At 13:32 04 January 2011, BruceGreeff wrote:
Thanks Martin I did use the "vector" word talking about the winch case - because the cable has mass (our steel cable is ~150Kg so not insignificant) and there is a pull at a downward angle. At top of launch cable angle approaches 90 degrees to fuselage - If you want proof look at one of the videos on you tube. http://www.youtube.com/watch?v=v2Qh95I_YM0 http://www.youtube.com/watch?v=np8OGPZ2pvE As Doug Greenwell points out - there is constant acceleration on winch launch because the flight path is curved, describing a horisontal S. I don't know how what magnitude the acceleration has, but subjectively it is only significant in the brief rotation to steep climb, and possibly on the level out if you are less than smooth... Generally it is a relatively small change from a little over 1g to a little under 1g at release. Anyone have the maths capability to calculate for a known situation? Cheers Bruce On 2011/01/04 1:43 PM, Martin Gregorie wrote: On Tue, 04 Jan 2011 10:57:01 +0200, BruceGreeff wrote: Of course - the angle that the flight path can make relative to the ground is proportional to the excess power available - hence the low rate of climb behind the cub, versus the extreme angle on a winch. Aerodynamics guys - Am I confused? Sounds fair to me except that you omitted two fairly significant forces: - the weight of the cable - the tension in the cable. Both will add to the load carried by the wing. The tension should add a fairly constant load to the wing once the glider has rotated into full climb since the throttle setting remains fairly constant[*] from rotation until the glider is near the top, but the effective cable weight will increase as more of it is lifted off the ground and then as the whole cable gets closer to vertical. [*] this is true on a calm day but is obviously incorrect in the presense of turbulence or a significant wind gradient. -- Bruce Greeff T59D #1771 & Std Cirrus #57 Hopefully this post will go this time ... I did try modelling a winch launch some time ago. It's very dependent on the assumptions you make on piloting technique and winch control (constant power, tension, cable speed?), but in general once you've transitioned into full climb the accelerations as felt by the pilot seem to be very small ( 0.1g). Hence the danger of overstressing, since you've no physical indication of the high wing loads due to the cable tension & weight. |
another poor man's car engine conversion | jan olieslagers[_2_] | Home Built | 19 | February 22nd 09 03:49 PM |
Poor readability | Kees Mies | Owning | 2 | August 14th 04 04:22 AM |
Poor Guy | Bob Chilcoat | Owning | 6 | July 17th 04 06:45 PM |
I'm grateful for poor people who are willing to murder & die | Krztalizer | Military Aviation | 0 | April 20th 04 11:11 PM |
Concorde in FS2002: No lateral views | A. Bomanns | Simulators | 3 | July 19th 03 11:33 AM |
