Converting a USA C of A from Standard to Experimental
Old December 3rd 10, 10:18 PM
RAS56 RAS56 is offline
Member
First recorded activity by AviationBanter: Dec 2010
Thanks guys for all the gouge! I really appreciate it!!
Looks like my first call is to the FSDO closest to me...in San Antonio...that is unless someone has dealt with the ones in D/FW or Houston and had less headaches.
Again, many thanks!
Rob S.
ps-any -19 owners done the lift up panel mod? Wondering if it is worth the hassle...
Old December 4th 10, 02:17 AM posted to rec.aviation.soaring
Andy[_1_]
Default Converting a USA C of A from Standard to Experimental
Again, many thanks!
Rob S.
the hassle...
RAS56
I flew a 19b for 15 years and 1,500 hours and never had an issue with
the fixed panel and I'm over 6ft tall. Don't change it unless you
have a real reason to do so. The canopy gas strut is barely strong
enough to hold up the canopy and is a real bitch to replace. Unlike
some gliders the strut is still under compression when the canopy is
fully open and you have to make a special tool that you hope will hold
it compressed while you do the installation. Do a good job on the
tool, if it lets go it could make quite a mess.
Andy
New Standard D25 - New Standard D25 sun n fun 2010 (Custom).jpg Glen in Orlando Aviation Photos 0 April 22nd 10 11:49 PM
experimental to standard certificate shkdriver Soaring 20 January 19th 10 09:25 AM
Converting a glider from Experiemental to Standard Airworthiness Peter[_1_] Soaring 2 November 15th 09 06:20 AM
Converting GPS info [email protected] Piloting 9 March 14th 06 01:36 AM
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
