poor lateral control on a slow tow?
Old January 1st 11, 03:09 PM posted to rec.aviation.soaring
Derek C
Default poor lateral control on a slow tow?
On Jan 1, 11:15*am, Doug Greenwell wrote:
At 20:23 31 December 2010, bildan wrote:
On Dec 31, 1:06=A0pm, Todd *wrote:
I too agree with the real or perceived tow handling characteristics.
Looking at things =A0from and aerodynamics standpoint (and I am about
as
far from and aerodynamicist as you can get) it should seem that part
of the empirical data would suggest an experiment where you fly a
glider equipped with and Angel of Attack meter at your typical tow
speeds and record the AoA at various speeds. =A0Then fly that glider
on
tow at those same speeds and record the results.
Done that - and as nearly as I can see, there's no difference in AoA.
I've flown some pretty heavy high performance gliders behind some
pretty bad tow pilots - one of them stalled the tug with me on tow.
If I'm careful not to over-control the ailerons, there's no problem at
all.
Heavily ballasted gliders respond sluggishly in roll just due to the
extra roll inertia. *A pilot trying to hold a precise position behind
a tug needs and expects crisp aileron response. *When he doesn't get
it, he increases the amount and frequency of aileron with a
corresponding increase in adverse yaw. *If he's less than equally
crisp with rudder to oppose the adverse yaw, it gets wobbly.
Where did you mount the AoA meter?
It's not the angle of attack that's the problem, but the change in local
incidence along the wing. *The overall lift may not change by very much
when near to the tug wake, but its distribution along the wing does, with
increased lift at the tips and reduced lift at the root - putting the
aileron region close to the stall and hence reducing control
effectiveness.
I agree that increased roll inertia due to ballast is a factor, but since
the same factor applies to maintaining bank angle in a thermalling turn I
don't see how it can account for a significant difference in handling
between tow and thermalling?- Hide quoted text -
- Show quoted text -
What started the debate at Lasham was using a Rotax engined Falke as a
glider tug. This towed best at about 50 to 55 knots (c.f. 60+ knots
with a normal tug), but K13s with a stalling speed of 36 knots felt
very unhappy behind it, especially two up. In a conventional powered
aircraft you pull the nose up (to increase the angle of attack and
produce more lift) and increase power to climb, the extra power being
used to prevent the aircraft from slowing down. I don't see why
gliders should behave any differently, except that the power is coming
from an external source. As you try not to tow in the wake and
downwash from the tug, I can't see that this is particularly
significant,
Derek C
Old January 1st 11, 03:34 PM posted to rec.aviation.soaring
Doug Greenwell
At 15:09 01 January 2011, Derek C wrote:
characteristics.
Looking at things =3DA0from and aerodynamics standpoint (and I am
abou=
t
as
part
speeds and record the AoA at various speeds. =3DA0Then fly that
glider
on
AoA.
at
all.
extra roll inertia. =A0A pilot trying to hold a precise position
behind
a tug needs and expects crisp aileron response. =A0When he doesn't
get
corresponding increase in adverse yaw. =A0If he's less than equally
local
incidence along the wing. =A0The overall lift may not change by very
much
with
effectiveness.
since
turn
I
significant,
Derek C
In a steady climb in any light aircraft the climb angles are so low (
10deg) that the lift remains pretty well equal to weight. For example a
10deg climb angle at 60 kts corresponds to an impressive climb rate of
10.5kts - but that would only give Lift = Weight/cos(10deg) = 1.02 x
Weight. You don't need to increase lift to climb - you increase thrust
to overcome the aft component of the weight, and the stick comes back to
maintain speed ... at constant speed the increased power input comes out
as increasing potential energy = increasing height.
I think a lot of people confuse the actions needed to initiate a climb
with what is actually happening in a steady climb.
On your second point, if you are on tow anywhere sensible behind a tug you
are in its wake and are being affected by the wing downwash. Wake is not
really a good word, since it seems to get confused with the much more
localised (and turbulent) propwash.
A (very) crude way of visualising the affected wake area is to imagine a
cylinder with a diameter equal to the tug wing span extending back from
the tug - that's the downwash region, and then in addition there's an
upwash region extending perhaps another half-span out either side.
Old January 1st 11, 03:49 PM posted to rec.aviation.soaring
Doug Greenwell
whoops - I should have said Lift = Weight*cos(10deg) = 0.985 x
Weight, since in a climb the thrust (or tow cable) is supporting part of
the the weight .... long night, early morning :-)
Old January 1st 11, 04:43 PM posted to rec.aviation.soaring
Derek C
characteristics.
abou=
t
as
part
glider
on
AoA.
at
all.
behind
get
local
much
with
effectiveness.
since
turn
I
significant,
Derek C
10deg) that the lift remains pretty well equal to weight. *For example a
Weight. *You don't need to increase lift to climb - you increase thrust
with what is actually happening in a steady climb. *
are in its wake and are being affected by the wing downwash. *Wake is not
upwash region extending perhaps another half-span out either side.- Hide quoted text -
So why did a K13 feel on the verge of a stall at 50 knots on tow? All
the classic symptoms of a stall were there, including mushy controls,
wallowing around and buffeting. If you got even slightly low it seemed
quite difficult to get back up to the normal position. Lack of
elevator effectiveness is yet another sympton of the stall!
Fortunately we have given up aerotowing with the Falke. It just seemed
like a good idea at the time because its flying speeds are more
closely matched to a glider; in theory anyway.
Derek C
Old January 1st 11, 05:27 PM posted to rec.aviation.soaring
Doug Greenwell
At 16:43 01 January 2011, Derek C wrote:
characteristics.
Looking at things =3D3DA0from and aerodynamics standpoint (and I
am
abou=3D
t
as
part
a
tow
speeds and record the AoA at various speeds. =3D3DA0Then fly
that
glider
on
AoA.
tow.
problem
at
all.
extra roll inertia. =3DA0A pilot trying to hold a precise position
behind
a tug needs and expects crisp aileron response. =3DA0When he
doesn't
get
corresponding increase in adverse yaw. =3DA0If he's less than
equally
in
local
incidence along the wing. =3DA0The overall lift may not change by
very
much
does,
with
effectiveness.
since
turn
I
handling
a
coming
significant,
Derek C
10deg) that the lift remains pretty well equal to weight. =A0For example
a
10.5kts - but that would only give Lift =3D Weight/cos(10deg) =3D 1.02
x
Weight. =A0You don't need to increase lift to climb - you increase
thrust
to
out
as increasing potential energy =3D increasing height.
with what is actually happening in a steady climb. =A0
yo=
u
are in its wake and are being affected by the wing downwash. =A0Wake
is
n=
ot
a
from
an
Hide
quoted text -
Derek C
good question - which suggests that something more complicated was going
on?
Lack of elevator effectiveness is not really a symptom of stall as such
... it's a symptom of low airspeed. So for buffeting and mushy,
ineffective elevator to be happening at an indicated airspeed of 50-55
knots I'm wondering whether the tailplane was stalling rather than the
wing?
In this case you'd a tug with a wing span of a similar size to the glider
(14.5m to 16m), which would put the tug and glider tip vortices very close
together. Two adjacent vortices of the same sign tend to wind up round
each other and merge quite quickly - if this happened with the two sets of
tip vortices it would generate an increased downwash near the tail and push
the local (negative) incidence past the stall angle.
I'd be the first to admit this is getting rather speculative - but these
possible interaction effects would be amenable to some fairly
straightforward wind tunnel testing ... a good student project for next
year!
Old January 2nd 11, 11:01 AM posted to rec.aviation.soaring
Derek C
characteristics.
am
abou=3D
t
as
part
a
tow
that
glider
on
AoA.
tow.
problem
at
all.
behind
doesn't
get
equally
in
local
very
much
does,
with
effectiveness.
since
turn
I
handling
a
coming
significant,
Derek C
a
x
thrust
to
out
yo=
u
is
n=
ot
a
from
an
Hide
quoted text -
Derek C
on? *
.. it's a symptom of low airspeed. *So for buffeting and mushy,
wing?
together. *Two adjacent vortices of the same sign tend to wind up round
straightforward wind tunnel testing *... a good student project for next
year!-
Actually the only totally reliable sysmptom of being stalled is that
the elevator will no longer raise the nose. The elevator should still
be effective at 50 knots, so it's more likely that the wing is close
to the stall. The stall is only strictly related to the angle of
attack. During a aerotow climb the wing has to support an additional
weight component as well as drag, so the effective wing loading may
well be increased, requiring a greater angle of attack for a given
airspeed. Going 10 knots faster seems to cure the problem.
Derek C
Old January 2nd 11, 01:20 PM posted to rec.aviation.soaring
characteristics.
am
abou=3D
t
as
part
a
tow
that
glider
on
AoA.
tow.
problem
at
all.
behind
doesn't
get
equally
in
local
very
much
does,
with
effectiveness.
since
turn
I
handling
a
coming
significant,
Derek C
a
x
thrust
to
out
yo=
u
is
n=
ot
a
from
an
Hide
quoted text -
Derek C
on? *
wing?
year!-
Derek C- Hide quoted text -
'Actually the only totally reliable sysmptom of being stalled is that
the elevator will no longer raise the nose.'
HUH? Many cases possible where we could have full elevator and not
be stalled. (I demonstrate this is 2-33 and grob 103 and ask-21.
All you need is heavy pilot (forward CG) and gentle stick back to the
stop. Glider will mush, but not stall. Elevator will not raise the
nose........wing does not have angle to stall.
On tow the only additional "weight component" would be a downward
component to the tow rope (thrust). Since the tension on the tow rope
is fairly low........it should not have a big effect, but there is
some effect.
But yeah, that extra 10 knots makes all the difference in the world.
(I remember occasionally getting a "slow tow" when flying a 2-32 with
three aboard..........what a handful!!!
Cookie
Old January 2nd 11, 03:06 PM posted to rec.aviation.soaring
n7ly
*'Actually the only totally reliable sysmptom of being stalled is that
HUH? * Many cases possible where we could have full elevator and not
be stalled. *(I demonstrate this is 2-33 and grob 103 and ask-21.
stop. *Glider will mush, but not stall. *Elevator will not raise the
whoa - depends on who's defining "stall". The FAA definition is indeed
that when the aircraft does not respond in the direction of the
control input that it's done. When you can no longer move the elevator
up, you're done. Nose doesn't respond in direction of aft stick
deflection, you're stalled. I don't remember exactly the way they
word it, but the result is that touch the elevator limit, that's it.
Slow entry rates result in higher stall speeds. Forward cg's give
higher stall speeds. Trim settings (on some configs) affect stall
speeds. Weight, etc., etc. The scene that seems the most insidious
is the slow entry rate. They sneak up on you, kind of like a slow tow.
Old January 2nd 11, 07:53 PM posted to rec.aviation.soaring
Doug Greenwell
At 13:20 02 January 2011, wrote:
On Jan 2, 6:01=A0am, Derek C wrote:
characteristics.
Looking at things =3D3D3DA0from and aerodynamics standpoint
(a=
nd I
am
abou=3D3D
t
as
tha=
t
part
fl=
y
a
typical
tow
speeds and record the AoA at various speeds. =3D3D3DA0Then
fly
that
glider
on
difference
in
AoA.
som=
e
on
tow.
problem
at
all.
to
extra roll inertia. =3D3DA0A pilot trying to hold a precise
posi=
tion
behind
a tug needs and expects crisp aileron response. =3D3DA0When
he
doesn't
get
corresponding increase in adverse yaw. =3D3DA0If he's less
than
equally
change
in
local
incidence along the wing. =3D3DA0The overall lift may not
change
by
very
much
does,
with
putting
effectiveness.
factor,
b=
ut
since
thermallin=
g
turn
I
handling
Falke
a=
s
a
knots
felt
powere=
d
and
bei=
ng
coming
significant,
Derek C
low
10deg) that the lift remains pretty well equal to weight. =3DA0For
exa=
mple
=3D
a
rate
of
10.5kts - but that would only give Lift =3D3D Weight/cos(10deg)
=3D3=
D 1.02
x
Weight. =3DA0You don't need to increase lift to climb - you
increase
thrust
bac=
k
to
comes
out
as increasing potential energy =3D3D increasing height.
cli=
mb
with what is actually happening in a steady climb. =3DA0
a
t=
ug
yo=3D
u
=3DA0Wa=
ke
is
n=3D
ot
mor=
e
imagi=
ne
a
back
from
there's
an
side.-
Hide
=3D
quoted text -
All
controls,
seemed
seemed
Derek C
goin=
g
on? =A0
such
.. it's a symptom of low airspeed. =A0So for buffeting and mushy,
50-55
wing?
glid=
er
cl=
ose
together. =A0Two adjacent vortices of the same sign tend to wind up
rou=
nd
sets=
of
and
push
thes=
e
straightforward wind tunnel testing =A0... a good student project
for
n=
ext
year!-
some effect.
Cookie
Depends on your definition of 'stall' - whether the nose drops or not
depends so much on the aircraft configuration, the aerofoil section and
the stall entry technique.
NASA did a 'deep-stall' test program in the early 80s with a modified
1-36 which was able to carry on pitching up to 70deg AoA ... look at the
incidence on this photo!
http://www.dfrc.nasa.gov/gallery/pho.../ECN-26845.jpg
Old January 2nd 11, 08:13 PM posted to rec.aviation.soaring
Derek C
On Jan 2, 1:20*pm, "
component to the tow rope (thrust). *Since the tension on the tow rope
is fairly low........it should *not have a big effect, but there is
some effect.
Cookie
I know that you have some 'persons of size' out in the States, but I
have never flown a glider that could not stalled in straight flight
with a legal weight (less than 110kg, 242lbs) person in the front
seat. This includes the K21 and the G103. Sometimes you run out of
trim when circling in a thermal with such folk. I weigh about 190lbs
by the way.
Derek C
another poor man's car engine conversion jan olieslagers[_2_] Home Built 19 February 22nd 09 03:49 PM
Poor readability Kees Mies Owning 2 August 14th 04 04:22 AM
Poor Guy Bob Chilcoat Owning 6 July 17th 04 06:45 PM
I'm grateful for poor people who are willing to murder & die Krztalizer Military Aviation 0 April 20th 04 11:11 PM
Concorde in FS2002: No lateral views A. Bomanns Simulators 3 July 19th 03 11:33 AM
