On Dec 8, 1:03*pm, jcarlyle wrote:
For two reasons: *(1) it costs less to perform the biannual inspection, and (2) you aren't broadcasting your tail number to the Feds. Ok, valid points. I just checked with my local avionics shop. $95 for mode C and $125 for mode S. Not a deal breaker for me. As to broadcasting the tail number - the TT21 installation menus allow the aircraft ICAO code and the registration to be set but I don't think there is an equipment requirement for them to be set. In other words I think it will work if the defaults are left unchanged. Is there any regulation that requires a mode S transponder to transmit that data in US? Andy |
On Dec 8, 12:37*pm, Andy wrote:
On Dec 8, 1:03*pm, jcarlyle wrote: For two reasons: *(1) it costs less to perform the biannual inspection, and (2) you aren't broadcasting your tail number to the Feds. Ok, valid points. I just checked with my local avionics shop. $95 for mode C and $125 for mode S. Not a deal breaker for me. As to broadcasting the tail number *- the TT21 installation menus allow the aircraft ICAO code and the registration to be set but I don't think there is an equipment requirement for them to be set. *In other words I think it will work if the defaults are left unchanged. Is there any regulation that requires a mode S transponder to transmit that data in US? Andy A Mode S transponder absolutely has to transmit the aircraft ICAO address, a correctly configured ICAO address is required for the transponder to actually work--bad things might happen if two aircraft had the same default ICAO address were being interrogated at the same time. I am not sure where else this is captured in the regulations, but checking this is a requirement at install and during the biannual "Part 43 Appendix F" test. Part 43 Appendix F... (f) Mode S Address: Interrogate the Mode S transponder and verify that it replies only to its assigned address. Use the correct address and at least two incorrect addresses. The interrogations should be made at a nominal rate of 50 interrogations per second. --- I can't find it quickly in the regs but it may just be that the requirement in 14CFR 91.215 (b) to operate in compliance with TSO C-112 (which then captures you the pilot and not just the manufacturer and that TSO's incorporation of RTCA DO-181 which may spell out the Mode S address requirement). There better be an overriding requirement, otherwise somebody could argue a pilot can can just change it at any time. Yes its the off season but I'm not so bored yet to fully follow this though. Please be very careful here. Make sure your Mode S transponder is using the correct ICAO address (the one registered to your aircraft). If you really think you are goign to be doing bad things within view of ATC then maybe you should rethink how you are flying. Darryl |
What Darryl said.
You might like to know that the avionics technician who did my VFR transponder checks went to his computer and got the proper ICAO code from the FAA. The reason is the "S" in Mode S stands for selective, and they want to be darn sure ATC is broadcasting to the proper aircraft. I was being tongue in cheek with my previous post. There's no reason, given the price and low power draw of the Trig TT21, that anyone should even consider buying anything else right now (unless they're replacing an existing transponder with the same type). -John On Dec 8, 3:37 pm, Andy wrote: As to broadcasting the tail number - the TT21 installation menus allow the aircraft ICAO code and the registration to be set but I don't think there is an equipment requirement for them to be set. In other words I think it will work if the defaults are left unchanged. Is there any regulation that requires a mode S transponder to transmit that data in US? |
On Dec 8, 2:48*pm, jcarlyle wrote:
What Darryl said. You might like to know that the avionics technician who did my VFR transponder checks went to his computer and got the proper ICAO code from the FAA. The reason is the "S" in Mode S stands for selective, and they want to be darn sure ATC is broadcasting to the proper aircraft. All seems very reasonable and I would have no intention of using an incorrect ICAO address. Did your technician also check that the transmitted registration number, which seems to be a separate data entry on the TT21, was correct? Andy |
Yes, he did.
-John On Dec 8, 5:38 pm, Andy wrote: All seems very reasonable and I would have no intention of using an incorrect ICAO address. Did your technician also check that the transmitted registration number, which seems to be a separate data entry on the TT21, was correct? Andy |
On Dec 8, 1:48*pm, jcarlyle wrote:
What Darryl said. You might like to know that the avionics technician who did my VFR transponder checks went to his computer and got the proper ICAO code from the FAA. The reason is the "S" in Mode S stands for selective, and they want to be darn sure ATC is broadcasting to the proper aircraft. I was being tongue in cheek with my previous post. There's no reason, given the price and low power draw of the Trig TT21, that anyone should even consider buying anything else right now (unless they're replacing an existing transponder with the same type). -John On Dec 8, 3:37 pm, Andy wrote: As to broadcasting the tail number *- the TT21 installation menus allow the aircraft ICAO code and the registration to be set but I don't think there is an equipment requirement for them to be set. *In other words I think it will work if the defaults are left unchanged. Is there any regulation that requires a mode S transponder to transmit that data in US?- Hide quoted text - - Show quoted text - Price is the reason $400 to $500 less than the Trig Mode C. Richard www.craggyaero.com |
On Dec 9, 7:38*am, Richard wrote:
On Dec 8, 1:48*pm, jcarlyle wrote: What Darryl said. You might like to know that the avionics technician who did my VFR transponder checks went to his computer and got the proper ICAO code from the FAA. The reason is the "S" in Mode S stands for selective, and they want to be darn sure ATC is broadcasting to the proper aircraft. I was being tongue in cheek with my previous post. There's no reason, given the price and low power draw of the Trig TT21, that anyone should even consider buying anything else right now (unless they're replacing an existing transponder with the same type). -John On Dec 8, 3:37 pm, Andy wrote: As to broadcasting the tail number *- the TT21 installation menus allow the aircraft ICAO code and the registration to be set but I don't think there is an equipment requirement for them to be set. *In other words I think it will work if the defaults are left unchanged. Is there any regulation that requires a mode S transponder to transmit that data in US?- Hide quoted text - - Show quoted text - Price is the reason *$400 to $500 less than the Trig Mode C. Richardwww.craggyaero.com Trig does not make a "Mode C" transponder. Darryl |
On Dec 9, 7:46*am, Darryl Ramm wrote:
On Dec 9, 7:38*am, Richard wrote: On Dec 8, 1:48*pm, jcarlyle wrote: What Darryl said. You might like to know that the avionics technician who did my VFR transponder checks went to his computer and got the proper ICAO code from the FAA. The reason is the "S" in Mode S stands for selective, and they want to be darn sure ATC is broadcasting to the proper aircraft. I was being tongue in cheek with my previous post. There's no reason, given the price and low power draw of the Trig TT21, that anyone should even consider buying anything else right now (unless they're replacing an existing transponder with the same type). -John On Dec 8, 3:37 pm, Andy wrote: As to broadcasting the tail number *- the TT21 installation menus allow the aircraft ICAO code and the registration to be set but I don't think there is an equipment requirement for them to be set. *In other words I think it will work if the defaults are left unchanged.. Is there any regulation that requires a mode S transponder to transmit that data in US?- Hide quoted text - - Show quoted text - Price is the reason *$400 to $500 less than the Trig Mode C. Richardwww.craggyaero.com Trig does not make a "Mode C" transponder. Darryl- Hide quoted text - - Show quoted text - Sorry I agree on the Mode S tell the other vendor to correct his web site. Trig TT21 Class 2 Mode C Transponder with Built-in Altitude Encoder $2095 If you compare to the 35,000' $700 to $800 Less Richard www.craggyaero.com |
On Dec 9, 8:58*am, Richard wrote:
Trig TT21 Class 2 Mode C Transponder with Built-in Altitude Encoder $2095 If you compare to the 35,000' * * * $700 to $800 Less Right, but you can buy the TT21 for a lot less than that if you shop around. Trig has a minimum advertised retail price policy but some vendors are selling much lower. It's the old "put one in the order basket to see the real price" trick. Check Aircraft Spruce as an example. Andy |
On Dec 9, 8:22*am, Andy wrote:
On Dec 9, 8:58*am, Richard wrote: Trig TT21 Class 2 Mode C Transponder with Built-in Altitude Encoder $2095 If you compare to the 35,000' * * * $700 to $800 Less Right, but you can buy the TT21 for a lot less than that if you shop around. *Trig has a minimum advertised retail price policy but some vendors are selling much lower. *It's the old "put one in the order basket to see the real price" trick. Check Aircraft Spruce as an example. Andy Richard You seem to be referring to this page http://www.cumulus-soaring.com/trig.htm I expect Paul will have the "Mode C" typo fixed asap, but the same page has lots of information on the Trig TT21/22 making clear they are Mode S transponder. --- There are at least three USA glider dealers actively selling the Trig TT21. Cumulus Soaring - http://www.cumulus-soaring.com/trig.htm Williams Soaring - http://www.williamssoaring.com/catalog/index.html (a dealer but no Trig info on their web store yet) Wings and Wheels - http://www.wingsandwheels.com/Transp...20Microair.htm And Tim there is advertising this new Sandia transponder as well. Jeez Tim! Maybe Tim or Richard can clarify the actual 12 VDC power consumption of the Sandia transponder. I understand the USA Trig distributor wanted higher upfront commitment from the channel than other distributors and that may be a reason why fewer dealers are carrying them than other brands. I don't know why Craggy Aero does not sell the Trig transponders. It would seems a very natural fit for the PowerFLARM that Craggy Aero has been doing a great job promoting. As for the relative cost. Most glider pilots do just fine installing a lower cost and lower power consumption 125W transponder (whether a new Trig TT21 or the Becker ATC-4401-175 many of us use). So for new transponders for gliders in the USA any price comparison really should be against the street price of a TT21. It really is irrelevant that the Sandia is a 200W transponder, that does not justify a price comparison to a Trig TT22 200W transponder. And as others have pointed out we need to be a little careful comparing advertised and actual street prices. It is great to see pilots using a transponder (any transponder) where we have high density airliner and fast jet traffic etc. and a Mode S or Mode C transponder works well there today (but its the long term ADS-B future where a Mode S shines). But I'd hate to see glider pilots not aware of the issues and thinking that buying a cheaper Mode C transponder today is a better decision than a slightly more expensive Mode S transponder, especially when all the other important specs are better with the Mode S. And I'd definitively not like to see us as a community back in a situation where pilots are discussing debilitating transponder power usage and more rounds of misinformation on power consumption, and lack of use of transponders, because of this. So Richard or Tim or anybody else do you have actual 12 VDC power consumption specs on the Sandia transponder? Darryl |
Transponder vs. Portable Transponder Detectors | John Murphy | Soaring | 16 | December 20th 08 07:25 AM |
transponder | LJ Blodgett | Home Built | 4 | March 19th 07 05:22 PM |
TRANSPONDER | LJ Blodgett | Home Built | 5 | January 8th 07 06:50 PM |
wtb transponder | LJ | Aviation Marketplace | 0 | September 7th 06 05:05 PM |
Which Transponder? | Danl Johnson | Soaring | 10 | October 29th 04 05:54 PM |
