poor lateral control on a slow tow?
Old January 4th 11, 12:40 PM posted to rec.aviation.soaring
Default poor lateral control on a slow tow?
On Jan 4, 7:27*am, Doug Greenwell wrote:
At 01:01 04 January 2011, wrote:
On Jan 3, 3:34=A0pm, Doug Greenwell *wrote:
At 19:12 03 January 2011, Craig wrote:
On Jan 1, 3:06=3DA0am, Doug Greenwell =A0wrote:
At 21:47 31 December 2010, Martin Gregorie wrote:
On Fri, 31 Dec 2010 12:09:08 -0800, Derek C wrote:
On Dec 31, 6:19=3DA0pm, bildan =3DA0wrote:
On Dec 31, 4:40=3DA0am, "Doug" =3DA0wrote:
As an aerodynamicist/flight dynamicist recently re-soloed
after
25
years off, people keep asking me hard questions. =3DA0One
that
h=
as
come
up recently is why a heavy glider on tow feels horrible, but
thermalling in the same glider at lower speeds is fine? (see
also
Mike Fox's article on aerotowing in the October issue of
S&G).
I did some calculations, and I reckon it's probably due to
tug
wing wake (tip vortices generating a downwash inboard, upwash
outboard) changing the lift distribution on the glider wing -
with
an
increased angle of attack out at the tips reducing aileron
effectiveness. =3DA0There's possibly an interesting academic
research
project here, but it's always best to get a reality check
first
Is poor handling at low speed on tow a common experience?
=3DA0I'd
appreciate any thoughts/comments/war stories ... particularly
bad
tug/glider/speed combinations, incidents of wing drop during
a
tow
etc etc?
Doug Greenwell
I suspect, but can't know unless I flew with you, that you are
unconsciously trying to "steer" the glider with ailerons.
=3DA0Overuse
of
ailerons is very common and it makes aero tow 'wobbly'.
=3DA0If
you
consciously use rudder to aim the nose at the tug's tail and
just
keep
the same bank angle as the tug with ailerons, it might work
better.
Wake effects are generally favorable if you stay at the right
height
relative to the tug. =3DA0Using a slightly higher tow position
can
sometimes help a lot.
The tip vortices rotate inward above the propwash which, if
allowed
to
do so, will drift the glider to the center position and help
keep
it
there. =3DA0I haven't noticed any tendency for them to yaw a
glide=
r
towards
a tugs wing tip.- Hide quoted text -
- Show quoted text -
There was a debate on our club forum about why gliders feel
uncomfortable on slow tows that are still well above their
normal
stalling speed. We think the answer is that the glider is being
asked
to
climb with the tug providing the thrust via the rope. The glider
is
still effectively in free flight and therefore has to fly at a
greater
angle of attack for a given airspeed to produce the extra lift
for
climbing. Hence its stalling speed is somewhat increased.
If the tug's downwash field extends back far enough to include
glider, its AOA will be relative to the downwash streamlines. Add
downwash angle to the climb angle of the tug-glider combination
will
mak=3D
e
the glider look quite nose-high to its pilot. =3DA0
I know that the downwash angle is roughly 1/3 of the wing AOA at
4-5
chords behind the wing, i.e. about where the tailplane is, but not
what
its angle might be at the end of a tow rope.
martin@ =3DA0 | Martin Gregorie
gregorie. | Essex, UK
org =3DA0 =3DA0 =3DA0 |
The downwash angle doesn't change much past the tail, and a half to
a
third of the tug AoA is a good first guess.
My modeling suggest that there does seem to be an overall reduction
in
th=3D
e
glider wing lift (downwash over the centre wing having more of an
effect
than upwash over the tips), so the glider requires another degree
or
two
in AoA - so feeling even more nose-up to the pilot!
Many thanks to the aerodynamics folks for cogent replies. =A0From a
structures and vectors standpoint, the greatest amount of downward
catenary force possible from the rope is the rope's own weight (in
other words, damn little). =A0 If the towplane and glider are at
exactly
the same elevation the vertical component of the catenary force
equals
half the rope weight. =A0Any other vertical forces imparted to the
sailplane result from the vector generated by the relative positions
of the towplane and glider. Kudos to Doug for the stimulating
discussion.
Thanks,
Craig
It's been very interesting - and sparked off a few potentially very
interesting research topics (typical academic - always an eye to the
next
journal paper!)
Good point on the rope forces - I hadn't looked at it that way, but
as
you say any bow in the tow rope won't actually have a significant
effect
on the static forces/moments on the glider .. just as well, because
it's
quite difficult to calculate the shape once you take drag forces into
account!
Doug- Hide quoted text -
Actually, 5 or 10 pounds of down force at the glider's nose would be
significant. * Every loosen your shoulder belts and lean
forward?.....this little weight shift will change pitch and speed.
Now with a cg hook ...probably not significant.
Cookie
true - but it would take a very small elevator deflection to trim it out- Hide quoted text -
Yeah.........Hey, I am not saying that this is the answer to the
question........I have yet to see any answer which fully explains the
phenomon........I am just bringing up this issue of the tow rope
because it was brought up in the earlier discussion. It is just one
of the "suspects" in the investigation.
We all agree that at a given speed, faily slow, that a glider handles
fine in gliding flight, and has troubles on tow at the same speed.
So there are obvious differences during tow.........the tow rope
hooked to the nose is one, along with all the others we have
discussed, like down wash, vortex, etc.......
Cookie
Old January 4th 11, 12:53 PM posted to rec.aviation.soaring
Doug Greenwell
On Dec 31, 6:19=3D3DA0pm, bildan =3D3DA0wrote:
after
25
=3D3DA0One
that
h=3D
as
come
but
(see
also
S&G).
to
tug
upwash
wing
with
an
effectiveness. =3D3DA0There's possibly an interesting
academi=
c
research
first
=3D3DA0I'd
particularly
bad
during
a
tow
etc etc?
Doug Greenwell
are
=3D3DA0Overuse
of
=3D3DA0If
you
and
just
keep
better.
right
height
relative to the tug. =3D3DA0Using a slightly higher tow
positio=
n
can
allowed
to
keep
it
there. =3D3DA0I haven't noticed any tendency for them to yaw
a
glide=3D
r
towards
normal
being
asked
to
glider
is
a
greater
lift
for
Add
will
mak=3D3D
e
the glider look quite nose-high to its pilot. =3D3DA0
at
4-5
not
what
martin@ =3D3DA0 | Martin Gregorie
org =3D3DA0 =3D3DA0 =3D3DA0 |
half
to
a
reduction
in
th=3D3D
e
an
effect
degree
or
two
=3DA0From
a
(in
other words, damn little). =3DA0 If the towplane and glider are at
exactly
equals
half the rope weight. =3DA0Any other vertical forces imparted to
positions
discussion.
Thanks,
Craig
very
next
journal paper!)
but
as
effect
it's
into
account!
significant. =A0 Every loosen your shoulder belts and lean
Cookie
out-=
Hide quoted text -
Cookie
Life's never simple! This thread has been really useful in highlighting
for me a number of factors that I hadn't really thought about when I
first started looking at this phenomenon.. All I need now is a bright grad
student to spend a year doing the sums while I go fly :-)
Old January 4th 11, 01:23 PM posted to rec.aviation.soaring
OK..........how about this for (simple) explaination?
"Climbing in descending air" (that's what I get from all of the
complicated explainations of down wash, vortex etc.)
I think that if we compared a motor glider climbing at say 50 MPH and
500 FPM to the same glider on tow at the same climb angle and rate,
and if we assume the air behind the tow plane is moving
downward..........
Then the glider on tow would have a larger AoA.....???
Cookie
Old January 4th 11, 01:48 PM posted to rec.aviation.soaring
Doug Greenwell
downward..........
Cookie
For the same lift (see previous!) and the same indicated airspeed the AoA
should be the same, because the angle of attack is measured relative to
your motion through the air.
The AoA for a given lift at a given airspeed could only change if
something significant happens to part of the airflow around the glider
wing (for example putting the flaps down, opening the airbrakes, icing up,
hitting the propwash, or flying into a tip vortex*)
The pitch angle relative to the ground on the other hand will be larger
for two reasons - (a) you are climbing and (b) the airmass you are in is
moving downwards.
It's really difficult to explain without something to draw on ... oh for
a whiteboard or at the very least the back of an envelope!
*not necessarily a bad thing: birds use the upwash outboard of a tip
vortex to increase range by flying in a v-formation - so perhaps what we
should be doing is towing two gliders at a time ...
Old January 5th 11, 02:13 AM posted to rec.aviation.soaring
AGL
In very slow flight without flaps my 1-35 drops into a stall long
before it gets as bad as a tow does at 60 statute mph. You would
think that I would have stalled out of the tow too. Perhaps the
wallowing around on tow is just the turbulent air on the ailerons and
not an imminent stall at all. (Think rotor in wave or turbulence
behind a hill on a smaller scale)
Are there any reports of incidents where a glider drops into a stall
on a slow tow or are there just complaints of glider pilot annoyance?
(I agree it's not fun)
For example, if the air turbulence was going "down" on the right side
just when you try to bank "left" that would make the controls feel
sluggish. At some angle of bank, assuming that everything else was
symmetrical, the two ailerons would be in different parts of the
turbulence, confusing the situation.
Has anyone tried some flaps in an integrated flap machine (which
reduces stall speed) to see if the wallowing goes away?
Unfortunately, my trailer is in a snowbank.
Old January 5th 11, 02:48 AM posted to rec.aviation.soaring
bildan
With every flapped glider I've flown, negative flap improves aileron
response fairly dramatically. Positive flap does lower the stall
speed a little.
I've flown a 20 meter Nimbus 2C ballasted to 11 lbs/sq ft wing loading
behind a tug pilot accustomed to towing 2-33's. The speed was low
enough to need +1 flap but it didn't wallow. The tug pilot turned off
his radio when he got tired of me yelling for more speed than what he
"knew" was right.
Old January 5th 11, 09:04 AM posted to rec.aviation.soaring
Doug Greenwell
speed a little.
"knew" was right.
Sorry if this is an obvious question (never flown a flapped glider), but
with an integrated flap system what is the relative movement of the
ailerons and flaps? Presumably the ailerons don't move at all for
negative settings?
Doug
Old January 5th 11, 01:09 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
response fairly dramatically. Positive flap does lower the stall speed
a little.
"knew" was right.
negative settings?
On an ASW-20 flaps and ailerons move together so the trailing edge
remains straight with the stick central in the flying flap settings: +8
(thermal) through -9 (max negative flap). When stick is moved laterally
the flap deflects half as far as the aileron. In landing flap settings
the ailerons mover to -8 degrees - what the RC glider guys call 'crow
mode'. This reduces tip stalling tendencies and the handbook says this
also increases drag.
martin@ | Martin Gregorie
org |
Old January 5th 11, 02:11 PM posted to rec.aviation.soaring
Doug Greenwell
speed
a little.
loading
off
"knew" was right.
but
negative settings?
org |
Ok - so that would help in reducing stall speed slightly, but would not
help with the spanwise lift distribution.
Is the aileron/flap interconnect a standard arrangement, or are there
flapped gliders without it?
Old January 5th 11, 05:59 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
On 1/5/2011 7:11 AM, Doug Greenwell wrote:
Is the aileron/flap interconnect a standard arrangement...
Kinda-sorta, "Yes, but..."
or are there
....because the answer to this question is also (if unequivocally so), "Yes."
(I've owned 3.)
Regards,
Bob W.
P.S. Very e-e-enteresting discussion with (apparently ) real potential to
clarify some folks' understanding of things. I remain in the F = Ma camp!
another poor man's car engine conversion jan olieslagers[_2_] Home Built 19 February 22nd 09 03:49 PM
Poor readability Kees Mies Owning 2 August 14th 04 04:22 AM
Poor Guy Bob Chilcoat Owning 6 July 17th 04 06:45 PM
I'm grateful for poor people who are willing to murder & die Krztalizer Military Aviation 0 April 20th 04 11:11 PM
Concorde in FS2002: No lateral views A. Bomanns Simulators 3 July 19th 03 11:33 AM
