New Vent!
Old December 9th 10, 08:36 PM posted to rec.aviation.soaring
Papa3
Default New Vent!
On Dec 9, 3:11*am, "Matt Herron Jr." wrote:
What keeps rain, wasps, mice, etc. from entering the vent hole when on
the ground?
The same thing that keeps them from coming in through: the apple core
window, the nose vent, the spar carry through, the wheel well, ie.
nothing :-)
Look at it this way - when the ship's assembled and on the line,
there are lots of easier ways for varmints to get in. When it's
disassmbled in the trailer, there are huge holes where the wings used
to be.
Old December 7th 10, 09:49 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default New Vent!
On 12/7/2010 11:16 AM, wrote:
I have an exit vent in the lower aft area of the fuselage of both my
'27 and '28. With all the other stuff done sealing rudder hinge,
elevator drive, horn splitters, etc, it improved negative pressure and
flow and resulted in less noise. This vent is a huge ass ache to put
in with the associated nozzle, has significant structural implications
requiring reinforcement, and simply, is not for the faint hearted.
The new vent on top is in a low pressure area which helps a lot with
getting flow and reduced cockpit pressure. It also takes an hour and a
half to install instead of about 10 hr. It's structural implications
are minimal. It slightly reduces available baggage storage in the top
center 4 inches.
Both my gliders will have rear vents closed this winter and '28 will
get top vent.
I got so much air from the front vent and eyeball vent on my ASH 26 E
(standard tail vents at the rudder cables) that I plugged up half the
duct work from the nose to make it easier to control. Still get tons of
air from the eyeball and scoop when I open them, so the air doesn't seem
to have any trouble getting out of the glider. I don't know where it is
leaving, however.
How low must the cockpit pressure be to assure myself the air isn't
going out the canopy/cockpit edge, gear doors or wing roots?
What is a good way to measure the cockpit pressure?
email me)
Old December 7th 10, 10:29 PM posted to rec.aviation.soaring
Grider Pirate
Default New Vent!
center 4 inches.
get top vent.
leaving, however.
email me)
In my case a water manometer* connected to the static system on one
side and open to cabin pressure on the other. All I need to do is get
around to it. I've been carrying thte bits and pieces in my trailer
for a couple years now, but I always think I'm going to fly 500k, and
don't want to carry stuff around (while I actually fly 'round the
patch all day).
*just a piece of clear vinyl tubing actually
Old December 8th 10, 12:20 AM posted to rec.aviation.soaring
Kevin Christner
Default New Vent!
center 4 inches.
get top vent.
FWIW
UH
What work needs to be done to fit these to other types? Reglass the
cockpit scoop to fit the inside of the fuselage shell?
2C
Old December 8th 10, 02:12 AM posted to rec.aviation.soaring
Andrzej Kobus
Default New Vent!
I assume this vent will not work with a fuselage tank installed,
correct?
Old December 8th 10, 12:50 PM posted to rec.aviation.soaring
Default New Vent!
correct?
Requires mod to fuselage tank. This is in prototyping and mold making
and will be available early next year. Probably not
as a home kit. It is much more complicated to install than the vent.
UH/LX
Old December 8th 10, 12:48 PM posted to rec.aviation.soaring
Default New Vent!
center 4 inches.
get top vent.
FWIW
UH
What work needs to be done to fit these to other types? *Reglass the
2C
One done so far is for '24/27/28/29. It is molded to follow the inside
contour of the fuselage which has a lap joint.
To make one to fit another type, outer shape needs to be matched and
inner shape needs to be matched. Long answer
to say it probably won't be right. Other ships may follow- we'll see.
UH/LX
Old December 8th 10, 01:14 PM posted to rec.aviation.soaring
Andy[_1_]
Default New Vent!
UH/LX
Any thought of making an extended baggage tray for the 28? There is
no reason it couldn't extend back like the 27 does. That would give me
back the forward of spar space that I would lose with the collector
plate. That forward of spar space is filled on my glider with 2 water
bottles, hand held radio, parachute bag, and canopy cover. (and the
essential landout deterrent - the stale peanut butter sandwich)
Maybe the reason my 28 is quiet is that all the space between my head
and the tail is stuffed full
What measurements have been done on performance gains? I'd like to
see data for your 28 pre vent and post vent for sink rate at 90kts. I
won't spend $500 to reduce noise level or increase ventilation but I
would for a significant reduction in the sink rate at high speeds.
Andy
Old December 7th 10, 11:15 PM posted to rec.aviation.soaring
JS
Default New Vent!
I experienced the reaction of several pilots to Paul's AS-W20 vent
mod, all positive. First saw this kit in Hank's shop. Looked at my
vent parts when I was up at Williams the other day.
To hopefully answer Andy's question: The largest part (the scoop
from the canopy rail to the hard mounted outer part) is removable.
Velcro onto the canopy frame and a ring of foam sealing the throat
where it slides into the outer part. It will take some room in the
baggage compartment, but not most of it.
In my 27 I won't be able to use much of the scoop, since there's an
"E" Oxygen bottle in the upper baggage compartment and currently an
APRS black box strapped on top of it.
Regarding flatulence, it's more about moving hot air (including that
I've generated in this forum) since many of us fly where it gets
bloody hot.
"More beans, Mr. Taggart?"
On Dec 7, 6:56*am, Andy wrote:
Looks nice but where do I put all the stuff that now sits in the over-
spar storage area? *I don't think I want to discard my landout kit so
I can fit a vent system that has an unknown (to me) performance
advantage.
Andy
Quiet Vent Ron (RW) Soaring 26 June 30th 18 04:31 PM
JS-1 Exhaust Vent sisu1a Soaring 16 July 27th 10 03:32 AM
Quiet Vent Ramy Soaring 6 October 27th 06 05:27 AM
337 for vent covers? Robert M. Gary Owning 14 November 12th 05 05:31 PM
Eye Ball Vent B. Iten Soaring 4 September 4th 04 09:38 AM
