![]() Is there a conflict between rule 10.9.5.3 and rule 11.2.2.4? 10.9.5.3 says the safety finish is only valid if no more points were claimed after the finish fix: "10.9.5.3 When a Safety finish is active, a pilot may (using a Task Claim form - Rule 10.5.1.3.1) claim a finish by obtaining one fix within the Safety finish cylinder, provided the slope from the claimed fix to the Projected Finish Location is not less than 200 feet per mile and no claimed turnpoint was achieved after the time of the claimed fix." But 11.2.2.4 is intended to allow a new task attempt after finishing: What happens if a pilot make a valid safety finish then waits for the weather to clear, restarts, and makes a second task attempt that is abandoned after the first turnpoint? *It appears that the the first task attempt is invalidated because a claimed turnpoint was achieved after the safety finish fix. Does there need to be some language in 10.9.5.3 that allows a second task attempt? I think it's pretty clear that "no claimed turnpoint" refers to the first task attempt. After all, under the old rules you could land, takeoff again and restart, and we understood the new task was not an additional turnpoint per safety finish. All we're doing now is changing things so you don't have to land. John Cochrane |
On Dec 28, 7:06*am, John Cochrane
wrote: Is there a conflict between rule 10.9.5.3 and rule 11.2.2.4? 10.9.5.3 says the safety finish is only valid if no more points were claimed after the finish fix: "10.9.5.3 When a Safety finish is active, a pilot may (using a Task Claim form - Rule 10.5.1.3.1) claim a finish by obtaining one fix within the Safety finish cylinder, provided the slope from the claimed fix to the Projected Finish Location is not less than 200 feet per mile and no claimed turnpoint was achieved after the time of the claimed fix." But 11.2.2.4 is intended to allow a new task attempt after finishing: What happens if a pilot make a valid safety finish then waits for the weather to clear, restarts, and makes a second task attempt that is abandoned after the first turnpoint? *It appears that the the first task attempt is invalidated because a claimed turnpoint was achieved after the safety finish fix. Does there need to be some language in 10.9.5.3 that allows a second task attempt? I think it's pretty clear that "no claimed turnpoint" refers to the first task attempt. After all, under the old rules you could land, takeoff again and restart, and we understood the new task was not an additional turnpoint per safety finish. All we're doing now is changing things so you don't have to land. John Cochrane I think the significant difference between the old and new rules is that the log file for the first attempt will now be the same log file as for the second attempt. Under the old rules the first flight log had to be submitted before the next attempt and was therefore completely separate from the second attempt log file. As long as the CD has the same interpretation and Winscore handles it properly then no issue. Andy |
Good to see you put back the "finish" call, but wouldn't it be a good
idea to also make a call entering the pattren? With the 4-mile call, finish, and entering down-wind for runway X, a clear flow progression would be shown and spacing for pattern entry would be enhanced. Calling entry to the pattern is good airmanship and should be included in the rules. As observed at Parowan this year, only about half the pilots were making a pattern entry call. If I don't know who else is trying to land I can't make adjustment to accomodate them. Food for thought, JJ |
On Dec 27, 2:21*pm, "John Godfrey (QT)"
wrote: Discussion invited. http://www.ssa.org/files/member/2011...20Summary%2010... John Godfrey (QT) SSA Competition Rules Committee Hmm, Item #11 - Landing at an airport - coordinates are no longer assumed: Doug Jacobs/2010 Mifflin Regional Day 1 rule? ;-) TA |
On Dec 30, 11:09*pm, Frank wrote:
On Dec 27, 2:21*pm, "John Godfrey (QT)" wrote: Discussion invited. http://www.ssa.org/files/member/2011...20Summary%2010... John Godfrey (QT) SSA Competition Rules Committee Hmm, Item #11 - Landing at an airport - coordinates are no longer assumed: *Doug Jacobs/2010 Mifflin Regional Day 1 rule? ;-) TA That occurrance did raise the issue. In Doug's case the correct result was accomplished by measuring to his point of furthest progress which was on downwind beyond the end of the airport. It did lead to a review of the associated rules with an eye toward avoiding possible conflicting choices by the scorer. HNY UH UH |
USA 2010 Competition Rules Committee Minutes Posted | John Godfrey (QT)[_2_] | Soaring | 43 | December 23rd 10 02:33 AM |
2011 USA competition schedule ? | Dave Nadler | Soaring | 22 | October 19th 10 08:07 PM |
Proposed US Competition Rules Changes for 2010 | [email protected] | Soaring | 1 | December 17th 09 05:20 PM |
2008 Proposed US Competition Rules Changes | [email protected] | Soaring | 18 | December 31st 07 07:21 PM |
Proposed 2005 Rules On SRA Site | Ken Kochanski (KK) | Soaring | 79 | January 27th 05 06:51 PM |
