At 02:13 05 January 2011, AGL wrote:
In very slow flight without flaps my 1-35 drops into a stall long before it gets as bad as a tow does at 60 statute mph. You would think that I would have stalled out of the tow too. Perhaps the wallowing around on tow is just the turbulent air on the ailerons and not an imminent stall at all. (Think rotor in wave or turbulence behind a hill on a smaller scale) Are there any reports of incidents where a glider drops into a stall on a slow tow or are there just complaints of glider pilot annoyance? (I agree it's not fun) For example, if the air turbulence was going "down" on the right side just when you try to bank "left" that would make the controls feel sluggish. At some angle of bank, assuming that everything else was symmetrical, the two ailerons would be in different parts of the turbulence, confusing the situation. Has anyone tried some flaps in an integrated flap machine (which reduces stall speed) to see if the wallowing goes away? Unfortunately, my trailer is in a snowbank. That's a useful comment: the aerodynamic modelling I did suggests that the lateral control problems on tow should be different (worse) than those in a typical stall, because the wing is stalling at the tips rather than the root. No-one has yet admitted to actually stalling or dropping a wing on tow - so the effect seems to be annoying rather than dangerous. Flaps should (theoretically) improve matters by (a) reducing stall speed and (b) shifting the spanwise lift distribution inboard and unloading the tips. However, if the flaps are integrated with the ailerons then the associated aileron droop would counteract (b). |
On 1/5/2011 12:53 AM, Doug Greenwell wrote:
At 02:13 05 January 2011, AGL wrote: Has anyone tried some flaps in an integrated flap machine (which reduces stall speed) to see if the wallowing goes away? Unfortunately, my trailer is in a snowbank. That's a useful comment: the aerodynamic modelling I did suggests that the lateral control problems on tow should be different (worse) than those in a typical stall, because the wing is stalling at the tips rather than the root. No-one has yet admitted to actually stalling or dropping a wing on tow - so the effect seems to be annoying rather than dangerous. Flaps should (theoretically) improve matters by (a) reducing stall speed and (b) shifting the spanwise lift distribution inboard and unloading the tips. However, if the flaps are integrated with the ailerons then the associated aileron droop would counteract (b). My ASH 26E has the flaps and ailerons moving in unison in the 1,2, and 3 "cruise" positions; flap 4 (thermal) moves the flaps down a bit more than the ailerons, so there is some washout in the wing. That might make it handle better during a slow tow than it otherwise would. I've never had a slow tow, so I can't say. If I ever take another tow, I'll compare flap 3 and 4 with the tow plane going "slow". -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - " |
another poor man's car engine conversion | jan olieslagers[_2_] | Home Built | 19 | February 22nd 09 03:49 PM |
Poor readability | Kees Mies | Owning | 2 | August 14th 04 04:22 AM |
Poor Guy | Bob Chilcoat | Owning | 6 | July 17th 04 06:45 PM |
I'm grateful for poor people who are willing to murder & die | Krztalizer | Military Aviation | 0 | April 20th 04 11:11 PM |
Concorde in FS2002: No lateral views | A. Bomanns | Simulators | 3 | July 19th 03 11:33 AM |
