At 09:10 24 November 2010, Bruce Hoult wrote:
On Nov 24, 1:18=A0pm, Johan Nykvist wrote: In my oppinion, Duo, DG 500, DG1000 (a beast to ground handle) ect are not primary trainers. Not rugged enough.. What do you base this on? We just moved from Twin Astirs to DG1000s. I can't see any way in which a fixed gear DG1000 Club is more of a beast to ground handle than a Twin Astir! In particular, lifting the tail to put the dolly on is considerably lighter. That this is so should be fairly obvious from the fact that a properly ballasted DG1000 Club is very nearly balanced on the main wheel and may sit on either the nose wheel or the tail wheel. Lacking nose wheels, and not wanting the nose to come into contact with the ground either at rest or when using the wheel brake, the main wheel on the Twin Astir is considerably further forward than it is on a 3-wheel undercarriage glider such as the ASK-21, Twin II/III, or DG1000 Club. The same is also true of the non-Club version of the DG1000 -- the retractable wheel is very far forward and there is a lot of weight on the tail. Perhaps you are not distinguishing between the (cheaper) Club and standard versions of the DG1000? Here's what I'm talking about: http://is.gd/hGLKd I'm also not sure where you get the "Not rugged enough" opinion. They seem to be very well built. Oh, Im sorry! I didnt think of the club version. My experience is from DG1000T. Its retractble landingear is hard work to operate. Also im not sure its rugged enough for longterm abuse from learners somtimes hard landings...well, some experineced pilots too! =) Not to mention the electrical gear.. Personally I think all of them is great gliders. But maby not for basic training. I ofcoarse can be wrong. My main point is they might be a to tricky to for beginners (to hard learning curve) to maintain correct airspeed at landings ect. Due to the higher performance, its accelerates very quickly when lowering the attitude. Is my personal oppinion. Sorry for not being clear enogh. The perfect world, I think, would be ASK 21 for basic training and a DuoT, DG1000T or ArcusT for the more advanced training. Nice ship on the link!! =) |
Personally I think all of them is great gliders. But maby not for basic training. I of coarse can be wrong. You are. Our club regularly uses the DG1000 for primary training. Retractable gear and 20 meters, no problem whatsoever. And rugged it is. The only weak point is the less than optimal view from the rear seat. Critics may mention the high cockpit which is hard to enter and the heavy tail. Well, the technique to enter the cockpit can be learned. And the heavy tail can easily be lifted if one of the pilots or whoever sits on the gliders nose. At least we are very happy with it. |
Club Class Gliders | Sam Giltner[_1_] | Soaring | 4 | December 3rd 08 03:28 AM |
Basic Training Gliders | Derek Copeland | Soaring | 35 | December 26th 05 02:19 PM |
Basic Training Gliders | Justin Craig | Soaring | 0 | December 6th 05 10:07 PM |
Soaring club close to NYC, with high-performance gliders | City Dweller | Soaring | 9 | September 29th 05 11:55 AM |
