On 11/24/2010 5:41 PM, 150flivver wrote:
On Nov 22, 9:55 am, Alexander wrote: Thanks, This WebTrak thingy is a very neat tool. I was able to see the plane in question: http://avtanski.net/images/var/jet.png As you can see, it turned out he didn't land on SJC, although from my location (marked on the map) it looked right on the way to there. I asked because I live in the area from over 10 years and this is the first time I see something like that - just curious. Regards, - Alex On Nov 21, 2:06 am, (John Clear) wrote: In , Alexander wrote: Hello, Today around 10:52am PDT (+/- a couple of minutes) I was in south San Jose when I heard a very loud jet engine noise overhead. When I looked up I saw something that looked like a F-18 on the SJC landing path for 30L or 30R. It may have been a different plane - sorry, I did not have my glasses - but it was definitely a military jet. Did anybody notice this, and what was a military jet doing landing on a civil airport? I didn't see anything on the SJC flight tracker. I watched 10:45am to 10:55am. http://sjc.webtrak-lochard.com/template/index.html FlightAware doesn't show anything military at SJC or at Moffett either. John -- John Clear - http://www.clear-prop.org/ Many military fighters are restricted to landing at fields that have barriers (cables) for an arrested landing if needed. They'll land at fields without barriers under special circumstances such as an airshow but they get a waiver from their command to do so. Which military fighter is that? No problem for F-15, F-16, F/A 18, etc to land without cables. I don't know if I've ever even seen cables at military bases such as Aviano where fighters land daily. I'd be interested in your source of information. |
On Nov 30, 10:30*am, John wrote:
On 11/24/2010 5:41 PM, 150flivver wrote: On Nov 22, 9:55 am, Alexander *wrote: Thanks, This WebTrak thingy is a very neat tool. I was able to see the plane in question: *http://avtanski.net/images/var/jet.png As you can see, it turned out he didn't land on SJC, although from my location (marked on the map) it looked right on the way to there. *I asked because I live in the area from over 10 years and this is the first time I see something like that - just curious. Regards, - Alex On Nov 21, 2:06 am, (John Clear) wrote: In , Alexander *wrote: Hello, Today around 10:52am PDT (+/- a couple of minutes) I was in south San Jose when I heard a very loud jet engine noise overhead. *When I looked up I saw something that looked like a F-18 on the SJC landing path for 30L or 30R. *It may have been a different plane - sorry, I did not have my glasses - but it was definitely a military jet. Did anybody notice this, and what was a military jet doing landing on a civil airport? I didn't see anything on the SJC flight tracker. *I watched 10:45am to 10:55am. http://sjc.webtrak-lochard.com/template/index.html FlightAware doesn't show anything military at SJC or at Moffett either. |
On Dec 2, 11:00*am, 150flivver wrote:
On Nov 30, 10:30*am, John wrote: On 11/24/2010 5:41 PM, 150flivver wrote: On Nov 22, 9:55 am, Alexander *wrote: Thanks, This WebTrak thingy is a very neat tool. I was able to see the plane in question: *http://avtanski.net/images/var/jet.png As you can see, it turned out he didn't land on SJC, although from my location (marked on the map) it looked right on the way to there. *I asked because I live in the area from over 10 years and this is the first time I see something like that - just curious. Regards, - Alex On Nov 21, 2:06 am, (John Clear) wrote: In , Alexander *wrote: Hello, Today around 10:52am PDT (+/- a couple of minutes) I was in south San Jose when I heard a very loud jet engine noise overhead. *When I looked up I saw something that looked like a F-18 on the SJC landing path for 30L or 30R. *It may have been a different plane - sorry, I did not have my glasses - but it was definitely a military jet. Did anybody notice this, and what was a military jet doing landing on a civil airport? I didn't see anything on the SJC flight tracker. *I watched 10:45am to 10:55am. http://sjc.webtrak-lochard.com/template/index.html FlightAware doesn't show anything military at SJC or at Moffett either. John -- John Clear - * * * * * * * * *http://www.clear-prop.org/ Many military fighters are restricted to landing at fields that have barriers (cables) for an arrested landing if needed. *They'll land at fields without barriers under special circumstances such as an airshow but they get a waiver from their command to do so. Which military fighter is that? * No problem for F-15, F-16, F/A 18, etc to land without cables. *I don't know if I've ever even seen cables at military bases such as Aviano where fighters land daily. *I'd be interested in your source of information. Aviano definitely has barriers/cables for fighter use. *They are visible on an overhead photo of the runway. *Some cables are recessed into the runway and are elevated for use by the control tower. *Others sit on top of the runway elevated a couple inches off the ground by rubber donuts. *Normal landings touchdown past the cable to prevent wear and tear on them or damage to underwing stores should the cable pop up and contact them. *Fighters don't use the cable on land unless there's a problem, so they can land at fields without them but for safety's sake, they are generally operated at airfields that have them. *I'm retired air force (1500 hours fighter) and never landed at an airfield without barriers. Here's the arresting gear available at Aviano: A-GEAR - Rwy 05 apch end BAK-12 avbl O/R, 15 min PN. When Rwy 05 in use, BAK-12 (2463') and dep end BAK-12s and E5 rigged. When Rwy 23 in use, BAK-12 (2402') and dep end BAK-12s and E5 rigged. |
Brutal F18 Landing On An Aircraft Carrier..............Military Video Clip | Hansi | Naval Aviation | 5 | July 18th 06 02:12 PM |
Brutal F18 Landing On An Aircraft Carrier..............Military Video Clip | Lufthansi | Piloting | 9 | July 2nd 06 09:08 AM |
Brutal F18 Landing On An Aircraft Carrier..............Military Video Clip | Hansi | Instrument Flight Rules | 0 | June 28th 06 11:07 PM |
[sci.military.naval, rec.aviation.military] Lost Sunderland Flying Boat Found! | Sunderland | Military Aviation | 0 | April 4th 04 06:27 PM |
Military jet makes emergency landing at MidAmerica | Otis Willie | Military Aviation | 0 | September 1st 03 02:28 AM |
