MIT UAV soaring technique
Old December 6th 10, 03:40 PM posted to rec.aviation.soaring
bildan
Default MIT UAV soaring technique
http://www.technologyreview.com/blog...6103/?p1=Blogs
Old December 6th 10, 03:56 PM posted to rec.aviation.soaring
jcarlyle
Reminds me of the Dean who was trying to convince a wealthy alumni to
contribute. The Alum said he wouldn't, because everything the school
did was impractical. The Dean, in an effort to prove they focused hard
on practicality, handed the Alum a doctoral thesis entitled
"Increasing Egg Production". The Alum opened it, read the first
sentence, and declared that it proved his point precisely. The first
sentence read: "First, assume a spherical chicken".
-John
Old December 6th 10, 05:14 PM posted to rec.aviation.soaring
Matt Herron Jr.
sentence read: *"First, assume a spherical chicken".
-John
Finally! Some scientific justification for my thermal centering
technique. It is called the WFOOIA algorithm, an acronym for "Whoops!
Flew Out Of It Again". Other pilots may freely use this techniques as
long as the author(s) are properly credited... As it is open source,
pilots may also improve upon the technique, provided they share it
with the community.
Matt (Jr.)
Old December 6th 10, 07:13 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
I smell a certain lack of preliminary research: any RC glider pilot will
tell you that pressure sensing TE varios for models have been available
for a long time. It would seem to be a lot easier and less power-hungry
to sample one of these than to calculate climb rate from GPS output.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 6th 10, 09:55 PM posted to rec.aviation.soaring
bildan
On Dec 6, 12:13*pm, Martin Gregorie
martin@ * | Martin Gregorie
org * * * |
Whether this blogger has a good understanding of thermalling technique
or not, it's interesting that UAV makers (Presumably for the military)
have an interest in UAV's that automatically find and use thermals.
It makes sense they should be interested. Maybe thermal finding
instrumentation will come out of it.
Old December 6th 10, 10:01 PM posted to rec.aviation.soaring
Andrew Blanchard
Autonomous Soaring has been around for awhile.
Take a look at:
http://soaring.goosetechnologies.com/
Cheers,
Andrew
Old December 6th 10, 10:26 PM
shkdriver shkdriver is offline
Member
First recorded activity by AviationBanter: Aug 2008
It looks to me like someone in the study confused the little thermal strength indicator cones of the graphic with individual thermals.
Old December 7th 10, 02:09 AM posted to rec.aviation.soaring
Andy[_1_]
Default winch launching a 17 m shk
On Dec 6, 2:40*pm, shkdriver
Anyone have any experience/thoughts to share about winch launching a
shempp-hirth SHK? My example has CG tost hook on gear leg.
Thanks,
Scott W.
shkdriver
Read the pilot handbook?
Old December 7th 10, 05:04 PM posted to rec.aviation.soaring
HoUdino
OCSA did a few auto tows off a dry lake with an SHK a few years
ago...climbs like a homesick angel!
LT/HU
Old December 8th 10, 06:35 AM posted to rec.aviation.soaring
GM
On Dec 6, 4:40*pm, shkdriver
Thanks,
Scott W.
shkdriver
Should not be a problem. Keep in mind that when the SHK was designed,
winch-launching was the primary take-off method in Germany. Even some
of the earlier glass ships like the ASW-15a did have only a CG-hook
while the aero-tow hook was an option.
welding technique for clusters wright1902glider Home Built 26 March 27th 09 12:49 AM
Question technique Patrick R7 Aviation Photos 4 September 30th 08 01:50 PM
spinner trimming technique Dick Home Built 0 January 25th 05 11:57 PM
instructor technique Mike Stramba Soaring 8 October 3rd 03 09:45 PM
Flying Technique Question of the Day Jim Vincent Soaring 24 October 3rd 03 03:29 PM
