poor lateral control on a slow tow?
Old January 6th 11, 09:09 AM posted to rec.aviation.soaring
Doug Greenwell
Default poor lateral control on a slow tow?
At 18:52 05 January 2011, Andreas Maurer wrote:
On Wed, 5 Jan 2011 09:23:29 -0800 (PST), Derek C
Gliders appear to get near to the stall during slow aerotows at much
greater than their normal free flight stalling airspeeds. I would
suggest that aerotowing must increase the wing loading in some way.
I have to admit that I didn't bother to read all the 120+ postings
about this topic, so please forgive me if the things that I'm going to
post have already been mentioned in this thread.
The main factor for the seemingly odd flying characteristics behind
the tow plane is the downwash of the latter.
Let me explain:
The downwash has a significant angle (the air is deflected downwards
behind the tow plane's wing to up to four degrees!), but due to the
larger span of the glider it only affects the inner part of the
glider's wing.
Therefore, if the glider if lying laterally displaced, only one wing
is affected by the downwash of the tow plane - four degrees of AoA
difference between left and right wing need a lot of aileron to
correct.
Likeise, if the glider is flying straight behind the tow plane, the
downwash *decreases* the AoA of the affected inner part of the wing.
Getting the nose up by pulling back will restore the lift of the inner
part of the glider's wing, but now the outer parts of the wing have a
much higher AoA than they have in free flight.
Voila, meet the the conditions for poor alieron efficiency (high AoA!)
and tip stall.
The downwash is reduced by
- wingloading of the tow plane
- wing span of the tow plane
In other words: The more a tow plane looks like a motorglider (say, a
Dimona, or Katana Extreme), the less the flight characteristics of the
glider are affected.
Anyone who has ever been towed behind a motorglider or a microlight
will testify that problems like poor lateral control or running out
of elevator don't exist there, despite a far slower tow (55 kts
compared to a typical 70-75 kts behind a typical tow plane like
Reorqeur or Pawnee).
One interesting fact:
When Akaflieg Braunschweig flight-tested their SB-13 flying wing (with
a back-swept wing), they encountered a nose-down momentum after
lift-off that could not be recovered and usually lead to a crash
immediately after lift-off.
Explanation:
The downwash of the tow plane (Robin Remorqeur) hit the inner part of
the wing, decreasing its AoA (and lift) and therefore shifting the
center of lift backwards due to the sweepback.
Increasing the length of the tow rope helped.
Greetings from a snowy Germany
Andreas
Interesting experience with the SB-13.
There's a chapter in Eric Brown's book 'Wings of the Weird &
Wonderful' in which he describes flight tests of the GAL 56 flying wing
glider in 1946. This was a 28deg swept wing with an aspect ratio of 5.8
towed by a Spitfire IX* (!!!) to 20000ft (!!).
He describes the opposite effect, with a very strong (often
uncontrollable) nose-up pitch on take-off - this was thought to be due to
ground effect. In this case the tug span was similar (37ft) to the glider
span (45ft), so the wake/wing interaction would be different.
Interestingly he also reports that the GAL56 could be flown hands-free on
the tow - unless the tug slipstream was entered, in which case all lateral
and longitudinal control was lost. Robert Kronfield was later killed
spinning this aircraft.
Old January 6th 11, 04:11 PM posted to rec.aviation.soaring
Andreas Maurer
On Thu, 06 Jan 2011 09:09:39 +0000, Doug Greenwell
Coooooooooool.
Definitely. I think that the slipstream and the turbulence of that
huge propellor might have an influence, too.
Seems like some gliders actually stabilize themselves behind a tow
plane.
Here's an example of a free-flight test of a space shuttle model that
flew well in aerotow, but worse in free flight.
Ladies and gents, Great Britains only serious contribution to
spaceflight - the Reliant Shuttle:
http://www.youtube.com/watch?v=pJdrlWR-yFM
Andreas
Old January 6th 11, 04:40 PM posted to rec.aviation.soaring
Doug Greenwell
wing
5.8
Coooooooooool.
every tug pilots dream ... wonder what the climb rate was like!
to
glider
Possibly - he had trouble getting the nose down on landing too.
on
lateral
plane.
Andreas
That's a bit unfair ... we did manage one satellite into orbit on Black
Arrow
Old January 6th 11, 05:16 PM posted to rec.aviation.soaring
Derrick Steed
What do you expect from the juvenile mentality of the top gear presenters?
I'll bet they switched the explosive bolts for standard ones.
Derrick.
wing
5.8
Coooooooooool.
to
glider
on
lateral
plane.
Andreas
Arrow
Old January 6th 11, 06:20 PM posted to rec.aviation.soaring
Andy[_1_]
wing
glider in 1946. *This was a 28deg swept wing with an aspect ratio of
5.8
towed by a Spitfire IX* (!!!) to 20000ft (!!). *
Coooooooooool.
to
ground effect. *In this case the tug span was similar (37ft) to the
glider
on
lateral
and longitudinal control was lost. *Robert Kronfield was later killed
plane.
Andreas
Arrow- Hide quoted text -
- Show quoted text -
What about Skynet? I worked the Skynet 4 program.
Andy
Old January 6th 11, 06:32 PM posted to rec.aviation.soaring
sisu1a
What about Skynet?
Talk about thread drift! The Terminator has nothing to do with this
discussion thank you very much.
Old January 7th 11, 10:13 AM posted to rec.aviation.soaring
Doug Greenwell
wing
glider in 1946. =A0This was a 28deg swept wing with an aspect ratio
of
5.8
towed by a Spitfire IX* (!!!) to 20000ft (!!). =A0
Coooooooooool.
due
to
ground effect. =A0In this case the tug span was similar (37ft) to
glider
hands-free
on
lateral
and longitudinal control was lost. =A0Robert Kronfield was later
killed
plane.
that
http://www.youtube.com/watch?v=3DpJdrlWR-yFM
Andreas
Black
Andy
true - I should have one british satellite on a british launcher!
Old January 7th 11, 11:08 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Launched in 1971 and its still up there. Its radio was still working in
2006. Its orbit is expected to decay around 2106. Not too dusty for the
second attempt at launching a satellite.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
another poor man's car engine conversion jan olieslagers[_2_] Home Built 19 February 22nd 09 03:49 PM
Poor readability Kees Mies Owning 2 August 14th 04 04:22 AM
Poor Guy Bob Chilcoat Owning 6 July 17th 04 06:45 PM
I'm grateful for poor people who are willing to murder & die Krztalizer Military Aviation 0 April 20th 04 11:11 PM
Concorde in FS2002: No lateral views A. Bomanns Simulators 3 July 19th 03 11:33 AM
