![]() "sid" wrote in message om... "Kevin Brooks" wrote in message The fact that the USAF,USN, USA, etc., are not going to place those assets in a situation of undue risk is patently obvious. The fact that your Russian "super AAM" is nothing more than a concept at present does not change that. Gee, I thought that the ISR assets were expected to assist in the conduct of a war. On our terms. Recent experiences aside, wars are slam full of "undue risk". Undue risk is what you avoid. Which is why they won't be sending ACS and the E-10 into IADS environments. Thats whole issue here, while SOF aircraft are thought of, and built as, warplanes, the Boeings, Embraers, and Gulfstreams contemplated for these roles have no such engineering. Please point to the "special engineering" that sets an AFSOC CN 235/295 apart from one of those Gulfstreams. Fact is they are very vulnerable platforms that are being considered for vital missions and that potential adversaries are building weapons to field against. Big jump from that Russian firm "slowly" pursuing a very long range AAM program to "are building". Yet these aircraft will be expected to take part in warfare. As few platforms that the ISR force has or will have, and as important as they are to the conduct of contemporary and contemplated US military ops, a capable opponent will find them juicy targets and he can buy the equipment to do something about it. Look, we are NOT sending them into contested airspace, OK? Period. Now, tell me which foe these systems will be used against that we will not acheive air superiority/dominance over in very short order? A commander may well be forced to put these aircraft into areas of "undue risk" to get the job done (as was done with the OP-2Es), or risk not getting the job done at all. There is that strange "OP-2E's" you keep ranting about... And again, we are not going to send these assets in against "undue risk". That some AF units seem to be exempt from the possibility of taking enemy fire has been a long term inherent cultural issue apparently. I'm not the only one to say it either: http://www.airpower.maxwell.af.mil/a...jun/cahoon.htm C-17 drivers just recently went through combat certification for the first time. The question begs, why weren't they treated as warfighters all along? Meaningless. ACS and E-10 are not airlifters. Airlifters may indeed have to drop down into a MANPADS/AAA threat environment to perform their mission--ACS and the E-10 do not. Sure, its not a real problem today, it won't be next year either, but then again the ACS and E-10 won't be fielded until how many years down the road? By the time they are operational, and S-400 s-300 equipped opponent could well render them impotent. Quick! Call the Pentagon and tell them you have discovered the flaw in the plans that so many professionals have been developing for decades now! This is not being planned for. Apparently you missed this part of this "piece"?: http://www.fas.org/irp/program/collect/SIGINTWP.pdf "ADA Susceptibility: GR/CS and ARL susceptibility to SA 10 and SA 12 threats was the cornerstone of the argument to eliminate them from the system. While it is true that they are susceptible to the threats, they are no less so than many of the retained systems. Rivet Joint,EP3, ES3, all retained by the study, fly at altitudes similar to Army systems. Their survivability will require stand-off as well. GR/CS normally flies in the same vicinity as JSTARS and AWACS, two targets an enemy would likely pursue with more vigor than an RC12. Discussions made it clear that the entire air campaign was not considered in the analysis. In fact, constraints of the ADA threat were not uniformly applied. Had it been so, many other platforms would have to become HAPs as well (JSTARS, AWACS)." As an FYI those SAM systems have advertised standoff ranges greater than that of JSTARS and ACS. I'm not the only one thinking of this either: http://www.aiaa.org/aerospace/Articl...hiveIssueID=22 "For example, the standoff range for defending against SAMs [surface-to-air missiles] is changing, and you will have to go to space. Then you may want to move JSTARS [Joint Surveillance and Target Attack Radar System] and AWACS [Airborne Warning and Control System] capabilities into space. So past elements that have given situational awareness in the theater may involve trade-ups." I don't know where you get these ideas, but the E-8 JSTARS surveillance range reportedly reaches out to around 250 km--SA-10/12 manage what, maybe 90 km? "In a risky bid to extend strike missions by making it easier for planes to refuel, he ordered tanker aircraft -- which are relatively vulnerable, because they lack their own warning radar and armaments -- to venture into Iraqi airspace, even though Iraq's dense air defense network had not been eliminated." Credible, yes. But what does he mean by "eliminated"? We know that they continued to pop off MANPADS even as the troops and marines entered into the city--but again, those MANPADS were no threat to the tankers. So why were they concerned. Obviously the longer range threat had not been rendered below the "undue threat" threshold. That is not what the evidence indicates. In fact, were any longer range systems used to engage the KC's? Nope--the threat was ameliorated. What vulnerabilities? The supposed vulnerability to a missile that has yet been built, guided by a system not yet developed, while engaging in overflights through an IADS that just won't happen? Not much of a "vulnerability" you have illustrated there. You are wrong about this. Besides, you mean susceptability here??? My beef is vulnerability issues, there is a difference. Hint--vulnerability is not an issue if susceptability is controlled. But to the point, the S-300 and S-400 are entirely capapble of countering our ISR assets. Thats a fact.: http://www.house.gov/pitts/initiativ...ew-brief-9.htm (the google cached version works) "The Russians sold the SA-10 (Russian designation S-300, NATO:Grumble) to China, and recently agreed to sell them to Iran. The Russians are aggressively marketing these systems and China may also build versions for export, just as they did with the single digit SAMs. Several more countries may acquire and field these systems within the next 10 years. The major factor preventing proliferation is the high price tag of these systems. However, the Russians are also developing and selling improvement kits to the single digit SAMs to provide near double-digit SAMs performance at a fraction of the cost.' 'In short, the battlefield 10 years from now may be a far more dangerous place than today, and it will take a toll on our pilots if we do not act to mitigate the increased threat." Sorry, not a "fact". Fact--SA-10 has a reported max range around 90 km, and the E-8 can stand off well beyond that and map the terrain well beyond that out-of-range S-300. As an FYI the Navy is moving the P-3s away from the overland tactical support role. What? Yes. P-3s(Not talking about EP-3s) and MMA will not be used in the overland role due to vulenrability issues. Did you miss this as well? http://www.lexingtoninstitute.org/defense/111803ISR.pdf "However, Navy leadership removing P-3 from overland missions in hostile airspace due to survivability concerns." Note the "in hostile airspace" bit. And BTW, we are not discussing P-3's or MMA--we are discussing ACS and E-10, along with the K-767, right? Gee, the VP-26 vet who wrote up the description I read must have had all of his facts wrong. He indicated that the engine was lost, and the fire was in that vicinity--whether or not it also involved the fuel tankage is a moot point. Here's what it says. Note the "unclear" part: "Several rounds ripped into the outer portion of their starboard wing, knocking out #4 engine and starting a fire. They pulled the emergency handle and succeeded in feathering the prop, but could not extinguish the flames. It was unclear whether the fire originated from the engine nacelle or from within the wing itself." I will standby this statement. Who cares what you are standing by? The guy who reported the incident did not even know what the root cause (engine or wing/fuel tank fire) was, but you do, huh? The wing burned through as they were about to land. Hydrodynamic ram killed that airplane and its crew. FYI, *any* airplane with an uncontrolled fire in its engine/wing is susceptable to subsequent structural failure. And you ignored the fact that aircraft designed exclusively for military use have also been lost to ..50 cal and below hits--so where is this much greater vulnerability of the P-3 in view of that fact? Any civil transport, such as this one was (before being modified), is terribly vulnerable: http://www.concordesst.com/accident/...es/flames1.jpg But much can be done to mitigate the effects. And is being done on "War"planes: http://jas.jcs.mil/news/pdf/2003_fall.pdf "When it comes to providing aircraft fuel system ballis-tic tolerance capability, it is necessary to understand that protecting from a catastrophic explosion in a fuel tank ullage cannot be accomplished solely with self-sealing fuel cells. To provide the desired level of ballistic tolerance requires a hand-in-hand compli-mentary approach which incorpo-rates both self-sealing fuel cells and OBIGGS. Ultimately, it is necessary to incorporate the appropriate fuel system requirements verbiage requir-ing a self-sealing capability and that damage from certain high explosive incendiary and/or armor piercing incendiary rounds must not cause catastrophic explosion. This will drive a solution, which provides the proper level of survivability protec-tion for both permanently mounted and auxiliary internal fuel cells." Control the susceptability. I.e, the "L" in ARL-M... I also note that in the first few sentences the authors identify the difference between "susceptability" and "vulnerability"--the latter does not come into play if the former is controlled such that hits don't occur--which will be the predominant environment that the ACS and E-10 will operate in. Glad you found out the difference between the two. I think you fit firmly in the camp described below. Its a very wrong and hubris filled view, but I'll let some much more credible sources speak make the case: http://jas.jcs.mil/news/pdf/2003_fall.pdf FYI, I stopped going to your sources shortly after determining that you were twisting the position of the Lexington Institute in regards to the viability of using commercial airframes in roles such as ACS and E-10. snip How can you be so verbose and still fail to answer the question regarding what you think that "L" in ARL means? Brooks |
"Kevin Brooks" wrote in message ...
FYI, I stopped going to your sources shortly after determining that you were twisting the position of the Lexington Institute in regards to the viability of using commercial airframes in roles such as ACS and E-10. Never, not once, have you cited any references, at least I've offered up SOMETHING to supoort my case. You say I twisted what Lexington Institute has to say. You are completely wrong. In the ISR lessons learned, Dr. Thompson was addressing ISR as it stood this summer in light of recent experiences. You've ignored the "lessons unlearned" part quite well. In the ACS paper, of the two platforms, he very much sided against the EMB(and I couldn't agree with him more), but he figures cost will be the driver in the program which means the EMB may well end up the choice. He never stated an opinion one way or the other about using civil airframes. Ditto for the paper on the E-10. As a matter of fact, he is stressing the importance of fielding the radar and not really even broaching what airframe(more on theat later) it will be on. Those two papers had a very narrow focus. You are putting more into them than they offer. At least I've cited references, most of which are .mil. When are you going to back up your "facts" with anything other than your derisive retorts? Please point to the "special engineering" that sets an AFSOC CN 235/295 apart from one of those Gulfstreams. As one whose day job involves aviation safety and aircraft engineering, I can say a whole lot about this....but I won't bore you. In a nutshell, what the CN-235 has going for it is its very simplicity. Also its relatively clandestine use-its not emitting, nor loitering for long periods on station like the ACS and E-10 will-certainly helps in reducing its suceptability as well. I knew some SOF types when I lived near Hurlburt some years ago, and they hated that airplane by the way. In their words, "What a piece of crap". IIRC there is talk of replacing them...but I won't twist anything for you. Not much is written about the AX yet, but I'll wager a bet that it certainly will benefit from survivability analysis and engineering. Wanna put some cash on it? Fact is they are very vulnerable platforms that are being considered for vital missions and that potential adversaries are building weapons to field against. Big jump from that Russian firm "slowly" pursuing a very long range AAM program to "are building". The Novator AAM is in slow development. The S-300 S-400 are no joke systems. Its explicitly stated they are intended to be employed against AWACS. No twisting from me here Kevin. Read it for yourself... http://www.aeronautics.ru/s400triumph.htm "While the Triumph[S-400] SAM system is capable of firing older 48N6E missiles, it will use a brand new missile currently in final stages of development. This new missile would feature a combination of semi-active/active homing, an effective range of up to 400km and it will be capable of hitting new-generation air-to-surface missiles and AWACS aircraft." Look, we are NOT sending them into contested airspace, OK? Period. There is that strange "OP-2E's" you keep ranting about... And again, we are not going to send these assets in against "undue risk". Some guys whose remains finally made it home to Arlington recently were certainly ordered into contested airspace in their ISR assets...Even in the face of "undue risk". The job had to get done. Thats what war-real war-is about Kevin. You seem to be suffering from a fairly bad bout of "Victory Disease" Kevin, this may help you get over it: http://www.army.mil/prof_writing/vol...03/9_03_5.html That some AF units seem to be exempt from the possibility of taking enemy fire has been a long term inherent cultural issue apparently. I'm not the only one to say it either: http://www.airpower.maxwell.af.mil/a...jun/cahoon.htm You didn't bother to read this I presume...Go ahead. Learn something new Kevin. Its an old paper, but pertinent to the debate. C-17 drivers just recently went through combat certification for the first time. The question begs, why weren't they treated as warfighters all along? Meaningless. ACS and E-10 are not airlifters. Airlifters may indeed have to drop down into a MANPADS/AAA threat environment to perform their mission--ACS and the E-10 do not. Whats not meaningless is the fact...yes Fact...the AF was caught off guard about the need to consider the C-17 a warplane and its operators warfighters. From AvWeek Jan.5'04: "The C-130 community has had a weapons instructor course (WIC) for many years. But no one expected the C-17 force to [come] under fire very often...." Judging from what was written in 1983 all the way to what was written in 2004, the AF has a relatively poor track record at figuring out which of their assets may be getting shot at down the road. Quick! Call the Pentagon and tell them you have discovered the flaw in the plans that so many professionals have been developing for decades now! From whats written below its a topic of offical debate, but mostly classified apparently...As it should be. My guess is that the Budgeteering and Powerpointing Prowess is most important in acquisitions right now. Suriviablity analysis is not getting the attention it needs. http://www.fas.org/irp/program/collect/SIGINTWP.pdf "ADA Susceptibility: GR/CS and ARL susceptibility to SA 10 and SA 12 threats was the cornerstone of the argument to eliminate them from the system. While it is true that they are susceptible to the threats, they are no less so than many of the retained systems. Rivet Joint,EP3, ES3, all retained by the study, fly at altitudes similar to Army systems. Their survivability will require stand-off as well. GR/CS normally flies in the same vicinity as JSTARS and AWACS, two targets an enemy would likely pursue with more vigor than an RC12. Discussions made it clear that the entire air campaign was not considered in the analysis. In fact, constraints of the ADA threat were not uniformly applied. Had it been so, many other platforms would have to become HAPs as well (JSTARS, AWACS)." I don't know where you get these ideas, but the E-8 JSTARS surveillance range reportedly reaches out to around 250 km--SA-10/12 manage what, maybe 90 km? Since I'm sure you didn't open up the link on the S-400 , here is what it says: http://www.aeronautics.ru/s300site.htm KEY CHARACTERISTICS S-300PMU1 S-300MU2 S-400 Range, km (max) 150 200 400 Altitude, km (max) 25-27 25+ 25+ Altitude, km (min) 10 10 10 So why were they concerned. Obviously the longer range threat had not been rendered below the "undue threat" threshold. That is not what the evidence indicates. In fact, were any longer range systems used to engage the KC's? Nope--the threat was ameliorated. We know that after the fact. With tankers going "forward". , maybe its time they need some WICs as well. And why stop there include the ISR folks as well. As an FYI the whole point about the E-10 could well be moot: http://www.aviationnow.com/avnow/new...s/02094wna.xml My beef is that these airframes represent easy kills and the COTS culture is ignoring the problem. The threat to them while airborne isn't there today, but some guys who mean us ill will are working hard on that problem. Easy kills on the tarmac are another issue as well and certainly possible today. A few bits of shrapnel and its Buh-Bye shiny new 767-400. An airframe that can be expected to take a measured amount of battle damage is a necessity for ALL military aircraft. The problem is, in order to save costs, this analysis is not getting done. It'll cost lives down the road too, just like past times when vulnerability issues were ignored. What the DOD and the manufacturers should do is subject these airframes to some rigourous survivability analysis. To digress a bit, the MMA is expected to retain the low level recce and sub attack mission, so the MMA really needs the benefit of such analysis as well. Modify FAR PART 125 and MIL-STD-1530A damage tolerance standards to include the spectre of the MANPADS threat, and spread the total costs over civil and military production alike. I'm off the soapbox. And, oh yes, I DO know what the "L" in ARL means... sid |
![]() "sid" wrote in message om... "Kevin Brooks" wrote in message ... rant snipped Look, we are NOT sending them into contested airspace, OK? Period. There is that strange "OP-2E's" you keep ranting about... And again, we are not going to send these assets in against "undue risk". Some guys whose remains finally made it home to Arlington recently were certainly ordered into contested airspace in their ISR assets...Even in the face of "undue risk". The job had to get done. Thats what war-real war-is about Kevin. Are you talking about the DASH-7 ARL that punched into a freakin' mountainside? Geeze, just what kind of damage tolerance are you demanding? snip I don't know where you get these ideas, but the E-8 JSTARS surveillance range reportedly reaches out to around 250 km--SA-10/12 manage what, maybe 90 km? Since I'm sure you didn't open up the link on the S-400 , here is what it says: http://www.aeronautics.ru/s300site.htm KEY CHARACTERISTICS S-300PMU1 S-300MU2 S-400 Range, km (max) 150 200 400 Altitude, km (max) 25-27 25+ 25+ Altitude, km (min) 10 10 10 Uhmmm...isn't S-400 the ABM derivitive? Which explains it longer range--against targets waaay upstairs in their radar horizon at that range? As to the others....250 km is greater than either of them. Now, how often are you going to see those systems up near the FLOT? That's right--pretty much never. Talk about being an ATACMS magnet... snip My beef is that these airframes represent easy kills and the COTS culture is ignoring the problem. The threat to them while airborne isn't there today, but some guys who mean us ill will are working hard on that problem. Easy kills on the tarmac are another issue as well and certainly possible today. A few bits of shrapnel and its Buh-Bye shiny new 767-400. An airframe that can be expected to take a measured amount of battle damage is a necessity for ALL military aircraft. Oh, gee whiz, what about those C-40's? And those aircraft specified to go into low threat areas? I guess you would discount the future use of CRAF assets as well, right? What with all of those nasty super long range AAM's...oops, that's right, they are just ghostware. snip And, oh yes, I DO know what the "L" in ARL means... I don't think you do, from the angle of your rants. It does NOT mean "low altitude", nor does it mean "low chance of surviving its mission". Brooks sid |
... Look, we are NOT sending them into contested airspace, OK? Period. There is that strange "OP-2E's" you keep ranting about... And again, we are not going to send these assets in against "undue risk". Some guys whose remains finally made it home to Arlington recently were certainly ordered into contested airspace in their ISR assets...Even in the face of "undue risk". The job had to get done. Thats what war-real war-is about Kevin. Are you talking about the DASH-7 ARL that punched into a freakin' mountainside? Geeze, just what kind of damage tolerance are you demanding? Hate to disappoint you but...No, I'm not talking about what happened in Colombia at all. Laos actually. Since you are spouting all these "facts", I thought you'd know all about it. Uhmmm...isn't S-400 the ABM derivitive? Which explains it longer range--against targets waaay upstairs in their radar horizon at that range? As to the others....250 km is greater than either of them. Now, how often are you going to see those systems up near the FLOT? That's right--pretty much never. Talk about being an ATACMS magnet... On your last point, its a matter of active concern. The radars and targeting systems for these systems are bit tougher to counter. Be honest, did you ever think the Serbs were capable of shooting down that F-117 before it happend Kevin? Paycheck says no. Of course I don't expect you to open this: http://www.airpower.maxwell.af.mil/a...pietrucha.html Everyone seems to understand the S-400's threat against aircraft...except you. Oh yeah, have you checked out anything on "Three Attacks Three Defenses?" Oh, gee whiz, what about those C-40's? And those aircraft specified to go into low threat areas? I guess you would discount the future use of CRAF assets as well, right? What with all of those nasty super long range AAM's...oops, that's right, they are just ghostware. C-17s were expected to be in low threat areas...until recently. I should have phrased my statement (which I'm sure you will misconstrue as a rant) to say ALL aircraft involved in the active conduct of a battle...even the ones that traditionally have operated on the periphery. For C-40s et all, thats where the changes to Part-25 (typo'd as 125 earlier)and MIL-STD-1530A come in. MANPADS is now a threat to ALL transport category aircraft. Speaking of CRAF(which isn't instituted right now BTW)... Even though it wasn't a flight under DOD auspicies, DHL-and eventually LLoyds of London-have paid dearly for operating in a hot war zone. By the Grace of God only that crew and aircraft didn't end up in a smoking hole, and Thank God too that it was empty and not carrying 300 or so of our finest. Yes I know it was freight dog, so don't get all ****y about that little "fact". Did you see the size of the shrapnel hole where the fragment entered the bottom of the wing and started that hydrodynamic ram created fire? Its really small so look carefully. http://gallery.colofinder.net/dhl-ai...le12042003a010 I wonder what a S-400 warhead would do to a similarly engineered EMB-145? Novator's product is a bit more than ghostware, but I don't want to disturb any of your "facts". And, oh yes, I DO know what the "L" in ARL means... I don't think you do, from the angle of your rants. It does NOT mean "low altitude", nor does it mean "low chance of surviving its mission". LOL!! I worked for the operator that had the DASH-7s before the Army got them(I've moved on since). Regardless, the ACS won't have an "L" attached. Its expected to be"one of the first to the fight". |
![]() "sid" wrote in message om... "Kevin Brooks" wrote in message ... Look, we are NOT sending them into contested airspace, OK? Period. There is that strange "OP-2E's" you keep ranting about... And again, we are not going to send these assets in against "undue risk". Some guys whose remains finally made it home to Arlington recently were certainly ordered into contested airspace in their ISR assets...Even in the face of "undue risk". The job had to get done. Thats what war-real war-is about Kevin. Are you talking about the DASH-7 ARL that punched into a freakin' mountainside? Geeze, just what kind of damage tolerance are you demanding? Hate to disappoint you but...No, I'm not talking about what happened in Colombia at all. Laos actually. Since you are spouting all these "facts", I thought you'd know all about it. We have not lost an ARL in Laos. Uhmmm...isn't S-400 the ABM derivitive? Which explains it longer range--against targets waaay upstairs in their radar horizon at that range? As to the others....250 km is greater than either of them. Now, how often are you going to see those systems up near the FLOT? That's right--pretty much never. Talk about being an ATACMS magnet... On your last point, its a matter of active concern. The radars and targeting systems for these systems are bit tougher to counter. Be honest, did you ever think the Serbs were capable of shooting down that F-117 before it happend Kevin? Paycheck says no. Hand it over. Anybody with have a brain knows that stealth is not completely infallible, and that golden BB's do exist. The F-117 is a tough enough target to acquire and hit--but it is not *impossible*. Of course I don't expect you to open this: http://www.airpower.maxwell.af.mil/a...pietrucha.html Everyone seems to understand the S-400's threat against aircraft...except you. Uhmmm...note that scenario has them facing F-15E's, not E-10's or ARL's? Gee, wonder why... As to the realism of that particular threat...a single ATACMS battery sitting in that same UAE territory can drill your S-400 site each time the radar gets flipped on. Joint operations is a wonderful thing, isn't it? snip Oh, gee whiz, what about those C-40's? And those aircraft specified to go into low threat areas? I guess you would discount the future use of CRAF assets as well, right? What with all of those nasty super long range AAM's...oops, that's right, they are just ghostware. C-17s were expected to be in low threat areas...until recently. I should have phrased my statement (which I'm sure you will misconstrue as a rant) to say ALL aircraft involved in the active conduct of a battle...even the ones that traditionally have operated on the periphery. For C-40s et all, thats where the changes to Part-25 (typo'd as 125 earlier)and MIL-STD-1530A come in. MANPADS is now a threat to ALL transport category aircraft. Oh, no! We have to scrap all of our airliners NOW! Build new ones that meet your lofty criteria for survivability, right? Speaking of CRAF(which isn't instituted right now BTW)... Even though it wasn't a flight under DOD auspicies, DHL-and eventually LLoyds of London-have paid dearly for operating in a hot war zone. By the Grace of God only that crew and aircraft didn't end up in a smoking hole, and Thank God too that it was empty and not carrying 300 or so of our finest. Yes I know it was freight dog, so don't get all ****y about that little "fact". No, the "fact" you conveniently ignore is that it WAS a civil aircraft, it WAS hit by a MANPADS, and...it did not fall apart! It actually *survived*. Not a good example to support your "commercial airframes can't handle modern combat requirements" sermon, now is it? snip I wonder what a S-400 warhead would do to a similarly engineered EMB-145? Probably the same thing it would do if it hit any *military* aircraft--blow it to hell and back. You are trying to compare the effects of a MANPADS strike (which we now know is survivable on the part of a commercial aircraft, thanks again for the example) to that of a big honking warhead like what is carried on the S-300/400 class weapons?! Novator's product is a bit more than ghostware, but I don't want to disturb any of your "facts". Then tell us where it is--when is the first testflight? What kind of guidance system will it use? Come on now--give us the specifics on this new uber-weapon. And, oh yes, I DO know what the "L" in ARL means... I don't think you do, from the angle of your rants. It does NOT mean "low altitude", nor does it mean "low chance of surviving its mission". LOL!! I worked for the operator that had the DASH-7s before the Army got them(I've moved on since). Regardless, the ACS won't have an "L" attached. Its expected to be"one of the first to the fight". I hate to tell you this, but the ARL also serves in that role--or did you think we deployed them to Korea for grins and giggles? The key is *where* it conducts its "fight"...yep, somewhere well to the rear of the FLOT, with due regard to any potential threat systems that *could* cause it problems if it moved into their envelope. This has been loads of fun, but in the end it sounds a bit like that fellow's one-man crusade against those eee-vil oil companies who stole his kool-aid/gas formula that gives him 100 miles to the gallon, and can't understand *why* the mainstream tech world just can't seem to grasp the importance of his discovery... So adios, and have a nice day--we can revisit this the day we start trying to penetrate the bad guys' IADS with those ERJ's.... Brooks |
... Hate to disappoint you but...No, I'm not talking about what happened in Colombia at all. Laos actually. Since you are spouting all these "facts", I thought you'd know all about it. We have not lost an ARL in Laos. Yeah. I know that. Apparently you are unaware of the ISR assets we DID lose in Laos. Hand it over. Anybody with have a brain knows that stealth is not completely infallible, and that golden BB's do exist. The F-117 is a tough enough target to acquire and hit--but it is not *impossible*. I only have your word for it and so far your words have not been substantiated or proven particularly reliable. Do you think we are the only ones pursuing innovative networked targeting systems? You are showing more signs of that "Voctory Disease". Of course I don't expect you to open this: http://www.airpower.maxwell.af.mil/a...pietrucha.html Everyone seems to understand the S-400's threat against aircraft...except you. Uhmmm...note that scenario has them facing F-15E's, not E-10's or ARL's? Gee, wonder why... As to the realism of that particular threat...a single ATACMS battery sitting in that same UAE territory can drill your S-400 site each time the radar gets flipped on. Joint operations is a wonderful thing, isn't it? Excellent!! You did open a link. I urge you to open the others as well...especially those dealing with surviviability. Whatever you think of my points here, there is wealth of good stuff there. I'm heartened that you now know the difference between "vulnerability" and "susceptability" Networked systems, that certainly wont be fielded by 2006, is what it takes to defeat that kind of threat. What is expected to serve as the nexus for the networked systems? Why our airborne ISR assets of course. Neutralize them and we have a big problem. Our potential adversaries are aware of this and have stated they want to counter those assets in a big way. Once you get done doing the research on ISR asset losses in Laos, read up on Three Attacks Three Defenses For C-40s et all, thats where the changes to Part-25 (typo'd as 125 earlier)and MIL-STD-1530A come in. MANPADS is now a threat to ALL transport category aircraft. Oh, no! We have to scrap all of our airliners NOW! Build new ones that meet your lofty criteria for survivability, right? Thats silly Kevin. What CAN be done is to harden those civil airframes destined for military use to a measured level. Then leverage at least some of those enhancements (whatever analysis shows to be the best) into new construction aircraft. On the civil side, all thats being proposed are pork riddled expensive countermeasure sets. IF you were to read up on survivability, you would see a balance between susceptability and vulnerability is what it takes for sucess. The big problem is the analysis is not getting done for aircraft that will sorely need the protection one day. No, the "fact" you conveniently ignore is that it WAS a civil aircraft, it WAS hit by a MANPADS, and...it did not fall apart! It actually *survived*. Not a good example to support your "commercial airframes can't handle modern combat requirements" sermon, now is it? Didn't ignore it one bit. It was a very small piece of shrapnel that caused that winfg to burn almost all the way off. Because this aircraft landed means little. It had no hydraulics (and no manual reversion), and the left after spar was burned 85 to 90 pct through. The fact that airplane landed really doesn't say much except that it was a calm day, the aircraft was empty and light, and the captain had just recently been reviewing the United DC-10 no hydraulics landing. If it had been windy, or if the airplane had been heavier, or if the captain had not thought about how to maneuver with engines only, the story would have been different. They were really, really lucky. An aircraft that had been built to take at least some damage which is what these people are all about making sure happens: http://jas.jcs.mil/main.htm would have had a whole lot better chance at making it back alive. I hate to tell you this, but the ARL also serves in that role--or did you think we deployed them to Korea for grins and giggles? The key is *where* it conducts its "fight"...yep, somewhere well to the rear of the FLOT, with due regard to any potential threat systems that *could* cause it problems if it moved into their envelope. Essentially a cold war type deployment prior to the initiation of hostilities. You are exhibiting more symptoms of the Victory Disease. http://www.army.mil/prof_writing/vol...03/9_03_5.html With a projected SAR/MTI range of 120 km (in flat terrain) ACS would be well within range of S-300 S-400 threats. On a parting note. Did you see where the E-10 isn't likely to be built anytime soon anyway? |
Magneto/comm interference on TKM MX-R Narco 120 replacement | Eugene Wendland | Home Built | 5 | January 13th 04 02:17 PM |
Canada to order replacement for the Sea King | Ed Majden | Military Aviation | 3 | December 18th 03 07:02 PM |
Replacement for C130? | John Penta | Military Aviation | 24 | September 29th 03 07:11 PM |
Narco MK 16 replacement | SoulReaver714 | Aviation Marketplace | 1 | September 23rd 03 04:38 PM |
Hellfire Replacement | Eric Moore | Military Aviation | 6 | July 2nd 03 02:22 AM |
