrol spec is agreed and the fuel widely available the better. This would also be of great help to the large number of light aircraft powered by engines originally designed to use 80/87. At 07:11 19 November 2010, Alan wrote: In article *Jim *writes: You spend enough to buy a house on your motorglider and are trying to save a few bucks on fuel? *Avoiding 100LL is often not about trying to save money. *If you spent that much money on the motorglider, you probably want to feed it the best fuel for it, which may not be 100LL. *I don't know about the engines used in motorgliders, but the Rotax engines used in many of the light sport aircraft "prefer" mogas over 100LL, as the lead content results in shorter service intervals for things like oil changes, gearbox servicing, and possible engine overhaul. * *Alan Ah the devil is in the details and the question about concerns with Ethanol blend fuels that are an issue in the USA may not be in the UK. The real question is what do Rotax or the aircraft manufacture say about Mogas with Ethanol blends? And what experience do people actually have operating at high Ethanol blends E10, E15 etc. Its not just an automatic extrapolation that because non-blended or low-blend (5%) Mogas is "better" (for some definition of what better means) than 100LL that all ethanol blends of Mogas will be. In many cases I suspect that the motorglider manufacturers do not have enough experience with Ethanol blended fuels to know what the answer should be. Let alone the question of what Ethanol blends might do to fuel tanks and hoses etc. there is the question of whether the Engine and carb etc. are suitable for higher blend ethanol fuels. To take the example offered of Rotax/light sport example further Rotax themselves have qualified some (but not all of their) engines to use up to E10 blends but no more. Other engines are limited to E5. (see http://www.rotax-aircraft-engines.co...us/d04851.pdf). So if you live in the USA in a state where fuel is pushing E15 you might really want to consider AVGAS. For example see how Remos handle this issue here http://www.remos.com/media/news/noti...l-blended-fuel .... Use Mogas over 100LL but Mogas is not recommended if it contains Ethanol. Not exactly clear from this at what blend ratio it might be better to use 100LL. The rotary engines in Schleicher motogliders run better on Avgas 100LL than Mogas so its a non-issue. The Solo engines in DG motorgliders and others have traditionally had Mogas recommended, but again that advice may not necessarily apply if the Mogas is a high Ethanol blend. Check with DG or Binder for their advice - and be clear you are asking specifically about Ethanol blends not conventional Mogas. Having drained enough water out of AVGAS tanks in light aircraft to scare me I would be concerned about dissolved water contamination in high Ethanol blends. Darryl |
On Nov 19, 7:04*am, Darryl Ramm wrote:
On Nov 19, 5:29*am, Nigel Cottrell wrote: Rotax specifically say that 100ll should only be used if 95 ron unleaded is unavailable due to increased wear and unsuitability to their 2 stroke engines. We have never used 100ll in our 505 due to this advice from Rotax. The sooner an unleaded aviation petrol spec is agreed and the fuel widely available the better. This would also be of great help to the large number of light aircraft powered by engines originally designed to use 80/87. At 07:11 19 November 2010, Alan wrote: In article *Jim *writes: You spend enough to buy a house on your motorglider and are trying to save a few bucks on fuel? *Avoiding 100LL is often not about trying to save money. *If you spent that much money on the motorglider, you probably want to feed it the best fuel for it, which may not be 100LL. *I don't know about the engines used in motorgliders, but the Rotax engines used in many of the light sport aircraft "prefer" mogas over 100LL, as the lead content results in shorter service intervals for things like oil changes, gearbox servicing, and possible engine overhaul. * *Alan Ah the devil is in the details and the question about concerns with Ethanol blend fuels that are an issue in the USA may not be in the UK. The real question is what do Rotax or the aircraft manufacture say about Mogas with Ethanol blends? And what experience do people actually have operating at high Ethanol blends E10, E15 etc. Its not just an automatic extrapolation that because non-blended or low-blend (5%) Mogas is "better" (for some definition of what better means) than 100LL that all ethanol blends of Mogas will be. In many cases I suspect that the motorglider manufacturers do not have enough experience with Ethanol blended fuels to know what the answer should be. Let alone the question of what Ethanol blends might do to fuel tanks and hoses etc. there is the question of whether the Engine and carb etc. are suitable for higher blend ethanol fuels. To take the example offered of Rotax/light sport example further Rotax themselves have qualified some (but not all of their) engines to use up to E10 blends but no more. Other engines are limited to E5. (seehttp://www.rotax-aircraft-engines.com/portaldata/5/dokus/d04851.pdf). So if you live in the USA in a state where fuel is pushing E15 you might really want to consider AVGAS. For example see how Remos handle this issue herehttp://www.remos.com/media/news/notification-use-ethanol-blended-fuel ... Use Mogas over 100LL but Mogas is not recommended if it contains Ethanol. Not exactly clear from this at what blend ratio it might be better to use 100LL. The rotary engines in Schleicher motogliders run better on Avgas 100LL than Mogas so its a non-issue. The Solo engines in DG motorgliders and others have traditionally had Mogas recommended, but again that advice may not necessarily apply if the Mogas is a high Ethanol blend. Check with DG or Binder for their advice - and be clear you are asking specifically about Ethanol blends not conventional Mogas. Having drained enough water out of AVGAS tanks in light aircraft to scare me I would be concerned about dissolved water contamination in high Ethanol blends. Darryl- Hide quoted text - - Show quoted text - Alan and Nigel are right, several rotax powered motogliders DO prefer Mogas. Metal tanks in the HK-36. Lead in 100LL can cause plug and gearbox problems. I know because I do the support for two HK -36 research birds aerodyne |
On Nov 19, 1:44*pm, wrote:
On Nov 19, 7:04*am, Darryl Ramm wrote: On Nov 19, 5:29*am, Nigel Cottrell wrote: Rotax specifically say that 100ll should only be used if 95 ron unleaded is unavailable due to increased wear and unsuitability to their 2 stroke engines. We have never used 100ll in our 505 due to this advice from Rotax. The sooner an unleaded aviation petrol spec is agreed and the fuel widely available the better. This would also be of great help to the large number of light aircraft powered by engines originally designed to use 80/87. At 07:11 19 November 2010, Alan wrote: In article *Jim *writes: You spend enough to buy a house on your motorglider and are trying to save a few bucks on fuel? *Avoiding 100LL is often not about trying to save money. *If you spent that much money on the motorglider, you probably want to feed it the best fuel for it, which may not be 100LL. *I don't know about the engines used in motorgliders, but the Rotax engines used in many of the light sport aircraft "prefer" mogas over 100LL, as the lead content results in shorter service intervals for things like oil changes, gearbox servicing, and possible engine overhaul. * *Alan Ah the devil is in the details and the question about concerns with Ethanol blend fuels that are an issue in the USA may not be in the UK. The real question is what do Rotax or the aircraft manufacture say about Mogas with Ethanol blends? And what experience do people actually have operating at high Ethanol blends E10, E15 etc. Its not just an automatic extrapolation that because non-blended or low-blend (5%) Mogas is "better" (for some definition of what better means) than 100LL that all ethanol blends of Mogas will be. In many cases I suspect that the motorglider manufacturers do not have enough experience with Ethanol blended fuels to know what the answer should be. Let alone the question of what Ethanol blends might do to fuel tanks and hoses etc. there is the question of whether the Engine and carb etc. are suitable for higher blend ethanol fuels. To take the example offered of Rotax/light sport example further Rotax themselves have qualified some (but not all of their) engines to use up to E10 blends but no more. Other engines are limited to E5. (seehttp://www.rotax-aircraft-engines.com/portaldata/5/dokus/d04851.pdf). So if you live in the USA in a state where fuel is pushing E15 you might really want to consider AVGAS. For example see how Remos handle this issue herehttp://www.remos.com/media/news/notification-use-ethanol-blended-fuel ... Use Mogas over 100LL but Mogas is not recommended if it contains Ethanol. Not exactly clear from this at what blend ratio it might be better to use 100LL. The rotary engines in Schleicher motogliders run better on Avgas 100LL than Mogas so its a non-issue. The Solo engines in DG motorgliders and others have traditionally had Mogas recommended, but again that advice may not necessarily apply if the Mogas is a high Ethanol blend. Check with DG or Binder for their advice - and be clear you are asking specifically about Ethanol blends not conventional Mogas. Having drained enough water out of AVGAS tanks in light aircraft to scare me I would be concerned about dissolved water contamination in high Ethanol blends. Darryl- Hide quoted text - - Show quoted text - Alan and Nigel are right, several rotax powered motogliders DO prefer Mogas. Metal tanks in the HK-36. Lead in 100LL can cause plug and *gearbox problems. *I know because I do the support for two HK -36 research birds aerodyne BTW I was not disputing that, but the choice is not automatic what you should do when higher Ethanol blends are involved, e.g. if the choice is say between E15 mogas and 100LL avgas? Is it? Rotax says not to use E10 in the 912/914 series engines AFAIK. So what do you do, I expect you are required to run Avgas if the only other choice was E15? At least E15 should be labeled at the pump, good luck knowing what exactly you get in many states in the USA now. But to the point that is is not just "automatically best" to use Avgas 100LL, that is absolutely correct. Owners better read the manual. Darryl |
It's time to mount the fuel tanks | Lou | Home Built | 1 | March 31st 07 07:07 PM |
Leaking Fiberglass Fuel Tanks | [email protected] | Home Built | 0 | January 2nd 07 01:10 AM |
Ethanol & capacitance fuel-level sensors | Adam Aulick | Home Built | 4 | May 20th 06 03:28 PM |
Fuel Tanks C172 | [email protected] | Owning | 1 | May 2nd 06 05:45 AM |
Epoxy for Fuel Tanks | Doug Palmer | Home Built | 1 | April 12th 06 02:53 AM |
