JS-1 Exhaust Vent
Old July 26th 10, 12:33 AM posted to rec.aviation.soaring
sisu1a
Default JS-1 Exhaust Vent
Gotta hand it to Johan Bosman on this one... look at pg 5 of this pdf:
http://www.streckenflug.at/news/js_c...on_2010_07.pdf
Personally I think his take on the exhaust vent is simply ingenious.
The opening on that thing is immense and has got to allow much air to
pass, but flow is organized by that little louver/wing. Pure genius.
I may just be preoccupied on the subject right now since I'm in the
middle of making vented ASW-20 hatches (Mandl and Butler styles) for
the upcoming 20 gathering at Tehachapi. Pics to follow...
-Paul
Old July 26th 10, 02:52 AM posted to rec.aviation.soaring
Bruno[_2_]
Paul,
I am greatly looking forward to seeing your work at the upcoming 20
get together. I was talking to a few pilots I respect at the Region 9
Logan contest last week and mentioned your proposed vent and they said
that there will be a problem with the hatch being off to one side and
not centered. What do you think? Still count me in for trying one
out.
Bruno - B4
On Jul 25, 4:33*pm, sisu1a wrote:
Gotta hand it to Johan Bosman on this one... look at pg 5 of this pdf:http://www.streckenflug.at/news/js_c...on_2010_07.pdf
-Paul
Old July 26th 10, 03:07 AM posted to rec.aviation.soaring
Dave Nadler
On Jul 25, 8:52*pm, Bruno wrote:
... there will be a problem with the hatch being off to one side and
not centered...
You mean, like the DG exit vents ?
Old July 27th 10, 04:32 AM posted to rec.aviation.soaring
John Bojack[_2_]
"Dave Nadler" wrote in message
No, like the Antares 220 volt electrical plug outlet and outboard fire
extinguisher bracket.
Old July 26th 10, 03:11 AM posted to rec.aviation.soaring
Darryl Ramm
On Jul 25, 5:52*pm, Bruno wrote:
Paul,
get together. *I was talking to a few pilots I respect at the Region 9
not centered. *What do you think? *Still count me in for trying one
out. *
Bruno - B4
-Paul
Maybe equally impressive to the engineering of the JS1 exhaust vent is
the psychological-gamesmanship of emphasizing the performance
enhancement effects of this just prior to the 18m Worlds. Love it.
Darryl
Old July 26th 10, 08:30 AM posted to rec.aviation.soaring
Brad[_2_]
Paul,
out. *
Bruno - B4
-Paul
Darryl
perhaps some will file the trailing edge of their wings to a knife
like edge...............no, wait, that's been done before!
Old July 26th 10, 05:54 AM posted to rec.aviation.soaring
Tim Taylor
-Paul
I still think a reversed NACA duct will work better than the Butler
and much better than the Mandl. The Mandl throws the low speed air
out into the faster air stream. The JS design accelerates half the
air over the airfoil but what happens to the air under the airfoil?
Old July 26th 10, 09:02 AM posted to rec.aviation.soaring
noel.wade
and much better than the Mandl. *The Mandl throws the low speed air
out into the faster air stream. *The JS design accelerates half the
All good points, but I have an even bigger question: What happens when
the cockpit air intakes are closed (say on a cold day or at high/cold
altitudes)? It seems to me that there would be an ideal extractor
position & size (or louver camber/AOA) for each particular air intake
position... You're looking for a balance in order to keep the fuselage
airflow from being unnecessarily disturbed at one end or the other,
right? I mean, with a tight canopy seal and closed intakes isn't your
fixed-size extractor going to be starved for airflow once the cockpit
pressure reaches its minimum, and that is going to in turn wind up
disturbing the airflow over the extractor itself?
--Noel
Old July 26th 10, 04:58 PM posted to rec.aviation.soaring
Grider Pirate
altitudes)? *It seems to me that there would be an ideal extractor
right? *I mean, with a tight canopy seal and closed intakes isn't your
--Noel
EXACTLY!! No extractor design optimized for a given airspeed and vent
opening will be optimal for all speeds and vent openings. When might
I close my vents (mostly)? Likely running near redline near cloudbase
or the PCA. (though that doesn't happen as often as I'd like!). I
made one for my Speed Astir (aka - the Grob solar sauna) right after
seeing the DG article. I have no idea how it changes the glider
performance, but it keeps ME from roasting quite so much, and that's
gotta' help!
Old July 26th 10, 05:05 PM posted to rec.aviation.soaring
nurflugel[_2_]
The NACA duct was designed such that the edges create vortices
which force the air into the duct. Reversing the flow through a NACA
duct is an inefficient way to exit fluid from a body.
Quiet Vent Ron (RW) Soaring 26 June 30th 18 05:31 PM
Quiet Vent Ramy Soaring 6 October 27th 06 06:27 AM
337 for vent covers? Robert M. Gary Owning 14 November 12th 05 06:31 PM
Tail Vent? jjcact Soaring 1 June 10th 05 04:10 PM
Eye Ball Vent B. Iten Soaring 4 September 4th 04 10:38 AM
